Windows XP Home may have infections?
Started by Ghost, September 17, 2015, 12:43:42 AM
Hi, Ghost.  It appears that McAfee is "stuck" in the Windows Security Center.  ComboFix can remove the reference since McAfee is no longer installed.  If you still get a caution, please let me know.
Custom CFScript
SecCenter::
  • Close any open browsers.
Ghost
Hi Corrine.
I dont seem to be getting the mcafee error now;-).
ComboFix 15-09-07.01 - coolcee 09/19/2015  15:53:25.2.1 - x86
Microsoft Windows XP Home Edition  5.1.2600.3.1252.1.1033.18.510.235 [GMT -4:00]
Running from: c:\documents and settings\coolcee\Desktop\ComboFix.exe
Command switches used :: c:\documents and settings\coolcee\Desktop\CFScript.txt
AV: McAfee Anti-Virus and Anti-Spyware *Enabled/Updated* {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
FW: McAfee Firewall *Enabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
(((((((((((((((((((((((((   Files Created from 2015-08-19 to 2015-09-19  )))))))))))))))))))))))))))))))
2015-09-19 16:29 . 2015-09-19 16:29   --------   d-----w-   c:\documents and settings\coolcee\Application Data\AVAST Software
2015-09-19 16:20 . 2015-09-19 16:20   208664   ----a-w-   c:\windows\system32\drivers\aswVmm.sys
2015-09-19 16:20 . 2015-09-19 16:20   434184   ----a-w-   c:\windows\system32\drivers\aswSP.sys
2015-09-19 16:20 . 2015-09-19 16:20   49776   ----a-w-   c:\windows\system32\drivers\aswRvrt.sys
2015-09-19 16:20 . 2015-09-19 16:20   76000   ----a-w-   c:\windows\system32\drivers\aswMonFlt.sys
2015-09-19 16:20 . 2015-09-19 16:20   24016   ----a-w-   c:\windows\system32\drivers\aswHwid.sys
2015-09-19 16:20 . 2015-09-19 16:20   55200   ----a-w-   c:\windows\system32\drivers\aswRdr.sys
2015-09-19 16:20 . 2015-09-19 16:18   789296   ----a-w-   c:\windows\system32\drivers\aswSnx.sys
2015-09-19 16:20 . 2015-09-19 16:18   313472   ----a-w-   c:\windows\system32\aswBoot.exe
2015-09-19 16:18 . 2015-09-19 16:18   43112   ----a-w-   c:\windows\avastSS.scr
2015-09-19 16:11 . 2015-09-19 16:27   --------   d-----w-   c:\program files\Avast
2015-09-19 15:51 . 2015-09-19 15:51   --------   d-----w-   c:\documents and settings\All Users\Application Data\AVAST Software
2015-09-19 00:59 . 2008-04-14 02:57   79872   ------w-   c:\windows\system32\dllcache\msxml6r.dll
2015-09-19 00:59 . 2009-07-31 15:05   1372672   ------w-   c:\windows\system32\msxml6.dll
2015-09-19 00:59 . 2009-07-31 15:05   1372672   ------w-   c:\windows\system32\dllcache\msxml6.dll
2015-09-19 00:59 . 2008-04-14 02:57   79872   ------w-   c:\windows\system32\msxml6r.dll
2015-09-19 00:48 . 2008-04-14 09:41   4255   ------w-   c:\windows\system32\drivers\adv01nt5.dll
2015-09-19 00:47 . 2008-04-14 09:42   11325   ------w-   c:\windows\system32\drivers\vchnt5.dll
2015-09-19 00:47 . 2008-04-14 04:26   12800   ------w-   c:\windows\system32\drivers\usb8023x.sys
2015-09-19 00:47 . 2008-04-14 04:06   44672   ------w-   c:\windows\system32\drivers\uagp35.sys
2015-09-19 00:47 . 2008-04-14 04:06   5888   ------w-   c:\windows\system32\drivers\smbali.sys
2015-09-19 00:47 . 2008-04-14 03:53   13240   ------w-   c:\windows\system32\drivers\slwdmsup.sys
2015-09-19 00:47 . 2008-04-14 04:13   14208   ------w-   c:\windows\system32\drivers\wacompen.sys
2015-09-19 00:47 . 2008-04-14 02:04   25471   ------w-   c:\windows\system32\drivers\watv10nt.sys
2015-09-19 00:47 . 2008-04-14 02:04   22271   ------w-   c:\windows\system32\drivers\watv06nt.sys
2015-09-19 00:47 . 2008-04-14 02:04   11935   ------w-   c:\windows\system32\drivers\wadv11nt.sys
2015-09-19 00:47 . 2008-04-14 02:04   11871   ------w-   c:\windows\system32\drivers\wadv09nt.sys
2015-09-19 00:47 . 2008-04-14 02:04   11807   ------w-   c:\windows\system32\drivers\wadv07nt.sys
2015-09-19 00:47 . 2008-04-14 02:04   11295   ------w-   c:\windows\system32\drivers\wadv08nt.sys
2015-09-19 00:39 . 2015-09-19 00:39   --------   d-----w-   c:\windows\EHome
2015-09-19 00:28 . 2015-09-19 02:17   --------   d-----w-   C:\219139e4c70a557a317b
2015-09-18 15:15 . 2015-09-18 15:15   --------   d-----w-   c:\documents and settings\All Users\Application Data\Licenses
2015-09-18 15:15 . 2012-05-02 16:17   1070152   ----a-w-   c:\windows\system32\MSCOMCTL.OCX
2015-09-18 15:15 . 2009-03-24 16:52   129872   ----a-w-   c:\windows\system32\MSSTDFMT.DLL
2015-09-18 15:15 . 2015-09-18 15:24   --------   d-----w-   c:\program files\SpywareBlaster
2015-09-18 15:14 . 2015-09-18 15:39   --------   d-----w-   c:\program files\SpywareGuard
2015-09-18 13:05 . 2015-09-18 13:06   --------   d-----w-   c:\program files\SP3
2015-09-18 01:10 . 2015-09-18 01:10   --------   d-sh--w-   c:\documents and settings\NetworkService\PrivacIE
2015-09-18 01:10 . 2015-09-18 01:10   --------   d-sh--w-   c:\documents and settings\NetworkService\UserData
2015-09-18 01:10 . 2015-09-18 01:10   --------   d-sh--w-   c:\documents and settings\NetworkService\IECompatCache
2015-09-18 01:04 . 2004-08-10 21:05   14240   ----a-w-   c:\windows\system32\drivers\wg6n.sys
2015-09-18 01:04 . 2004-08-10 21:05   14240   ----a-w-   c:\windows\system32\drivers\wg5n.sys
2015-09-18 01:04 . 2004-08-10 21:05   14240   ----a-w-   c:\windows\system32\drivers\wg4n.sys
2015-09-18 01:04 . 2004-08-10 21:05   14240   ----a-w-   c:\windows\system32\drivers\wg3n.sys
2015-09-18 01:04 . 2004-08-10 20:53   21075   ----a-w-   c:\windows\system32\drivers\wpsdrvnt.sys
2015-09-18 01:04 . 2004-08-10 20:51   59984   ----a-w-   c:\windows\system32\drivers\Teefer.sys
2015-09-18 01:04 . 2004-08-10 21:05   83096   ----a-w-   c:\windows\system32\SSSensor.dll
2015-09-18 01:04 . 2015-09-18 01:04   --------   d-----w-   c:\program files\Sygate
2015-09-18 01:03 . 2015-09-18 01:03   --------   d-----w-   c:\program files\Common Files\Wise Installation Wizard
2015-09-18 00:49 . 2015-09-18 00:49   --------   d-----w-   c:\documents and settings\coolcee\Application Data\SumatraPDF
2015-09-18 00:49 . 2015-09-18 00:49   --------   d-----w-   c:\program files\SumatraPDF
2015-09-17 02:31 . 2015-09-17 03:12   --------   d-----w-   c:\documents and settings\All Users\Application Data\Malwarebytes' Anti-Malware (portable)
2015-09-17 00:34 . 2015-09-17 02:21   --------   d-----w-   C:\FRST
2015-09-16 20:53 . 2015-09-17 02:31   170200   ----a-w-   c:\windows\system32\drivers\MBAMSwissArmy.sys
2015-09-16 20:52 . 2015-09-17 02:25   121560   ----a-w-   c:\windows\system32\drivers\mbamchameleon.sys
2015-09-16 20:52 . 2015-09-16 20:56   --------   d-----w-   c:\program files\Malwarebytes Anti-Malware
2015-09-16 20:52 . 2015-09-16 20:52   --------   d-----w-   c:\documents and settings\All Users\Application Data\Malwarebytes
2015-09-16 20:52 . 2015-06-18 12:41   23256   ----a-w-   c:\windows\system32\drivers\mbam.sys
2015-09-16 20:47 . 2015-09-16 20:47   --------   d-----w-   c:\program files\7-Zip
2015-09-16 20:47 . 2015-09-16 20:49   --------   d-----w-   c:\program files\Power Defrag
2015-09-16 20:34 . 2015-09-16 20:34   --------   d-----w-   c:\program files\Mozilla Maintenance Service
2015-09-16 20:27 . 2015-09-16 20:27   --------   d-----w-   c:\documents and settings\coolcee\Local Settings\Application Data\Mozilla
2015-09-16 18:32 . 2015-09-16 18:33   --------   d-----w-   c:\program files\CCleaner
2015-09-16 18:28 . 2015-09-16 18:28   --------   d-----w-   c:\program files\VS Revo Group
2015-09-15 22:25 . 2004-08-04 04:56   21504   ------w-   c:\windows\system32\hidserv.dll
------- Sigcheck -------
Note: Unsigned files aren't necessarily malware.
[7] 2008-04-14 . D8E14A61ACC1D4A6CD0D38AEBAC7FA3B . 57856 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\spoolsv.exe
[7] 2008-04-14 . D8E14A61ACC1D4A6CD0D38AEBAC7FA3B . 57856 . . [5.1.2600.5512] . . c:\windows\SoftwareDistribution\Download\9866fb57abdc0ea2f5d4e132d055ba4e\spoolsv.exe
[-] 2005-06-11 . AD3D9D191AEA7B5445FE1D82FFBB4788 . 57856 . . [5.1.2600.2696] . . c:\windows\$hf_mig$\KB896423\SP2QFE\spoolsv.exe
[-] 2005-06-10 . DA81EC57ACD4CDC3D4C51CF3D409AF9F . 57856 . . [5.1.2600.2696] . . c:\windows\$NtServicePackUninstall$\spoolsv.exe
[-] 2005-06-10 . DA81EC57ACD4CDC3D4C51CF3D409AF9F . 57856 . . [5.1.2600.2696] . . c:\windows\system32\spoolsv.exe
REGEDIT4
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\explorer\shelliconoverlayidentifiers\00avast]
@="{472083B0-C522-11CF-8763-00608CC02F24}"
[HKEY_CLASSES_ROOT\CLSID\{472083B0-C522-11CF-8763-00608CC02F24}]
2015-09-19 16:18   696120   ----a-w-   c:\program files\Avast\ashShell.dll
"dla"="c:\windows\system32\dla\tfswctrl.exe" [2004-12-06 127035]
"DMXLauncher"="c:\program files\Dell\Media Experience\DMXLauncher.exe" [2005-01-27 86016]
"SmcService"="c:\progra~1\Sygate\SPF\smc.exe" [2004-08-13 2532576]
"AvastUI.exe"="c:\program files\Avast\AvastUI.exe" [2015-09-19 6134544]
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Corel Photo Downloader]
2005-08-31 17:06   106496   ----a-w-   c:\program files\Corel\Corel Photo Album 6\MediaDetect.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ctfmon.exe]
2004-08-04 11:00   15360   ------w-   c:\windows\system32\ctfmon.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\DVDLauncher]
2005-02-23 22:19   53248   ------w-   c:\program files\CyberLink\PowerDVD\DVDLauncher.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\HotKeysCmds]
2005-04-06 01:19   77824   ----a-w-   c:\windows\system32\hkcmd.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IgfxTray]
2005-04-06 01:22   94208   ----a-w-   c:\windows\system32\igfxtray.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\IntelMeM]
2003-09-04 02:12   221184   ----a-w-   c:\program files\Intel\Modem Event Monitor\IntelMEM.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ISUSPM Startup]
2005-06-10 16:44   249856   ----a-w-   c:\program files\Common Files\InstallShield\UpdateService\ISUSPM.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\ISUSScheduler]
2005-06-10 16:44   81920   ----a-w-   c:\program files\Common Files\InstallShield\UpdateService\issch.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\MSMSGS]
2008-04-14 09:42   1695232   ----a-w-   c:\program files\Messenger\msmsgs.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Persistence]
2005-04-06 01:23   114688   ----a-w-   c:\windows\system32\igfxpers.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\SoundMAXPnP]
2004-10-15 01:42   1404928   ----a-w-   c:\program files\Analog Devices\Core\smax4pnp.exe
R0 aswRvrt;avast! Revert;c:\windows\system32\drivers\aswRvrt.sys [9/19/2015 12:20 PM 49776]
R0 aswVmm;avast! VM Monitor;c:\windows\system32\drivers\aswVmm.sys [9/19/2015 12:20 PM 208664]
R1 aswSnx;aswSnx;c:\windows\system32\drivers\aswSnx.sys [9/19/2015 12:20 PM 789296]
R1 aswSP;aswSP;c:\windows\system32\drivers\aswSP.sys [9/19/2015 12:20 PM 434184]
R2 aswHwid;avast! HardwareID;c:\windows\system32\drivers\aswHwid.sys [9/19/2015 12:20 PM 24016]
R2 aswMonFlt;aswMonFlt;c:\windows\system32\drivers\aswMonFlt.sys [9/19/2015 12:20 PM 76000]
R3 MBAMProtector;MBAMProtector;c:\windows\system32\drivers\mbam.sys [9/16/2015 4:52 PM 23256]
S2 MBAMService;MBAMService;c:\program files\Malwarebytes Anti-Malware\mbamservice.exe [9/16/2015 4:52 PM 1133880]
S4 MBAMScheduler;MBAMScheduler;c:\program files\Malwarebytes Anti-Malware\mbamscheduler.exe [9/16/2015 4:52 PM 1871160]
2015-09-19 c:\windows\Tasks\avast! Emergency Update.job
- c:\program files\Avast\AvastEmUpdate.exe [2015-09-19 16:18]
2015-09-19 c:\windows\Tasks\User_Feed_Synchronization-{7BB9EFBE-0EB2-4B05-A0C7-DE9E7907DF5E}.job
- c:\windows\system32\msfeedssync.exe [2007-08-13 09:31]
uStart Page = hxxp://www.bing.com/
uSearchMigratedDefaultURL = hxxp://www.google.com/search?q={searchTerms}&sourceid=ie7&rls=com.microsoft:en-US&ie=utf8&oe=utf8
uInternet Connection Wizard,ShellNext = iexplore
TCP: DhcpNameServer = 75.75.76.76 75.75.75.75
FF - ProfilePath - c:\documents and settings\coolcee\Application Data\Mozilla\Firefox\Profiles\wult6a61.default-1442591269296\
FF - prefs.js: browser.startup.homepage - hxxps://www.google.com/?gws_rd=ssl
Rootkit scan 2015-09-19 16:04
scanning hidden processes ...
scanning hidden files ...
scan completed successfully
hidden files: 0
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\vsdatant]
"ImagePath"=""
- - - - - - - > 'explorer.exe'(2376)
Completion time: 2015-09-19  16:08:27
ComboFix-quarantined-files.txt  2015-09-19 20:08
ComboFix2.txt  2015-09-19 17:15
Pre-Run: 64,138,178,560 bytes free
Post-Run: 64,129,200,128 bytes free
- - End Of File - - 7C4DC1F96BAAC284601961C040E68391
91722E6BC3A2B40FF00222DCA4A3DB3E
Maybe not but the Security Center is still wrong and I haven't seen any signs of McAfee in Programs or in registry entries from the logs.
This works for all versions of Windows (see How do I restore security settings to a known working state?).
  • Click Start > Run > type cmd >  Press Enter >
  • Type or copy/paste the following and press Enter again:
    secedit /configure /cfg %windir%\repair\secsetup.inf /db secsetup.sdb /verbose
  • Wait for the "Task Is Completed" message and then restart the computer.
Ghost
Hi Corrine,
Followed instructions for cmd command and get this in the cmd window:
'secedit' is not recognized as an internal or external command, operable program or batch file
Security Check showed:  "Windows Security Center service is not running!"  In addition, CF is still showing McAfee.  Just one last thing before cleaning up the tools we used:
Type services.msc in the Run box.  Then check that wscsvc is Started and set to Automatic.
Again, my encouragement to convince the person to use Linux until a new computer is purchased, most especially if there will be anything related to finances.
  • Remove disinfection tools
  • Create registry backup
  • Purge system restore
  • Click Run
Ghost
Hi Corrine,
QuoteThen check that wscsvc is Started and set to Automatic.
It is started and set to automatic;-).
# DelFix v1.011 - Logfile created 19/09/2015 at 21:07:16
# Updated 18/08/2015 by Xplode
# Username : coolcee - BIGCEE
# Operating System : Microsoft Windows XP Service Pack 3 (32 bits)
~ Removing disinfection tools ...
Deleted : C:\Qoobox
Deleted : C:\Combofix
Deleted : C:\FRST
Deleted : C:\ComboFix.txt
Deleted : C:\Documents and Settings\coolcee\Desktop\Addition.txt
Deleted : C:\Documents and Settings\coolcee\Desktop\ComboFix.exe
Deleted : C:\Documents and Settings\coolcee\Desktop\ComboFix.txt
Deleted : C:\Documents and Settings\coolcee\Desktop\ComboFix2.txt
Deleted : C:\Documents and Settings\coolcee\Desktop\Fixlog.txt
Deleted : C:\Documents and Settings\coolcee\Desktop\FRST.exe
Deleted : C:\Documents and Settings\coolcee\Desktop\FRST.txt
Deleted : C:\Documents and Settings\coolcee\Desktop\SecurityCheck.exe
Deleted : C:\Documents and Settings\coolcee\Desktop\TFC.exe
Deleted : C:\WINDOWS\grep.exe
Deleted : C:\WINDOWS\PEV.exe
Deleted : C:\WINDOWS\NIRCMD.exe
Deleted : C:\WINDOWS\MBR.exe
Deleted : C:\WINDOWS\SED.exe
Deleted : C:\WINDOWS\SWREG.exe
Deleted : C:\WINDOWS\SWSC.exe
Deleted : C:\WINDOWS\SWXCACLS.exe
Deleted : C:\WINDOWS\Zip.exe
Deleted : HKLM\SOFTWARE\Swearware
Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\combofix.exe
~ Creating registry backup ... OK
~ Cleaning system restore ...
Deleted : RP #677 [Installed Windows XP KB955069. | 09/19/2015 01:19:14]
Deleted : RP #678 [Installed Windows XP KB973687. | 09/19/2015 01:20:25]
Deleted : RP #679 [Installed Windows XP KB955759. | 09/19/2015 01:21:37]
Deleted : RP #680 [Installed Windows XP KB956572. | 09/19/2015 01:22:56]
Deleted : RP #681 [Installed Windows XP KB956802. | 09/19/2015 01:24:20]
Deleted : RP #682 [Installed Windows XP KB956803. | 09/19/2015 01:25:29]
Deleted : RP #683 [Installed Windows XP KB956844. | 09/19/2015 01:26:38]
Deleted : RP #684 [Installed Windows XP KB958644. | 09/19/2015 01:27:48]
Deleted : RP #685 [Installed Windows XP KB959426. | 09/19/2015 01:28:58]
Deleted : RP #686 [Installed Windows XP KB960225. | 09/19/2015 01:30:12]
Deleted : RP #687 [Installed Windows XP KB960803. | 09/19/2015 01:31:21]
Deleted : RP #688 [Installed Windows XP KB960859. | 09/19/2015 01:32:33]
Deleted : RP #689 [Installed Windows XP KB961501. | 09/19/2015 01:33:44]
Deleted : RP #690 [Installed Windows XP KB967715. | 09/19/2015 01:35:02]
Deleted : RP #691 [Installed Windows XP KB968389. | 09/19/2015 01:36:21]
Deleted : RP #692 [Installed Windows XP KB969059. | 09/19/2015 01:37:35]
Deleted : RP #693 [Installed Windows XP KB970238. | 09/19/2015 01:38:45]
Deleted : RP #694 [Installed Windows XP KB970430. | 09/19/2015 01:39:56]
Deleted : RP #695 [Installed Windows XP KB971468. | 09/19/2015 01:41:06]
Deleted : RP #696 [Installed Windows XP KB971657. | 09/19/2015 01:42:16]
Deleted : RP #697 [Installed Windows XP KB971737. | 09/19/2015 01:43:26]
Deleted : RP #698 [Installed Windows XP KB972270. | 09/19/2015 01:44:45]
Deleted : RP #699 [Installed Windows XP KB973507. | 09/19/2015 01:45:55]
Deleted : RP #700 [Installed Windows XP KB973687. | 09/19/2015 01:47:05]
Deleted : RP #701 [Installed Windows XP KB973815. | 09/19/2015 01:48:15]
Deleted : RP #702 [Installed Windows XP KB973869. | 09/19/2015 01:49:26]
Deleted : RP #703 [Installed Windows XP KB974112. | 09/19/2015 01:50:37]
Deleted : RP #704 [Installed Windows XP KB974318. | 09/19/2015 01:51:46]
Deleted : RP #705 [Installed Windows XP KB974392. | 09/19/2015 01:52:57]
Deleted : RP #706 [Installed Windows XP KB974571. | 09/19/2015 01:54:05]
Deleted : RP #707 [Installed Windows XP KB975025. | 09/19/2015 01:55:13]
Deleted : RP #708 [Installed Windows XP KB975467. | 09/19/2015 01:56:20]
Deleted : RP #709 [Installed Windows XP KB975560. | 09/19/2015 01:57:31]
Deleted : RP #710 [Installed Windows XP KB975561. | 09/19/2015 01:58:46]
Deleted : RP #711 [Installed Windows XP KB975562. | 09/19/2015 02:00:00]
Deleted : RP #712 [Installed Windows XP KB975713. | 09/19/2015 02:01:12]
Deleted : RP #713 [Installed Windows XP KB977914. | 09/19/2015 02:02:27]
Deleted : RP #714 [Installed Windows XP KB978037. | 09/19/2015 02:03:38]
Deleted : RP #715 [Installed Windows XP KB978338. | 09/19/2015 02:04:47]
Deleted : RP #716 [Installed Windows XP KB978542. | 09/19/2015 02:05:59]
Deleted : RP #717 [Installed Windows XP KB978601. | 09/19/2015 02:07:10]
Deleted : RP #718 [Installed Windows XP KB978706. | 09/19/2015 02:08:21]
Deleted : RP #719 [Installed Windows XP KB979309. | 09/19/2015 02:09:31]
Deleted : RP #720 [Installed Windows XP KB979482. | 09/19/2015 02:10:41]
Deleted : RP #721 [Installed Windows XP KB979559. | 09/19/2015 02:11:51]
Deleted : RP #722 [Installed Windows XP KB979683. | 09/19/2015 02:13:10]
Deleted : RP #723 [Installed Windows XP KB980218. | 09/19/2015 02:14:31]
Deleted : RP #724 [Installed Windows XP KB980232. | 09/19/2015 02:15:46]
Deleted : RP #725 [Revo Uninstaller's restore point - avast! Free Antivirus | 09/19/2015 14:27:23]
Deleted : RP #726 [avast! Free Antivirus Setup | 09/19/2015 14:28:59]
Deleted : RP #727 [avast! antivirus system restore point | 09/19/2015 16:12:53]
Deleted : RP #728 [Revo Uninstaller's restore point - Avast Free Antivirus | 09/20/2015 00:18:26]
Deleted : RP #729 [avast! antivirus system restore point | 09/20/2015 00:19:31]
Deleted : RP #730 [Revo Uninstaller's restore point - Avast Free Antivirus | 09/20/2015 00:22:10]
Deleted : RP #731 [avast! antivirus system restore point | 09/20/2015 00:33:18]
New restore point created !
########## - EOF - ##########
Thank you,
Ghost
Let me know if the person takes you up on the offer to use Linux.  :)
Ghost
Hi Corrine,
I will do that and thanks again for your help;-)
Ghost
