EMERGENCY!!!
Started by Moses, July 29, 2017, 06:57:54 PM
Moses
Hi,
At this point I can still see that something is not right.  It is better, but still......
for example, this morning I was on my work desk and had no programs open and yet the cursor on my mouse had that round wring spinning around and around as if I am waiting for it to finish doing something. But, there was nothing I was doing.
I went to Task Manager to verify there weren't any open processes etc.   I did refresh a couple of times but the only that worked was restarting the computer.   I did uninstall Java.
techie
If you still have Malwarebytes installed, run a scan and when it is completed, you will be given an option to uninstall or quarantine Geek Buddy. I would probably uninstall Spybot, it was giving errors, in the logs. If you don't use Comodo cloud services I would uninstall it. Adaware is optional, keep if want, but it uses resources as well. I personally do not like toolbars in browsers. I would consider uninstalling Google toolbar and Bing toolbar.
You can run PC Decrapifier and it will recommend things not needed. You can then decide if you want them or not.
https://www.pcdecrapifier.com/
Recommended reading about things to try to improve WIN 7 performance.
https://support.microsoft.com/en-us/help/15055/windows-7-optimize-windows-better-performance
Set your performance rating. When you setup or clean install Win 7 the performance rating isn't normally set and should be run or re-scanned. Setting the performance rating does help.
https://www.lifewire.com/windows-experience-index-3506854
Other than a pup or two your system seems to be clean malware or viruses.
This will give you some things to look at. It's not an automatic thing, it takes some work to improve performance.
Please let us know what you decide to remove and if you have problems with the removal.
Moses
I uninstalled comodo cloud services and Spybot. After the spybot uninstallation I got this error, (see photo).
Also, I did do another malwarebytes scan, however it did not give my any option to remove or quarantine the Geek Buddy which still shows up.
Moses
I did also uninstall the bing tool bar. Probably will also remove the google toolbar as well.
Will there be anything left for removing the daily tracking cookies that I pick when surfing?
Moses
google tool bar also gone.....
Moses
Techie,
you mentioned about Adaware (to remove if I wanted) but I don't see it anywhere listed in my programs.
It is the WebCompanion you have installed not AAW.  It has a startup service that runs continually.  Let us know if you uninstall it or keep it.
Edit Note:
  Let's run AdwCleaner first:
Please download Adware Cleaner and save it to your Desktop.
  • Right-click on AdwCleaner.exe and select Run As Administrator
  • The tool will start to update the database, please wait a bit.
  • Click on the Scan button.
  • AdwCleaner will begin.  Please be patient as the scan may take some time to complete.
  • After the scan has finished, click on the Clean button.
  • After rebooting, a logfile report (AdwCleaner[S#].txt) will open automatically (where the largest value of # represents the most recent report).
If you are "up for it" I'm willing to have another go at removing remnants as well as GeekBuddy.  However, it will unfortunately require a new set of FRST logs.  If you're willing, restart the computer and then follow the instructions below.
  • Right click to run as administrator. When the tool opens click Yes to disclaimer.
  • Note:  After FRST completes updating and the tool appears, check the box next to Addition.txt under the "Optional Scan" section
  • Press Scan button.
  • Please copy/paste both logs in your reply.
As before, the FRST logs are very long.  Please watch after posting the reply to ensure that the log has completely posted.  You'll know the log(s) are complete when you see the following lines at the end when viewing the completed reply.
==================== End of Addition.txt ============================
==================== End of FRST.txt ============================
Note:  I have to go out this afternoon so there will likely be a delay in responding.  I won't forget you though!
Moses
QuoteIt is the WebCompanion you have installed not AAW.  It has a startup service that runs continually.  Let us know if you uninstall it or keep it.
I uninstalled it as well. These are things they gave me after the Windows 7 reinstallation.
Edited by winchester73 to fix tags
Moses
# AdwCleaner 7.0.1.0 - Logfile created on Thu Aug 10 18:20:14 2017
# Updated on 2017/05/08 by Malwarebytes
# Running on Windows 7 Home Premium (X64)
# Mode: clean
# Support: https://www.malwarebytes.com/support
***** [ Services ] *****
No malicious services deleted.
***** [ Folders ] *****
Deleted: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Lavasoft\WebCompanion
***** [ Files ] *****
No malicious files deleted.
***** [ DLL ] *****
No malicious DLLs cleaned.
***** [ WMI ] *****
No malicious WMI cleaned.
***** [ Shortcuts ] *****
No malicious shortcuts cleaned.
***** [ Tasks ] *****
No malicious tasks deleted.
***** [ Registry ] *****
Deleted: [Key] - HKCU\Software\Microsoft\Internet Explorer\DOMStorage\ak.staticimgfarm.com
Deleted: [Key] - HKCU\Software\Microsoft\Internet Explorer\DOMStorage\foxit-phantom-pdf-standard.en.softonic.com
Deleted: [Key] - HKCU\Software\Microsoft\Internet Explorer\DOMStorage\softonic.com
Deleted: [Key] - HKCU\Software\Microsoft\Internet Explorer\DOMStorage\staticimgfarm.com
Deleted: [Key] - HKCU\Software\Microsoft\Internet Explorer\DOMStorage\windows-live-mail.en.softonic.com
Deleted: [Key] - HKLM\SOFTWARE\Lavasoft\Web Companion
Deleted: [Key] - HKU\S-1-5-21-2293580261-1291186321-2028678180-1000\Software\Lavasoft\Web Companion
Deleted: [Key] - HKCU\Software\Lavasoft\Web Companion
Deleted: [Value] - HKU\S-1-5-21-2293580261-1291186321-2028678180-1000\Software\Microsoft\Windows\CurrentVersion\Run|Web Companion
Deleted: [Value] - HKCU\Software\Microsoft\Windows\CurrentVersion\Run|Web Companion
Deleted: [Key] - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\webcompanion.com
Deleted: [Key] - HKU\S-1-5-21-2293580261-1291186321-2028678180-1000\Software\drpsu
Deleted: [Key] - HKCU\Software\drpsu
Deleted: [Key] - HKCU\Software\Microsoft\Internet Explorer\DOMStorage\easypdfcombine.dl.myway.com
Deleted: [Key] - HKCU\Software\Microsoft\Internet Explorer\DOMStorage\myway.com
***** [ Firefox (and derivatives) ] *****
No malicious Firefox entries deleted.
***** [ Chromium (and derivatives) ] *****
No malicious Chromium entries deleted.
::Tracing keys deleted
::Winsock settings cleared
::Additional Actions: 0
C:/AdwCleaner/AdwCleaner[S0].txt - [2515 B] - [2017/8/10 18:18:14]
########## EOF - C:\AdwCleaner\AdwCleaner[C0].txt ##########
Moses
Here is the first FRST scan:
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 09-08-2017
Ran by Me (administrator) on PC-9898 (10-08-2017 22:08:13)
Running from C:\Users\Me\Desktop\Repair
Loaded Profiles: Me (Available Profiles: Me)
Platform: Windows 7 Home Premium Service Pack 1 (X64) Language: English (United States)
Internet Explorer Version 11 (Default browser: IE)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
==================== Processes (Whitelisted) =================
(If an entry is included in the fixlist, the process will be closed. The file will not be moved.)
(AVAST Software) C:\Program Files\AVAST Software\Avast\AvastSvc.exe
(COMODO Security Solutions) C:\Program Files\COMODO\COMMON\COSService.exe
(McAfee, Inc.) C:\Program Files (x86)\McAfee\SiteAdvisor\mcsacore.exe
(COMODO Security Solutions) C:\Program Files\COMODO\COMMON\SynchronizationService.exe
(Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe
(Intel Corporation) C:\Windows\System32\igfxtray.exe
(Intel Corporation) C:\Windows\System32\hkcmd.exe
(Intel Corporation) C:\Windows\System32\igfxpers.exe
(Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\mbamtray.exe
(Skype Technologies S.A.) C:\Program Files (x86)\Skype\Phone\Skype.exe
(AVAST Software) C:\Program Files\AVAST Software\Avast\avastui.exe
(Microsoft Corporation) C:\Windows\System32\rundll32.exe
(Hewlett-Packard) C:\Program Files (x86)\HP\HP Software Update\hpwuschd2.exe
(Microsoft Corp.) C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE
(Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
(Microsoft Corp.) C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVCM.EXE
(McAfee, Inc.) C:\Program Files (x86)\McAfee\SiteAdvisor\saUI.exe
(AVAST Software s.r.o.) C:\Program Files\AVAST Software\Avast\x64\aswidsagenta.exe
(Microsoft Corporation) C:\Program Files\Internet Explorer\iexplore.exe
==================== Registry (Whitelisted) ====================
(If an entry is included in the fixlist, the registry item will be restored to default or removed. The file will not be moved.)
HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe [16408320 2015-12-04] (Realtek Semiconductor)
HKLM\...\Run: [AvastUI.exe] => C:\Program Files\AVAST Software\Avast\AvLaunch.exe [213832 2017-08-02] (AVAST Software)
HKLM\...\Run: [Malwarebytes TrayApp] => C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\mbamtray.exe [3146704 2017-05-09] (Malwarebytes)
HKLM-x32\...\Run: [HP Software Update] => C:\Program Files (x86)\Hp\HP Software Update\HPWuSchd2.exe [96056 2013-05-30] (Hewlett-Packard)
Winlogon\Notify\igfxcui: C:\Windows\system32\igfxdev.dll (Intel Corporation)
HKLM\SOFTWARE\Policies\Microsoft\Windows Defender: Restriction <==== ATTENTION
HKU\S-1-5-21-2293580261-1291186321-2028678180-1000\...\Run: [Skype] => C:\Program Files (x86)\Skype\Phone\Skype.exe [27815896 2017-07-28] (Skype Technologies S.A.)
Startup: C:\Users\Me\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Monitor Ink Alerts - HP Officejet Pro 6830.lnk [2017-08-10]
ShortcutTarget: Monitor Ink Alerts - HP Officejet Pro 6830.lnk -> C:\Program Files\HP\HP Officejet Pro 6830\Bin\HPStatusBL.dll (Hewlett-Packard Development Company, LP)
BootExecute: autocheck autochk * sdnclean64.exe
==================== Internet (Whitelisted) ====================
(If an item is included in the fixlist, if it is a registry item it will be removed or restored to default.)
Tcpip\Parameters: [DhcpNameServer] 10.100.102.1
Tcpip\..\Interfaces\{3E5A35ED-A886-497A-912D-9B4DCF9CE114}: [DhcpNameServer] 10.100.102.1
Internet Explorer:
HKU\S-1-5-21-2293580261-1291186321-2028678180-1000\Software\Microsoft\Internet Explorer\Main,Start Page = hxxps://www.google.co.il/
SearchScopes: HKU\.DEFAULT -> DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
SearchScopes: HKU\S-1-5-21-2293580261-1291186321-2028678180-1000 -> {C0C3A6C6-03BC-4195-8FCB-AEA091301353} URL = hxxps://search.yahoo.com/yhs/search?hspart=lvs&hsimp=yhs-awc&type=lvs__webcompa__1_0__ya__ch_WCYID10181_1333_170802__yaie&p={searchTerms}
BHO: Windows Live ID Sign-in Helper -> {9030D464-4C02-4ABF-8ECC-5164760863C6} -> C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll [2011-03-28] (Microsoft Corp.)
BHO: McAfee WebAdvisor BHO -> {B164E929-A1B6-4A06-B104-2CD0E90A88FF} -> c:\Program Files (x86)\McAfee\SiteAdvisor\x64\McIEPlg.dll [2017-07-25] (McAfee, Inc.)
BHO-x32: Windows Live ID Sign-in Helper -> {9030D464-4C02-4ABF-8ECC-5164760863C6} -> C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll [2011-03-28] (Microsoft Corp.)
BHO-x32: Windows Live Messenger Companion Helper -> {9FDDE16B-836F-4806-AB1F-1455CBEFF289} -> C:\Program Files (x86)\Windows Live\Companion\companioncore.dll [2011-05-13] (Microsoft Corporation)
BHO-x32: McAfee WebAdvisor BHO -> {B164E929-A1B6-4A06-B104-2CD0E90A88FF} -> c:\Program Files (x86)\McAfee\SiteAdvisor\McIEPlg.dll [2017-07-25] (McAfee, Inc.)
Handler: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files (x86)\McAfee\SiteAdvisor\x64\McIEPlg.dll [2017-07-25] (McAfee, Inc.)
Handler-x32: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\Program Files (x86)\McAfee\SiteAdvisor\McIEPlg.dll [2017-07-25] (McAfee, Inc.)
FireFox:
FF HKLM\...\Firefox\Extensions: [{4ED1F68A-5463-4931-9384-8FFF5ED91D92}] - C:\Program Files (x86)\McAfee\SiteAdvisor\saffplg.xpi
FF Extension: (McAfee WebAdvisor) - C:\Program Files (x86)\McAfee\SiteAdvisor\saffplg.xpi [2017-07-20]
FF HKLM-x32\...\Firefox\Extensions: [{4ED1F68A-5463-4931-9384-8FFF5ED91D92}] - C:\Program Files (x86)\McAfee\SiteAdvisor\saffplg.xpi
FF Plugin: @microsoft.com/GENUINE -> disabled [No File]
FF Plugin: @Microsoft.com/NpCtrl,version=1.0 -> c:\Program Files\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
FF Plugin-x32: @microsoft.com/GENUINE -> disabled [No File]
FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 -> c:\Program Files (x86)\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
FF Plugin-x32: @microsoft.com/WLPG,version=15.4.3502.0922 -> C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll [2011-05-13] (Microsoft Corporation)
FF Plugin-x32: @microsoft.com/WLPG,version=15.4.3538.0513 -> C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll [2011-05-13] (Microsoft Corporation)
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-08-02] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.33.5\npGoogleUpdate3.dll [2017-08-02] (Google Inc.)
FF Plugin-x32: Adobe Reader -> C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2017-04-05] (Adobe Systems Inc.)
Chrome:
CHR DefaultSearchURL: Default -> hxxps://search.yahoo.com/search?fr=mcafee&type=C210US91105D20170803&p={searchTerms}
CHR DefaultSearchKeyword: Default -> McAfee
CHR Profile: C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default [2017-08-10]
CHR Extension: (Google מצגות) - C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2017-08-02]
CHR Extension: (Google Docs) - C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake [2017-08-02]
CHR Extension: (כונן Google) - C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf [2017-08-02]
CHR Extension: (YouTube) - C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2017-08-02]
CHR Extension: (McAfee® WebAdvisor) - C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Extensions\fheoggkfdfchfphceeifdbepaooicaho [2017-08-03]
CHR Extension: (Google Docs Offline) - C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2017-08-02]
CHR Extension: (Chrome Web Store Payments) - C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2017-08-02]
CHR Extension: (Gmail) - C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2017-08-02]
CHR Extension: (Chrome Media Router) - C:\Users\Me\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2017-08-02]
CHR HKLM\...\Chrome\Extension: [fheoggkfdfchfphceeifdbepaooicaho] - hxxp://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [fheoggkfdfchfphceeifdbepaooicaho] - hxxp://clients2.google.com/service/update2/crx
==================== Services (Whitelisted) ====================
R3 aswbIDSAgent; C:\Program Files\AVAST Software\Avast\x64\aswidsagenta.exe [7430992 2017-08-02] (AVAST Software s.r.o.)
R2 avast! Antivirus; C:\Program Files\AVAST Software\Avast\AvastSvc.exe [263312 2017-08-02] (AVAST Software)
R2 COSService.exe; C:\Program Files\COMODO\COMMON\COSService.exe [3550400 2014-10-07] (COMODO Security Solutions)
R2 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [4470736 2017-05-09] (Malwarebytes)
R2 McAfee SiteAdvisor Service; C:\Program Files (x86)\McAfee\SiteAdvisor\McSACore.exe [590880 2017-07-25] (McAfee, Inc.)
R2 SynchronizationService.exe; C:\Program Files\COMODO\COMMON\SynchronizationService.exe [2575552 2014-10-07] (COMODO Security Solutions)
S3 WinDefend; C:\Program Files\Windows Defender\mpsvc.dll [1011712 2013-05-27] (Microsoft Corporation)
===================== Drivers (Whitelisted) ======================
R1 aswbidsdriver; C:\Windows\system32\drivers\aswbidsdrivera.sys [320008 2017-08-02] (AVAST Software s.r.o.)
R0 aswbidsh; C:\Windows\system32\drivers\aswbidsha.sys [198976 2017-08-02] (AVAST Software s.r.o.)
R0 aswblog; C:\Windows\system32\drivers\aswbloga.sys [343288 2017-08-02] (AVAST Software s.r.o.)
R0 aswbuniv; C:\Windows\system32\drivers\aswbuniva.sys [57728 2017-08-02] (AVAST Software s.r.o.)
S3 aswHwid; C:\Windows\system32\drivers\aswHwid.sys [46984 2017-08-02] (AVAST Software)
R2 aswMonFlt; C:\Windows\system32\drivers\aswMonFlt.sys [146704 2017-08-09] (AVAST Software)
R1 aswRdr; C:\Windows\system32\drivers\aswRdr2.sys [110352 2017-08-02] (AVAST Software)
R0 aswRvrt; C:\Windows\system32\drivers\aswRvrt.sys [84392 2017-08-02] (AVAST Software)
R1 aswSnx; C:\Windows\system32\drivers\aswSnx.sys [1015880 2017-08-09] (AVAST Software)
R1 aswSP; C:\Windows\system32\drivers\aswSP.sys [585608 2017-08-02] (AVAST Software)
R2 aswStm; C:\Windows\system32\drivers\aswStm.sys [198768 2017-08-02] (AVAST Software)
R0 aswVmm; C:\Windows\system32\drivers\aswVmm.sys [361336 2017-08-02] (AVAST Software)
R0 bdisk; C:\Windows\System32\DRIVERS\bdisk.sys [85488 2014-10-07] (COMODO Security Solutions Inc.)
R0 CBUFS; C:\Windows\System32\DRIVERS\CBUFS.sys [230712 2014-10-07] (COMODO Security Solutions Inc.)
R0 cbvd; C:\Windows\System32\DRIVERS\cbvd.sys [677744 2014-10-07] (COMODO Security Solutions Inc.)
R1 ESProtectionDriver; C:\Windows\system32\drivers\mbae64.sys [77376 2017-06-27] ()
R0 iaStorF; C:\Windows\System32\DRIVERS\iaStorF.sys [30960 2015-05-29] (Intel Corporation)
R2 MBAMChameleon; C:\Windows\system32\drivers\MBAMChameleon.sys [188352 2017-08-08] (Malwarebytes)
R3 MBAMFarflt; C:\Windows\system32\drivers\farflt.sys [101784 2017-08-10] (Malwarebytes)
R3 MBAMProtection; C:\Windows\system32\drivers\mbam.sys [45472 2017-08-10] (Malwarebytes)
R0 MBAMSwissArmy; C:\Windows\System32\drivers\MBAMSwissArmy.sys [253856 2017-08-10] (Malwarebytes)
R3 MBAMWebProtection; C:\Windows\system32\drivers\mwac.sys [84256 2017-08-10] (Malwarebytes)
R3 MEIx64; C:\Windows\System32\DRIVERS\TeeDriverx64.sys [180480 2015-10-08] (Intel Corporation)
R3 mfesapsn; C:\Program Files (x86)\McAfee\SiteAdvisor\x64\mfesapsn.sys [111608 2017-02-14] (McAfee, Inc.)
R0 Reparse; C:\Windows\System32\DRIVERS\CBReparse.sys [674160 2014-10-07] (COMODO Security Solutions Inc.)
R3 Serenum; C:\Windows\System32\DRIVERS\nuvserenum.sys [23552 2014-01-12] (Windows (R) Win 7 DDK provider)
R3 Serial; C:\Windows\System32\DRIVERS\nuvserial.sys [86016 2014-01-12] (Nuvoton Technology Corp.)
R3 SmbDrvI; C:\Windows\System32\DRIVERS\Smb_driver_Intel.sys [33960 2015-09-08] (Synaptics Incorporated)
R3 vdbus; C:\Windows\System32\DRIVERS\vdbus.sys [826040 2014-10-07] (COMODO Security Solutions Inc.)
==================== NetSvcs (Whitelisted) ===================
==================== One Month Created files and folders ========
(If an entry is included in the fixlist, the file/folder will be moved.)
2017-08-10 21:16 - 2017-08-10 21:20 - 000000000 ____D C:\AdwCleaner
2017-08-10 21:15 - 2017-08-10 21:16 - 008185288 _____ (Malwarebytes) C:\Users\Me\Desktop\adwcleaner_7.0.1.0.exe
2017-08-10 19:29 - 2017-08-10 19:29 - 000000085 _____ C:\Windows\wininit.ini
2017-08-10 19:29 - 2017-08-10 19:29 - 000000000 ____D C:\Windows\System32\Tasks\Safer-Networking
2017-08-10 17:11 - 2017-08-10 17:11 - 000000000 ____D C:\Users\Me\AppData\Local\{B00911BF-D408-41AD-BE9E-43D1F4D6EFA5}
2017-08-10 10:45 - 2017-08-10 10:45 - 000000000 ____D C:\Users\Me\AppData\Local\{4A5AB992-B212-4968-B0BA-E3A41E34930B}
2017-08-10 08:22 - 2017-08-10 08:22 - 000000000 ____D C:\Users\Me\AppData\Local\{05EA1DF3-ABA0-44BD-A3A5-E3579AF74930}
2017-08-09 23:26 - 2017-08-09 23:26 - 000000000 ____D C:\Users\Me\AppData\Local\{F1DD11D8-5EFE-4F84-99C2-14CF695DF8C9}
2017-08-09 23:22 - 2017-08-09 23:22 - 000000000 ____D C:\Users\Me\AppData\Roaming\Sun
2017-08-09 20:15 - 2017-08-09 20:15 - 000000000 ____D C:\Users\Me\AppData\Local\{8FE66117-AA84-4463-8443-25681E472C8B}
2017-08-09 19:39 - 2017-08-09 19:39 - 000000020 _____ C:\Windows\È÷±
2017-08-09 17:50 - 2017-08-09 17:50 - 000000000 ____D C:\Users\Me\AppData\Local\{11FEDDE6-EFD1-4AD8-A8D5-142FB28F2F51}
2017-08-09 13:19 - 2017-08-09 13:36 - 000000000 ____D C:\Users\Me\Desktop\New folder
2017-08-09 13:02 - 2017-08-09 13:02 - 000000000 ____D C:\Users\Me\AppData\Local\{C02A0389-078C-4785-ABF3-8CC056C036D7}
2017-08-09 09:51 - 2017-08-09 09:51 - 000000000 ____D C:\Users\Me\AppData\Local\{04A10720-FC08-445A-BE91-A48FC9AA1E0C}
2017-08-09 07:49 - 2017-07-29 17:56 - 000117248 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\tdx.sys
2017-08-09 07:49 - 2017-07-21 17:26 - 000518144 _____ C:\Windows\SysWOW64\msjetoledb40.dll
2017-08-09 07:49 - 2017-07-21 17:26 - 000290816 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msjtes40.dll
2017-08-09 07:49 - 2017-07-15 21:35 - 000394448 _____ (Microsoft Corporation) C:\Windows\system32\iedkcs32.dll
2017-08-09 07:49 - 2017-07-15 20:52 - 000346320 _____ (Microsoft Corporation) C:\Windows\SysWOW64\iedkcs32.dll
2017-08-09 07:49 - 2017-07-14 18:29 - 002319872 _____ (Microsoft Corporation) C:\Windows\system32\tquery.dll
2017-08-09 07:49 - 2017-07-14 18:29 - 002222080 _____ (Microsoft Corporation) C:\Windows\system32\mssrch.dll
2017-08-09 07:49 - 2017-07-14 18:29 - 002058240 _____ (Microsoft Corporation) C:\Windows\system32\Query.dll
2017-08-09 07:49 - 2017-07-14 18:29 - 000778240 _____ (Microsoft Corporation) C:\Windows\system32\mssvp.dll
2017-08-09 07:49 - 2017-07-14 18:29 - 000486400 _____ (Microsoft Corporation) C:\Windows\system32\wer.dll
2017-08-09 07:49 - 2017-07-14 18:29 - 000034304 _____ (Microsoft Corporation) C:\Windows\system32\werdiagcontroller.dll
2017-08-09 07:49 - 2017-07-14 18:10 - 001549824 _____ (Microsoft Corporation) C:\Windows\SysWOW64\tquery.dll
2017-08-09 07:49 - 2017-07-14 18:10 - 001363968 _____ (Microsoft Corporation) C:\Windows\SysWOW64\Query.dll
2017-08-09 07:49 - 2017-07-14 18:10 - 000382976 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wer.dll
2017-08-09 07:49 - 2017-07-14 17:57 - 000050688 _____ (Microsoft Corporation) C:\Windows\system32\wermgr.exe
2017-08-09 07:49 - 2017-07-14 17:50 - 000054272 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wermgr.exe
2017-08-09 07:49 - 2017-07-14 17:50 - 000028672 _____ (Microsoft Corporation) C:\Windows\SysWOW64\werdiagcontroller.dll
2017-08-09 07:49 - 2017-07-14 09:49 - 025733632 _____ (Microsoft Corporation) C:\Windows\system32\mshtml.dll
2017-08-09 07:49 - 2017-07-14 09:45 - 000417792 _____ (Microsoft Corporation) C:\Windows\system32\html.iec
2017-08-09 07:49 - 2017-07-14 09:44 - 000576512 _____ (Microsoft Corporation) C:\Windows\system32\vbscript.dll
2017-08-09 07:49 - 2017-07-14 09:38 - 002899456 _____ (Microsoft Corporation) C:\Windows\system32\iertutil.dll
2017-08-09 07:49 - 2017-07-14 09:22 - 000615936 _____ (Microsoft Corporation) C:\Windows\system32\ieui.dll
2017-08-09 07:49 - 2017-07-14 09:19 - 000817664 _____ (Microsoft Corporation) C:\Windows\system32\jscript.dll
2017-08-09 07:49 - 2017-07-14 09:08 - 000968704 _____ (Microsoft Corporation) C:\Windows\system32\MsSpellCheckingFacility.exe
2017-08-09 07:49 - 2017-07-14 09:02 - 000489984 _____ (Microsoft Corporation) C:\Windows\system32\dxtmsft.dll
2017-08-09 07:49 - 2017-07-14 08:35 - 005981184 _____ (Microsoft Corporation) C:\Windows\system32\jscript9.dll
2017-08-09 07:49 - 2017-07-14 08:35 - 000315392 _____ (Microsoft Corporation) C:\Windows\system32\dxtrans.dll
2017-08-09 07:49 - 2017-07-14 08:16 - 000262144 _____ (Microsoft Corporation) C:\Windows\system32\webcheck.dll
2017-08-09 07:49 - 2017-07-14 08:10 - 000806912 _____ (Microsoft Corporation) C:\Windows\system32\msfeeds.dll
2017-08-09 07:49 - 2017-07-14 08:09 - 002132992 _____ (Microsoft Corporation) C:\Windows\system32\inetcpl.cpl
2017-08-09 07:49 - 2017-07-14 08:09 - 001359360 _____ (Microsoft Corporation) C:\Windows\system32\mshtmlmedia.dll
2017-08-09 07:49 - 2017-07-14 07:40 - 015254016 _____ (Microsoft Corporation) C:\Windows\system32\ieframe.dll
2017-08-09 07:49 - 2017-07-14 07:23 - 003240960 _____ (Microsoft Corporation) C:\Windows\system32\wininet.dll
2017-08-09 07:49 - 2017-07-14 07:07 - 001545728 _____ (Microsoft Corporation) C:\Windows\system32\urlmon.dll
2017-08-09 07:49 - 2017-07-14 06:58 - 000800768 _____ (Microsoft Corporation) C:\Windows\system32\ieapfltr.dll
2017-08-09 07:49 - 2017-07-14 05:54 - 020270080 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mshtml.dll
2017-08-09 07:49 - 2017-07-14 05:48 - 000499200 _____ (Microsoft Corporation) C:\Windows\SysWOW64\vbscript.dll
2017-08-09 07:49 - 2017-07-14 05:44 - 002290176 _____ (Microsoft Corporation) C:\Windows\SysWOW64\iertutil.dll
2017-08-09 07:49 - 2017-07-14 05:38 - 000663552 _____ (Microsoft Corporation) C:\Windows\SysWOW64\jscript.dll
2017-08-09 07:49 - 2017-07-14 05:17 - 004546048 _____ (Microsoft Corporation) C:\Windows\SysWOW64\jscript9.dll
2017-08-09 07:49 - 2017-07-14 05:12 - 000693248 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msfeeds.dll
2017-08-09 07:49 - 2017-07-14 05:11 - 002057216 _____ (Microsoft Corporation) C:\Windows\SysWOW64\inetcpl.cpl
2017-08-09 07:49 - 2017-07-14 05:11 - 001155072 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mshtmlmedia.dll
2017-08-09 07:49 - 2017-07-14 05:09 - 013663744 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ieframe.dll
2017-08-09 07:49 - 2017-07-14 04:53 - 002767872 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wininet.dll
2017-08-09 07:49 - 2017-07-14 04:50 - 001314816 _____ (Microsoft Corporation) C:\Windows\SysWOW64\urlmon.dll
2017-08-09 07:49 - 2017-07-08 18:34 - 000370920 _____ (Microsoft Corporation) C:\Windows\system32\clfs.sys
2017-08-09 07:49 - 2017-07-08 18:00 - 003224064 _____ (Microsoft Corporation) C:\Windows\system32\win32k.sys
2017-08-09 07:49 - 2017-07-07 18:37 - 000631176 _____ (Microsoft Corporation) C:\Windows\system32\winresume.efi
2017-08-09 07:49 - 2017-07-07 18:33 - 005547752 _____ (Microsoft Corporation) C:\Windows\system32\ntoskrnl.exe
2017-08-09 07:49 - 2017-07-07 18:33 - 000706792 _____ (Microsoft Corporation) C:\Windows\system32\winload.efi
2017-08-09 07:49 - 2017-07-07 18:33 - 000363752 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\volmgrx.sys
2017-08-09 07:49 - 2017-07-07 18:33 - 000154856 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\ksecpkg.sys
2017-08-09 07:49 - 2017-07-07 18:33 - 000095464 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\ksecdd.sys
2017-08-09 07:49 - 2017-07-07 18:31 - 001732864 _____ (Microsoft Corporation) C:\Windows\system32\ntdll.dll
2017-08-09 07:49 - 2017-07-07 18:29 - 001212928 _____ (Microsoft Corporation) C:\Windows\system32\rpcrt4.dll
2017-08-09 07:49 - 2017-07-07 18:29 - 000463872 _____ (Microsoft Corporation) C:\Windows\system32\certcli.dll
2017-08-09 07:49 - 2017-07-07 18:29 - 000149504 _____ (Microsoft Corporation) C:\Windows\system32\t2embed.dll
2017-08-09 07:49 - 2017-07-07 18:15 - 004001000 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ntkrnlpa.exe
2017-08-09 07:49 - 2017-07-07 18:15 - 003945192 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ntoskrnl.exe
2017-08-09 07:49 - 2017-07-07 18:13 - 001314112 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ntdll.dll
2017-08-09 07:49 - 2017-07-07 18:11 - 000666112 _____ (Microsoft Corporation) C:\Windows\SysWOW64\rpcrt4.dll
2017-08-09 07:49 - 2017-07-07 18:11 - 000109568 _____ (Microsoft Corporation) C:\Windows\SysWOW64\t2embed.dll
2017-08-09 07:49 - 2017-07-07 18:10 - 000342528 _____ (Microsoft Corporation) C:\Windows\SysWOW64\certcli.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 001311744 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msjet40.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000866816 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mswdat10.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000641536 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mswstr10.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000616448 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msrepl40.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000475648 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msxbde40.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000375808 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mspbde40.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000343552 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msrd3x40.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000339968 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msexcl40.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000310272 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msrd2x40.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000240640 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msltus40.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000144896 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msjint40.dll
2017-08-09 07:49 - 2017-07-01 16:05 - 000083968 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msjter40.dll
2017-08-09 07:48 - 2017-07-21 17:26 - 000409600 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msexch40.dll
2017-08-09 07:48 - 2017-07-21 17:26 - 000282624 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mstext40.dll
2017-08-09 07:48 - 2017-07-14 18:29 - 000491520 _____ (Microsoft Corporation) C:\Windows\system32\mssph.dll
2017-08-09 07:48 - 2017-07-14 18:29 - 000288256 _____ (Microsoft Corporation) C:\Windows\system32\mssphtb.dll
2017-08-09 07:48 - 2017-07-14 18:29 - 000115200 _____ (Microsoft Corporation) C:\Windows\system32\mssitlb.dll
2017-08-09 07:48 - 2017-07-14 18:29 - 000099840 _____ (Microsoft Corporation) C:\Windows\system32\mssprxy.dll
2017-08-09 07:48 - 2017-07-14 18:29 - 000075264 _____ (Microsoft Corporation) C:\Windows\system32\msscntrs.dll
2017-08-09 07:48 - 2017-07-14 18:29 - 000014336 _____ (Microsoft Corporation) C:\Windows\system32\msshooks.dll
2017-08-09 07:48 - 2017-07-14 18:12 - 000591872 _____ (Microsoft Corporation) C:\Windows\system32\SearchIndexer.exe
2017-08-09 07:48 - 2017-07-14 18:12 - 000249856 _____ (Microsoft Corporation) C:\Windows\system32\SearchProtocolHost.exe
2017-08-09 07:48 - 2017-07-14 18:11 - 000113664 _____ (Microsoft Corporation) C:\Windows\system32\SearchFilterHost.exe
2017-08-09 07:48 - 2017-07-14 18:10 - 001400320 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mssrch.dll
2017-08-09 07:48 - 2017-07-14 18:10 - 000666624 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mssvp.dll
2017-08-09 07:48 - 2017-07-14 18:10 - 000337408 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mssph.dll
2017-08-09 07:48 - 2017-07-14 18:10 - 000197120 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mssphtb.dll
2017-08-09 07:48 - 2017-07-14 18:10 - 000104448 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mssitlb.dll
2017-08-09 07:48 - 2017-07-14 18:10 - 000059392 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msscntrs.dll
2017-08-09 07:48 - 2017-07-14 18:10 - 000034816 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mssprxy.dll
2017-08-09 07:48 - 2017-07-14 18:00 - 000427520 _____ (Microsoft Corporation) C:\Windows\SysWOW64\SearchIndexer.exe
2017-08-09 07:48 - 2017-07-14 18:00 - 000164352 _____ (Microsoft Corporation) C:\Windows\SysWOW64\SearchProtocolHost.exe
2017-08-09 07:48 - 2017-07-14 17:59 - 000086528 _____ (Microsoft Corporation) C:\Windows\SysWOW64\SearchFilterHost.exe
2017-08-09 07:48 - 2017-07-14 17:59 - 000009728 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msshooks.dll
2017-08-09 07:48 - 2017-07-14 10:16 - 002724864 _____ (Microsoft Corporation) C:\Windows\system32\mshtml.tlb
2017-08-09 07:48 - 2017-07-14 10:15 - 000004096 _____ (Microsoft Corporation) C:\Windows\system32\ieetwcollectorres.dll
2017-08-09 07:48 - 2017-07-14 09:47 - 000066560 _____ (Microsoft Corporation) C:\Windows\system32\iesetup.dll
2017-08-09 07:48 - 2017-07-14 09:45 - 000048640 _____ (Microsoft Corporation) C:\Windows\system32\ieetwproxystub.dll
2017-08-09 07:48 - 2017-07-14 09:44 - 000088064 _____ (Microsoft Corporation) C:\Windows\system32\MshtmlDac.dll
2017-08-09 07:48 - 2017-07-14 09:29 - 000054784 _____ (Microsoft Corporation) C:\Windows\system32\jsproxy.dll
2017-08-09 07:48 - 2017-07-14 09:28 - 000034304 _____ (Microsoft Corporation) C:\Windows\system32\iernonce.dll
2017-08-09 07:48 - 2017-07-14 09:20 - 000144384 _____ (Microsoft Corporation) C:\Windows\system32\ieUnatt.exe
2017-08-09 07:48 - 2017-07-14 09:20 - 000116224 _____ (Microsoft Corporation) C:\Windows\system32\ieetwcollector.exe
2017-08-09 07:48 - 2017-07-14 09:19 - 000814080 _____ (Microsoft Corporation) C:\Windows\system32\jscript9diag.dll
2017-08-09 07:48 - 2017-07-14 08:49 - 000077824 _____ (Microsoft Corporation) C:\Windows\system32\JavaScriptCollectionAgent.dll
2017-08-09 07:48 - 2017-07-14 08:48 - 000087552 _____ (Microsoft Corporation) C:\Windows\system32\tdc.ocx
2017-08-09 07:48 - 2017-07-14 08:47 - 000107520 _____ (Microsoft Corporation) C:\Windows\system32\inseng.dll
2017-08-09 07:48 - 2017-07-14 08:42 - 000199680 _____ (Microsoft Corporation) C:\Windows\system32\msrating.dll
2017-08-09 07:48 - 2017-07-14 08:40 - 000092160 _____ (Microsoft Corporation) C:\Windows\system32\mshtmled.dll
2017-08-09 07:48 - 2017-07-14 08:33 - 000152064 _____ (Microsoft Corporation) C:\Windows\system32\occache.dll
2017-08-09 07:48 - 2017-07-14 08:11 - 000725504 _____ (Microsoft Corporation) C:\Windows\system32\ie4uinit.exe
2017-08-09 07:48 - 2017-07-14 06:01 - 002724864 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mshtml.tlb
2017-08-09 07:48 - 2017-07-14 05:48 - 000341504 _____ (Microsoft Corporation) C:\Windows\SysWOW64\html.iec
2017-08-09 07:48 - 2017-07-14 05:48 - 000062464 _____ (Microsoft Corporation) C:\Windows\SysWOW64\iesetup.dll
2017-08-09 07:48 - 2017-07-14 05:48 - 000047616 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ieetwproxystub.dll
2017-08-09 07:48 - 2017-07-14 05:47 - 000064000 _____ (Microsoft Corporation) C:\Windows\SysWOW64\MshtmlDac.dll
2017-08-09 07:48 - 2017-07-14 05:42 - 000047104 _____ (Microsoft Corporation) C:\Windows\SysWOW64\jsproxy.dll
2017-08-09 07:48 - 2017-07-14 05:41 - 000030720 _____ (Microsoft Corporation) C:\Windows\SysWOW64\iernonce.dll
2017-08-09 07:48 - 2017-07-14 05:39 - 000476160 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ieui.dll
2017-08-09 07:48 - 2017-07-14 05:38 - 000620032 _____ (Microsoft Corporation) C:\Windows\SysWOW64\jscript9diag.dll
2017-08-09 07:48 - 2017-07-14 05:38 - 000115712 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ieUnatt.exe
2017-08-09 07:48 - 2017-07-14 05:30 - 000416256 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dxtmsft.dll
2017-08-09 07:48 - 2017-07-14 05:26 - 000060416 _____ (Microsoft Corporation) C:\Windows\SysWOW64\JavaScriptCollectionAgent.dll
2017-08-09 07:48 - 2017-07-14 05:25 - 000091136 _____ (Microsoft Corporation) C:\Windows\SysWOW64\inseng.dll
2017-08-09 07:48 - 2017-07-14 05:25 - 000073216 _____ (Microsoft Corporation) C:\Windows\SysWOW64\tdc.ocx
2017-08-09 07:48 - 2017-07-14 05:23 - 000168960 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msrating.dll
2017-08-09 07:48 - 2017-07-14 05:22 - 000076288 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mshtmled.dll
2017-08-09 07:48 - 2017-07-14 05:21 - 000279040 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dxtrans.dll
2017-08-09 07:48 - 2017-07-14 05:20 - 000130048 _____ (Microsoft Corporation) C:\Windows\SysWOW64\occache.dll
2017-08-09 07:48 - 2017-07-14 05:13 - 000230400 _____ (Microsoft Corporation) C:\Windows\SysWOW64\webcheck.dll
2017-08-09 07:48 - 2017-07-14 04:48 - 000710144 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ieapfltr.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 001460736 _____ (Microsoft Corporation) C:\Windows\system32\lsasrv.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 001163264 _____ (Microsoft Corporation) C:\Windows\system32\kernel32.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000880640 _____ (Microsoft Corporation) C:\Windows\system32\advapi32.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000731648 _____ (Microsoft Corporation) C:\Windows\system32\kerberos.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000690688 _____ (Microsoft Corporation) C:\Windows\system32\adtschema.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000503808 _____ (Microsoft Corporation) C:\Windows\system32\srcore.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000419840 _____ (Microsoft Corporation) C:\Windows\system32\KernelBase.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000362496 _____ (Microsoft Corporation) C:\Windows\system32\wow64win.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000345600 _____ (Microsoft Corporation) C:\Windows\system32\schannel.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000316928 _____ (Microsoft Corporation) C:\Windows\system32\msv1_0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000312320 _____ (Microsoft Corporation) C:\Windows\system32\ncrypt.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000243712 _____ (Microsoft Corporation) C:\Windows\system32\wow64.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000215552 _____ (Microsoft Corporation) C:\Windows\system32\winsrv.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000210432 _____ (Microsoft Corporation) C:\Windows\system32\wdigest.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000190464 _____ (Microsoft Corporation) C:\Windows\system32\rpchttp.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000146432 _____ (Microsoft Corporation) C:\Windows\system32\msaudite.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000135680 _____ (Microsoft Corporation) C:\Windows\system32\sspicli.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000123904 _____ (Microsoft Corporation) C:\Windows\system32\bcrypt.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000086528 _____ (Microsoft Corporation) C:\Windows\system32\TSpkg.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000063488 _____ (Microsoft Corporation) C:\Windows\system32\setbcdlocale.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000060416 _____ (Microsoft Corporation) C:\Windows\system32\msobjs.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000059904 _____ (Microsoft Corporation) C:\Windows\system32\appidapi.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000050176 _____ (Microsoft Corporation) C:\Windows\system32\srclient.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000044032 _____ (Microsoft Corporation) C:\Windows\system32\csrsrv.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000043520 _____ (Microsoft Corporation) C:\Windows\system32\cryptbase.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000034816 _____ (Microsoft Corporation) C:\Windows\system32\appidsvc.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000028672 _____ (Microsoft Corporation) C:\Windows\system32\sspisrv.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000028160 _____ (Microsoft Corporation) C:\Windows\system32\secur32.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000022016 _____ (Microsoft Corporation) C:\Windows\system32\credssp.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000016384 _____ (Microsoft Corporation) C:\Windows\system32\ntvdm64.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000013312 _____ (Microsoft Corporation) C:\Windows\system32\wow64cpu.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000006656 _____ (Microsoft Corporation) C:\Windows\system32\apisetschema.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000006144 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-security-base-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000005120 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-file-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000004608 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-threadpool-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000004608 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-processthreads-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-sysinfo-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-synch-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-localregistry-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-localization-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-rtlsupport-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-processenvironment-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-namedpipe-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-misc-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-memory-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-libraryloader-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-heap-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-xstate-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-util-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-string-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-profile-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-io-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-interlocked-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-handle-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-fibers-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-errorhandling-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-delayload-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-debug-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-datetime-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:29 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-console-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 001114112 _____ (Microsoft Corporation) C:\Windows\SysWOW64\kernel32.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000275456 _____ (Microsoft Corporation) C:\Windows\SysWOW64\KernelBase.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000261120 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msv1_0.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000254464 _____ (Microsoft Corporation) C:\Windows\SysWOW64\schannel.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000223232 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ncrypt.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000172032 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wdigest.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000141312 _____ (Microsoft Corporation) C:\Windows\SysWOW64\rpchttp.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000096768 _____ (Microsoft Corporation) C:\Windows\SysWOW64\sspicli.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000082944 _____ (Microsoft Corporation) C:\Windows\SysWOW64\bcrypt.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000065536 _____ (Microsoft Corporation) C:\Windows\SysWOW64\TSpkg.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000043008 _____ (Microsoft Corporation) C:\Windows\SysWOW64\srclient.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000022016 _____ (Microsoft Corporation) C:\Windows\SysWOW64\secur32.dll
2017-08-09 07:48 - 2017-07-07 18:11 - 000005120 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wow32.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000690688 _____ (Microsoft Corporation) C:\Windows\SysWOW64\adtschema.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000644096 _____ (Microsoft Corporation) C:\Windows\SysWOW64\advapi32.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000554496 _____ (Microsoft Corporation) C:\Windows\SysWOW64\kerberos.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000146432 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msaudite.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000060416 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msobjs.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000050688 _____ (Microsoft Corporation) C:\Windows\SysWOW64\appidapi.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000017408 _____ (Microsoft Corporation) C:\Windows\SysWOW64\credssp.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000006656 _____ (Microsoft Corporation) C:\Windows\SysWOW64\apisetschema.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000005120 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-file-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000004608 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-processthreads-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000004096 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-sysinfo-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000004096 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-synch-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000004096 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-misc-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000004096 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-localregistry-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000004096 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-localization-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003584 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-processenvironment-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003584 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-namedpipe-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003584 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-memory-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003584 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-libraryloader-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003584 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-interlocked-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003584 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-heap-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-string-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-rtlsupport-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-profile-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-io-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-handle-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-fibers-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-errorhandling-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-delayload-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-debug-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-datetime-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:10 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-console-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 18:02 - 000148480 _____ (Microsoft Corporation) C:\Windows\system32\appidpolicyconverter.exe
2017-08-09 07:48 - 2017-07-07 18:01 - 000064000 _____ (Microsoft Corporation) C:\Windows\system32\auditpol.exe
2017-08-09 07:48 - 2017-07-07 18:01 - 000062464 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\appid.sys
2017-08-09 07:48 - 2017-07-07 18:01 - 000017920 _____ (Microsoft Corporation) C:\Windows\system32\appidcertstorecheck.exe
2017-08-09 07:48 - 2017-07-07 17:58 - 000338432 _____ (Microsoft Corporation) C:\Windows\system32\conhost.exe
2017-08-09 07:48 - 2017-07-07 17:57 - 000296960 _____ (Microsoft Corporation) C:\Windows\system32\rstrui.exe
2017-08-09 07:48 - 2017-07-07 17:54 - 000291328 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxsmb10.sys
2017-08-09 07:48 - 2017-07-07 17:54 - 000159744 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxsmb.sys
2017-08-09 07:48 - 2017-07-07 17:54 - 000129536 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxsmb20.sys
2017-08-09 07:48 - 2017-07-07 17:53 - 000112640 _____ (Microsoft Corporation) C:\Windows\system32\smss.exe
2017-08-09 07:48 - 2017-07-07 17:53 - 000030720 _____ (Microsoft Corporation) C:\Windows\system32\lsass.exe
2017-08-09 07:48 - 2017-07-07 17:51 - 000050176 _____ (Microsoft Corporation) C:\Windows\SysWOW64\auditpol.exe
2017-08-09 07:48 - 2017-07-07 17:48 - 000025600 _____ (Microsoft Corporation) C:\Windows\SysWOW64\setup16.exe
2017-08-09 07:48 - 2017-07-07 17:48 - 000014336 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ntvdm64.dll
2017-08-09 07:48 - 2017-07-07 17:48 - 000007680 _____ (Microsoft Corporation) C:\Windows\SysWOW64\instnm.exe
2017-08-09 07:48 - 2017-07-07 17:48 - 000002048 _____ (Microsoft Corporation) C:\Windows\SysWOW64\user.exe
2017-08-09 07:48 - 2017-07-07 17:47 - 000036352 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cryptbase.dll
2017-08-09 07:48 - 2017-07-07 17:47 - 000006144 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-security-base-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 17:47 - 000004608 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-threadpool-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 17:47 - 000003584 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-xstate-l1-1-0.dll
2017-08-09 07:48 - 2017-07-07 17:47 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-util-l1-1-0.dll
2017-08-09 07:39 - 2017-08-09 07:39 - 000000000 ____D C:\Users\Me\AppData\Local\{4C062A90-177F-44D5-8FDF-C68139E42C86}
2017-08-08 22:03 - 2017-08-08 22:03 - 000000000 ____D C:\Users\Me\AppData\Local\{A6A23E6E-31A4-407E-99B8-AC3978E47406}
2017-08-08 19:33 - 2017-08-08 19:34 - 000000000 ____D C:\MGADiagToolOutput
2017-08-08 19:33 - 2017-08-08 19:33 - 000000000 ____D C:\ProgramData\Office Genuine Advantage
2017-08-08 19:32 - 2017-08-08 19:32 - 002031992 _____ (Microsoft Corporation) C:\Users\Me\Desktop\MGADiag.exe
2017-08-08 14:56 - 2017-08-08 14:56 - 000000000 ____D C:\Users\Me\AppData\Local\{F5A31D31-A8F8-4130-82D7-F71463F254C1}
2017-08-08 12:11 - 2017-08-08 12:11 - 000000000 ____D C:\Users\Me\AppData\Local\{460AC32A-7C0F-4519-9DC8-BC7017192261}
2017-08-08 12:05 - 2017-08-08 12:05 - 000000000 ____D C:\Users\Me\AppData\Local\{6686DC8E-7E48-4884-8965-DBCFF667EFF2}
2017-08-08 11:32 - 2017-08-08 11:32 - 000000000 ____D C:\Users\Me\AppData\Local\{C149CBA7-08B3-4088-830B-5A5384F46F39}
2017-08-08 10:57 - 2017-08-08 10:57 - 000000000 ____D C:\Users\Me\AppData\Local\{09B79CEF-EC1D-49DC-AFDA-DCA763E6FD38}
2017-08-08 10:05 - 2017-08-08 10:05 - 000057985 _____ C:\Users\Me\Desktop\imageedit_3_Yossi.pdf
2017-08-08 09:34 - 2017-08-08 09:34 - 000000000 ____D C:\Users\Me\AppData\Local\{934FEF31-EBAD-4FCD-98B5-3AB8B1BD5A6E}
2017-08-08 08:30 - 2017-08-10 22:01 - 000253856 _____ (Malwarebytes) C:\Windows\system32\Drivers\MBAMSwissArmy.sys
2017-08-08 08:30 - 2017-08-10 22:01 - 000101784 _____ (Malwarebytes) C:\Windows\system32\Drivers\farflt.sys
2017-08-08 08:30 - 2017-08-10 22:01 - 000084256 _____ (Malwarebytes) C:\Windows\system32\Drivers\mwac.sys
2017-08-08 08:30 - 2017-08-10 22:01 - 000045472 _____ (Malwarebytes) C:\Windows\system32\Drivers\mbam.sys
2017-08-08 08:30 - 2017-08-08 08:30 - 000188352 _____ (Malwarebytes) C:\Windows\system32\Drivers\MBAMChameleon.sys
2017-08-08 08:29 - 2017-08-08 10:10 - 000001911 _____ C:\Users\Public\Desktop\Malwarebytes.lnk
2017-08-08 08:29 - 2017-08-08 08:29 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes
2017-08-08 08:29 - 2017-08-08 08:29 - 000000000 ____D C:\ProgramData\Malwarebytes
2017-08-08 08:29 - 2017-08-08 08:29 - 000000000 ____D C:\Program Files\Malwarebytes
2017-08-08 08:29 - 2017-06-27 12:06 - 000077376 _____ C:\Windows\system32\Drivers\mbae64.sys
2017-08-08 07:34 - 2017-08-08 07:34 - 000000000 ____D C:\Users\Me\AppData\Local\{892DC713-11FD-4598-9B33-97C214C95629}
2017-08-07 21:57 - 2017-08-07 21:57 - 000000000 ____D C:\Users\Me\AppData\Local\{3402C467-DA41-4DA9-9F79-B22C8278FFE1}
2017-08-07 19:33 - 2017-08-07 19:33 - 000000000 ____D C:\Users\Me\AppData\Local\{EB0E6458-6E5F-4C6B-A676-766A120FFA80}
2017-08-07 19:05 - 2017-08-10 22:08 - 000000000 ____D C:\FRST
2017-08-07 18:02 - 2017-08-09 23:12 - 000000000 ____D C:\Users\Me\Desktop\Repair
2017-08-07 17:52 - 2017-08-07 17:52 - 000000000 ____D C:\Users\Me\AppData\Local\{8E53314F-C9D3-4571-A693-D59D9660AD4D}
2017-08-07 16:08 - 2017-08-08 20:05 - 000000000 ____D C:\Users\Me\Desktop\August 2017
2017-08-07 16:06 - 2017-08-07 16:06 - 000000000 ____H C:\Windows\system32\Drivers\Msft_User_WpdMtpDr_01_09_00.Wdf
2017-08-07 13:54 - 2017-08-07 13:54 - 000000000 ____D C:\Users\Me\AppData\Local\{029119A8-A770-4641-88CC-111ADE7A2EFC}
2017-08-07 09:02 - 2017-08-07 09:02 - 000000000 ____D C:\Users\Me\AppData\Local\{5ED359C8-D5C2-4DFF-A908-E04D8ED9A76B}
2017-08-07 08:25 - 2017-08-07 08:25 - 000000000 ____D C:\Users\Me\AppData\Local\{DA86E741-5EC1-4583-A0EE-1FFD499139AB}
2017-08-06 20:25 - 2017-08-06 20:25 - 000000000 ____D C:\Users\Me\AppData\Local\{DD947DDF-A5C8-4FAC-8223-36A4406F10AC}
2017-08-06 18:48 - 2017-08-06 18:48 - 000000000 ____D C:\Users\Me\Documents\ProcAlyzer Dumps
2017-08-06 18:27 - 2017-08-06 18:27 - 000000000 ____D C:\Users\Me\AppData\Local\{29D7ECDB-1A41-4B74-9A1E-7B3519C86DB3}
2017-08-06 17:27 - 2017-08-06 17:27 - 000000000 ____D C:\Users\Me\AppData\Local\{04855CD3-987A-469D-8800-A168C0727F9C}
2017-08-06 16:45 - 2017-08-06 16:45 - 000000000 ____D C:\Users\Me\AppData\Local\{1EACED71-E7AC-4381-8E5C-D7A13B2EBA0E}
2017-08-06 16:39 - 2017-08-06 16:39 - 000000000 ____D C:\Users\Me\AppData\Local\{14DE0BCF-0A55-40D5-BC25-48FF704CE579}
2017-08-06 15:28 - 2017-08-06 15:28 - 000000000 ____D C:\Users\Me\AppData\Local\ElevatedDiagnostics
2017-08-06 15:00 - 2017-08-06 15:00 - 000000000 ____D C:\Users\Me\AppData\Local\{E2EC4A38-7119-42C8-9F84-05594859BB07}
2017-08-06 14:22 - 2017-08-06 14:22 - 000000000 ____D C:\Users\Me\AppData\Local\{19D2D708-C20F-4C74-B30B-11867ACC0E78}
2017-08-06 13:54 - 2017-08-06 13:54 - 000000000 ____D C:\Users\Me\AppData\Local\{796A265F-3352-43C2-A433-BB1F6BE0251C}
2017-08-06 13:11 - 2017-08-10 17:33 - 000000000 ____D C:\Users\Me\Desktop\Moshe
2017-08-06 12:08 - 2017-08-06 12:08 - 000000000 ____D C:\Users\Me\AppData\Local\{BE07BFCD-F33A-4F35-8881-F1BB66116206}
2017-08-06 11:17 - 2017-08-08 08:48 - 000000000 ____D C:\Program Files (x86)\COMODO
2017-08-06 11:17 - 2017-08-06 11:17 - 000000000 ____D C:\ProgramData\COMODO
2017-08-06 10:20 - 2017-08-06 10:20 - 000000000 ____D C:\Users\Me\AppData\Local\{9F57EF30-0817-4D79-AA9E-E2A480FAD9D5}
2017-08-06 10:09 - 2017-08-06 12:41 - 000000000 ____D C:\Windows\ComodoVirtualDrives
2017-08-06 08:23 - 2017-08-06 08:23 - 000000000 ____D C:\Users\Me\AppData\Local\{96531027-51C9-4821-8A8F-0164FC3F5DE6}
2017-08-05 23:24 - 2017-08-05 23:24 - 000000000 ____D C:\Users\Me\AppData\Local\{AB9E373B-76A3-48E5-A2F7-18502D58E863}
2017-08-05 21:17 - 2017-08-05 21:18 - 000000000 ____D C:\Users\Me\AppData\Local\{347ABC91-F403-48D7-A323-5D36DEE28715}
2017-08-05 21:17 - 2017-08-05 21:17 - 000000000 ____D C:\Users\Me\AppData\Local\{30EB5069-2892-45E5-BB6B-A306726477BB}
2017-08-04 16:27 - 2017-08-04 16:27 - 000000000 ____D C:\Users\Me\AppData\Local\{55712B2D-6889-461C-9426-73AE8A4C6A18}
2017-08-04 12:05 - 2017-08-04 12:05 - 000388906 _____ C:\Users\Me\Desktop\image2017-08-04-113552.pdf
2017-08-04 11:30 - 2017-08-04 11:30 - 000000000 ____D C:\Users\Me\AppData\Local\{C295AFDE-244B-40FA-BA5A-F471C1839C5A}
2017-08-04 09:10 - 2017-08-10 21:03 - 000000000 ____D C:\Program Files (x86)\Spybot - Search & Destroy 2
2017-08-04 09:10 - 2017-08-10 19:29 - 000000000 ____D C:\ProgramData\Spybot - Search & Destroy
2017-08-04 08:30 - 2017-08-04 08:30 - 000000000 ____D C:\Users\Me\AppData\Local\{59434F80-5F08-42E5-BFB9-A287D4AABF9C}
2017-08-03 21:51 - 2017-08-03 21:51 - 000000000 ____D C:\Users\Me\AppData\Local\{0DB1A0ED-E4E5-4878-BF25-C0F44C15F673}
2017-08-03 19:16 - 2017-08-03 19:16 - 000000000 ____D C:\Users\Me\AppData\Local\{90FC95E7-5CFE-488F-A312-04DB6A99A6AF}
2017-08-03 19:12 - 2017-08-03 19:12 - 000000000 ____D C:\Users\Me\AppData\Local\Deployment
2017-08-03 19:12 - 2017-08-03 19:12 - 000000000 ____D C:\Users\Me\AppData\Local\Apps\2.0
2017-08-03 19:05 - 2017-08-03 19:05 - 000000000 ____D C:\Users\Me\AppData\Local\{1153D0D3-A802-4867-9FBF-9942C199372D}
2017-08-03 17:40 - 2017-08-03 17:40 - 000000000 ____D C:\Users\Me\AppData\Local\{FD0C385E-67D4-4D7C-9BB8-DFF4B32A13CA}
2017-08-03 16:30 - 2017-08-03 16:30 - 000000000 ____D C:\Users\Me\AppData\Local\{53D7D38C-E109-476C-B06B-DE61EA8DB6A3}
2017-08-03 16:04 - 2017-08-03 16:04 - 000000000 ____D C:\Users\Moshe\.VirtualBox
2017-08-03 16:04 - 2017-08-03 16:04 - 000000000 ____D C:\Users\Moshe\.android
2017-08-03 16:04 - 2017-08-03 16:04 - 000000000 ____D C:\New Folder
2017-08-03 16:00 - 2017-08-03 16:00 - 000001107 _____ C:\Users\Public\Desktop\E-Z Contact Book.lnk
2017-08-03 16:00 - 2017-08-03 16:00 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\E-Z Contact Book
2017-08-03 15:55 - 2017-08-03 15:55 - 000000000 ____D C:\Users\Me\AppData\Local\{46E21E10-16B7-4777-9060-36D1B697FDCB}
2017-08-03 14:38 - 2017-08-03 14:38 - 000000000 ____D C:\Users\Me\AppData\Roaming\WinRAR
2017-08-03 14:36 - 2017-08-03 14:36 - 000000000 ____D C:\Users\Me\AppData\Local\{A1937F5C-1B23-47C5-B0D3-B30BE0EA43B5}
2017-08-03 12:22 - 2017-08-03 12:22 - 000000000 ____D C:\Users\Me\AppData\Local\{A1BC0E1C-AEB5-4C05-9ED0-EA2C3F33A7DC}
2017-08-03 12:05 - 2017-08-03 12:05 - 000001458 _____ C:\Users\Me\Desktop\Windows Live Mail.lnk
2017-08-03 12:05 - 2017-08-03 12:05 - 000000000 ____D C:\Users\Me\AppData\Local\{680824F6-B6D3-4605-8A35-85CDF3250750}
2017-08-03 12:02 - 2017-08-03 12:05 - 000000000 ____D C:\RESTORE-FROM-COMODO
2017-08-03 10:37 - 2017-08-03 10:37 - 000000000 ____H C:\Windows\system32\Drivers\Msft_Kernel_vdbus_01009.Wdf
2017-08-03 10:37 - 2014-10-07 14:14 - 003550400 _____ (COMODO Security Solutions) C:\Windows\system32\Drivers\COSService.exe
2017-08-03 10:37 - 2014-10-07 14:14 - 002575552 _____ (COMODO Security Solutions) C:\Windows\system32\Drivers\SynchronizationService.exe
2017-08-03 10:36 - 2017-08-10 19:31 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\COMODO
2017-08-03 10:36 - 2017-08-10 19:31 - 000000000 ____D C:\Program Files\COMODO
2017-08-03 10:36 - 2017-08-07 23:26 - 000000799 _____ C:\Users\Public\Desktop\COMODO BackUp.lnk
2017-08-03 10:36 - 2017-08-03 10:36 - 001700352 _____ (Microsoft Corporation) C:\Windows\SysWOW64\gdiplus.dll
2017-08-03 10:36 - 2017-08-03 10:36 - 001060864 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mfc71.dll
2017-08-03 10:36 - 2017-08-03 10:36 - 000348160 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msvcr71.dll
2017-08-03 09:33 - 2017-08-03 09:33 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
2017-08-03 09:32 - 2017-08-03 09:32 - 000000000 ____D C:\Program Files\Microsoft Silverlight
2017-08-03 09:32 - 2017-08-03 09:32 - 000000000 ____D C:\Program Files (x86)\Microsoft Silverlight
2017-08-03 09:29 - 2017-08-03 09:29 - 000000000 ____D C:\Users\Me\AppData\Local\{742454CF-D572-4C82-95F9-78BF5BA012DE}
2017-08-03 08:54 - 2017-08-03 08:54 - 000001125 _____ C:\Users\Me\Desktop\E-Z Contact Book (2).lnk
2017-08-03 08:53 - 2017-08-03 08:56 - 000000000 ____D C:\Users\Me\Desktop\BackUPs
2017-08-03 08:45 - 2017-08-07 13:09 - 000000000 ____D C:\Program Files (x86)\McAfee
2017-08-03 08:45 - 2017-08-03 08:45 - 000000000 ____D C:\ProgramData\McAfee
2017-08-03 08:36 - 2017-08-03 08:36 - 000000000 ____D C:\Users\Me\AppData\Roaming\Macromedia
2017-08-03 08:32 - 2017-08-09 09:42 - 000803328 _____ (Adobe Systems Incorporated) C:\Windows\SysWOW64\FlashPlayerApp.exe
2017-08-03 08:32 - 2017-08-09 09:42 - 000144896 _____ (Adobe Systems Incorporated) C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
2017-08-03 08:32 - 2017-08-09 09:42 - 000004324 _____ C:\Windows\System32\Tasks\Adobe Flash Player Updater
2017-08-03 08:32 - 2017-08-09 09:42 - 000000000 ____D C:\Windows\system32\Macromed
2017-08-03 08:31 - 2017-08-09 09:42 - 000000000 ____D C:\Windows\SysWOW64\Macromed
2017-08-03 08:14 - 2017-08-03 08:14 - 000000000 ____D C:\Users\Me\AppData\Local\{29F8AEEA-29FE-48A4-97E2-D0A1A79D86C7}
2017-08-03 08:12 - 2017-08-03 08:12 - 000000000 ____D C:\Users\Me\AppData\Roaming\AnyDesk
2017-08-02 23:44 - 2017-08-02 23:44 - 000000000 ____D C:\Users\Me\AppData\Local\{79AB745E-EEB1-4696-AC7E-872B7E95A08D}
2017-08-02 23:26 - 2017-08-02 23:26 - 000000000 ____D C:\Users\Me\AppData\Local\{0801CB3A-E4B3-4F17-B625-8969FB9D63F9}
2017-08-02 22:48 - 2017-08-02 22:48 - 000000966 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\I.R.I.S. OCR Registration.lnk
2017-08-02 22:48 - 2017-08-02 22:48 - 000000000 ____D C:\Program Files (x86)\Hewlett-Packard
2017-08-02 22:47 - 2017-08-09 23:19 - 000000000 ____D C:\Users\Me\AppData\Roaming\HpUpdate
2017-08-02 22:47 - 2017-08-02 22:48 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HP
2017-08-02 22:47 - 2017-08-02 22:47 - 000003598 _____ C:\Windows\System32\Tasks\HPCustParticipation HP Officejet Pro 6830
2017-08-02 22:47 - 2017-08-02 22:47 - 000002200 _____ C:\Users\Public\Desktop\HP Officejet Pro 6830.lnk
2017-08-02 22:47 - 2017-08-02 22:47 - 000001152 _____ C:\Users\Public\Desktop\Shop for Supplies - HP Officejet Pro 6830.lnk
2017-08-02 22:47 - 2014-07-18 19:48 - 000763968 ____N (Hewlett-Packard Development Company, LP) C:\Windows\system32\HPDiscoPM7212.dll
2017-08-02 22:46 - 2017-08-02 22:48 - 000000000 ____D C:\Program Files (x86)\HP
2017-08-02 22:46 - 2017-08-02 22:46 - 000000057 _____ C:\ProgramData\Ament.ini
2017-08-02 22:46 - 2017-08-02 22:46 - 000000000 ____D C:\ProgramData\HP
2017-08-02 22:46 - 2017-08-02 22:46 - 000000000 ____D C:\Program Files\HP
2017-08-02 22:01 - 2017-08-02 22:01 - 000000000 ____D C:\Users\Me\AppData\Local\{08D51DE5-250E-4C47-8B6F-E40C0C080773}
2017-08-02 21:39 - 2017-08-02 21:39 - 000000000 ____D C:\Users\Me\AppData\Local\{75F6B19C-17C4-4696-B449-ABEB8F0ECDAB}
2017-08-02 21:35 - 2017-08-06 16:25 - 000001278 _____ C:\Users\Me\Desktop\Desktop - Shortcut.lnk
2017-08-02 21:05 - 2017-08-02 21:05 - 000187267 _____ C:\Users\Me\Documents\bookmark2.htm
2017-08-02 20:47 - 2017-08-10 18:14 - 000000000 ____D C:\Users\Me\AppData\Roaming\E-Z Contact Book
2017-08-02 20:47 - 2017-08-03 16:00 - 000000000 ____D C:\Program Files (x86)\E-Z Contact Book
2017-08-02 20:47 - 2017-08-03 09:11 - 000000000 ____D C:\Users\Me\Desktop\E-Z Contact Book
2017-08-02 20:47 - 2017-08-02 20:47 - 000000000 ____D C:\ProgramData\Isolated Storage
2017-08-02 20:47 - 2017-08-02 20:47 - 000000000 ____D C:\ProgramData\E-Z Contact Book
2017-08-02 20:19 - 2017-08-04 11:31 - 000000000 ____D C:\Users\Me\AppData\Local\Windows Live Writer
2017-08-02 20:19 - 2017-08-03 17:53 - 000000000 ____D C:\Users\Me\AppData\Roaming\Windows Live Writer
2017-08-02 20:19 - 2017-08-02 20:19 - 000000000 ____D C:\Users\Me\AppData\Local\{06494044-CAD0-4C35-91A1-105C8B971905}
2017-08-02 20:10 - 2017-08-02 20:10 - 000000000 ____D C:\Windows\en
2017-08-02 20:09 - 2017-08-08 12:42 - 000001374 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Live Photo Gallery.lnk
2017-08-02 20:09 - 2017-08-08 12:42 - 000001305 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Live Movie Maker.lnk
2017-08-02 20:08 - 2017-08-08 12:41 - 000001458 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Live Mail.lnk
2017-08-02 20:08 - 2017-08-02 20:08 - 000000020 _____ C:\Windows\¨ô—
2017-08-02 20:07 - 2017-08-08 12:42 - 000002486 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Live Messenger.lnk
2017-08-02 20:05 - 2017-08-08 12:43 - 000000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Live
2017-08-02 20:05 - 2017-08-02 20:10 - 000000000 ____D C:\Program Files (x86)\Windows Live
2017-08-02 20:05 - 2011-05-13 15:37 - 000048488 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\fssfltr.sys
2017-08-02 20:04 - 2017-08-02 20:05 - 000000000 ____D C:\Program Files\Windows Live
2017-08-02 20:02 - 2009-09-04 17:44 - 000515416 _____ (Microsoft Corporation) C:\Windows\SysWOW64\XAudio2_5.dll
2017-08-02 20:02 - 2009-09-04 17:44 - 000069464 _____ (Microsoft Corporation) C:\Windows\SysWOW64\XAPOFX1_3.dll
2017-08-02 20:02 - 2009-09-04 17:29 - 000523088 _____ (Microsoft Corporation) C:\Windows\system32\d3dx10_42.dll
2017-08-02 20:02 - 2009-09-04 17:29 - 000453456 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d3dx10_42.dll
2017-08-02 20:00 - 2006-11-29 13:06 - 004398360 _____ (Microsoft Corporation) C:\Windows\system32\d3dx9_32.dll
2017-08-02 20:00 - 2006-11-29 13:06 - 003426072 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d3dx9_32.dll
2017-08-02 19:57 - 2017-08-05 21:17 - 000000000 ____D C:\Users\Me\AppData\Local\Windows Live
2017-08-02 19:36 - 2017-08-02 19:36 - 000003246 _____ C:\Windows\System32\Tasks\{A370589A-2F81-4005-A949-A5EFD4F307A0}
2017-08-02 19:25 - 2017-08-02 19:25 - 000000000 ____D C:\Users\Me\AppData\Local\{FBB5F706-C0E2-4B39-AC63-547EAC699F77}
2017-08-02 19:13 - 2017-08-03 08:32 - 000000000 ____D C:\Users\Me\AppData\Local\Adobe
2017-08-02 19:13 - 2017-08-02 19:13 - 000000000 ____D C:\Users\Me\AppData\LocalLow\Adobe
2017-08-02 18:41 - 2017-08-02 22:48 - 000000000 ____D C:\Users\Me\AppData\Local\HP
2017-08-02 18:35 - 2017-08-10 22:04 - 000000000 ____D C:\Users\Me\AppData\Roaming\Skype
2017-08-02 18:34 - 2017-08-10 07:58 - 000000000 ____D C:\ProgramData\Skype
2017-08-02 18:34 - 2017-08-02 18:34 - 000002697 _____ C:\Users\Public\Desktop\Skype.lnk
2017-08-02 18:34 - 2017-08-02 18:34 - 000000000 ___RD C:\Program Files (x86)\Skype
2017-08-02 18:34 - 2017-08-02 18:34 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Skype
2017-08-02 18:16 - 2017-08-02 18:16 - 000000000 ____D C:\Users\Me\Documents\Custom Office Templates
2017-08-02 16:58 - 2017-08-02 16:58 - 000000000 ____D C:\Users\Me\VirtualBox VMs
2017-08-02 16:58 - 2017-08-02 16:58 - 000000000 ____D C:\Users\Me\Tracing
2017-08-02 16:58 - 2017-08-02 16:58 - 000000000 ____D C:\Users\Me\Favorites newest
2017-08-02 16:57 - 2017-08-02 16:57 - 000000000 ____D C:\Users\Me\My Albums
2017-08-02 16:57 - 2015-08-12 08:13 - 000000000 ___RD C:\Users\Me\Google Drive
2017-08-02 16:49 - 2017-08-02 16:49 - 000000000 ____D C:\Users\Me\Documents\אנגלית דא ג21-ג22 אשין יהודית [3003003] אלפון_files
2017-08-02 16:38 - 2017-08-02 16:38 - 000000000 ___RD C:\Users\Me\Documents\Scanned Documents
2017-08-02 16:38 - 2017-08-02 16:38 - 000000000 ____D C:\Users\Me\Documents\SQL Server Management Studio
2017-08-02 16:38 - 2017-08-02 16:38 - 000000000 ____D C:\Users\Me\Documents\RCT3Demo 1.1
Moses
2017-08-02 16:38 - 2017-08-02 16:38 - 000000000 ____D C:\Users\Me\Documents\pictures of michal guttman
2017-08-02 16:38 - 2017-08-02 16:38 - 000000000 ____D C:\Users\Me\Documents\Palm OS Desktop
2017-08-02 16:38 - 2011-09-05 16:35 - 000000000 ____D C:\Users\Me\Documents\ScheduleOCR Input
2017-08-02 16:37 - 2017-08-03 19:16 - 000000000 ____D C:\Users\Me\Documents\Outlook Files
2017-08-02 16:37 - 2017-08-02 16:37 - 000000000 ____D C:\Users\Me\Documents\Original from Vineland
2017-08-02 16:37 - 2017-08-02 16:37 - 000000000 ____D C:\Users\Me\Documents\OneNote Notebooks
2017-08-02 16:36 - 2017-08-07 23:26 - 000000909 _____ C:\Users\Me\Desktop\Audacity.lnk
2017-08-02 16:36 - 2017-08-02 16:37 - 000000000 ____D C:\Users\Me\Documents\New Folder
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\My Albums
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\michal-parshas korach
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\Integration Services Script Task
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\Integration Services Script Component
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\iFree Skype Recorder
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\HpReg_Backup
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\HP
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\Fax
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\facebook
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\DriverGenius
2017-08-02 16:36 - 2017-08-02 16:36 - 000000000 ____D C:\Users\Me\Documents\CyberLink
2017-08-02 16:36 - 2017-02-09 22:24 - 000010384 _____ C:\Users\Me\Documents\אנגלית דא ג21-ג22 אשין יהודית [3003003] אלפון.xls
2017-08-02 16:36 - 2017-02-09 22:22 - 000011005 _____ C:\Users\Me\Documents\אנגלית דא ג21-ג22 אשין יהודית [3003003] אלפון (1).xls
2017-08-02 16:36 - 2016-08-08 16:45 - 000203571 _____ C:\Users\Me\Documents\bookmark.htm
2017-08-02 16:36 - 2015-06-22 19:59 - 001409572 _____ C:\Users\Me\Documents\policy2-4.pdf
2017-08-02 16:36 - 2015-06-22 18:31 - 001511556 _____ C:\Users\Me\Documents\xtra2.pdf
2017-08-02 16:36 - 2015-06-22 18:28 - 001475630 _____ C:\Users\Me\Documents\xtra1.pdf
2017-08-02 16:36 - 2014-06-23 19:38 - 001540238 _____ C:\Users\Me\Documents\jjh.xps
2017-08-02 16:36 - 2014-02-01 20:23 - 000088036 _____ C:\Users\Me\Documents\metzav.xps
2017-08-02 16:36 - 2013-10-01 09:21 - 000007319 _____ C:\Users\Me\Documents\,.eml
2017-08-02 16:36 - 2013-08-02 11:23 - 000076819 _____ C:\Users\Me\Documents\Untitled (2).wma
2017-08-02 16:36 - 2013-08-02 11:22 - 000099269 _____ C:\Users\Me\Documents\Untitled.wma
2017-08-02 16:36 - 2013-04-07 17:10 - 004202204 _____ C:\Users\Me\Documents\Doar.pdf
2017-08-02 16:36 - 2012-09-07 16:04 - 000004522 _____ C:\Users\Me\Documents\ורוד.wlmp
2017-08-02 16:36 - 2012-08-17 14:54 - 000001630 _____ C:\Users\Me\Documents\My Movie.wlmp
2017-08-02 16:36 - 2012-07-26 20:18 - 000022063 _____ C:\Users\Me\Documents\מצגת מצחיקה.wlmp
2017-08-02 16:36 - 2012-07-26 15:56 - 000006038 _____ C:\Users\Me\Documents\חברות טובות.wlmp
2017-08-02 16:36 - 2012-07-25 19:53 - 000023854 _____ C:\Users\Me\Documents\Movie 1.wlmp
2017-08-02 16:36 - 2012-07-25 19:22 - 000014921 _____ C:\Users\Me\Documents\movie 2.wlmp
2017-08-02 16:36 - 2012-07-02 09:24 - 000435096 _____ C:\Users\Me\Documents\kollel America4.pdf
2017-08-02 16:36 - 2012-06-30 23:05 - 001199245 _____ C:\Users\Me\Documents\kolel America3.pdf
2017-08-02 16:36 - 2012-06-30 23:03 - 000433864 _____ C:\Users\Me\Documents\kolel America2.pdf
2017-08-02 16:36 - 2012-06-30 23:01 - 001213885 _____ C:\Users\Me\Documents\kolel America1.pdf
2017-08-02 16:36 - 2011-01-10 21:47 - 000000388 _____ C:\Users\Me\Documents\spider.sav
2017-08-02 16:36 - 2009-06-05 13:12 - 000760320 _____ (Microsoft Corporation) C:\Users\Me\Documents\msrdp.ocx
2017-08-02 14:28 - 2017-08-05 22:44 - 000000000 ____D C:\Users\Me\.android
2017-08-02 14:28 - 2017-08-02 21:35 - 000000000 ____D C:\Users\Me\.VirtualBox
2017-08-02 14:28 - 2017-08-02 14:28 - 000000000 ____D C:\Moshe Ashin  31-7-2017
2017-08-02 12:02 - 2017-08-02 12:02 - 000000000 ___RD C:\Users\Me\Desktop\Microsoft Office 2013
2017-08-02 11:08 - 2017-08-02 11:08 - 000400464 _____ (AVAST Software) C:\Windows\system32\aswBoot.exe
2017-08-02 11:08 - 2017-08-02 11:07 - 000343288 _____ (AVAST Software s.r.o.) C:\Windows\system32\Drivers\aswbloga.sys
2017-08-02 11:08 - 2017-08-02 11:07 - 000320008 _____ (AVAST Software s.r.o.) C:\Windows\system32\Drivers\aswbidsdrivera.sys
2017-08-02 11:08 - 2017-08-02 11:07 - 000198976 _____ (AVAST Software s.r.o.) C:\Windows\system32\Drivers\aswbidsha.sys
2017-08-02 11:08 - 2017-08-02 11:07 - 000057728 _____ (AVAST Software s.r.o.) C:\Windows\system32\Drivers\aswbuniva.sys
2017-08-02 11:06 - 2017-08-02 11:06 - 000000000 ____D C:\Users\Me\Desktop\OZ-TAL
2017-08-02 11:05 - 2017-08-07 23:26 - 000001966 _____ C:\Users\Public\Desktop\Avast Free Antivirus.lnk
2017-08-02 11:05 - 2017-08-02 11:06 - 000000000 ____D C:\2install
2017-08-02 11:05 - 2017-08-02 11:05 - 000000000 ____D C:\Users\Me\AppData\Roaming\AVAST Software
2017-08-02 11:05 - 2017-08-02 11:05 - 000000000 ____D C:\Users\Me\AppData\Local\CEF
2017-08-02 11:05 - 2017-08-02 11:05 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AVAST Software
2017-08-02 11:04 - 2017-08-10 21:03 - 000000000 ____D C:\Program Files\Google
2017-08-02 11:04 - 2017-08-09 19:58 - 001015880 _____ (AVAST Software) C:\Windows\system32\Drivers\aswsnx.sys
2017-08-02 11:04 - 2017-08-09 19:58 - 000146704 _____ (AVAST Software) C:\Windows\system32\Drivers\aswmonflt.sys
2017-08-02 11:04 - 2017-08-02 11:08 - 000585608 _____ (AVAST Software) C:\Windows\system32\Drivers\aswSP.sys
2017-08-02 11:04 - 2017-08-02 11:08 - 000361336 _____ (AVAST Software) C:\Windows\system32\Drivers\aswVmm.sys
2017-08-02 11:04 - 2017-08-02 11:08 - 000198768 _____ (AVAST Software) C:\Windows\system32\Drivers\aswStm.sys
2017-08-02 11:04 - 2017-08-02 11:08 - 000146664 _____ (AVAST Software) C:\Windows\system32\Drivers\aswmonflt.sys.150166133723003
2017-08-02 11:04 - 2017-08-02 11:08 - 000110352 _____ (AVAST Software) C:\Windows\system32\Drivers\aswRdr2.sys
2017-08-02 11:04 - 2017-08-02 11:08 - 000084392 _____ (AVAST Software) C:\Windows\system32\Drivers\aswRvrt.sys
2017-08-02 11:04 - 2017-08-02 11:08 - 000046984 _____ (AVAST Software) C:\Windows\system32\Drivers\aswHwid.sys
2017-08-02 11:04 - 2017-08-02 11:08 - 000003914 _____ C:\Windows\System32\Tasks\Avast Emergency Update
2017-08-02 11:04 - 2017-08-02 11:04 - 000000000 ____D C:\Program Files\AVAST Software
2017-08-02 10:13 - 2017-08-02 20:49 - 000798048 _____ C:\Windows\SysWOW64\PerfStringBackup.INI
2017-08-02 10:10 - 2017-08-02 11:08 - 000000000 ____D C:\ProgramData\AVAST Software
2017-08-02 10:09 - 2017-06-04 15:30 - 002577304 _____ C:\Users\Me\Desktop\ShowMyPC.exe
2017-08-02 10:03 - 2017-08-05 21:27 - 000004476 _____ C:\Windows\System32\Tasks\Adobe Acrobat Update Task
2017-08-02 10:03 - 2017-08-02 19:14 - 000002441 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acrobat Reader DC.lnk
2017-08-02 10:03 - 2017-08-02 10:03 - 000002047 _____ C:\Users\Public\Desktop\Acrobat Reader DC.lnk
2017-08-02 10:02 - 2017-08-02 10:02 - 000000000 ____D C:\Program Files (x86)\Adobe
2017-08-02 10:01 - 2017-06-04 15:30 - 002577304 _____ C:\Users\Public\Desktops
2017-08-02 10:01 - 2015-12-30 10:48 - 001420960 _____ C:\Users\Public\Desktop\AnyDesk.exe
2017-08-02 09:59 - 2017-08-02 12:11 - 000000000 ____D C:\ProgramData\Adobe
2017-08-02 09:59 - 2017-08-02 09:59 - 000000000 ____D C:\Users\Me\AppData\LocalLow\Oracle
2017-08-02 09:58 - 2017-08-09 23:23 - 000000000 ____D C:\ProgramData\Oracle
2017-08-02 09:58 - 2017-08-09 18:31 - 000109504 _____ C:\Users\Me\AppData\Local\GDIPFONTCACHEV1.DAT
2017-08-02 09:58 - 2017-08-02 09:58 - 000000000 ____D C:\Users\Me\AppData\LocalLow\Sun
2017-08-02 09:57 - 2017-08-02 09:57 - 000001307 _____ C:\Users\Public\Desktop\Ashampoo Burning Studio FREE.lnk
2017-08-02 09:57 - 2017-08-02 09:57 - 000000000 ____D C:\Users\Me\AppData\Roaming\Ashampoo
2017-08-02 09:57 - 2017-08-02 09:57 - 000000000 ____D C:\Users\Me\AppData\Local\ashampoo
2017-08-02 09:57 - 2017-08-02 09:57 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ashampoo
2017-08-02 09:57 - 2017-08-02 09:57 - 000000000 ____D C:\ProgramData\Ashampoo
2017-08-02 09:57 - 2017-08-02 09:57 - 000000000 ____D C:\Program Files (x86)\Ashampoo
2017-08-02 09:52 - 2017-08-10 21:03 - 000000000 ____D C:\Program Files (x86)\Google
2017-08-02 09:52 - 2017-08-10 19:57 - 000000000 ____D C:\Users\Me\AppData\Local\Google
2017-08-02 09:52 - 2017-08-08 07:49 - 000002189 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
2017-08-02 09:52 - 2017-08-08 07:49 - 000002177 _____ C:\Users\Public\Desktop\Google Chrome.lnk
2017-08-02 09:52 - 2017-08-02 09:57 - 000003330 _____ C:\Windows\System32\Tasks\GoogleUpdateTaskMachineUA
2017-08-02 09:52 - 2017-08-02 09:57 - 000003202 _____ C:\Windows\System32\Tasks\GoogleUpdateTaskMachineCore
2017-08-02 09:51 - 2017-08-10 21:20 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Lavasoft
2017-08-02 09:50 - 2017-08-02 09:50 - 000003152 _____ C:\Windows\System32\Tasks\klcp_update
2017-08-02 09:50 - 2017-08-02 09:50 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack
2017-08-02 09:50 - 2017-08-02 09:50 - 000000000 ____D C:\Program Files (x86)\K-Lite Codec Pack
2017-08-02 09:49 - 2017-08-02 09:49 - 000000000 ____D C:\Users\Me\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinRAR
2017-08-02 09:49 - 2017-08-02 09:49 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR
2017-08-02 09:49 - 2017-08-02 09:49 - 000000000 ____D C:\Program Files\WinRAR
2017-08-02 09:39 - 2017-08-02 09:39 - 000000000 ____D C:\Windows\System32\Tasks\OfficeSoftwareProtectionPlatform
2017-08-02 09:39 - 2017-08-02 09:39 - 000000000 ____D C:\Users\Me\AppData\Local\Microsoft Help
2017-08-02 03:09 - 2017-08-02 19:13 - 000000000 ____D C:\Users\Me\AppData\Roaming\Adobe
2017-08-01 13:47 - 2013-11-26 11:16 - 003419136 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d2d1.dll
2017-08-01 13:47 - 2013-11-23 01:48 - 003928064 _____ (Microsoft Corporation) C:\Windows\system32\d2d1.dll
2017-08-01 04:01 - 2017-05-12 19:25 - 001251328 _____ (Microsoft Corporation) C:\Windows\SysWOW64\DWrite.dll
2017-08-01 04:01 - 2017-05-12 18:58 - 001648128 _____ (Microsoft Corporation) C:\Windows\system32\DWrite.dll
2017-08-01 04:01 - 2017-05-12 18:58 - 001180160 _____ (Microsoft Corporation) C:\Windows\system32\FntCache.dll
2017-08-01 04:01 - 2016-10-11 16:33 - 000187392 _____ (Microsoft Corporation) C:\Windows\SysWOW64\UIAnimation.dll
2017-08-01 04:01 - 2016-10-11 16:06 - 000221184 _____ (Microsoft Corporation) C:\Windows\system32\UIAnimation.dll
2017-08-01 04:00 - 2016-04-14 16:49 - 000603648 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d3d10level9.dll
2017-08-01 04:00 - 2016-04-14 16:21 - 000647680 _____ (Microsoft Corporation) C:\Windows\system32\d3d10level9.dll
2017-08-01 04:00 - 2015-07-30 21:06 - 002565120 _____ (Microsoft Corporation) C:\Windows\system32\d3d10warp.dll
2017-08-01 04:00 - 2015-07-30 20:57 - 001987584 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d3d10warp.dll
2017-08-01 03:58 - 2016-04-09 07:20 - 001230848 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WindowsCodecs.dll
2017-08-01 03:58 - 2016-04-09 06:52 - 001424896 _____ (Microsoft Corporation) C:\Windows\system32\WindowsCodecs.dll
2017-08-01 03:58 - 2015-12-09 00:54 - 002285056 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msmpeg2vdec.dll
2017-08-01 03:58 - 2015-12-08 22:07 - 002777088 _____ (Microsoft Corporation) C:\Windows\system32\msmpeg2vdec.dll
2017-08-01 03:58 - 2015-02-04 06:16 - 000465920 _____ (Microsoft Corporation) C:\Windows\system32\WMPhoto.dll
2017-08-01 03:58 - 2015-02-04 05:54 - 000417792 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMPhoto.dll
2017-08-01 02:28 - 2017-07-31 15:37 - 000000000 ____D C:\Windows\Panther
2017-08-01 01:30 - 2017-08-01 01:30 - 000001345 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Media Center.lnk
2017-08-01 01:30 - 2017-08-01 01:30 - 000001326 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows DVD Maker.lnk
2017-07-31 18:03 - 2015-07-30 16:13 - 000124624 _____ (Microsoft Corporation) C:\Windows\system32\PresentationCFFRasterizerNative_v0300.dll
2017-07-31 18:03 - 2015-07-30 16:13 - 000103120 _____ (Microsoft Corporation) C:\Windows\SysWOW64\PresentationCFFRasterizerNative_v0300.dll
2017-07-31 18:01 - 2013-10-14 18:00 - 000028368 _____ (Microsoft Corporation) C:\Windows\system32\IEUDINIT.EXE
2017-07-31 17:54 - 2017-07-31 17:54 - 000942592 _____ (Microsoft Corporation) C:\Windows\system32\jsIntl.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000645120 _____ (Microsoft Corporation) C:\Windows\SysWOW64\jsIntl.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000616104 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ieapfltr.dat
2017-07-31 17:54 - 2017-07-31 17:54 - 000616104 _____ (Microsoft Corporation) C:\Windows\system32\ieapfltr.dat
2017-07-31 17:54 - 2017-07-31 17:54 - 000247808 _____ (Microsoft Corporation) C:\Windows\system32\msls31.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000235520 _____ (Microsoft Corporation) C:\Windows\system32\url.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000235008 _____ (Microsoft Corporation) C:\Windows\system32\elshyph.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000233472 _____ (Microsoft Corporation) C:\Windows\SysWOW64\url.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000194048 _____ (Microsoft Corporation) C:\Windows\SysWOW64\elshyph.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000182272 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msls31.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000167424 _____ (Microsoft Corporation) C:\Windows\system32\iexpress.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000151552 _____ (Microsoft Corporation) C:\Windows\SysWOW64\iexpress.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000143872 _____ (Microsoft Corporation) C:\Windows\system32\wextract.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000139264 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wextract.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000135680 _____ (Microsoft Corporation) C:\Windows\system32\iepeers.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000131072 _____ (Microsoft Corporation) C:\Windows\system32\IEAdvpack.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000116736 _____ (Microsoft Corporation) C:\Windows\SysWOW64\iepeers.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000111616 _____ (Microsoft Corporation) C:\Windows\SysWOW64\IEAdvpack.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000105984 _____ (Microsoft Corporation) C:\Windows\system32\iesysprep.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000090112 _____ (Microsoft Corporation) C:\Windows\system32\SetIEInstalledDate.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000086016 _____ (Microsoft Corporation) C:\Windows\SysWOW64\iesysprep.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000086016 _____ (Microsoft Corporation) C:\Windows\system32\RegisterIEPKEYs.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000081408 _____ (Microsoft Corporation) C:\Windows\system32\icardie.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000074240 _____ (Microsoft Corporation) C:\Windows\SysWOW64\SetIEInstalledDate.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000071680 _____ (Microsoft Corporation) C:\Windows\SysWOW64\RegisterIEPKEYs.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000069120 _____ (Microsoft Corporation) C:\Windows\SysWOW64\icardie.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000062464 _____ (Microsoft Corporation) C:\Windows\system32\pngfilt.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000056832 _____ (Microsoft Corporation) C:\Windows\SysWOW64\pngfilt.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000052224 _____ (Microsoft Corporation) C:\Windows\system32\msfeedsbs.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000048640 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mshtmler.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000048640 _____ (Microsoft Corporation) C:\Windows\system32\mshtmler.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000048128 _____ (Microsoft Corporation) C:\Windows\system32\imgutil.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000043008 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msfeedsbs.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000036352 _____ (Microsoft Corporation) C:\Windows\SysWOW64\imgutil.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000030208 _____ (Microsoft Corporation) C:\Windows\system32\licmgr10.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000024576 _____ (Microsoft Corporation) C:\Windows\SysWOW64\licmgr10.dll
2017-07-31 17:54 - 2017-07-31 17:54 - 000013824 _____ (Microsoft Corporation) C:\Windows\system32\mshta.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000013312 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mshta.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000013312 _____ (Microsoft Corporation) C:\Windows\system32\msfeedssync.exe
2017-07-31 17:54 - 2017-07-31 17:54 - 000012800 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msfeedssync.exe
2017-07-31 17:50 - 2017-07-31 17:50 - 000859648 _____ (Microsoft Corporation) C:\Windows\system32\tdh.dll
2017-07-31 17:50 - 2017-07-31 17:50 - 000619520 _____ (Microsoft Corporation) C:\Windows\SysWOW64\tdh.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 001682432 _____ (Microsoft Corporation) C:\Windows\system32\XpsPrint.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 001238528 _____ (Microsoft Corporation) C:\Windows\system32\d3d10.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 001158144 _____ (Microsoft Corporation) C:\Windows\SysWOW64\XpsPrint.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 001080832 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d3d10.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000522752 _____ (Microsoft Corporation) C:\Windows\system32\XpsGdiConverter.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000364544 _____ (Microsoft Corporation) C:\Windows\SysWOW64\XpsGdiConverter.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000363008 _____ (Microsoft Corporation) C:\Windows\system32\dxgi.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000333312 _____ (Microsoft Corporation) C:\Windows\system32\d3d10_1core.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000296960 _____ (Microsoft Corporation) C:\Windows\system32\d3d10core.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000293376 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dxgi.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000249856 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d3d10_1core.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000245248 _____ (Microsoft Corporation) C:\Windows\system32\WindowsCodecsExt.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000220160 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d3d10core.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000207872 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WindowsCodecsExt.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000194560 _____ (Microsoft Corporation) C:\Windows\system32\d3d10_1.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000161792 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d3d10_1.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000010752 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-downlevel-advapi32-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000010752 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000009728 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000009728 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000005632 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-downlevel-shlwapi-l2-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000005632 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-downlevel-ole32-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000005632 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000005632 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-downlevel-ole32-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000004096 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-downlevel-user32-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000004096 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000003584 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-downlevel-advapi32-l2-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000003584 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-downlevel-version-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000003072 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-downlevel-shell32-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-downlevel-version-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000003072 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-downlevel-shell32-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000002560 ____H (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-downlevel-normaliz-l1-1-0.dll
2017-07-31 17:40 - 2017-07-31 17:40 - 000002560 ____H (Microsoft Corporation) C:\Windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll
2017-07-31 17:37 - 2017-07-31 17:37 - 001887232 _____ (Microsoft Corporation) C:\Windows\system32\d3d11.dll
2017-07-31 17:37 - 2017-07-31 17:37 - 001505280 _____ (Microsoft Corporation) C:\Windows\SysWOW64\d3d11.dll
2017-07-31 17:00 - 2017-08-09 10:17 - 000000000 ____D C:\Windows\system32\MRT
2017-07-31 16:59 - 2017-08-09 10:14 - 140394280 ____C (Microsoft Corporation) C:\Windows\system32\MRT.exe
2017-07-31 16:33 - 2012-03-01 09:46 - 000023408 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\fs_rec.sys
2017-07-31 16:33 - 2012-03-01 09:28 - 000005120 _____ (Microsoft Corporation) C:\Windows\system32\wmi.dll
2017-07-31 16:33 - 2012-03-01 08:29 - 000005120 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wmi.dll
2017-07-31 16:28 - 2014-07-01 01:24 - 000008856 _____ (Microsoft Corporation) C:\Windows\system32\icardres.dll
2017-07-31 16:28 - 2014-07-01 01:14 - 000008856 _____ (Microsoft Corporation) C:\Windows\SysWOW64\icardres.dll
2017-07-31 16:28 - 2014-06-06 09:16 - 000035480 _____ (Microsoft Corporation) C:\Windows\SysWOW64\TsWpfWrp.exe
2017-07-31 16:28 - 2014-06-06 09:12 - 000035480 _____ (Microsoft Corporation) C:\Windows\system32\TsWpfWrp.exe
2017-07-31 16:28 - 2014-03-10 00:48 - 001389208 _____ (Microsoft Corporation) C:\Windows\system32\icardagt.exe
2017-07-31 16:28 - 2014-03-10 00:48 - 000171160 _____ (Microsoft Corporation) C:\Windows\system32\infocardapi.dll
2017-07-31 16:28 - 2014-03-10 00:47 - 000619672 _____ (Microsoft Corporation) C:\Windows\SysWOW64\icardagt.exe
2017-07-31 16:28 - 2014-03-10 00:47 - 000099480 _____ (Microsoft Corporation) C:\Windows\SysWOW64\infocardapi.dll
2017-07-31 16:26 - 2017-06-15 23:23 - 000753664 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\http.sys
2017-07-31 16:26 - 2017-06-13 01:49 - 001363456 _____ (Microsoft Corporation) C:\Windows\system32\wdc.dll
2017-07-31 16:26 - 2017-06-13 01:49 - 000594432 _____ (Microsoft Corporation) C:\Windows\system32\wvc.dll
2017-07-31 16:26 - 2017-06-13 01:49 - 000475136 _____ (Microsoft Corporation) C:\Windows\system32\sysmon.ocx
2017-07-31 16:26 - 2017-06-13 01:49 - 000058880 _____ (Microsoft Corporation) C:\Windows\system32\pdhui.dll
2017-07-31 16:26 - 2017-06-13 01:29 - 001227264 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wdc.dll
2017-07-31 16:26 - 2017-06-13 01:29 - 000444928 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wvc.dll
2017-07-31 16:26 - 2017-06-13 01:29 - 000390144 _____ (Microsoft Corporation) C:\Windows\SysWOW64\sysmon.ocx
2017-07-31 16:26 - 2017-06-13 01:28 - 000047104 _____ (Microsoft Corporation) C:\Windows\SysWOW64\pdhui.dll
2017-07-31 16:26 - 2017-06-13 01:14 - 000379392 _____ (Microsoft Corporation) C:\Windows\system32\msinfo32.exe
2017-07-31 16:26 - 2017-06-13 01:14 - 000172544 _____ (Microsoft Corporation) C:\Windows\system32\perfmon.exe
2017-07-31 16:26 - 2017-06-13 01:14 - 000103936 _____ (Microsoft Corporation) C:\Windows\system32\resmon.exe
2017-07-31 16:26 - 2017-06-13 01:06 - 000303616 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msinfo32.exe
2017-07-31 16:26 - 2017-06-13 01:06 - 000157184 _____ (Microsoft Corporation) C:\Windows\SysWOW64\perfmon.exe
2017-07-31 16:26 - 2017-06-13 01:06 - 000103424 _____ (Microsoft Corporation) C:\Windows\SysWOW64\resmon.exe
2017-07-31 16:26 - 2017-06-10 18:59 - 000313856 _____ (Microsoft Corporation) C:\Windows\system32\Wldap32.dll
2017-07-31 16:26 - 2017-06-10 18:39 - 000271360 _____ (Microsoft Corporation) C:\Windows\SysWOW64\Wldap32.dll
2017-07-31 16:26 - 2017-06-09 18:33 - 001680616 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\ntfs.sys
2017-07-31 16:26 - 2017-06-06 18:30 - 001867264 _____ (Microsoft Corporation) C:\Windows\system32\ExplorerFrame.dll
2017-07-31 16:26 - 2017-06-06 18:12 - 001499648 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ExplorerFrame.dll
2017-07-31 16:26 - 2017-06-02 11:10 - 000733696 _____ (Microsoft Corporation) C:\Windows\HelpPane.exe
2017-07-31 16:26 - 2017-05-30 07:56 - 001895656 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\tcpip.sys
2017-07-31 16:26 - 2017-05-30 07:56 - 000377576 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\netio.sys
2017-07-31 16:26 - 2017-05-30 07:56 - 000287976 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\FWPKCLNT.SYS
2017-07-31 16:26 - 2017-05-21 07:24 - 000002048 _____ (Microsoft Corporation) C:\Windows\system32\tzres.dll
2017-07-31 16:26 - 2017-05-21 07:06 - 000002048 _____ (Microsoft Corporation) C:\Windows\SysWOW64\tzres.dll
2017-07-31 16:26 - 2017-05-16 18:35 - 000986856 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\dxgkrnl.sys
2017-07-31 16:26 - 2017-05-16 18:35 - 000265448 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\dxgmms1.sys
2017-07-31 16:26 - 2017-05-16 18:30 - 000144384 _____ (Microsoft Corporation) C:\Windows\system32\cdd.dll
2017-07-31 16:26 - 2017-05-12 21:26 - 000382696 _____ (Adobe Systems Incorporated) C:\Windows\system32\atmfd.dll
2017-07-31 16:26 - 2017-05-12 21:22 - 000806912 _____ (Microsoft Corporation) C:\Windows\system32\usp10.dll
2017-07-31 16:26 - 2017-05-12 21:22 - 000405504 _____ (Microsoft Corporation) C:\Windows\system32\gdi32.dll
2017-07-31 16:26 - 2017-05-12 21:22 - 000100864 _____ (Microsoft Corporation) C:\Windows\system32\fontsub.dll
2017-07-31 16:26 - 2017-05-12 21:22 - 000046080 _____ (Adobe Systems) C:\Windows\system32\atmlib.dll
2017-07-31 16:26 - 2017-05-12 21:22 - 000041472 _____ (Microsoft Corporation) C:\Windows\system32\lpk.dll
2017-07-31 16:26 - 2017-05-12 21:22 - 000014336 _____ (Microsoft Corporation) C:\Windows\system32\dciman32.dll
2017-07-31 16:26 - 2017-05-12 21:07 - 000308456 _____ (Adobe Systems Incorporated) C:\Windows\SysWOW64\atmfd.dll
2017-07-31 16:26 - 2017-05-12 21:03 - 000629760 _____ (Microsoft Corporation) C:\Windows\SysWOW64\usp10.dll
2017-07-31 16:26 - 2017-05-12 21:03 - 000313344 _____ (Microsoft Corporation) C:\Windows\SysWOW64\gdi32.dll
2017-07-31 16:26 - 2017-05-12 21:03 - 000070656 _____ (Microsoft Corporation) C:\Windows\SysWOW64\fontsub.dll
2017-07-31 16:26 - 2017-05-12 21:03 - 000025600 _____ (Microsoft Corporation) C:\Windows\SysWOW64\lpk.dll
2017-07-31 16:26 - 2017-05-12 21:03 - 000010240 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dciman32.dll
2017-07-31 16:26 - 2017-05-12 20:43 - 000034304 _____ (Adobe Systems) C:\Windows\SysWOW64\atmlib.dll
2017-07-31 16:26 - 2017-05-10 18:33 - 000091368 _____ (Microsoft Corporation) C:\Windows\system32\MigAutoPlay.exe
2017-07-31 16:26 - 2017-05-10 18:29 - 014183936 _____ (Microsoft Corporation) C:\Windows\system32\shell32.dll
2017-07-31 16:26 - 2017-05-10 18:29 - 003165184 _____ (Microsoft Corporation) C:\Windows\system32\wucltux.dll
2017-07-31 16:26 - 2017-05-10 18:29 - 000192512 _____ (Microsoft Corporation) C:\Windows\system32\wuwebv.dll
2017-07-31 16:26 - 2017-05-10 18:29 - 000098816 _____ (Microsoft Corporation) C:\Windows\system32\wudriver.dll
2017-07-31 16:26 - 2017-05-10 18:28 - 000091136 _____ (Microsoft Corporation) C:\Windows\system32\WinSetupUI.dll
2017-07-31 16:26 - 2017-05-10 18:16 - 000091368 _____ (Microsoft Corporation) C:\Windows\SysWOW64\MigAutoPlay.exe
2017-07-31 16:26 - 2017-05-10 18:14 - 002651136 _____ (Microsoft Corporation) C:\Windows\system32\wuaueng.dll
2017-07-31 16:26 - 2017-05-10 18:13 - 000709120 _____ (Microsoft Corporation) C:\Windows\system32\wuapi.dll
2017-07-31 16:26 - 2017-05-10 18:13 - 000140288 _____ (Microsoft Corporation) C:\Windows\system32\wuauclt.exe
2017-07-31 16:26 - 2017-05-10 18:13 - 000037888 _____ (Microsoft Corporation) C:\Windows\system32\wups2.dll
2017-07-31 16:26 - 2017-05-10 18:13 - 000037888 _____ (Microsoft Corporation) C:\Windows\system32\wuapp.exe
2017-07-31 16:26 - 2017-05-10 18:13 - 000036864 _____ (Microsoft Corporation) C:\Windows\system32\wups.dll
2017-07-31 16:26 - 2017-05-10 18:13 - 000012288 _____ (Microsoft Corporation) C:\Windows\system32\wu.upgrade.ps.dll
2017-07-31 16:26 - 2017-05-10 18:12 - 012880896 _____ (Microsoft Corporation) C:\Windows\SysWOW64\shell32.dll
2017-07-31 16:26 - 2017-05-10 18:12 - 000174080 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wuwebv.dll
2017-07-31 16:26 - 2017-05-10 18:00 - 000573440 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wuapi.dll
2017-07-31 16:26 - 2017-05-10 18:00 - 000093696 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wudriver.dll
2017-07-31 16:26 - 2017-05-10 18:00 - 000035328 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wuapp.exe
2017-07-31 16:26 - 2017-05-10 18:00 - 000030208 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wups.dll
2017-07-31 16:26 - 2017-05-09 18:30 - 000757248 _____ (Microsoft Corporation) C:\Windows\system32\win32spl.dll
2017-07-31 16:26 - 2017-05-09 18:29 - 000970240 _____ (Microsoft Corporation) C:\Windows\system32\localspl.dll
2017-07-31 16:26 - 2017-05-09 18:11 - 000497664 _____ (Microsoft Corporation) C:\Windows\SysWOW64\win32spl.dll
2017-07-31 16:26 - 2017-05-07 18:33 - 000094440 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mountmgr.sys
2017-07-31 16:26 - 2017-05-07 18:29 - 000011264 _____ (Microsoft Corporation) C:\Windows\system32\msmmsp.dll
2017-07-31 16:26 - 2017-04-28 01:50 - 003550208 _____ (Microsoft Corporation) C:\Windows\SysWOW64\D3DCompiler_47.dll
2017-07-31 16:26 - 2017-04-21 18:34 - 001133568 _____ (Microsoft Corporation) C:\Windows\system32\cdosys.dll
2017-07-31 16:26 - 2017-04-21 18:15 - 000805376 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cdosys.dll
2017-07-31 16:26 - 2017-04-17 18:37 - 002065408 _____ (Microsoft Corporation) C:\Windows\system32\ole32.dll
2017-07-31 16:26 - 2017-04-17 18:37 - 000876544 _____ (Microsoft Corporation) C:\Windows\system32\oleaut32.dll
2017-07-31 16:26 - 2017-04-17 18:37 - 000512000 _____ (Microsoft Corporation) C:\Windows\system32\rpcss.dll
2017-07-31 16:26 - 2017-04-17 18:37 - 000026112 _____ (Microsoft Corporation) C:\Windows\system32\oleres.dll
2017-07-31 16:26 - 2017-04-17 18:37 - 000008704 _____ (Microsoft Corporation) C:\Windows\system32\comcat.dll
2017-07-31 16:26 - 2017-04-17 18:12 - 001417728 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ole32.dll
2017-07-31 16:26 - 2017-04-17 18:12 - 000581632 _____ (Microsoft Corporation) C:\Windows\SysWOW64\oleaut32.dll
2017-07-31 16:26 - 2017-04-17 18:12 - 000026112 _____ (Microsoft Corporation) C:\Windows\SysWOW64\oleres.dll
2017-07-31 16:26 - 2017-04-17 17:54 - 000007168 _____ (Microsoft Corporation) C:\Windows\SysWOW64\comcat.dll
2017-07-31 16:26 - 2017-04-12 18:32 - 001483776 _____ (Microsoft Corporation) C:\Windows\system32\crypt32.dll
2017-07-31 16:26 - 2017-04-12 18:32 - 000229376 _____ (Microsoft Corporation) C:\Windows\system32\wintrust.dll
2017-07-31 16:26 - 2017-04-12 18:32 - 000190976 _____ (Microsoft Corporation) C:\Windows\system32\cryptsvc.dll
2017-07-31 16:26 - 2017-04-12 18:32 - 000141824 _____ (Microsoft Corporation) C:\Windows\system32\cryptnet.dll
2017-07-31 16:26 - 2017-04-12 18:26 - 000179200 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wintrust.dll
2017-07-31 16:26 - 2017-04-12 18:25 - 001176064 _____ (Microsoft Corporation) C:\Windows\SysWOW64\crypt32.dll
2017-07-31 16:26 - 2017-04-12 18:25 - 000145920 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cryptsvc.dll
2017-07-31 16:26 - 2017-04-12 18:25 - 000106496 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cryptnet.dll
2017-07-31 16:26 - 2017-04-12 16:05 - 004296704 _____ (Microsoft Corporation) C:\Windows\system32\D3DCompiler_47.dll
2017-07-31 16:26 - 2017-04-05 17:55 - 000460800 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\srv.sys
2017-07-31 16:26 - 2017-04-05 17:55 - 000405504 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\srv2.sys
2017-07-31 16:26 - 2017-04-05 17:55 - 000168960 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\srvnet.sys
2017-07-31 16:26 - 2017-04-04 17:53 - 000496128 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\afd.sys
2017-07-31 16:26 - 2017-03-30 18:03 - 000046080 _____ (Microsoft Corporation) C:\Windows\system32\rundll32.exe
2017-07-31 16:26 - 2017-03-30 17:58 - 000045056 _____ (Microsoft Corporation) C:\Windows\SysWOW64\rundll32.exe
2017-07-31 16:26 - 2017-03-10 19:32 - 001389056 _____ (Microsoft Corporation) C:\Windows\system32\pla.dll
2017-07-31 16:26 - 2017-03-10 19:32 - 000300544 _____ (Microsoft Corporation) C:\Windows\system32\pdh.dll
2017-07-31 16:26 - 2017-03-10 19:20 - 001508352 _____ (Microsoft Corporation) C:\Windows\SysWOW64\pla.dll
2017-07-31 16:26 - 2017-03-10 19:20 - 000237056 _____ (Microsoft Corporation) C:\Windows\SysWOW64\pdh.dll
2017-07-31 16:26 - 2017-03-10 18:57 - 000009216 _____ (Microsoft Corporation) C:\Windows\system32\plasrv.exe
2017-07-31 16:26 - 2017-03-10 18:55 - 000205312 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\fastfat.sys
2017-07-31 16:26 - 2017-03-10 18:55 - 000195584 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\exfat.sys
2017-07-31 16:26 - 2017-03-07 19:30 - 000085504 _____ (Microsoft Corporation) C:\Windows\system32\asycfilt.dll
2017-07-31 16:26 - 2017-03-07 19:17 - 000067584 _____ (Microsoft Corporation) C:\Windows\SysWOW64\asycfilt.dll
2017-07-31 16:26 - 2017-03-04 04:27 - 001574912 _____ (Microsoft Corporation) C:\Windows\system32\quartz.dll
2017-07-31 16:26 - 2017-03-04 04:27 - 000093696 _____ (Microsoft Corporation) C:\Windows\system32\mfmjpegdec.dll
2017-07-31 16:26 - 2017-03-04 04:14 - 001329664 _____ (Microsoft Corporation) C:\Windows\SysWOW64\quartz.dll
2017-07-31 16:26 - 2017-03-04 04:14 - 000077312 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mfmjpegdec.dll
2017-07-31 16:26 - 2017-02-09 19:32 - 000769536 _____ (Microsoft Corporation) C:\Windows\system32\samsrv.dll
2017-07-31 16:26 - 2017-02-09 19:32 - 000106496 _____ (Microsoft Corporation) C:\Windows\system32\samlib.dll
2017-07-31 16:26 - 2017-02-09 19:32 - 000040960 _____ (Microsoft Corporation) C:\Windows\system32\WcsPlugInService.dll
2017-07-31 16:26 - 2017-02-09 19:31 - 000625664 _____ (Microsoft Corporation) C:\Windows\system32\mscms.dll
2017-07-31 16:26 - 2017-02-09 19:31 - 000250880 _____ (Microsoft Corporation) C:\Windows\system32\icm32.dll
2017-07-31 16:26 - 2017-02-09 19:14 - 000481792 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mscms.dll
2017-07-31 16:26 - 2017-02-09 19:14 - 000215040 _____ (Microsoft Corporation) C:\Windows\SysWOW64\icm32.dll
2017-07-31 16:26 - 2017-02-09 19:14 - 000060416 _____ (Microsoft Corporation) C:\Windows\SysWOW64\samlib.dll
2017-07-31 16:26 - 2017-02-09 18:51 - 000032768 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WcsPlugInService.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000994760 _____ (Microsoft Corporation) C:\Windows\system32\ucrtbase.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000063840 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-private-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000020832 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-math-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000019808 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-multibyte-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000017760 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-string-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000017760 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-stdio-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000016224 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-runtime-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000015712 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-convert-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000014176 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-time-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000014176 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-localization-l1-2-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000013664 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-filesystem-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000012640 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-process-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000012640 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-heap-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000012640 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-conio-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-utility-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-locale-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-crt-environment-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-synch-l1-2-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000012128 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-processthreads-l1-1-1.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000011616 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-xstate-l2-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000011616 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-timezone-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000011616 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-file-l2-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:36 - 000011608 _____ (Microsoft Corporation) C:\Windows\system32\api-ms-win-core-file-l1-2-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000922432 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ucrtbase.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000066400 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-private-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000022368 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-math-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000019808 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-multibyte-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000017760 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-string-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000017760 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-stdio-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000016224 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-runtime-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000015712 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-convert-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000014176 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-time-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000014176 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-localization-l1-2-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000013664 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-filesystem-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000012640 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-process-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000012640 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-heap-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000012640 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-conio-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000012128 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-utility-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000012128 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-locale-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000012128 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-crt-environment-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000012128 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-synch-l1-2-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000012128 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-processthreads-l1-1-1.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000011616 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-xstate-l2-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000011616 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-timezone-l1-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000011616 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-file-l2-1-0.dll
2017-07-31 16:26 - 2017-01-18 18:35 - 000011616 _____ (Microsoft Corporation) C:\Windows\SysWOW64\api-ms-win-core-file-l1-2-0.dll
2017-07-31 16:26 - 2017-01-13 21:00 - 000976896 _____ (Microsoft Corporation) C:\Windows\system32\inetcomm.dll
2017-07-31 16:26 - 2017-01-13 21:00 - 000084480 _____ (Microsoft Corporation) C:\Windows\system32\INETRES.dll
2017-07-31 16:26 - 2017-01-13 20:45 - 000741888 _____ (Microsoft Corporation) C:\Windows\SysWOW64\inetcomm.dll
2017-07-31 16:26 - 2017-01-13 20:45 - 000084480 _____ (Microsoft Corporation) C:\Windows\SysWOW64\INETRES.dll
2017-07-31 16:26 - 2017-01-11 21:01 - 001887744 _____ (Microsoft Corporation) C:\Windows\system32\msxml3.dll
2017-07-31 16:26 - 2017-01-11 21:01 - 000002048 _____ (Microsoft Corporation) C:\Windows\system32\msxml3r.dll
2017-07-31 16:26 - 2017-01-11 20:43 - 001241088 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msxml3.dll
2017-07-31 16:26 - 2017-01-11 20:43 - 000002048 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msxml3r.dll
2017-07-31 16:26 - 2016-11-21 21:12 - 000109568 _____ (Microsoft Corporation) C:\Windows\system32\hlink.dll
2017-07-31 16:26 - 2016-11-20 19:19 - 000084992 _____ (Microsoft Corporation) C:\Windows\SysWOW64\hlink.dll
2017-07-31 16:26 - 2016-11-20 17:07 - 000467392 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\cng.sys
2017-07-31 16:26 - 2016-11-10 19:32 - 001009152 _____ (Microsoft Corporation) C:\Windows\system32\user32.dll
2017-07-31 16:26 - 2016-11-10 19:19 - 000833024 _____ (Microsoft Corporation) C:\Windows\SysWOW64\user32.dll
2017-07-31 16:26 - 2016-11-09 19:41 - 000114408 _____ (Microsoft Corporation) C:\Windows\system32\consent.exe
2017-07-31 16:26 - 2016-11-09 19:33 - 003244032 _____ (Microsoft Corporation) C:\Windows\system32\msi.dll
2017-07-31 16:26 - 2016-11-09 19:33 - 001941504 _____ (Microsoft Corporation) C:\Windows\system32\authui.dll
2017-07-31 16:26 - 2016-11-09 19:33 - 000504320 _____ (Microsoft Corporation) C:\Windows\system32\msihnd.dll
2017-07-31 16:26 - 2016-11-09 19:33 - 000070144 _____ (Microsoft Corporation) C:\Windows\system32\appinfo.dll
2017-07-31 16:26 - 2016-11-09 19:33 - 000025088 _____ (Microsoft Corporation) C:\Windows\system32\msimsg.dll
2017-07-31 16:26 - 2016-11-09 19:17 - 002365440 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msi.dll
2017-07-31 16:26 - 2016-11-09 19:17 - 001806848 _____ (Microsoft Corporation) C:\Windows\SysWOW64\authui.dll
2017-07-31 16:26 - 2016-11-09 19:17 - 000337408 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msihnd.dll
2017-07-31 16:26 - 2016-11-09 19:17 - 000025088 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msimsg.dll
2017-07-31 16:26 - 2016-11-09 19:02 - 000128512 _____ (Microsoft Corporation) C:\Windows\system32\msiexec.exe
2017-07-31 16:26 - 2016-11-09 18:55 - 000073216 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msiexec.exe
2017-07-31 16:26 - 2016-10-11 18:32 - 000069120 _____ (Microsoft Corporation) C:\Windows\system32\nlsbres.dll
2017-07-31 16:26 - 2016-10-11 18:31 - 001148416 _____ (Microsoft Corporation) C:\Windows\system32\IMJP10.IME
2017-07-31 16:26 - 2016-10-11 18:31 - 001068544 _____ (Microsoft Corporation) C:\Windows\system32\msctf.dll
2017-07-31 16:26 - 2016-10-11 18:31 - 000878080 _____ (Microsoft Corporation) C:\Windows\system32\IMJP10K.DLL
2017-07-31 16:26 - 2016-10-11 18:31 - 000457216 _____ (Microsoft Corporation) C:\Windows\system32\imkr80.ime
2017-07-31 16:26 - 2016-10-11 18:31 - 000246784 _____ (Microsoft Corporation) C:\Windows\system32\input.dll
2017-07-31 16:26 - 2016-10-11 18:31 - 000176128 _____ (Microsoft Corporation) C:\Windows\system32\tintlgnt.ime
2017-07-31 16:26 - 2016-10-11 18:31 - 000175104 _____ (Microsoft Corporation) C:\Windows\system32\quick.ime
2017-07-31 16:26 - 2016-10-11 18:31 - 000175104 _____ (Microsoft Corporation) C:\Windows\system32\qintlgnt.ime
2017-07-31 16:26 - 2016-10-11 18:31 - 000175104 _____ (Microsoft Corporation) C:\Windows\system32\phon.ime
2017-07-31 16:26 - 2016-10-11 18:31 - 000175104 _____ (Microsoft Corporation) C:\Windows\system32\cintlgnt.ime
2017-07-31 16:26 - 2016-10-11 18:31 - 000175104 _____ (Microsoft Corporation) C:\Windows\system32\chajei.ime
2017-07-31 16:26 - 2016-10-11 18:31 - 000132608 _____ (Microsoft Corporation) C:\Windows\system32\pintlgnt.ime
2017-07-31 16:26 - 2016-10-11 18:18 - 001027584 _____ (Microsoft Corporation) C:\Windows\SysWOW64\IMJP10.IME
2017-07-31 16:26 - 2016-10-11 18:18 - 000829952 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msctf.dll
2017-07-31 16:26 - 2016-10-11 18:18 - 000701440 _____ (Microsoft Corporation) C:\Windows\SysWOW64\IMJP10K.DLL
2017-07-31 16:26 - 2016-10-11 18:18 - 000430080 _____ (Microsoft Corporation) C:\Windows\SysWOW64\imkr80.ime
2017-07-31 16:26 - 2016-10-11 18:18 - 000202240 _____ (Microsoft Corporation) C:\Windows\SysWOW64\input.dll
2017-07-31 16:26 - 2016-10-11 18:18 - 000126976 _____ (Microsoft Corporation) C:\Windows\SysWOW64\tintlgnt.ime
2017-07-31 16:26 - 2016-10-11 18:18 - 000125952 _____ (Microsoft Corporation) C:\Windows\SysWOW64\quick.ime
2017-07-31 16:26 - 2016-10-11 18:18 - 000125952 _____ (Microsoft Corporation) C:\Windows\SysWOW64\qintlgnt.ime
2017-07-31 16:26 - 2016-10-11 18:18 - 000125952 _____ (Microsoft Corporation) C:\Windows\SysWOW64\phon.ime
2017-07-31 16:26 - 2016-10-11 18:18 - 000125952 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cintlgnt.ime
2017-07-31 16:26 - 2016-10-11 18:18 - 000125952 _____ (Microsoft Corporation) C:\Windows\SysWOW64\chajei.ime
2017-07-31 16:26 - 2016-10-11 18:18 - 000090112 _____ (Microsoft Corporation) C:\Windows\SysWOW64\pintlgnt.ime
2017-07-31 16:26 - 2016-10-11 18:18 - 000069120 _____ (Microsoft Corporation) C:\Windows\SysWOW64\nlsbres.dll
2017-07-31 16:26 - 2016-10-11 17:55 - 000346112 _____ (Microsoft Corporation) C:\Windows\system32\bcdedit.exe
2017-07-31 16:26 - 2016-10-11 16:18 - 000419648 _____ C:\Windows\SysWOW64\locale.nls
2017-07-31 16:26 - 2016-10-11 16:17 - 000419648 _____ C:\Windows\system32\locale.nls
2017-07-31 16:26 - 2016-10-08 16:06 - 000633296 _____ (Microsoft Corporation) C:\Windows\system32\winload.exe
2017-07-31 16:26 - 2016-10-07 18:32 - 003649536 _____ (Microsoft Corporation) C:\Windows\system32\MSVidCtl.dll
2017-07-31 16:26 - 2016-10-07 18:12 - 002291712 _____ (Microsoft Corporation) C:\Windows\SysWOW64\MSVidCtl.dll
2017-07-31 16:26 - 2016-10-05 17:54 - 000090112 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\bowser.sys
2017-07-31 16:26 - 2016-09-15 17:56 - 000041984 _____ (Microsoft Corporation) C:\Windows\system32\UtcResources.dll
2017-07-31 16:26 - 2016-09-13 00:08 - 000107520 _____ (Microsoft Corporation) C:\Windows\system32\adsmsext.dll
2017-07-31 16:26 - 2016-09-12 23:49 - 000076800 _____ (Microsoft Corporation) C:\Windows\SysWOW64\adsmsext.dll
2017-07-31 16:26 - 2016-09-08 23:34 - 000263680 _____ (Microsoft Corporation) C:\Windows\system32\WebClnt.dll
2017-07-31 16:26 - 2016-09-08 23:34 - 000208896 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WebClnt.dll
2017-07-31 16:26 - 2016-09-08 23:34 - 000108544 _____ (Microsoft Corporation) C:\Windows\system32\davclnt.dll
2017-07-31 16:26 - 2016-09-08 23:34 - 000087040 _____ (Microsoft Corporation) C:\Windows\SysWOW64\davclnt.dll
2017-07-31 16:26 - 2016-09-08 17:55 - 000142336 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\mrxdav.sys
2017-07-31 16:26 - 2016-09-08 17:55 - 000106496 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\dfsc.sys
2017-07-31 16:26 - 2016-08-22 19:19 - 001386496 _____ (Microsoft Corporation) C:\Windows\system32\diagtrack.dll
2017-07-31 16:26 - 2016-08-12 20:02 - 014632960 _____ (Microsoft Corporation) C:\Windows\system32\wmp.dll
2017-07-31 16:26 - 2016-08-12 20:02 - 012574720 _____ (Microsoft Corporation) C:\Windows\system32\wmploc.DLL
2017-07-31 16:26 - 2016-08-12 20:02 - 000009728 _____ (Microsoft Corporation) C:\Windows\system32\spwmp.dll
2017-07-31 16:26 - 2016-08-12 20:02 - 000005120 _____ (Microsoft Corporation) C:\Windows\system32\msdxm.ocx
2017-07-31 16:26 - 2016-08-12 20:02 - 000005120 _____ (Microsoft Corporation) C:\Windows\system32\dxmasf.dll
2017-07-31 16:26 - 2016-08-12 19:47 - 012574208 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wmploc.DLL
2017-07-31 16:26 - 2016-08-12 19:47 - 011410432 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wmp.dll
2017-07-31 16:26 - 2016-08-12 19:31 - 000008192 _____ (Microsoft Corporation) C:\Windows\SysWOW64\spwmp.dll
2017-07-31 16:26 - 2016-08-12 19:31 - 000004096 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msdxm.ocx
2017-07-31 16:26 - 2016-08-12 19:31 - 000004096 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dxmasf.dll
2017-07-31 16:26 - 2016-08-12 19:26 - 000461312 _____ (Microsoft Corporation) C:\Windows\system32\scavengeui.dll
2017-07-31 16:26 - 2016-08-06 18:31 - 002023424 _____ (Microsoft Corporation) C:\Windows\system32\WsmSvc.dll
2017-07-31 16:26 - 2016-08-06 18:31 - 000347136 _____ (Microsoft Corporation) C:\Windows\system32\WSManMigrationPlugin.dll
2017-07-31 16:26 - 2016-08-06 18:31 - 000310784 _____ (Microsoft Corporation) C:\Windows\system32\WsmWmiPl.dll
2017-07-31 16:26 - 2016-08-06 18:31 - 000182272 _____ (Microsoft Corporation) C:\Windows\system32\WsmAuto.dll
2017-07-31 16:26 - 2016-08-06 18:31 - 000054272 _____ (Microsoft Corporation) C:\Windows\system32\WsmRes.dll
2017-07-31 16:26 - 2016-08-06 18:31 - 000012800 _____ (Microsoft Corporation) C:\Windows\system32\wsmplpxy.dll
2017-07-31 16:26 - 2016-08-06 18:15 - 001178112 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WsmSvc.dll
2017-07-31 16:26 - 2016-08-06 18:15 - 000249344 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WSManMigrationPlugin.dll
2017-07-31 16:26 - 2016-08-06 18:15 - 000214016 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WsmWmiPl.dll
2017-07-31 16:26 - 2016-08-06 18:15 - 000146944 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WsmAuto.dll
2017-07-31 16:26 - 2016-08-06 18:15 - 000054272 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WsmRes.dll
2017-07-31 16:26 - 2016-08-06 18:01 - 000266752 _____ (Microsoft Corporation) C:\Windows\system32\WSManHTTPConfig.exe
2017-07-31 16:26 - 2016-08-06 18:01 - 000013824 _____ (Microsoft Corporation) C:\Windows\system32\wsmprovhost.exe
2017-07-31 16:26 - 2016-08-06 17:53 - 000199168 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WSManHTTPConfig.exe
2017-07-31 16:26 - 2016-08-06 17:53 - 000012288 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wsmprovhost.exe
2017-07-31 16:26 - 2016-08-06 17:53 - 000010240 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wsmplpxy.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 004121600 _____ (Microsoft Corporation) C:\Windows\system32\mf.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 001202176 _____ (Microsoft Corporation) C:\Windows\system32\drmv2clt.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 001068544 _____ (Microsoft Corporation) C:\Windows\system32\cryptui.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000842240 _____ (Microsoft Corporation) C:\Windows\system32\blackbox.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000782848 _____ (Microsoft Corporation) C:\Windows\system32\wmdrmsdk.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000680448 _____ (Microsoft Corporation) C:\Windows\system32\audiosrv.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000641024 _____ (Microsoft Corporation) C:\Windows\system32\msscp.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000632320 _____ (Microsoft Corporation) C:\Windows\system32\evr.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000499712 _____ (Microsoft Corporation) C:\Windows\system32\AUDIOKSE.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000497664 _____ (Microsoft Corporation) C:\Windows\system32\drmmgrtn.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000440320 _____ (Microsoft Corporation) C:\Windows\system32\AudioEng.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000433152 _____ (Microsoft Corporation) C:\Windows\system32\mfplat.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000371712 _____ (Microsoft Corporation) C:\Windows\system32\qdvd.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000325632 _____ (Microsoft Corporation) C:\Windows\system32\msnetobj.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000295936 _____ (Microsoft Corporation) C:\Windows\system32\AudioSes.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000284672 _____ (Microsoft Corporation) C:\Windows\system32\EncDump.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000206848 _____ (Microsoft Corporation) C:\Windows\system32\mfps.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000187904 _____ (Microsoft Corporation) C:\Windows\system32\pcasvc.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000081920 _____ (Microsoft Corporation) C:\Windows\system32\cryptsp.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000037376 _____ (Microsoft Corporation) C:\Windows\system32\pcadm.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000008704 _____ (Microsoft Corporation) C:\Windows\system32\pcaevts.dll
2017-07-31 16:26 - 2016-06-14 20:16 - 000002048 _____ (Microsoft Corporation) C:\Windows\system32\mferror.dll
2017-07-31 16:26 - 2016-06-14 20:11 - 000663552 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\PEAuth.sys
2017-07-31 16:26 - 2016-06-14 18:21 - 003209216 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mf.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 001005056 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cryptui.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000988160 _____ (Microsoft Corporation) C:\Windows\SysWOW64\drmv2clt.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000744960 _____ (Microsoft Corporation) C:\Windows\SysWOW64\blackbox.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000617984 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wmdrmsdk.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000519680 _____ (Microsoft Corporation) C:\Windows\SysWOW64\qdvd.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000504320 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msscp.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000489984 _____ (Microsoft Corporation) C:\Windows\SysWOW64\evr.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000442368 _____ (Microsoft Corporation) C:\Windows\SysWOW64\AUDIOKSE.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000406016 _____ (Microsoft Corporation) C:\Windows\SysWOW64\drmmgrtn.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000374784 _____ (Microsoft Corporation) C:\Windows\SysWOW64\AudioEng.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000354816 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mfplat.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000265216 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msnetobj.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000195072 _____ (Microsoft Corporation) C:\Windows\SysWOW64\AudioSes.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000103424 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mfps.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000080896 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cryptsp.dll
2017-07-31 16:26 - 2016-06-14 18:21 - 000002048 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mferror.dll
2017-07-31 16:26 - 2016-06-14 18:15 - 000125952 _____ (Microsoft Corporation) C:\Windows\system32\audiodg.exe
2017-07-31 16:26 - 2016-06-14 18:15 - 000055808 _____ (Microsoft Corporation) C:\Windows\system32\rrinstaller.exe
2017-07-31 16:26 - 2016-06-14 18:15 - 000024576 _____ (Microsoft Corporation) C:\Windows\system32\mfpmp.exe
2017-07-31 16:26 - 2016-06-14 18:05 - 000050176 _____ (Microsoft Corporation) C:\Windows\SysWOW64\rrinstaller.exe
2017-07-31 16:26 - 2016-06-14 18:05 - 000023040 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mfpmp.exe
2017-07-31 16:26 - 2016-06-14 18:00 - 000011264 _____ (Microsoft Corporation) C:\Windows\system32\pcawrk.exe
2017-07-31 16:26 - 2016-06-14 18:00 - 000009728 _____ (Microsoft Corporation) C:\Windows\system32\pcalua.exe
2017-07-31 16:26 - 2016-05-12 16:05 - 000297984 _____ (Microsoft Corporation) C:\Windows\system32\bcryptprimitives.dll
2017-07-31 16:26 - 2016-05-12 16:04 - 000249352 _____ (Microsoft Corporation) C:\Windows\SysWOW64\bcryptprimitives.dll
2017-07-31 16:26 - 2016-03-24 01:43 - 000457400 _____ (Microsoft Corporation) C:\Windows\system32\ci.dll
2017-07-31 16:26 - 2016-03-24 01:40 - 000546656 _____ (Microsoft Corporation) C:\Windows\system32\winresume.exe
2017-07-31 16:26 - 2016-02-05 04:19 - 000381440 _____ (Microsoft Corporation) C:\Windows\system32\mfds.dll
2017-07-31 16:26 - 2016-02-04 21:41 - 000296448 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mfds.dll
2017-07-31 16:26 - 2015-11-05 22:05 - 000017408 _____ (Microsoft Corporation) C:\Windows\system32\wshrm.dll
2017-07-31 16:26 - 2015-11-05 22:02 - 000014848 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wshrm.dll
2017-07-31 16:26 - 2015-11-05 12:53 - 000146944 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\rmcast.sys
2017-07-31 16:26 - 2012-09-26 01:47 - 000078336 _____ (Microsoft Corporation) C:\Windows\SysWOW64\synceng.dll
2017-07-31 16:26 - 2012-09-26 01:46 - 000095744 _____ (Microsoft Corporation) C:\Windows\system32\synceng.dll
2017-07-31 16:25 - 2014-10-14 05:13 - 000683520 _____ (Microsoft Corporation) C:\Windows\system32\termsrv.dll
2017-07-31 16:24 - 2015-07-15 21:10 - 001743360 _____ (Microsoft Corporation) C:\Windows\system32\sysmain.dll
2017-07-31 16:24 - 2014-11-11 06:08 - 000241152 _____ (Microsoft Corporation) C:\Windows\system32\pku2u.dll
2017-07-31 16:24 - 2014-11-11 05:44 - 000186880 _____ (Microsoft Corporation) C:\Windows\SysWOW64\pku2u.dll
2017-07-31 16:23 - 2016-01-06 22:02 - 000275456 _____ (Microsoft Corporation) C:\Windows\system32\InkEd.dll
2017-07-31 16:23 - 2016-01-06 21:41 - 000216064 _____ (Microsoft Corporation) C:\Windows\SysWOW64\InkEd.dll
2017-07-31 16:23 - 2015-07-15 06:19 - 002004992 _____ (Microsoft Corporation) C:\Windows\system32\msxml6.dll
2017-07-31 16:23 - 2015-07-15 06:14 - 000002048 _____ (Microsoft Corporation) C:\Windows\system32\msxml6r.dll
2017-07-31 16:23 - 2015-07-15 05:55 - 001390592 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msxml6.dll
2017-07-31 16:23 - 2015-07-15 05:51 - 000002048 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msxml6r.dll
2017-07-31 16:23 - 2015-07-10 20:51 - 003722752 _____ (Microsoft Corporation) C:\Windows\system32\mstscax.dll
2017-07-31 16:23 - 2015-07-10 20:51 - 000158720 _____ (Microsoft Corporation) C:\Windows\system32\aaclient.dll
2017-07-31 16:23 - 2015-07-10 20:51 - 000044032 _____ (Microsoft Corporation) C:\Windows\system32\tsgqec.dll
2017-07-31 16:23 - 2015-07-10 20:34 - 003221504 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mstscax.dll
2017-07-31 16:23 - 2015-07-10 20:34 - 000036864 _____ (Microsoft Corporation) C:\Windows\SysWOW64\tsgqec.dll
2017-07-31 16:23 - 2015-07-10 20:33 - 000131584 _____ (Microsoft Corporation) C:\Windows\SysWOW64\aaclient.dll
2017-07-31 16:23 - 2015-06-02 03:07 - 000254976 _____ (Microsoft Corporation) C:\Windows\system32\cewmdm.dll
2017-07-31 16:23 - 2015-06-02 02:47 - 000210432 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cewmdm.dll
2017-07-31 16:23 - 2015-04-24 21:17 - 000633856 _____ (Microsoft Corporation) C:\Windows\system32\comctl32.dll
2017-07-31 16:23 - 2015-04-24 20:56 - 000530432 _____ (Microsoft Corporation) C:\Windows\SysWOW64\comctl32.dll
2017-07-31 16:23 - 2014-12-19 06:06 - 000210432 _____ (Microsoft Corporation) C:\Windows\system32\profsvc.dll
2017-07-31 16:23 - 2014-12-06 07:17 - 000303616 _____ (Microsoft Corporation) C:\Windows\system32\nlasvc.dll
2017-07-31 16:23 - 2014-12-06 06:50 - 000156672 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ncsi.dll
2017-07-31 16:23 - 2014-12-06 06:50 - 000052224 _____ (Microsoft Corporation) C:\Windows\SysWOW64\nlaapi.dll
2017-07-31 16:23 - 2014-06-18 05:18 - 000692736 _____ (Microsoft Corporation) C:\Windows\system32\osk.exe
2017-07-31 16:23 - 2014-06-18 04:51 - 000646144 _____ (Microsoft Corporation) C:\Windows\SysWOW64\osk.exe
2017-07-31 16:23 - 2013-11-27 04:41 - 000343040 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\usbhub.sys
2017-07-31 16:23 - 2013-11-27 04:41 - 000325120 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\usbport.sys
2017-07-31 16:23 - 2013-11-27 04:41 - 000099840 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\usbccgp.sys
2017-07-31 16:23 - 2013-11-27 04:41 - 000053248 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\usbehci.sys
2017-07-31 16:23 - 2013-11-27 04:41 - 000007808 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\usbd.sys
2017-07-31 16:23 - 2012-10-03 20:44 - 000216576 _____ (Micr
Moses
2017-07-31 16:23 - 2012-10-03 20:44 - 000216576 _____ (Microsoft Corporation) C:\Windows\system32\ncsi.dll
2017-07-31 16:23 - 2012-10-03 20:44 - 000070656 _____ (Microsoft Corporation) C:\Windows\system32\nlaapi.dll
2017-07-31 16:23 - 2011-11-17 09:35 - 000395776 _____ (Microsoft Corporation) C:\Windows\system32\webio.dll
2017-07-31 16:23 - 2011-11-17 08:35 - 000314880 _____ (Microsoft Corporation) C:\Windows\SysWOW64\webio.dll
2017-07-31 16:23 - 2011-06-15 13:02 - 000212992 _____ (Microsoft Corporation) C:\Windows\system32\odbctrac.dll
2017-07-31 16:23 - 2011-06-15 13:02 - 000163840 _____ (Microsoft Corporation) C:\Windows\system32\odbccp32.dll
2017-07-31 16:23 - 2011-06-15 13:02 - 000106496 _____ (Microsoft Corporation) C:\Windows\system32\odbccu32.dll
2017-07-31 16:23 - 2011-06-15 13:02 - 000106496 _____ (Microsoft Corporation) C:\Windows\system32\odbccr32.dll
2017-07-31 16:23 - 2011-06-15 11:55 - 000319488 _____ (Microsoft Corporation) C:\Windows\SysWOW64\odbcjt32.dll
2017-07-31 16:23 - 2011-06-15 11:55 - 000163840 _____ (Microsoft Corporation) C:\Windows\SysWOW64\odbctrac.dll
2017-07-31 16:23 - 2011-06-15 11:55 - 000122880 _____ (Microsoft Corporation) C:\Windows\SysWOW64\odbccp32.dll
2017-07-31 16:23 - 2011-06-15 11:55 - 000086016 _____ (Microsoft Corporation) C:\Windows\SysWOW64\odbccu32.dll
2017-07-31 16:23 - 2011-06-15 11:55 - 000081920 _____ (Microsoft Corporation) C:\Windows\SysWOW64\odbccr32.dll
2017-07-31 16:23 - 2011-05-24 14:42 - 000404480 _____ (Microsoft Corporation) C:\Windows\system32\umpnpmgr.dll
2017-07-31 16:23 - 2011-05-24 13:40 - 000064512 _____ (Microsoft Corporation) C:\Windows\SysWOW64\devobj.dll
2017-07-31 16:23 - 2011-05-24 13:40 - 000044544 _____ (Microsoft Corporation) C:\Windows\SysWOW64\devrtl.dll
2017-07-31 16:23 - 2011-05-24 13:39 - 000145920 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cfgmgr32.dll
2017-07-31 16:23 - 2011-05-24 13:37 - 000252928 _____ (Microsoft Corporation) C:\Windows\SysWOW64\drvinst.exe
2017-07-31 16:23 - 2010-12-23 13:42 - 001118720 _____ (Microsoft Corporation) C:\Windows\system32\sbe.dll
2017-07-31 16:23 - 2010-12-23 13:36 - 000259072 _____ (Microsoft Corporation) C:\Windows\system32\mpg2splt.ax
2017-07-31 16:23 - 2010-12-23 08:54 - 000850944 _____ (Microsoft Corporation) C:\Windows\SysWOW64\sbe.dll
2017-07-31 16:23 - 2010-12-23 08:50 - 000199680 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mpg2splt.ax
2017-07-31 16:22 - 2016-02-03 21:07 - 000091648 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\USBSTOR.SYS
2017-07-31 16:22 - 2016-01-22 09:18 - 000961024 _____ (Microsoft Corporation) C:\Windows\system32\CPFilters.dll
2017-07-31 16:22 - 2016-01-22 09:18 - 000723968 _____ (Microsoft Corporation) C:\Windows\system32\EncDec.dll
2017-07-31 16:22 - 2016-01-22 09:17 - 000159744 _____ (Microsoft Corporation) C:\Windows\system32\mtxoci.dll
2017-07-31 16:22 - 2016-01-22 09:04 - 000642048 _____ (Microsoft Corporation) C:\Windows\SysWOW64\CPFilters.dll
2017-07-31 16:22 - 2016-01-22 09:04 - 000535040 _____ (Microsoft Corporation) C:\Windows\SysWOW64\EncDec.dll
2017-07-31 16:22 - 2016-01-22 09:02 - 000176128 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msorcl32.dll
2017-07-31 16:22 - 2016-01-22 09:02 - 000114176 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mtxoci.dll
2017-07-31 16:22 - 2015-12-09 00:53 - 000509952 _____ (Microsoft Corporation) C:\Windows\SysWOW64\qedit.dll
2017-07-31 16:22 - 2015-12-08 22:07 - 000624640 _____ (Microsoft Corporation) C:\Windows\system32\qedit.dll
2017-07-31 16:22 - 2015-11-11 21:53 - 001735680 _____ (Microsoft Corporation) C:\Windows\system32\comsvcs.dll
2017-07-31 16:22 - 2015-11-11 21:53 - 000525312 _____ (Microsoft Corporation) C:\Windows\system32\catsrvut.dll
2017-07-31 16:22 - 2015-11-11 21:39 - 001242624 _____ (Microsoft Corporation) C:\Windows\SysWOW64\comsvcs.dll
2017-07-31 16:22 - 2015-11-11 21:39 - 000487936 _____ (Microsoft Corporation) C:\Windows\SysWOW64\catsrvut.dll
2017-07-31 16:22 - 2015-07-15 06:19 - 000052736 _____ (Microsoft Corporation) C:\Windows\system32\basesrv.dll
2017-07-31 16:22 - 2015-07-09 20:57 - 000193536 _____ (Microsoft Corporation) C:\Windows\system32\notepad.exe
2017-07-31 16:22 - 2015-07-09 20:57 - 000193536 _____ (Microsoft Corporation) C:\Windows\notepad.exe
2017-07-31 16:22 - 2015-07-09 20:42 - 000179712 _____ (Microsoft Corporation) C:\Windows\SysWOW64\notepad.exe
2017-07-31 16:22 - 2015-02-03 06:31 - 000215552 _____ (Microsoft Corporation) C:\Windows\system32\ubpm.dll
2017-07-31 16:22 - 2015-02-03 06:12 - 000171520 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ubpm.dll
2017-07-31 16:22 - 2014-06-19 01:23 - 001943696 _____ (Microsoft Corporation) C:\Windows\system32\dfshim.dll
2017-07-31 16:22 - 2014-06-19 01:23 - 001131664 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dfshim.dll
2017-07-31 16:22 - 2014-06-19 01:23 - 000156824 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mscorier.dll
2017-07-31 16:22 - 2014-06-19 01:23 - 000156312 _____ (Microsoft Corporation) C:\Windows\system32\mscorier.dll
2017-07-31 16:22 - 2014-06-19 01:23 - 000081560 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mscories.dll
2017-07-31 16:22 - 2014-06-19 01:23 - 000073880 _____ (Microsoft Corporation) C:\Windows\system32\mscories.dll
2017-07-31 16:22 - 2014-03-04 12:44 - 000722944 _____ (Microsoft Corporation) C:\Windows\system32\objsel.dll
2017-07-31 16:22 - 2014-03-04 12:44 - 000039936 _____ (Microsoft Corporation) C:\Windows\system32\wincredprovider.dll
2017-07-31 16:22 - 2014-03-04 12:43 - 000057344 _____ (Microsoft Corporation) C:\Windows\system32\cngprovider.dll
2017-07-31 16:22 - 2014-03-04 12:43 - 000056832 _____ (Microsoft Corporation) C:\Windows\system32\adprovider.dll
2017-07-31 16:22 - 2014-03-04 12:43 - 000053760 _____ (Microsoft Corporation) C:\Windows\system32\capiprovider.dll
2017-07-31 16:22 - 2014-03-04 12:43 - 000052736 _____ (Microsoft Corporation) C:\Windows\system32\dpapiprovider.dll
2017-07-31 16:22 - 2014-03-04 12:43 - 000044544 _____ (Microsoft Corporation) C:\Windows\system32\dimsroam.dll
2017-07-31 16:22 - 2014-03-04 12:17 - 000538112 _____ (Microsoft Corporation) C:\Windows\SysWOW64\objsel.dll
2017-07-31 16:22 - 2014-03-04 12:17 - 000051200 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cngprovider.dll
2017-07-31 16:22 - 2014-03-04 12:17 - 000049664 _____ (Microsoft Corporation) C:\Windows\SysWOW64\adprovider.dll
2017-07-31 16:22 - 2014-03-04 12:17 - 000048128 _____ (Microsoft Corporation) C:\Windows\SysWOW64\capiprovider.dll
2017-07-31 16:22 - 2014-03-04 12:17 - 000047616 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dpapiprovider.dll
2017-07-31 16:22 - 2014-03-04 12:17 - 000036864 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dimsroam.dll
2017-07-31 16:22 - 2014-03-04 12:17 - 000035328 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wincredprovider.dll
2017-07-31 16:22 - 2013-10-19 05:18 - 000081408 _____ (Microsoft Corporation) C:\Windows\system32\imagehlp.dll
2017-07-31 16:22 - 2013-10-19 04:36 - 000159232 _____ (Microsoft Corporation) C:\Windows\SysWOW64\imagehlp.dll
2017-07-31 16:22 - 2013-06-26 01:55 - 000785624 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\Wdf01000.sys
2017-07-31 16:22 - 2013-02-12 07:12 - 000019968 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\usb8023.sys
2017-07-31 16:22 - 2012-11-23 06:13 - 000068608 _____ (Microsoft Corporation) C:\Windows\system32\taskhost.exe
2017-07-31 16:22 - 2012-11-02 08:59 - 000478208 _____ (Microsoft Corporation) C:\Windows\system32\dpnet.dll
2017-07-31 16:22 - 2012-11-02 08:11 - 000376832 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dpnet.dll
2017-07-31 16:22 - 2012-03-17 10:58 - 000075120 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\partmgr.sys
2017-07-31 16:22 - 2011-08-17 08:26 - 000613888 _____ (Microsoft Corporation) C:\Windows\system32\psisdecd.dll
2017-07-31 16:22 - 2011-08-17 08:25 - 000108032 _____ (Microsoft Corporation) C:\Windows\system32\psisrndr.ax
2017-07-31 16:22 - 2011-08-17 07:24 - 000465408 _____ (Microsoft Corporation) C:\Windows\SysWOW64\psisdecd.dll
2017-07-31 16:22 - 2011-08-17 07:19 - 000075776 _____ (Microsoft Corporation) C:\Windows\SysWOW64\psisrndr.ax
2017-07-31 16:22 - 2011-03-03 09:24 - 000357888 _____ (Microsoft Corporation) C:\Windows\system32\dnsapi.dll
2017-07-31 16:22 - 2011-03-03 09:24 - 000183296 _____ (Microsoft Corporation) C:\Windows\system32\dnsrslvr.dll
2017-07-31 16:22 - 2011-03-03 09:21 - 000030208 _____ (Microsoft Corporation) C:\Windows\system32\dnscacheugc.exe
2017-07-31 16:22 - 2011-03-03 08:38 - 000270336 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dnsapi.dll
2017-07-31 16:22 - 2011-03-03 08:36 - 000028672 _____ (Microsoft Corporation) C:\Windows\SysWOW64\dnscacheugc.exe
2017-07-31 16:21 - 2015-12-09 00:54 - 001620992 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMVDECOD.DLL
2017-07-31 16:21 - 2015-12-09 00:54 - 001568768 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMVENCOD.DLL
2017-07-31 16:21 - 2015-12-09 00:54 - 001325056 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMSPDMOE.DLL
2017-07-31 16:21 - 2015-12-09 00:54 - 000902144 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMADMOD.DLL
2017-07-31 16:21 - 2015-12-09 00:54 - 000815616 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMADMOE.DLL
2017-07-31 16:21 - 2015-12-09 00:54 - 000740352 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wmpmde.dll
2017-07-31 16:21 - 2015-12-09 00:54 - 000739328 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMSPDMOD.DLL
2017-07-31 16:21 - 2015-12-09 00:54 - 000665088 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMVXENCD.DLL
2017-07-31 16:21 - 2015-12-09 00:54 - 000541184 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMVSDECD.DLL
2017-07-31 16:21 - 2015-12-09 00:54 - 000358400 _____ (Microsoft Corporation) C:\Windows\SysWOW64\WMVSENCD.DLL
2017-07-31 16:21 - 2015-12-09 00:54 - 000154112 _____ (Microsoft Corporation) C:\Windows\SysWOW64\VIDRESZR.DLL
2017-07-31 16:21 - 2015-12-09 00:53 - 000970240 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msmpeg2adec.dll
2017-07-31 16:21 - 2015-12-09 00:53 - 000829952 _____ (Microsoft Corporation) C:\Windows\SysWOW64\MSMPEG2ENC.DLL
2017-07-31 16:21 - 2015-12-09 00:53 - 000609280 _____ (Microsoft Corporation) C:\Windows\SysWOW64\MFWMAAEC.DLL
2017-07-31 16:21 - 2015-12-09 00:53 - 000415744 _____ (Microsoft Corporation) C:\Windows\SysWOW64\MP4SDECD.DLL
2017-07-31 16:21 - 2015-12-09 00:53 - 000241152 _____ (Microsoft Corporation) C:\Windows\SysWOW64\MPG4DECD.DLL
2017-07-31 16:21 - 2015-12-09 00:53 - 000241152 _____ (Microsoft Corporation) C:\Windows\SysWOW64\MP43DECD.DLL
2017-07-31 16:21 - 2015-12-09 00:53 - 000206848 _____ (Microsoft Corporation) C:\Windows\SysWOW64\RESAMPLEDMO.DLL
2017-07-31 16:21 - 2015-12-09 00:53 - 000206848 _____ (Microsoft Corporation) C:\Windows\SysWOW64\qasf.dll
2017-07-31 16:21 - 2015-12-09 00:53 - 000193536 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ksproxy.ax
2017-07-31 16:21 - 2015-12-09 00:53 - 000153600 _____ (Microsoft Corporation) C:\Windows\SysWOW64\COLORCNV.DLL
2017-07-31 16:21 - 2015-12-09 00:53 - 000079872 _____ (Microsoft Corporation) C:\Windows\SysWOW64\MP3DMOD.DLL
2017-07-31 16:21 - 2015-12-09 00:53 - 000067584 _____ (Microsoft Corporation) C:\Windows\SysWOW64\devenum.dll
2017-07-31 16:21 - 2015-12-09 00:53 - 000053248 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mfvdsp.dll
2017-07-31 16:21 - 2015-12-09 00:53 - 000004608 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ksuser.dll
2017-07-31 16:21 - 2015-12-08 22:07 - 001955328 _____ (Microsoft Corporation) C:\Windows\system32\WMVENCOD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 001888768 _____ (Microsoft Corporation) C:\Windows\system32\WMVDECOD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 001575424 _____ (Microsoft Corporation) C:\Windows\system32\WMSPDMOE.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 001393152 _____ (Microsoft Corporation) C:\Windows\system32\WMALFXGFXDSP.dll
2017-07-31 16:21 - 2015-12-08 22:07 - 001307136 _____ (Microsoft Corporation) C:\Windows\system32\msmpeg2adec.dll
2017-07-31 16:21 - 2015-12-08 22:07 - 001232896 _____ (Microsoft Corporation) C:\Windows\system32\WMADMOD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 001160192 _____ (Microsoft Corporation) C:\Windows\system32\MSMPEG2ENC.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 001153024 _____ (Microsoft Corporation) C:\Windows\system32\WMADMOE.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 001026048 _____ (Microsoft Corporation) C:\Windows\system32\wmpmde.dll
2017-07-31 16:21 - 2015-12-08 22:07 - 001010688 _____ (Microsoft Corporation) C:\Windows\system32\mcmde.dll
2017-07-31 16:21 - 2015-12-08 22:07 - 000978944 _____ (Microsoft Corporation) C:\Windows\system32\WMSPDMOD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000666112 _____ (Microsoft Corporation) C:\Windows\system32\WMVSDECD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000653824 _____ (Microsoft Corporation) C:\Windows\system32\MP4SDECD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000642048 _____ (Microsoft Corporation) C:\Windows\system32\WMVXENCD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000484864 _____ (Microsoft Corporation) C:\Windows\system32\MFWMAAEC.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000447488 _____ (Microsoft Corporation) C:\Windows\system32\WMVSENCD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000378880 _____ (Microsoft Corporation) C:\Windows\system32\SysFxUI.dll
2017-07-31 16:21 - 2015-12-08 22:07 - 000292352 _____ (Microsoft Corporation) C:\Windows\system32\VIDRESZR.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000254464 _____ (Microsoft Corporation) C:\Windows\system32\qasf.dll
2017-07-31 16:21 - 2015-12-08 22:07 - 000225792 _____ (Microsoft Corporation) C:\Windows\system32\RESAMPLEDMO.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000224768 _____ (Microsoft Corporation) C:\Windows\system32\MPG4DECD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000223744 _____ (Microsoft Corporation) C:\Windows\system32\MP43DECD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000189952 _____ (Microsoft Corporation) C:\Windows\system32\COLORCNV.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000100864 _____ (Microsoft Corporation) C:\Windows\system32\MP3DMOD.DLL
2017-07-31 16:21 - 2015-12-08 22:07 - 000076288 _____ (Microsoft Corporation) C:\Windows\system32\devenum.dll
2017-07-31 16:21 - 2015-12-08 22:07 - 000070144 _____ (Microsoft Corporation) C:\Windows\system32\mfvdsp.dll
2017-07-31 16:21 - 2015-12-08 22:07 - 000005120 _____ (Microsoft Corporation) C:\Windows\system32\ksuser.dll
2017-07-31 16:21 - 2015-12-08 22:06 - 000250880 _____ (Microsoft Corporation) C:\Windows\system32\ksproxy.ax
2017-07-31 16:21 - 2015-12-08 21:54 - 000116736 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\drmk.sys
2017-07-31 16:21 - 2015-12-08 21:12 - 000230400 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\portcls.sys
2017-07-31 16:21 - 2015-12-08 21:11 - 000005632 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\drmkaud.sys
2017-07-31 16:20 - 2016-06-26 03:27 - 000344576 _____ (Microsoft Corporation) C:\Windows\system32\ntprint.dll
2017-07-31 16:20 - 2016-06-26 03:27 - 000166400 _____ (Microsoft Corporation) C:\Windows\system32\inetpp.dll
2017-07-31 16:20 - 2016-06-26 03:27 - 000022528 _____ (Microsoft Corporation) C:\Windows\system32\inetppui.dll
2017-07-31 16:20 - 2016-06-25 22:53 - 000297472 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ntprint.dll
2017-07-31 16:20 - 2016-06-25 22:53 - 000061952 _____ (Microsoft Corporation) C:\Windows\system32\ntprint.exe
2017-07-31 16:20 - 2016-06-25 22:53 - 000048640 _____ (Microsoft Corporation) C:\Windows\system32\wpnpinst.exe
2017-07-31 16:20 - 2016-06-25 22:41 - 000061952 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ntprint.exe
2017-07-31 16:20 - 2016-05-11 20:02 - 000483840 _____ (Microsoft Corporation) C:\Windows\system32\StructuredQuery.dll
2017-07-31 16:20 - 2016-05-11 18:19 - 000363520 _____ (Microsoft Corporation) C:\Windows\SysWOW64\StructuredQuery.dll
2017-07-31 16:20 - 2015-11-14 02:09 - 000091648 _____ (Microsoft Corporation) C:\Windows\system32\mapistub.dll
2017-07-31 16:20 - 2015-11-14 02:09 - 000091648 _____ (Microsoft Corporation) C:\Windows\system32\mapi32.dll
2017-07-31 16:20 - 2015-11-14 02:08 - 000017920 _____ (Microsoft Corporation) C:\Windows\system32\fixmapi.exe
2017-07-31 16:20 - 2015-11-14 01:50 - 000076800 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mapistub.dll
2017-07-31 16:20 - 2015-11-14 01:50 - 000076800 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mapi32.dll
2017-07-31 16:20 - 2015-11-14 01:49 - 000014336 _____ (Microsoft Corporation) C:\Windows\SysWOW64\fixmapi.exe
2017-07-31 16:20 - 2015-08-05 20:56 - 001110016 _____ (Microsoft Corporation) C:\Windows\system32\schedsvc.dll
2017-07-31 16:20 - 2015-04-13 06:28 - 000328704 _____ (Microsoft Corporation) C:\Windows\system32\services.exe
2017-07-31 16:20 - 2014-12-11 20:47 - 000052736 _____ (Microsoft Corporation) C:\Windows\system32\TSWbPrxy.exe
2017-07-31 16:20 - 2013-07-12 13:41 - 000185344 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\usbvideo.sys
2017-07-31 16:20 - 2013-07-12 13:41 - 000100864 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\usbcir.sys
2017-07-31 16:20 - 2013-07-12 13:40 - 000109824 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\USBAUDIO.sys
2017-07-31 16:20 - 2013-07-03 07:40 - 000042496 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\usbscan.sys
2017-07-31 16:20 - 2013-07-03 07:05 - 000076800 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\hidclass.sys
2017-07-31 16:20 - 2013-07-03 07:05 - 000032896 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\hidparse.sys
2017-07-31 16:20 - 2011-03-11 09:34 - 001395712 _____ (Microsoft Corporation) C:\Windows\system32\mfc42.dll
2017-07-31 16:20 - 2011-03-11 09:34 - 001359872 _____ (Microsoft Corporation) C:\Windows\system32\mfc42u.dll
2017-07-31 16:20 - 2011-03-11 08:33 - 001164288 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mfc42u.dll
2017-07-31 16:20 - 2011-03-11 08:33 - 001137664 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mfc42.dll
2017-07-31 16:19 - 2016-05-12 20:15 - 000105472 _____ (Microsoft Corporation) C:\Windows\system32\winipsec.dll
2017-07-31 16:19 - 2016-05-12 20:14 - 000794624 _____ (Microsoft Corporation) C:\Windows\system32\gpsvc.dll
2017-07-31 16:19 - 2016-05-12 20:14 - 000502272 _____ (Microsoft Corporation) C:\Windows\system32\IPSECSVC.DLL
2017-07-31 16:19 - 2016-05-12 20:14 - 000373760 _____ (Microsoft Corporation) C:\Windows\system32\polstore.dll
2017-07-31 16:19 - 2016-05-12 20:14 - 000096256 _____ (Microsoft Corporation) C:\Windows\system32\gpapi.dll
2017-07-31 16:19 - 2016-05-12 20:14 - 000075776 _____ (Microsoft Corporation) C:\Windows\system32\FwRemoteSvr.dll
2017-07-31 16:19 - 2016-05-12 18:18 - 000274944 _____ (Microsoft Corporation) C:\Windows\SysWOW64\polstore.dll
2017-07-31 16:19 - 2016-05-12 18:18 - 000079360 _____ (Microsoft Corporation) C:\Windows\SysWOW64\gpapi.dll
2017-07-31 16:19 - 2016-05-12 18:18 - 000070144 _____ (Microsoft Corporation) C:\Windows\SysWOW64\winipsec.dll
2017-07-31 16:19 - 2016-05-12 18:18 - 000044032 _____ (Microsoft Corporation) C:\Windows\SysWOW64\FwRemoteSvr.dll
2017-07-31 16:19 - 2016-05-11 20:02 - 000444928 _____ (Microsoft Corporation) C:\Windows\system32\winhttp.dll
2017-07-31 16:19 - 2016-05-11 20:02 - 000327168 _____ (Microsoft Corporation) C:\Windows\system32\mswsock.dll
2017-07-31 16:19 - 2016-05-11 20:02 - 000296448 _____ (Microsoft Corporation) C:\Windows\system32\ws2_32.dll
2017-07-31 16:19 - 2016-05-11 18:19 - 000351744 _____ (Microsoft Corporation) C:\Windows\SysWOW64\winhttp.dll
2017-07-31 16:19 - 2016-05-11 18:19 - 000231424 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mswsock.dll
2017-07-31 16:19 - 2016-05-11 18:19 - 000206336 _____ (Microsoft Corporation) C:\Windows\SysWOW64\ws2_32.dll
2017-07-31 16:19 - 2016-05-11 18:11 - 000025088 _____ (Microsoft Corporation) C:\Windows\system32\netbtugc.exe
2017-07-31 16:19 - 2016-05-11 18:01 - 000026624 _____ (Microsoft Corporation) C:\Windows\SysWOW64\netbtugc.exe
2017-07-31 16:19 - 2016-05-11 17:58 - 000262144 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\netbt.sys
2017-07-31 16:19 - 2016-02-09 12:55 - 000030720 _____ (Microsoft Corporation) C:\Windows\system32\seclogon.dll
2017-07-31 16:19 - 2014-09-04 08:23 - 000424448 _____ (Microsoft Corporation) C:\Windows\system32\rastls.dll
2017-07-31 16:19 - 2014-09-04 08:04 - 000372736 _____ (Microsoft Corporation) C:\Windows\SysWOW64\rastls.dll
2017-07-31 16:19 - 2014-07-17 05:07 - 001118720 _____ (Microsoft Corporation) C:\Windows\system32\mstsc.exe
2017-07-31 16:19 - 2014-07-17 05:07 - 000455168 _____ (Microsoft Corporation) C:\Windows\system32\winlogon.exe
2017-07-31 16:19 - 2014-07-17 05:07 - 000235520 _____ (Microsoft Corporation) C:\Windows\system32\winsta.dll
2017-07-31 16:19 - 2014-07-17 05:07 - 000150528 _____ (Microsoft Corporation) C:\Windows\system32\rdpcorekmts.dll
2017-07-31 16:19 - 2014-07-17 04:40 - 000157696 _____ (Microsoft Corporation) C:\Windows\SysWOW64\winsta.dll
2017-07-31 16:19 - 2014-07-17 04:39 - 001051136 _____ (Microsoft Corporation) C:\Windows\SysWOW64\mstsc.exe
2017-07-31 16:19 - 2014-07-17 04:21 - 000212480 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\rdpwd.sys
2017-07-31 16:19 - 2014-07-17 04:21 - 000039936 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\tssecsrv.sys
2017-07-31 16:19 - 2013-07-26 05:24 - 000197120 _____ (Microsoft Corporation) C:\Windows\system32\shdocvw.dll
2017-07-31 16:19 - 2013-07-26 04:55 - 000180224 _____ (Microsoft Corporation) C:\Windows\SysWOW64\shdocvw.dll
2017-07-31 16:19 - 2012-04-26 08:41 - 000077312 _____ (Microsoft Corporation) C:\Windows\system32\rdpwsx.dll
2017-07-31 16:19 - 2012-04-26 08:34 - 000009216 _____ (Microsoft Corporation) C:\Windows\system32\rdrmemptylst.exe
2017-07-31 16:19 - 2011-12-16 11:46 - 000634880 _____ (Microsoft Corporation) C:\Windows\system32\msvcrt.dll
2017-07-31 16:19 - 2011-12-16 10:52 - 000690688 _____ (Microsoft Corporation) C:\Windows\SysWOW64\msvcrt.dll
2017-07-31 16:19 - 2011-08-27 08:37 - 000331776 _____ (Microsoft Corporation) C:\Windows\system32\oleacc.dll
2017-07-31 16:19 - 2011-08-27 07:26 - 000233472 _____ (Microsoft Corporation) C:\Windows\SysWOW64\oleacc.dll
2017-07-31 16:19 - 2011-02-05 20:10 - 000020352 _____ (Microsoft Corporation) C:\Windows\system32\kdusb.dll
2017-07-31 16:19 - 2011-02-05 20:10 - 000019328 _____ (Microsoft Corporation) C:\Windows\system32\kd1394.dll
2017-07-31 16:19 - 2011-02-05 20:10 - 000017792 _____ (Microsoft Corporation) C:\Windows\system32\kdcom.dll
2017-07-31 16:18 - 2016-04-06 18:27 - 000024576 _____ (Microsoft Corporation) C:\Windows\system32\jnwmon.dll
2017-07-31 16:18 - 2015-11-03 22:04 - 000241664 _____ (Microsoft Corporation) C:\Windows\system32\els.dll
2017-07-31 16:18 - 2015-11-03 21:55 - 000179712 _____ (Microsoft Corporation) C:\Windows\SysWOW64\els.dll
2017-07-31 16:18 - 2015-10-13 07:57 - 000950720 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\ndis.sys
2017-07-31 16:18 - 2015-03-04 07:41 - 000079360 _____ (Microsoft Corporation) C:\Windows\system32\clfsw32.dll
2017-07-31 16:18 - 2015-03-04 07:10 - 000058880 _____ (Microsoft Corporation) C:\Windows\SysWOW64\clfsw32.dll
2017-07-31 16:18 - 2014-12-08 06:09 - 000406528 _____ (Microsoft Corporation) C:\Windows\system32\scesrv.dll
2017-07-31 16:18 - 2014-12-08 05:46 - 000308224 _____ (Microsoft Corporation) C:\Windows\SysWOW64\scesrv.dll
2017-07-31 16:18 - 2014-10-25 04:57 - 000077824 _____ (Microsoft Corporation) C:\Windows\system32\packager.dll
2017-07-31 16:18 - 2014-10-25 04:32 - 000067584 _____ (Microsoft Corporation) C:\Windows\SysWOW64\packager.dll
2017-07-31 16:18 - 2013-10-12 05:32 - 000150016 _____ (Microsoft Corporation) C:\Windows\system32\wshom.ocx
2017-07-31 16:18 - 2013-10-12 05:31 - 000202752 _____ (Microsoft Corporation) C:\Windows\system32\scrrun.dll
2017-07-31 16:18 - 2013-10-12 05:04 - 000121856 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wshom.ocx
2017-07-31 16:18 - 2013-10-12 05:03 - 000163840 _____ (Microsoft Corporation) C:\Windows\SysWOW64\scrrun.dll
2017-07-31 16:18 - 2013-10-12 04:33 - 000168960 _____ (Microsoft Corporation) C:\Windows\system32\wscript.exe
2017-07-31 16:18 - 2013-10-12 04:33 - 000156160 _____ (Microsoft Corporation) C:\Windows\system32\cscript.exe
2017-07-31 16:18 - 2013-10-12 04:15 - 000141824 _____ (Microsoft Corporation) C:\Windows\SysWOW64\wscript.exe
2017-07-31 16:18 - 2013-10-12 04:15 - 000126976 _____ (Microsoft Corporation) C:\Windows\SysWOW64\cscript.exe
2017-07-31 16:18 - 2013-05-13 08:50 - 000052224 _____ (Microsoft Corporation) C:\Windows\system32\certenc.dll
2017-07-31 16:18 - 2013-05-13 06:43 - 001192448 _____ (Microsoft Corporation) C:\Windows\system32\certutil.exe
2017-07-31 16:18 - 2013-05-13 06:08 - 000903168 _____ (Microsoft Corporation) C:\Windows\SysWOW64\certutil.exe
2017-07-31 16:18 - 2013-05-13 06:08 - 000043008 _____ (Microsoft Corporation) C:\Windows\SysWOW64\certenc.dll
2017-07-31 16:18 - 2012-07-05 01:16 - 000073216 _____ (Microsoft Corporation) C:\Windows\system32\netapi32.dll
2017-07-31 16:18 - 2012-07-05 01:13 - 000136704 _____ (Microsoft Corporation) C:\Windows\system32\browser.dll
2017-07-31 16:18 - 2012-07-05 01:13 - 000059392 _____ (Microsoft Corporation) C:\Windows\system32\browcli.dll
2017-07-31 16:18 - 2012-07-05 00:16 - 000057344 _____ (Microsoft Corporation) C:\Windows\SysWOW64\netapi32.dll
2017-07-31 16:18 - 2012-07-05 00:14 - 000041984 _____ (Microsoft Corporation) C:\Windows\SysWOW64\browcli.dll
2017-07-31 16:18 - 2011-02-12 14:34 - 000267776 _____ (Microsoft Corporation) C:\Windows\system32\FXSCOVER.exe
2017-07-31 16:10 - 2013-10-12 05:30 - 000830464 _____ (Microsoft Corporation) C:\Windows\system32\nshwfp.dll
2017-07-31 16:10 - 2013-10-12 05:29 - 000859648 _____ (Microsoft Corporation) C:\Windows\system32\IKEEXT.DLL
2017-07-31 16:10 - 2013-10-12 05:29 - 000324096 _____ (Microsoft Corporation) C:\Windows\system32\FWPUCLNT.DLL
2017-07-31 16:10 - 2013-10-12 05:03 - 000656896 _____ (Microsoft Corporation) C:\Windows\SysWOW64\nshwfp.dll
2017-07-31 16:10 - 2013-10-12 05:01 - 000216576 _____ (Microsoft Corporation) C:\Windows\SysWOW64\FWPUCLNT.DLL
2017-07-31 16:09 - 2016-07-22 17:58 - 000142336 _____ (Microsoft Corporation) C:\Windows\system32\poqexec.exe
2017-07-31 16:09 - 2016-07-22 17:51 - 000123904 _____ (Microsoft Corporation) C:\Windows\SysWOW64\poqexec.exe
2017-07-31 16:09 - 2012-02-17 09:38 - 001031680 _____ (Microsoft Corporation) C:\Windows\system32\rdpcore.dll
2017-07-31 16:09 - 2012-02-17 08:34 - 000826880 _____ (Microsoft Corporation) C:\Windows\SysWOW64\rdpcore.dll
2017-07-31 16:09 - 2012-02-17 07:57 - 000023552 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\tdtcp.sys
2017-07-31 15:47 - 2017-07-31 15:47 - 000000000 ____D C:\Program Files (x86)\Intel
2017-07-31 15:47 - 2017-07-31 15:47 - 000000000 ____D C:\Intel
2017-07-31 15:47 - 2015-05-26 21:02 - 005375448 _____ (Intel Corporation) C:\Windows\system32\Drivers\igdkmd64.sys
2017-07-31 15:47 - 2015-05-26 21:00 - 000017082 _____ C:\Windows\system32\iglhxs64.vp
2017-07-31 15:47 - 2015-05-26 20:52 - 000440320 _____ (Intel Corporation) C:\Windows\system32\igfxrell.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000439808 _____ (Intel Corporation) C:\Windows\system32\igfxrfra.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000439808 _____ (Intel Corporation) C:\Windows\system32\igfxresn.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000439296 _____ (Intel Corporation) C:\Windows\system32\igfxrrus.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000439296 _____ (Intel Corporation) C:\Windows\system32\igfxrrom.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438784 _____ (Intel Corporation) C:\Windows\system32\igfxrsky.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438784 _____ (Intel Corporation) C:\Windows\system32\igfxrptg.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438784 _____ (Intel Corporation) C:\Windows\system32\igfxrplk.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438784 _____ (Intel Corporation) C:\Windows\system32\igfxrnld.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438784 _____ (Intel Corporation) C:\Windows\system32\igfxrita.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438784 _____ (Intel Corporation) C:\Windows\system32\igfxrhrv.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438784 _____ (Intel Corporation) C:\Windows\system32\igfxrdeu.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438272 _____ (Intel Corporation) C:\Windows\system32\igfxrhun.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438272 _____ (Intel Corporation) C:\Windows\system32\igfxrfin.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000438272 _____ (Intel Corporation) C:\Windows\system32\igfxrcsy.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000437760 _____ (Intel Corporation) C:\Windows\system32\igfxrtrk.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000437760 _____ (Intel Corporation) C:\Windows\system32\igfxrsve.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000437760 _____ (Intel Corporation) C:\Windows\system32\igfxrslv.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000437760 _____ (Intel Corporation) C:\Windows\system32\igfxrptb.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000437760 _____ (Intel Corporation) C:\Windows\system32\igfxrnor.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000437248 _____ (Intel Corporation) C:\Windows\system32\igfxrtha.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000437248 _____ (Intel Corporation) C:\Windows\system32\igfxrdan.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000435712 _____ (Intel Corporation) C:\Windows\system32\igfxrheb.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000435712 _____ (Intel Corporation) C:\Windows\system32\igfxrara.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000432128 _____ (Intel Corporation) C:\Windows\system32\igfxrjpn.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000431104 _____ (Intel Corporation) C:\Windows\system32\igfxrkor.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000429056 _____ (Intel Corporation) C:\Windows\system32\igfxrcht.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000428544 _____ (Intel Corporation) C:\Windows\system32\igfxrchs.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000286208 _____ (Intel Corporation) C:\Windows\system32\igfxrenu.lrc
2017-07-31 15:47 - 2015-05-26 20:52 - 000223664 _____ C:\Windows\system32\Gfxres.th-TH.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000210106 _____ C:\Windows\system32\Gfxres.el-GR.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000194245 _____ C:\Windows\system32\Gfxres.ru-RU.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000166170 _____ C:\Windows\system32\Gfxres.ar-SA.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000163421 _____ C:\Windows\system32\Gfxres.ja-JP.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000159008 _____ C:\Windows\system32\Gfxres.he-IL.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000149682 _____ C:\Windows\system32\Gfxres.it-IT.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000148042 _____ C:\Windows\system32\Gfxres.ko-KR.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000147393 _____ C:\Windows\system32\Gfxres.de-DE.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000147288 _____ C:\Windows\system32\Gfxres.es-ES.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000146004 _____ C:\Windows\system32\Gfxres.ro-RO.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000145491 _____ C:\Windows\system32\Gfxres.fr-FR.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000144645 _____ C:\Windows\system32\Gfxres.tr-TR.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000144260 _____ C:\Windows\system32\Gfxres.pt-BR.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000144020 _____ C:\Windows\system32\Gfxres.nl-NL.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000143932 _____ C:\Windows\system32\Gfxres.hu-HU.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000142882 _____ C:\Windows\system32\Gfxres.sv-SE.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000142877 _____ C:\Windows\system32\Gfxres.pt-PT.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000142717 _____ C:\Windows\system32\Gfxres.pl-PL.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000142289 _____ C:\Windows\system32\Gfxres.cs-CZ.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000142008 _____ C:\Windows\system32\Gfxres.fi-FI.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000141838 _____ C:\Windows\system32\Gfxres.sk-SK.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000141049 _____ C:\Windows\system32\Gfxres.hr-HR.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000137889 _____ C:\Windows\system32\Gfxres.sl-SI.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000137784 _____ C:\Windows\system32\Gfxres.nb-NO.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000137141 _____ C:\Windows\system32\Gfxres.da-DK.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000132623 _____ C:\Windows\system32\Gfxres.en-US.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000126976 _____ (Intel Corporation) C:\Windows\system32\igfxcpl.cpl
2017-07-31 15:47 - 2015-05-26 20:52 - 000126300 _____ C:\Windows\system32\Gfxres.zh-TW.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000124650 _____ C:\Windows\system32\Gfxres.zh-CN.resources
2017-07-31 15:47 - 2015-05-26 20:52 - 000000268 _____ C:\Windows\system32\GfxUI.exe.config
2017-07-31 15:47 - 2015-05-26 20:50 - 001981696 _____ C:\Windows\system32\iglhxa64.cpa
2017-07-31 15:47 - 2015-05-26 20:50 - 000059425 _____ C:\Windows\system32\iglhxo64.vp
2017-07-31 15:47 - 2015-05-26 20:50 - 000059398 _____ C:\Windows\system32\iglhxg64.vp
2017-07-31 15:47 - 2015-05-26 20:50 - 000059230 _____ C:\Windows\system32\iglhxc64.vp
2017-07-31 15:47 - 2015-05-26 20:50 - 000059104 _____ C:\Windows\system32\iglhxc64_dev.vp
2017-07-31 15:47 - 2015-05-26 20:50 - 000058796 _____ C:\Windows\system32\iglhxg64_dev.vp
2017-07-31 15:47 - 2015-05-26 20:50 - 000058109 _____ C:\Windows\system32\iglhxo64_dev.vp
2017-07-31 15:47 - 2015-05-26 20:50 - 000001074 _____ C:\Windows\system32\iglhxa64.vp
2017-07-31 15:46 - 2015-06-04 22:21 - 000513640 _____ (Intel Corporation) C:\Windows\system32\igfxsrvc.exe
2017-07-31 15:46 - 2015-06-04 22:21 - 000444008 _____ (Intel Corporation) C:\Windows\system32\igfxpers.exe
2017-07-31 15:46 - 2015-06-04 22:21 - 000401512 _____ (Intel Corporation) C:\Windows\system32\hkcmd.exe
2017-07-31 15:46 - 2015-06-04 22:21 - 000280680 _____ (Intel Corporation) C:\Windows\SysWOW64\IntelCpHeciSvc.exe
2017-07-31 15:46 - 2015-06-04 22:21 - 000256616 _____ (Intel Corporation) C:\Windows\system32\igfxext.exe
2017-07-31 15:46 - 2015-06-04 22:21 - 000173672 _____ (Intel Corporation) C:\Windows\system32\igfxtray.exe
2017-07-31 15:46 - 2015-06-04 22:20 - 000116224 _____ (Intel Corporation) C:\Windows\system32\igfxCoIn_v4229.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 012937864 _____ (Intel Corporation) C:\Windows\system32\igd10umd64.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 012694808 _____ (Intel Corporation) C:\Windows\system32\igdumd64.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 011245520 _____ (Intel Corporation) C:\Windows\SysWOW64\igd10umd32.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 011117808 _____ (Intel Corporation) C:\Windows\SysWOW64\igdumd32.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 001049576 _____ (Intel Corporation) C:\Windows\system32\igfxcmrt64.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 000940360 _____ (Intel Corporation) C:\Windows\SysWOW64\igfxcmrt32.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 000530968 _____ (Intel Corporation) C:\Windows\system32\iglhsip64.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 000525800 _____ (Intel Corporation) C:\Windows\SysWOW64\iglhsip32.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 000220432 _____ (Intel Corporation) C:\Windows\system32\iglhcp64.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 000184352 _____ (Intel Corporation) C:\Windows\SysWOW64\iglhcp32.dll
2017-07-31 15:46 - 2015-05-26 21:00 - 000031984 _____ (Intel Corporation) C:\Windows\system32\igfxexps.dll
2017-07-31 15:46 - 2015-05-26 20:53 - 000101376 _____ C:\Windows\system32\igdde64.dll
2017-07-31 15:46 - 2015-05-26 20:53 - 000081408 _____ C:\Windows\SysWOW64\igdde32.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 010811392 _____ (Intel Corporation) C:\Windows\SysWOW64\ig4icd32.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 009007616 _____ (Intel Corporation) C:\Windows\system32\igfxress.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000442880 _____ (Intel Corporation) C:\Windows\system32\igfxdev.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000410112 _____ (Intel Corporation) C:\Windows\system32\igfxTMM.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000384512 _____ (Intel Corporation) C:\Windows\system32\igfxpph.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000330752 _____ (Intel Corporation) C:\Windows\SysWOW64\igfxdv32.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000175104 _____ (Intel Corporation) C:\Windows\system32\gfxSrvc.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000142336 _____ (Intel Corporation) C:\Windows\system32\igfxdo.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000110592 _____ (Intel Corporation) C:\Windows\system32\hccutils.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000064000 _____ (Intel Corporation) C:\Windows\system32\igfxsrvc.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000025088 _____ (Intel Corporation) C:\Windows\SysWOW64\igfxexps32.dll
2017-07-31 15:46 - 2015-05-26 20:52 - 000009728 _____ ( ) C:\Windows\system32\IGFXDEVLib.dll
2017-07-31 15:46 - 2015-05-26 20:51 - 013028864 _____ (Intel Corporation) C:\Windows\system32\ig4icd64.dll
2017-07-31 15:46 - 2015-05-26 20:50 - 003511296 _____ (Intel Corporation) C:\Windows\system32\igfxcmjit64.dll
2017-07-31 15:46 - 2015-05-26 20:50 - 003121152 _____ (Intel Corporation) C:\Windows\SysWOW64\igfxcmjit32.dll
2017-07-31 15:46 - 2015-05-26 20:50 - 000575488 _____ (Intel Corporation) C:\Windows\system32\igfx11cmrt64.dll
2017-07-31 15:46 - 2015-05-26 20:50 - 000542720 _____ (Intel Corporation) C:\Windows\SysWOW64\igfx11cmrt32.dll
2017-07-31 15:46 - 2015-05-26 20:50 - 000094208 _____ C:\Windows\system32\IccLibDll_x64.dll
2017-07-31 15:45 - 2017-07-31 15:45 - 000000000 ____H C:\Windows\system32\Drivers\Msft_Kernel_Smb_driver_Intel_01011.Wdf
2017-07-31 15:45 - 2017-07-31 15:45 - 000000000 ____D C:\Program Files\Synaptics
2017-07-31 15:45 - 2015-09-08 03:18 - 000033960 _____ (Synaptics Incorporated) C:\Windows\system32\Drivers\Smb_driver_Intel.sys
2017-07-31 15:45 - 2015-06-04 22:21 - 005906536 _____ (Intel Corporation) C:\Windows\system32\GfxUI.exe
2017-07-31 15:45 - 2015-06-04 22:21 - 000187496 _____ (Intel Corporation) C:\Windows\system32\difx64.exe
2017-07-31 15:45 - 2015-05-26 20:50 - 000963452 _____ C:\Windows\SysWOW64\igcodeckrng600.bin
2017-07-31 15:45 - 2015-05-26 20:50 - 000963452 _____ C:\Windows\system32\igcodeckrng600.bin
2017-07-31 15:45 - 2015-05-26 20:50 - 000272928 _____ C:\Windows\SysWOW64\igvpkrng600.bin
2017-07-31 15:45 - 2015-05-26 20:50 - 000272928 _____ C:\Windows\system32\igvpkrng600.bin
2017-07-31 15:44 - 2017-07-31 15:44 - 000000000 ____H C:\ProgramData\DP45977C.lfl
2017-07-31 15:44 - 2017-07-31 15:44 - 000000000 ____D C:\Windows\SysWOW64\RTCOM
2017-07-31 15:44 - 2017-07-31 15:44 - 000000000 ____D C:\Windows\system32\DAX2
2017-07-31 15:44 - 2017-07-31 15:44 - 000000000 ____D C:\Program Files\Realtek
2017-07-31 15:43 - 2017-08-03 10:04 - 000018960 _____ (Logitech, Inc.) C:\Windows\system32\Drivers\LNonPnP.sys
2017-07-31 15:43 - 2017-07-31 15:43 - 000000000 ____H C:\Windows\system32\Drivers\MsftWdf_Kernel_01011_Coinstaller_Critical.Wdf
2017-07-31 15:43 - 2017-07-31 15:43 - 000000000 ____H C:\Windows\system32\Drivers\Msft_Kernel_TeeDriverx64_01011.Wdf
2017-07-31 15:43 - 2015-12-04 09:51 - 072203792 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RCoRes64.dat
2017-07-31 15:43 - 2015-12-04 09:51 - 014057256 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxAudioRealtek64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 013120760 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxVoiceAPO3064.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 012986528 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxVoiceAPO4064.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 009997848 _____ (Intel Corporation) C:\Windows\system32\IntelSSTAPO.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 007172920 _____ (Dolby Laboratories) C:\Windows\system32\R4EEP64A.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 005804772 _____ C:\Windows\system32\Drivers\rtvienna.dat
2017-07-31 15:43 - 2015-12-04 09:51 - 005776688 _____ (Nahimic Inc) C:\Windows\system32\NAHIMICV2apo.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 005289952 _____ (Nahimic Inc) C:\Windows\system32\NAHIMICAPOlfx.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 004694784 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\Drivers\RTKVHD64.sys
2017-07-31 15:43 - 2015-12-04 09:51 - 004463263 _____ C:\Windows\system32\Drivers\RTAIODAT.DAT
2017-07-31 15:43 - 2015-12-04 09:51 - 003299832 _____ (Yamaha Corporation) C:\Windows\system32\YamahaAE2.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 003271912 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RtkApi64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 003195648 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RtPgEx64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 003152937 _____ C:\Windows\system32\Drivers\rtkSSTsetting.dat
2017-07-31 15:43 - 2015-12-04 09:51 - 003053392 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RltkAPO64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 002893568 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RTSnMg64.cpl
2017-07-31 15:43 - 2015-12-04 09:51 - 002823280 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxAudioAPO7064.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 002693360 _____ (Realtek Semiconductor Corp.) C:\Windows\SysWOW64\RltkAPO.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 002190992 _____ (Yamaha Corporation) C:\Windows\system32\YamahaAE.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 002130584 _____ (DTS, Inc.) C:\Windows\system32\sltech64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 002110600 _____ (Waves Audio Ltd.) C:\Windows\system32\WavesGUILib64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 002050184 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxAudioEQ64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 002030200 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RCoInstII64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001435152 _____ (Synopsys, Inc.) C:\Windows\system32\SRRPTR64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001421104 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxAudioAPO6064.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001382240 _____ (TOSHIBA Corporation) C:\Windows\system32\tosade.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001356512 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RTCOM64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001334384 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxSpeechAPO64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001328504 _____ (DTS, Inc.) C:\Windows\system32\slcnt64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001211832 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxAudioAPO5064.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001186168 _____ (Intel Corporation) C:\Windows\system32\IntelSstCApoPropPage.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001164336 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxAudioAPO4064.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001020208 _____ (DTS, Inc.) C:\Windows\system32\sl3apo64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 001003864 _____ (Nahimic Inc) C:\Windows\system32\NahimicAPONSControl.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000998032 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxVoiceAPO2064.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000965032 _____ (Sony Corporation) C:\Windows\system32\SFSS_APO.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000933640 _____ (Sound Research, Corp.) C:\Windows\system32\SEHDRA64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000931624 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxAudioAPOShell64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000923752 _____ (Sony Corporation) C:\Windows\system32\MISS_APO.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000888480 _____ (TOSHIBA Corporation) C:\Windows\system32\tossaeapo64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000873472 _____ (TOSHIBA Corporation) C:\Windows\system32\tadefxapo264.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000716112 _____ (Sound Research, Corp.) C:\Windows\system32\SECOMN64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000689888 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RtDataProc64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000678192 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxAudioAPO30.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000677680 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxVolumeSDAPO.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000618192 _____ (Knowles Acoustics ) C:\Windows\system32\KAAPORT64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000596120 _____ (TOSHIBA Corporation) C:\Windows\system32\tosasfapo64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000589080 _____ (Sound Research, Corp.) C:\Windows\SysWOW64\SECOMN32.DLL
2017-07-31 15:43 - 2015-12-04 09:51 - 000532384 _____ (SRS Labs, Inc.) C:\Windows\system32\SRSTSX64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000467168 _____ (Synopsys, Inc.) C:\Windows\system32\SRAPO64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000448592 _____ (Sound Research, Corp.) C:\Windows\system32\SEAPO64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000447720 _____ (Dolby Laboratories) C:\Windows\system32\R4EED64A.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000387320 _____ (Dolby Laboratories, Inc.) C:\Windows\system32\RTEEP64A.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000381416 _____ (Synopsys, Inc.) C:\Windows\system32\SRCOM64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000369304 _____ (Dolby Laboratories) C:\Windows\system32\HiFiDAX2API.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000343712 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RtlCPAPI64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000341160 _____ (Synopsys, Inc.) C:\Windows\SysWOW64\SRCOM.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000341160 _____ (Synopsys, Inc.) C:\Windows\system32\SRCOM.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000340648 _____ (ICEpower a/s) C:\Windows\system32\ICEsoundAPO64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000330568 _____ (Waves Audio Ltd.) C:\Windows\system32\MaxxAudioAPO20.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000321720 _____ (Dolby Laboratories, Inc.) C:\Windows\system32\RP3DHT64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000321720 _____ (Dolby Laboratories, Inc.) C:\Windows\system32\RP3DAA64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000258504 _____ (TODO: <Company name>) C:\Windows\system32\slprp64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000231920 _____ (Synopsys, Inc.) C:\Windows\system32\SFNHK64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000224264 _____ (TOSHIBA Corporation) C:\Windows\system32\tossaemaxapo64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000221976 _____ (SRS Labs, Inc.) C:\Windows\system32\SRSTSH64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000214840 _____ (Dolby Laboratories, Inc.) C:\Windows\system32\RTEED64A.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000209536 _____ (SRS Labs, Inc.) C:\Windows\system32\SRSHP64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000192992 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RtkCfg64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000172584 _____ (TOSHIBA Corporation) C:\Windows\system32\toseaeapo64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000166208 _____ (SRS Labs, Inc.) C:\Windows\system32\SRSWOW64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000158704 _____ (TOSHIBA Corporation) C:\Windows\system32\tadefxapo.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000151792 _____ (Dolby Laboratories) C:\Windows\system32\R4EEL64A.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000134208 _____ (Dolby Laboratories) C:\Windows\system32\R4EEA64A.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000110992 _____ (Dolby Laboratories, Inc.) C:\Windows\system32\RTEEL64A.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000090920 _____ (Synopsys, Inc.) C:\Windows\system32\SFCOM64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000088352 _____ (Dolby Laboratories, Inc.) C:\Windows\system32\RTEEG64A.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000088328 _____ (Synopsys, Inc.) C:\Windows\system32\SFAPO64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000084624 _____ (Dolby Laboratories) C:\Windows\system32\R4EEG64A.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000083632 _____ (Virage Logic Corporation / Sonic Focus) C:\Windows\SysWOW64\SFCOM.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000075544 _____ (TOSHIBA CORPORATION.) C:\Windows\system32\tepeqapo64.dll
2017-07-31 15:43 - 2015-12-04 09:51 - 000023704 _____ (Realtek Semiconductor Corp.) C:\Windows\system32\RtkCoLDR64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 007096192 _____ (Dolby Laboratories) C:\Windows\system32\DDPP64A.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 006264640 _____ (Dolby Laboratories) C:\Windows\system32\DDPP64AF3.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 005338936 _____ (Dolby Laboratories) C:\Windows\system32\DolbyDAX2APOv211.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 003282032 _____ (Fortemedia Corporation) C:\Windows\system32\FMAPO64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 002437136 _____ (Dolby Laboratories) C:\Windows\system32\DolbyDAX2APOv201.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 001965816 _____ (Dolby Laboratories) C:\Windows\system32\DDPD64A.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 001959608 _____ (Dolby Laboratories) C:\Windows\system32\DDPD64AF3.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 001780624 _____ (DTS) C:\Windows\system32\DTSS2SpeakerDLL64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 001601952 _____ (Conexant Systems Inc.) C:\Windows\system32\CX64APO.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 001591064 _____ (DTS) C:\Windows\system32\DTSS2HeadphoneDLL64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 001508936 _____ (DTS) C:\Windows\system32\DTSBoostDLL64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000952984 _____ (Dolby Laboratories) C:\Windows\system32\DolbyDAX2APOProp.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000743968 _____ (DTS) C:\Windows\system32\DTSBassEnhancementDLL64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000727440 _____ (DTS) C:\Windows\system32\DTSSymmetryDLL64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000708320 _____ (DTS) C:\Windows\system32\DTSVoiceClarityDLL64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000574760 _____ (Andrea Electronics Corporation) C:\Windows\system32\AERTAC64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000514528 _____ (DTS) C:\Windows\system32\DTSU2PLFX64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000504312 _____ (DTS) C:\Windows\system32\DTSNeoPCDLL64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000500560 _____ (DTS) C:\Windows\system32\DTSU2PGFX64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000445408 _____ (DTS) C:\Windows\system32\DTSLimiterDLL64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000441272 _____ (DTS) C:\Windows\system32\DTSGainCompensatorDLL64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000428232 _____ (DTS) C:\Windows\system32\DTSU2PREC64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000362056 _____ (Dolby Laboratories) C:\Windows\system32\DDPO64AF3.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000327456 _____ (Dolby Laboratories) C:\Windows\system32\DDPO64A.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000310432 _____ (Dolby Laboratories) C:\Windows\system32\DDPA64F3.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000272720 _____ (Dolby Laboratories) C:\Windows\system32\DDPA64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000253904 _____ (DTS) C:\Windows\system32\DTSGFXAPO64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000253864 _____ (DTS) C:\Windows\system32\DTSLFXAPO64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000252880 _____ (DTS) C:\Windows\system32\DTSGFXAPONS64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000122328 _____ (Real Sound Lab SIA) C:\Windows\system32\CONEQMSAPOGUILibrary.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000118600 _____ (Andrea Electronics Corporation) C:\Windows\system32\AERTAR64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000118592 _____ C:\Windows\system32\AcpiServiceVnA64.dll
2017-07-31 15:43 - 2015-12-04 09:50 - 000105312 _____ C:\Windows\system32\audioLibVc.dll
2017-07-31 15:43 - 2015-09-23 14:19 - 000405472 _____ (Intel Corporation) C:\Windows\system32\PROUnstl.exe
2017-07-31 15:43 - 2015-08-18 11:43 - 000003114 _____ C:\Windows\system32\e1c62x64.din
2017-07-31 15:43 - 2015-08-12 15:27 - 000498160 _____ (Intel Corporation) C:\Windows\system32\Drivers\e1c62x64.sys
2017-07-31 15:43 - 2015-06-18 05:25 - 001854096 _____ (Logitech, Inc.) C:\Windows\system32\LkmdfCoInst.dll
2017-07-31 15:43 - 2015-06-18 05:25 - 000063120 _____ (Logitech, Inc.) C:\Windows\system32\LMouFiltCoInst.dll
2017-07-31 15:43 - 2015-05-29 17:05 - 000646408 _____ (Intel Corporation) C:\Windows\system32\Drivers\iaStorA.sys
2017-07-31 15:43 - 2015-05-29 17:05 - 000030960 _____ (Intel Corporation) C:\Windows\system32\Drivers\iaStorF.sys
2017-07-31 15:43 - 2013-07-25 03:08 - 000073480 _____ (Intel Corporation) C:\Windows\system32\e1cmsg.dll
2017-07-31 15:43 - 2013-07-11 03:27 - 000089888 _____ (Intel Corporation) C:\Windows\system32\NicInstC.dll
2017-07-31 15:43 - 2009-05-26 10:05 - 000036472 _____ (Intel Corporation) C:\Windows\system32\NicCo36.dll
2017-07-31 15:42 - 2015-10-08 22:15 - 000180480 _____ (Intel Corporation) C:\Windows\system32\Drivers\TeeDriverx64.sys
2017-07-31 15:42 - 2015-06-18 05:25 - 000086672 _____ (Logitech, Inc.) C:\Windows\system32\Drivers\LHidFilt.Sys
2017-07-31 15:42 - 2015-06-18 05:25 - 000069264 _____ (Logitech, Inc.) C:\Windows\system32\Drivers\LMouFilt.Sys
2017-07-31 15:42 - 2015-06-18 05:25 - 000050832 _____ (Logitech, Inc.) C:\Windows\system32\Drivers\LUsbFilt.sys
2017-07-31 15:42 - 2014-01-12 12:05 - 000086016 _____ (Nuvoton Technology Corp.) C:\Windows\system32\Drivers\nuvserial.sys
2017-07-31 15:42 - 2014-01-12 12:05 - 000023552 _____ (Windows (R) Win 7 DDK provider) C:\Windows\system32\Drivers\nuvserenum.sys
2017-07-31 15:42 - 2012-08-17 11:57 - 001795952 _____ (Microsoft Corporation) C:\Windows\system32\WdfCoInstaller01011.dll
2017-07-31 15:42 - 2012-07-26 07:55 - 000054376 _____ (Microsoft Corporation) C:\Windows\system32\Drivers\WdfLdr.sys
2017-07-31 15:42 - 2012-07-26 05:36 - 000009728 _____ (Microsoft Corporation) C:\Windows\system32\Wdfres.dll
2017-07-31 15:42 - 2012-06-02 17:35 - 000000003 _____ C:\Windows\system32\Drivers\MsftWdf_Kernel_01011_Inbox_Critical.Wdf
2017-07-31 15:41 - 2017-07-31 15:41 - 000000000 ____H C:\Windows\system32\Drivers\Msft_User_WpdFs_01_09_00.Wdf
2017-07-31 15:37 - 2017-08-06 16:09 - 000000000 ____D C:\Users\Me
2017-07-31 15:37 - 2017-08-02 03:09 - 000001417 _____ C:\Users\Me\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Internet Explorer.lnk
2017-07-31 15:37 - 2017-07-31 15:37 - 000000020 ___SH C:\Users\Me\ntuser.ini
2017-07-31 15:37 - 2017-07-31 15:37 - 000000000 ____D C:\Users\Me\AppData\Local\VirtualStore
2017-07-31 15:37 - 2011-04-12 11:28 - 000000000 ____D C:\Users\Me\AppData\Roaming\Media Center Programs
==================== One Month Modified files and folders ========
(If an entry is included in the fixlist, the file/folder will be moved.)
2017-08-10 22:06 - 2009-07-14 08:13 - 000785366 _____ C:\Windows\system32\PerfStringBackup.INI
2017-08-10 22:06 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\inf
2017-08-10 22:01 - 2009-07-14 08:08 - 000000006 ____H C:\Windows\Tasks\SA.DAT
2017-08-10 21:29 - 2009-07-14 07:45 - 000028928 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-1.C7483456-A289-439d-8115-601632D005A0
2017-08-10 21:29 - 2009-07-14 07:45 - 000028928 ____H C:\Windows\system32\7B296FB0-376B-497e-B012-9C450E1B7327-5P-0.C7483456-A289-439d-8115-601632D005A0
2017-08-10 16:05 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\rescache
2017-08-10 09:05 - 2009-07-14 06:20 - 000000000 ____D C:\Program Files\Common Files\Microsoft Shared
2017-08-09 19:47 - 2009-07-14 07:45 - 000429304 _____ C:\Windows\system32\FNTCACHE.DAT
2017-08-09 18:26 - 2011-04-12 11:28 - 000000000 ____D C:\Windows\ShellNew
2017-08-09 18:24 - 2009-07-14 05:34 - 000000387 _____ C:\Windows\win.ini
2017-08-08 10:10 - 2009-07-14 08:32 - 000000000 ____D C:\Windows\system32\FxsTmp
2017-08-06 15:28 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\system32\NDF
2017-08-05 22:44 - 2009-07-14 06:20 - 000000000 __RHD C:\Users\Public\Libraries
2017-08-03 06:02 - 2009-07-14 08:09 - 000000000 ____D C:\Windows\System32\Tasks\WPD
2017-08-02 23:11 - 2009-07-14 07:57 - 000001547 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Media Player.lnk
2017-08-02 14:26 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\security
2017-08-02 03:08 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\PolicyDefinitions
2017-08-01 03:44 - 2009-07-14 08:32 - 000000000 ____D C:\Program Files\Windows Defender
2017-08-01 03:44 - 2009-07-14 08:32 - 000000000 ____D C:\Program Files\DVD Maker
2017-08-01 03:44 - 2009-07-14 08:32 - 000000000 ____D C:\Program Files (x86)\Windows Defender
2017-08-01 03:44 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\SysWOW64\migwiz
2017-08-01 03:44 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\SysWOW64\Dism
2017-08-01 03:44 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\system32\migwiz
2017-08-01 03:44 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\system32\Dism
2017-08-01 03:44 - 2009-07-14 06:20 - 000000000 ____D C:\Program Files\Common Files\System
2017-08-01 03:43 - 2011-04-12 11:28 - 000000000 ____D C:\Program Files\Windows Journal
2017-08-01 02:28 - 2009-07-14 08:32 - 000028672 _____ C:\Windows\system32\config\BCD-Template
2017-08-01 01:30 - 2009-07-14 08:32 - 000000000 ___RD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games
2017-08-01 01:30 - 2009-07-14 06:20 - 000000000 ____D C:\Windows\system32\sysprep
==================== Files in the root of some directories =======
2017-08-02 22:46 - 2017-08-02 22:46 - 000000057 _____ () C:\ProgramData\Ament.ini
2017-07-31 15:44 - 2017-07-31 15:44 - 000000000 ____H () C:\ProgramData\DP45977C.lfl
Some files in TEMP:
2017-08-09 23:20 - 2017-08-09 23:20 - 000740416 _____ (Oracle Corporation) C:\Users\Me\AppData\Local\Temp\jre-8u144-windows-au.exe
2017-08-10 07:55 - 2017-08-10 07:55 - 014456872 _____ (Microsoft Corporation) C:\Users\Me\AppData\Local\Temp\vc_redist.x86.exe
==================== Bamital & volsnap ======================
(There is no automatic fix for files that do not pass verification.)
C:\Windows\system32\winlogon.exe => File is digitally signed
C:\Windows\system32\wininit.exe => File is digitally signed
C:\Windows\SysWOW64\wininit.exe => File is digitally signed
C:\Windows\explorer.exe => File is digitally signed
C:\Windows\SysWOW64\explorer.exe => File is digitally signed
C:\Windows\system32\svchost.exe => File is digitally signed
C:\Windows\SysWOW64\svchost.exe => File is digitally signed
C:\Windows\system32\services.exe => File is digitally signed
C:\Windows\system32\User32.dll => File is digitally signed
C:\Windows\SysWOW64\User32.dll => File is digitally signed
C:\Windows\system32\userinit.exe => File is digitally signed
C:\Windows\SysWOW64\userinit.exe => File is digitally signed
C:\Windows\system32\rpcss.dll => File is digitally signed
C:\Windows\system32\dnsapi.dll => File is digitally signed
C:\Windows\SysWOW64\dnsapi.dll => File is digitally signed
C:\Windows\system32\Drivers\volsnap.sys => File is digitally signed
LastRegBack: 2017-08-01 04:20
==================== End of FRST.txt ============================
Moses
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 09-08-2017
Ran by Me (10-08-2017 22:09:39)
Running from C:\Users\Me\Desktop\Repair
Windows 7 Home Premium Service Pack 1 (X64) (2017-07-31 12:37:33)
Boot Mode: Normal
Administrator (S-1-5-21-2293580261-1291186321-2028678180-500 - Administrator - Disabled)
Guest (S-1-5-21-2293580261-1291186321-2028678180-501 - Limited - Disabled)
Me (S-1-5-21-2293580261-1291186321-2028678180-1000 - Administrator - Enabled) => C:\Users\Me
AV: Avast Antivirus (Enabled - Up to date) {8EA8924E-BC81-DC44-8BB0-8BAE75D86EBF}
AV: Malwarebytes (Enabled - Up to date) {23007AD3-69FE-687C-2629-D584AFFAF72B}
AS: Malwarebytes (Enabled - Up to date) {98619B37-4FC4-67F2-1C99-EEF6D47DBD96}
AS: Windows Defender (Disabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
AS: Avast Antivirus (Enabled - Up to date) {35C973AA-9ABB-D3CA-B100-B0DC0E5F2402}
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 17.009.20058 - Adobe Systems Incorporated)
Adobe Flash Player 26 ActiveX (HKLM-x32\...\Adobe Flash Player ActiveX) (Version: 26.0.0.151 - Adobe Systems Incorporated)
Ashampoo Burning Studio FREE v.1.14.5 (HKLM-x32\...\{91B33C97-91F8-FFB3-581B-BC952C901685}_is1) (Version: 1.14.5 - Ashampoo GmbH & Co. KG)
Avast Free Antivirus (HKLM-x32\...\Avast Antivirus) (Version: 17.5.2303 - AVAST Software)
COMODO BackUp (HKLM\...\{B79E9FF2-D932-4FD5-BCAF-4DE6F2FBE521}) (Version: 4.4.1.23 - COMODO)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
E-Z Contact Book version 4.4.0.10 (HKLM-x32\...\{1B758D8A-B999-45AD-B7AA-14D10FDC19D2}_is1) (Version: 4.4.0.10 - Dmitri Karshakevich)
GeekBuddy (HKLM-x32\...\{DF554A50-ABE5-4091-A1E9-2D2E7E5254B7}) (Version: 4.18.122 - Comodo Security Solutions Inc)
Google Chrome (HKLM-x32\...\{A7A76FD6-91B5-3C7F-B37D-DFDA03F5FBAE}) (Version: 60.0.3112.90 - Google, Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.21.115 - Google Inc.) Hidden
HP Officejet Pro 6830 Basic Device Software (HKLM\...\{98040AB6-D667-409C-81E7-DB65836B3EE0}) (Version: 33.1.73.49987 - Hewlett-Packard Co.)
HP Officejet Pro 6830 Help (HKLM-x32\...\{28693307-6F99-4B5D-9FA3-4D9132DDA716}) (Version: 34.0.0 - Hewlett Packard)
HP Update (HKLM-x32\...\{912D30CF-F39E-4B31-AD9A-123C6B794EE2}) (Version: 5.005.002.002 - Hewlett-Packard)
I.R.I.S. OCR (HKLM-x32\...\{CA6BCA2F-EDEB-408F-850B-31404BE16A61}) (Version: 12.3.4.0 - HP)
Intel(R) Network Connections Drivers (HKLM\...\PROSet) (Version: 20.4 - Intel)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 9.17.10.4229 - Intel Corporation)
Junk Mail filter update (HKLM-x32\...\{1F6AB0E7-8CDD-4B93-8A23-AA9EB2FEFCE4}) (Version: 15.4.3502.0922 - Microsoft Corporation) Hidden
K-Lite Codec Pack 13.3.3 Full (HKLM-x32\...\KLiteCodecPack_is1) (Version: 13.3.3 - KLCP)
Malwarebytes version 3.1.2.1733 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.1.2.1733 - Malwarebytes)
McAfee WebAdvisor (HKLM-x32\...\{35ED3F83-4BDC-4c44-8EC6-6A8301C7413A}) (Version: 4.0.149 - McAfee, Inc.)
Mesh Runtime (HKLM-x32\...\{8C6D6116-B724-4810-8F2D-D047E6B7D68E}) (Version: 15.4.5722.2 - Microsoft Corporation) Hidden
Messenger Companion (HKLM-x32\...\{50816F92-1652-4A7C-B9BC-48F682742C4B}) (Version: 15.4.3502.0922 - Microsoft Corporation) Hidden
Microsoft .NET Framework 4.5.1 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.5.50938 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
Product Improvement Study for HP Officejet Pro 6830 (HKLM\...\{96ABEAD3-67AE-4BF7-8A16-F745352049B3}) (Version: 33.1.73.49987 - Hewlett-Packard Co.)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7680 - Realtek Semiconductor Corp.)
Skype™ 7.39 (HKLM-x32\...\{3B7E914A-93D5-4A29-92BB-AF8C3F66C431}) (Version: 7.39.102 - Skype Technologies S.A.)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 15.4.3538.0513 - Microsoft Corporation)
Windows Live Mesh ActiveX Control for Remote Connections (HKLM-x32\...\{2902F983-B4C1-44BA-B85D-5C6D52E2C441}) (Version: 15.4.5722.2 - Microsoft Corporation)
WinRAR 5.00 beta 8 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.00.8 - win.rar GmbH)
==================== Custom CLSID (Whitelisted): ==========================
ShellIconOverlayIdentifiers: [00asw] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShA64.dll [2017-08-02] (AVAST Software)
ShellIconOverlayIdentifiers: [COSDriveIconOverlay] -> {5FDACB62-6B7B-4116-9403-C5E0D3852A57} => C:\Program Files\COMODO\COMMON\ShellExtension.dll [2014-10-07] (C-O-M-O-D-O)
ShellIconOverlayIdentifiers: [COSSyncItemInSyncIconOverlay] -> {68F287EF-DA6D-4595-AF52-90FF6CE52AFE} => C:\Program Files\COMODO\COMMON\ShellExtension.dll [2014-10-07] (C-O-M-O-D-O)
ShellIconOverlayIdentifiers: [COSSyncItemModifiedIconOverlay] -> {AE67D273-7253-4236-B55E-D40055B305D6} => C:\Program Files\COMODO\COMMON\ShellExtension.dll [2014-10-07] (C-O-M-O-D-O)
ShellIconOverlayIdentifiers: [COSSyncItemNewIconOverlay] -> {022F23E9-DA0F-4A86-A728-CAF6150C0B63} => C:\Program Files\COMODO\COMMON\ShellExtension.dll [2014-10-07] (C-O-M-O-D-O)
ShellIconOverlayIdentifiers: [COSSyncItemUnsynchronizedIconOverlay] -> {4D7EE7CF-E7A1-45FE-8F80-3A37574918D7} => C:\Program Files\COMODO\COMMON\ShellExtension.dll [2014-10-07] (C-O-M-O-D-O)
ContextMenuHandlers1: [avast] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShA64.dll [2017-08-02] (AVAST Software)
ContextMenuHandlers1: [COMODOBackupUtility] -> {FA66022E-2FE4-4A29-916C-84A0D8173FBB} => C:\Program Files\COMODO\COMMON\ShellExtension.dll [2014-10-07] (C-O-M-O-D-O)
ContextMenuHandlers1: [WinRAR] -> {B41DB860-64E4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext.dll [2013-08-04] (Alexander Roshal)
ContextMenuHandlers1-x32: [WinRAR32] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext32.dll [2013-08-04] (Alexander Roshal)
ContextMenuHandlers2: [COMODOBackupUtility] -> {FA66022E-2FE4-4A29-916C-84A0D8173FBB} => C:\Program Files\COMODO\COMMON\ShellExtension.dll [2014-10-07] (C-O-M-O-D-O)
ContextMenuHandlers3: [00asw] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShA64.dll [2017-08-02] (AVAST Software)
ContextMenuHandlers3: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2017-05-09] (Malwarebytes)
ContextMenuHandlers4: [COMODOBackupUtility] -> {FA66022E-2FE4-4A29-916C-84A0D8173FBB} => C:\Program Files\COMODO\COMMON\ShellExtension.dll [2014-10-07] (C-O-M-O-D-O)
ContextMenuHandlers5: [igfxcui] -> {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => C:\Windows\system32\igfxpph.dll [2015-05-26] (Intel Corporation)
ContextMenuHandlers6: [avast] -> {472083B0-C522-11CF-8763-00608CC02F24} => C:\Program Files\AVAST Software\Avast\ashShA64.dll [2017-08-02] (AVAST Software)
ContextMenuHandlers6: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2017-05-09] (Malwarebytes)
ContextMenuHandlers6: [WinRAR] -> {B41DB860-64E4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext.dll [2013-08-04] (Alexander Roshal)
ContextMenuHandlers6-x32: [WinRAR32] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext32.dll [2013-08-04] (Alexander Roshal)
==================== Scheduled Tasks (Whitelisted) =============
Task: {00A5CB1B-6E8C-4063-AB19-50085DBE3783} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2017-08-02] (Google Inc.)
Task: {0668A67A-807F-40E3-897C-5E628C9CAD9F} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2017-08-02] (Google Inc.)
Task: {13C170A4-1489-4112-AD5F-9AD22EFD06F4} - System32\Tasks\Adobe Acrobat Update Task => C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [2017-07-19] (Adobe Systems Incorporated)
Task: {1CE3E195-CF64-4C94-922B-096108302EBA} - System32\Tasks\HPCustParticipation HP Officejet Pro 6830 => C:\Program Files\HP\HP Officejet Pro 6830\Bin\HPCustPartic.exe [2014-07-18] (Hewlett-Packard Development Company, LP)
Task: {2EBA72C6-84B7-42C3-A5DB-AB5D2E8B8CFC} - System32\Tasks\Adobe Flash Player Updater => C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2017-08-09] (Adobe Systems Incorporated)
Task: {7DA3353F-F707-4FDB-B9AC-8D25A57669AA} - System32\Tasks\{A370589A-2F81-4005-A949-A5EFD4F307A0} => C:\Windows\system32\pcalua.exe -a "C:\Users\Me\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\GBF4FI20\wlsetup-web.exe" -d C:\Users\Me\Desktop
Task: {C5A241AE-DA09-40B9-B2B5-10352836E66A} - System32\Tasks\klcp_update => C:\Program Files (x86)\K-Lite Codec Pack\Tools\CodecTweakTool.exe [2017-07-07] ()
Task: {E320DE47-8530-413B-9451-6CE3D796B314} - System32\Tasks\Avast Emergency Update => C:\Program Files\AVAST Software\Avast\AvEmUpdate.exe [2017-08-02] (AVAST Software)
(The entries could be listed to be restored or removed.)
Shortcut: C:\Users\Me\Favorites newest\Favorites\NCH Software Download Site.lnk -> hxxp://www.nch.com.au/index.htm
Shortcut: C:\Users\Me\Favorites\Links\Favorites\NCH Software Download Site.lnk -> hxxp://www.nch.com.au/index.htm
==================== Loaded Modules (Whitelisted) ==============
2017-08-03 10:38 - 2014-09-03 14:53 - 001508032 _____ () C:\Program Files\COMODO\COMMON\LIBEAY32.dll
2017-08-03 10:38 - 2014-09-03 14:53 - 000338112 _____ () C:\Program Files\COMODO\COMMON\SSLEAY32.dll
2017-07-31 15:46 - 2015-05-26 20:50 - 000094208 _____ () C:\Windows\System32\IccLibDll_x64.dll
2017-08-08 08:29 - 2017-06-27 12:06 - 002260432 _____ () C:\PROGRAM FILES\MALWAREBYTES\ANTI-MALWARE\MwacLib.dll
2017-08-02 11:07 - 2017-08-02 11:07 - 000162032 _____ () c:\Program Files\AVAST Software\Avast\x64\vaarclient.dll
2017-08-02 11:08 - 2017-08-02 11:08 - 000831664 _____ () C:\Program Files\AVAST Software\Avast\x64\ffl2.dll
2017-08-02 11:08 - 2017-08-02 11:08 - 000276808 _____ () c:\Program Files\AVAST Software\Avast\x64\StreamBack.dll
2017-08-02 11:08 - 2017-08-02 11:08 - 000170224 _____ () C:\Program Files\AVAST Software\Avast\JsonRpcServer.dll
2017-08-02 11:08 - 2017-08-02 11:08 - 000192664 _____ () C:\Program Files\AVAST Software\Avast\event_routing_rpc.dll
2017-08-02 11:08 - 2017-08-02 11:08 - 000224256 _____ () C:\Program Files\AVAST Software\Avast\tasks_core.dll
2017-08-10 13:58 - 2017-08-10 13:58 - 005894008 _____ () C:\Program Files\AVAST Software\Avast\defs\17081000\algo.dll
2017-08-02 11:08 - 2017-08-02 11:08 - 000689272 _____ () C:\Program Files\AVAST Software\Avast\ffl2.dll
2017-07-24 15:57 - 2017-07-24 15:57 - 001991640 ____R () C:\Program Files (x86)\Skype\Phone\skypert.dll
2017-08-02 11:08 - 2017-08-02 11:08 - 001065936 _____ () C:\Program Files\AVAST Software\Avast\AvChrome.dll
2017-08-02 11:08 - 2017-08-02 11:08 - 067109376 _____ () C:\Program Files\AVAST Software\Avast\libcef.dll
==================== Alternate Data Streams (Whitelisted) =========
(If an entry is included in the fixlist, only the ADS will be removed.)
==================== Safe Mode (Whitelisted) ===================
(If an entry is included in the fixlist, it will be removed from the registry. The "AlternateShell" will be restored.)
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
==================== Association (Whitelisted) ===============
(If an entry is included in the fixlist, the registry item will be restored to default or removed.)
==================== Internet Explorer trusted/restricted ===============
(If an entry is included in the fixlist, it will be removed from the registry.)
IE trusted site: HKU\.DEFAULT\...\localhost -> localhost
IE trusted site: HKU\.DEFAULT\...\webcompanion.com -> hxxp://webcompanion.com
IE trusted site: HKU\S-1-5-21-2293580261-1291186321-2028678180-1000\...\localhost -> localhost
==================== Hosts content: ===============================
2009-07-14 05:34 - 2009-06-11 00:00 - 000000824 _____ C:\Windows\system32\Drivers\etc\hosts
==================== Other Areas ============================
HKU\S-1-5-21-2293580261-1291186321-2028678180-1000\Control Panel\Desktop\\Wallpaper -> C:\Users\Me\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg
DNS Servers: 10.100.102.1
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System => (ConsentPromptBehaviorAdmin: 0) (ConsentPromptBehaviorUser: 3) (EnableLUA: 0)
Windows Firewall is enabled.
==================== FirewallRules (Whitelisted) ===============
FirewallRules: [{A8293969-6983-4743-90BC-F32754D1C5EE}] => (Allow) C:\Program Files (x86)\Skype\Phone\Skype.exe
FirewallRules: [{FD9AA708-B483-4441-92DC-D3C7B66A2239}] => (Allow) C:\Program Files (x86)\Windows Live\Contacts\wlcomm.exe
FirewallRules: [{76D88DC1-0818-4C8A-AAD6-C3197785DDB7}] => (Allow) LPort=2869
FirewallRules: [{D2DFE459-1A60-4770-B9F8-3E94587F5E4C}] => (Allow) LPort=1900
FirewallRules: [{25616596-68B8-4B46-A91D-9AEE5B6F2563}] => (Allow) C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe
FirewallRules: [{6AC80DBE-13FA-4FF6-92CA-49F4007D3686}] => (Allow) C:\Program Files (x86)\Windows Live\Mesh\MOE.exe
FirewallRules: [{451D4929-A555-4CF5-9FEC-3967A6FA8BD6}] => (Allow) C:\Program Files\HP\HP Officejet Pro 6830\bin\FaxApplications.exe
FirewallRules: [{9FE8B913-197E-47EC-819D-752C8DD3C4A1}] => (Allow) C:\Program Files\HP\HP Officejet Pro 6830\bin\DigitalWizards.exe
FirewallRules: [{EADEEC8D-592C-4A75-8B3E-E6CD3E74B438}] => (Allow) C:\Program Files\HP\HP Officejet Pro 6830\bin\SendAFax.exe
FirewallRules: [{6FB7AB05-A4EA-4F07-B479-610B884B9EA3}] => (Allow) C:\Program Files\HP\HP Officejet Pro 6830\Bin\DeviceSetup.exe
FirewallRules: [{41BA4218-E108-4AB6-A78D-4D3C9D33AE65}] => (Allow) LPort=5357
FirewallRules: [{A7C1A9DD-358A-42C3-8E71-A6EA31558F4E}] => (Allow) C:\Program Files\HP\HP Officejet Pro 6830\Bin\HPNetworkCommunicatorCom.exe
FirewallRules: [{0887FBD3-129E-45B5-A0C3-87F1F46C72EA}] => (Allow) C:\Users\Public\Desktop\AnyDesk.exe
FirewallRules: [{625AB7A0-7191-4770-8DD2-E24899338B8B}] => (Allow) C:\Users\Public\Desktop\AnyDesk.exe
FirewallRules: [{7FE9B846-3A01-4F09-B34C-81568946C831}] => (Allow) C:\Users\Public\Desktop\AnyDesk.exe
FirewallRules: [{7879008A-E20A-4019-8360-61ED79F6F706}] => (Allow) C:\Users\Public\Desktop\AnyDesk.exe
FirewallRules: [{EC1747BC-90B5-4208-B585-79FC26206391}] => (Allow) C:\Users\Public\Desktop\AnyDesk.exe
FirewallRules: [{74DBAF03-7436-45D6-87BA-BF41A3FC2D8C}] => (Allow) C:\Users\Public\Desktop\AnyDesk.exe
FirewallRules: [{CD0E990E-2907-4603-A2F9-1D37E159CE85}] => (Allow) C:\Program Files\COMODO\cCloud\cCloud.exe
FirewallRules: [{3838C265-CBEB-498F-97CF-B95D9EEC69BF}] => (Allow) C:\Program Files\COMODO\cCloud\cCloud.exe
FirewallRules: [{CE6DDBE4-FCB6-4A62-B23E-855E4BB42BE6}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
08-08-2017 07:58:41 Removed Foxit PhantomPDF
08-08-2017 12:37:52 Installed DirectX
08-08-2017 12:38:40 Installed DirectX
09-08-2017 10:13:21 Windows Update
09-08-2017 15:57:49 Removed HP Officejet Pro 6830 Basic Device Software
09-08-2017 18:17:42 Removed HP Officejet Pro 6830 Basic Device Software
09-08-2017 18:19:18 Removed HP Officejet Pro 6830 Basic Device Software
09-08-2017 18:20:57 Removed Microsoft Office Professional Plus 2013
09-08-2017 18:21:12 PROPLUS
09-08-2017 19:31:01 Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215
09-08-2017 19:32:12 Removed Microsoft Visual C++ 2010  x86 Redistributable - 10.0.40219
09-08-2017 19:37:41 Removed Microsoft Visual C++ 2010  x64 Redistributable - 10.0.40219
09-08-2017 19:38:18 Removed Microsoft SQL Server 2005 Compact Edition [ENU]
09-08-2017 19:43:03 Windows Update
09-08-2017 23:09:45 Restore Point Created by FRST
10-08-2017 09:01:24 Removed Java 8 Update 144 (64-bit)
10-08-2017 09:04:08 Removed Microsoft Visual C++ 2010  x64 Redistributable - 10.0.40219
10-08-2017 09:07:26 Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215
10-08-2017 09:08:51 Removed Microsoft Visual C++ 2010  x86 Redistributable - 10.0.40219
==================== Faulty Device Manager Devices =============
==================== Event log errors: =========================
Application errors:
Error: (08/10/2017 10:02:30 PM) (Source: WinMgmt) (EventID: 10) (User: )
Description: Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
Error: (08/10/2017 09:42:11 PM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (08/10/2017 09:22:02 PM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (08/10/2017 09:04:29 PM) (Source: WinMgmt) (EventID: 10) (User: )
Error: (08/10/2017 04:00:21 PM) (Source: SideBySide) (EventID: 9) (User: )
Description: Activation context generation failed for "c:\program files (x86)\spybot - search & destroy 2\Tools.dll".Error in manifest or policy file "c:\program files (x86)\spybot - search & destroy 2\Tools.dll" on line 2.
The manifest file root element must be assembly.
Error: (08/10/2017 04:00:20 PM) (Source: SideBySide) (EventID: 9) (User: )
Description: Activation context generation failed for "c:\program files (x86)\spybot - search & destroy 2\SDWinLogon.dll".Error in manifest or policy file "c:\program files (x86)\spybot - search & destroy 2\SDWinLogon.dll" on line 2.
Error: (08/10/2017 04:00:19 PM) (Source: SideBySide) (EventID: 9) (User: )
Description: Activation context generation failed for "c:\program files (x86)\spybot - search & destroy 2\SDTasks.dll".Error in manifest or policy file "c:\program files (x86)\spybot - search & destroy 2\SDTasks.dll" on line 2.
Error: (08/10/2017 04:00:18 PM) (Source: SideBySide) (EventID: 9) (User: )
Description: Activation context generation failed for "c:\program files (x86)\spybot - search & destroy 2\SDResources.dll".Error in manifest or policy file "c:\program files (x86)\spybot - search & destroy 2\SDResources.dll" on line 2.
Error: (08/10/2017 04:00:16 PM) (Source: SideBySide) (EventID: 9) (User: )
Description: Activation context generation failed for "c:\program files (x86)\spybot - search & destroy 2\SDLists.dll".Error in manifest or policy file "c:\program files (x86)\spybot - search & destroy 2\SDLists.dll" on line 2.
Description: Activation context generation failed for "c:\program files (x86)\spybot - search & destroy 2\SDLicense.dll".Error in manifest or policy file "c:\program files (x86)\spybot - search & destroy 2\SDLicense.dll" on line 2.
System errors:
Error: (08/10/2017 09:57:51 PM) (Source: Service Control Manager) (EventID: 7043) (User: )
Description: The Diagnostics Tracking Service service did not shut down properly after receiving a preshutdown control.
Error: (08/10/2017 09:57:18 PM) (Source: Service Control Manager) (EventID: 7043) (User: )
Description: The Group Policy Client service did not shut down properly after receiving a preshutdown control.
Error: (08/10/2017 09:20:09 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The Adobe Acrobat Update Service service terminated unexpectedly.  It has done this 1 time(s).
Description: The COMODO BackUp Service service terminated unexpectedly.  It has done this 1 time(s).
Description: The COMODO Online Storage Service service terminated unexpectedly.  It has done this 1 time(s).
Error: (08/10/2017 09:20:09 PM) (Source: Service Control Manager) (EventID: 7031) (User: )
Description: The Windows Live ID Sign-in Assistant service terminated unexpectedly.  It has done this 1 time(s).  The following corrective action will be taken in 10000 milliseconds: Restart the service.
Error: (08/10/2017 11:08:36 AM) (Source: Schannel) (EventID: 4119) (User: NT AUTHORITY)
Description: The following fatal alert was received: 20.
Error: (08/10/2017 12:16:27 AM) (Source: DCOM) (EventID: 10010) (User: )
Description: The server {995C996E-D918-4A8C-A302-45719A6F4EA7} did not register with DCOM within the required timeout.
Error: (08/10/2017 12:16:14 AM) (Source: DCOM) (EventID: 10010) (User: )
Description: The server {F9717507-6651-4EDB-BFF7-AE615179BCCF} did not register with DCOM within the required timeout.
Description: The server {3FCB7074-EC9E-4AAF-9BE3-C0E356942366} did not register with DCOM within the required timeout.
Processor: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
Percentage of memory in use: 60%
Total physical RAM: 1948.42 MB
Available physical RAM: 775.35 MB
Total Virtual: 3896.84 MB
Available Virtual: 2359.02 MB
Drive c: () (Fixed) (Total:465.66 GB) (Free:185.16 GB) NTFS
==================== MBR & Partition Table ==================
Disk: 0 (MBR Code: Windows 7 or 8) (Size: 465.8 GB) (Disk ID: DC809A13)
Partition 1: (Active) - (Size=100 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=465.7 GB) - (Type=07 NTFS)
==================== End of Addition.txt ============================
Hi, Moses.
Note:  Just in case you are subscribed to your topic and received an email notification, I've changed the instructions.  Before I provide you with a new script for removing files with FRST, let's check out a file.
Click here > Virus Total, to submit the file by following these instructions below:
  • Click on Choose File to open the File Upload window on your computer.
  • Go to C:\Windows and find the file named È÷±
  • Click on it, then click Open. This will place the file in the Search Engine at Virus Total.
  • Click on Scan it!.
  • If you receive File already analyzed, click the reanalyze button.
  • When the analysis has completed, click on View last analysis at the bottom of the page.
  • Copy and paste the url from that page into your next post for me to access.
As to safe places for downloading freeware, so many sites come with unwanted extras, you are best off going to the developer site rather than using one of the download sites.  As The Windows Club article, Safe software download sites: Beware of deceptive download links points out, CNET, BrotherSoft, Softonic, FreewareFiles, Tucows, Sourceforge and FileHippo use installers that try and first push third-party offers, bundleware and potentially unwanted programs on to your computer.  If you don't know where the developer site is, I suggest MajorGeeks.  A "custom" install of software is recommended.  It is also advised to continue watching each screen while installing software.
