Microsoft Edge Preview Builds
Started by Corrine, April 08, 2019, 09:49:13 PM
Dev channel update to 106.0.1363.0 is now live!
Added
  • Added a tooltip display on thumbs up/down so it is read aloud by Narrator
  • Updated the policy for Efficiency mode support
Improved reliability:
  • Fixed an issue where Web Select doesn't copy some images
  • Fixed an issue with Bluetooth focus on Duo devices
Changed behavior:  
  • Fixed orientation issue with printing
  • Fixed an issue where certain keyboard keys like the arrow keys do not work in text fields
  • Fixed missing smart explore icon on certain videos
Dev channel update to 107.0.1387.2 is now live!
Added Features:
  • Added the RestoreOnStartupUserURLsEnabled policy 
  • Improved the UI for trending search on mobile 
Changed behavior:  
  • Enabled new SmartScreen client on Mac 
  • Fixed an issue where the "File is not selected" text was truncated in Japanese when text scaling was applied 
  • Fixed an issue where AAD users could not sign into the browser
  • Fixed crash on password imports from the Settings page 
Dev channel update to 108.0.1438.1 is now live!
Added Features:
  • Added a management policy to disable Web Select
  • Added Games to
  • Added a management policy to control Workspaces
  • Added an experimental API to WebView2 for creating Shared Memory buffers with JavaScript objects
  • Improved Read Aloud UX on Android
  • Improved Read Aloud highlighting in iOS
  • Fixed an issue on HoloLens where restarting the device while Edge was still open caused Edge to be unable to navigate.
  • Fixed an issue where the edge://management page would not load
  • Fixed Find on Page tool that was showing results from a different tab than the one that was on
  • Fixed an issue where the Shopping prompt repeatedly appeared on the same page
  • Improved iOS writing assistant
  • Fixed an issue where Setting DownloadRestrictions group policy to BlockPotentiallyDangerousDownloads blocks all RDP file downloads
  • Fixed issue where none of the buttons on the Send Feedback dialog worked
  • Fixed issue for 8K video option that was not available on YouTube videos
  • Fixed scrollbar issue that was getting thin when scrolling
  • Fixed the Super Resolution was crashing the browser
Changed behavior: 
  • Fixed a crash when using Edge Bar
  • Fixed a crash when signing up for Microsoft Rewards
  • Fixed an issue where audio is sometimes distorted when using Efficiency Mode
  • Fixed an issue on mobile when Read Aloud options sometimes do not work
  • Fixed a crash when checking out using the Shopping tools and features
  • Fixed a crash when creating a new browser profile
  • Fixed an issue where passwords fail to be imported from a CSV file
  • Fixed an issue on mobile where Guided Switch doesn't properly redirect to the expected page if the page requires a sign-in
  • Fixed a crash when the Translate popup appears
  • Fixed a crash when navigating to edge://support/version
  • Fixed a crash when using the Command Palette in an InPrivate window
  • Fixed a crash when showing the address bar dropdown
  • Fixed the issue where placing the cursor on the far right of the screen and then using the scroll wheel doesn't scroll the page
  • Fixed an issue where Netflix playback fails with error D7355-1204
  • Fixed an issue where Visual Search sometimes doesn't open when it should
  • Obsoleted the Built-in Certificate Viewer policy
  • Fixed issue where only occurred when using the built-in duplicator tool
  • Fixed issue when browser was crashing when closing, and receiving a prompt to restore tabs unexpectedly
  • Fixed Issue where pinning wizard was not loading in Browser
  • Obsoleting the NewSmartScreenEnabled policy
  • Fixed crash of happened when opening the sidebar
  • Fixed Error with certificate not showing in the certificate picker if they had a long name, so they will show now
  • Fixed print preview dialog that was crashing (going blank) for certain PDFs
  • Fixed iOS password details so the view does not show an empty page
  • Fixed Android issue with Read Aloud would no longer work if you lost and re-connected to the network while it was reading
  • Fixed crash when autofilling passwords
  • Fixed add new folder and back text trimmed when bold text for iOS
  • Fixed bugs WebView2 apps would throw errors if their paths used Unicode characters
  • Enable NewTabPageAppLauncherEnabled policy
  • Fixed bugs for sites that certain sites like YouTube wouldn't load
  • Fixed opening a PWA would crash the browser
  • Fixed crash on launch when certain applications were installed
  • Changed behavior for Restore session when clicking on recently closed suggestion
  • Fixed a bug in WebView apps where certain dialogs like the File picker aren't appearing when the app is running with admin privileges
  • Fixed an issue with WebView apps where they fail to load if the path contains certain characters
  • Fixed Special handling for "Save as PDF" is done to print with respect to the selected percentage and not any other defaults
  • Fixed iOS issue when getting stuck in a sign-in loop when trying to sign into the browser
  • Fixed iOS issues when there was a crash on launch
  • Fixed hide transition when leaving scrollable area
  • Fixed Android Crash when using accessibility features
Dev Channel update to 109.0.1481.0 is live
Also see a new video about What's New in DevTools 107 and the browser extensions at Browser Extension Survey.
Added features:  
  • Added Open this page in Compatibility view toggle in the Add a page prompt for Internet Explorer mode pages.
  • Added open in new tab button on the Sidebar games.
  • WebView2
    • Added support for File Upload in UWP (#1639)
    • Added IDL validator tool.
  • Fixed Autofill account selection menu not entering credentials.
  • Fixed the browser crash with Autofill dialog when navigating to the cross button using an arrow key or pressing Tab or Shift + Delete keys while the focus is on the cross button.
  • Fixed the browser crash while using Find in Page in the PDF viewer.
  • Fixed Sidebar issue that causes the browser to crash.
  • Fixed the browser crash when signing out your profile in Workspace.
  • Fixed a crash related to Sidebar.
  • Fixed the browser crash that's related to HDR video.
  • Fixed a crash when navigating to certain websites.
  • Fixed the browser crash issue when clicking on the performance button after closing Kids mode window.
  • Fixed the browser crash when entering or exiting Full screen.
  • Fixed a crash related to recommended update.
  • Fixed the browser crash related to Assistance Home button.
  • Fixed a crash when interacting with visual search results
  • iOS
    • Fixed browser crash when launching.
    • Fixed browser crash related to notifications.
  • Android
    • Fixed browser crash when enabling Bold text in Android setting.
  • macOS
    • Fixed the browser crash related to account sync.
  • WebView2
    • Fixed crash when clicking on the thumbnail view in the taskbar and moving focus to the WebView2 window.
    • Fixed visual hosting crashes with Windows 10 Anniversary Update and older.
Dev Channel update to 109.0.1495.2 is live
Added features:
  • Android:
    • Added an option to remove Edge Featured top site.
  • iOS:
    • Immersive New Tab Page is now available.
  • WebView2:
    • Added Crash Reporting API.
    • Added Experimental Profile deletion interface.
  • Enterprise: (Note: Updates to documentation and administrative templates may not have occurred yet)
    • Four new policies:
      • WebHidAllowAllDevicesForUrls - automatically grants access for any device to a list of origins specified by the policy.
      • WebHidAllowDevicesForUrls - grants access for devices with vendor and product IDs matching the patterns specified by the policy.
      • WebHidAllowDevicesWithHidUsagesForUrls - grants access for devices containing top-level collections with HID usages matching the patterns specified by the policy.
      • MicrosoftRootStoreEnabled - Enable use of Microsoft Root Store over platform roots.
    • Replaced ExemptDomainFileTypePairsFromFileTypeDownloadWarnings Policy with ExemptFileTypeDownloadWarnings.
  • Fixed the browser crash when clicking the Show Sidebar option while an InPrivate window is opened.
  • Fixed a browser crash related to Tracking Prevention.
  • Fixed browser crash related to downloading updates.
  • Fixed browser crash when a PDF print is triggered from the PDF toolbar or context menu.
  • Fixed a crash related to Recommended Version update.
  • macOS:
    • Fixed freezing issue when a tab is dragged from one window into another.
  • WebView2:
    • Fixed a crash issue related to suspend memory.
    • Fixed a hang issue related to ConnectToBrowserWindow call.
    • Fixed CoreWebView2EnvironmentOptions.IsCustomCrashReportingEnabled throws System.NullReferenceException (#2895).
    • Fixed WPF Browser .Net apps throw Win32 exception.
    • Fixed UWP crashes on start.
  • Android:
    • Fixed browser crash when enabling Bold text in the Android setting.
    • Fixed crash related to Autofill Dropdown.
  • iOS:
    • Fixed browser crash when tapping on Visit Copied Link from the address bar.
    • Fixed the browser crash when trying to upload a file with configured App Protection policy.
Changed behavior:
  • Fixed unable to open local files when an instance of the browser is already running.
  • Fixed Find on Page issue not scrolling to the first highlighted match term.
  • Fixed Edge bar Search bar not scaling correctly when it's on Search only layout.
  • We disabled Web App recovery due to crashes.
  • Fixed a Sidebar issue when removing a 3rd party site.
  • Fixed blank print preview when pressing CTRL + P in PDF viewer.
  • Fixed kiosk printing issue with multiple large PDF print jobs.
  • Fixed the Close Workspace Sharing Pane button not working.
  • Fixed Missing address issue when auto-filling credit card info.
  • Fixed the screen recording issue using the submit feedback dialog's Record my problem feature.
  • iOS:
    • Fixed influenced ads from being displayed on other sites when a website is added to the Ad blocker exception list.
    • Fixed Require FaceID or Passcode option not working with passcode.
    • Fixed Translator pop-up prompt not displaying.
    • Fixed autofill not responding.
    • Fixed Tracking prevention UI becoming full screen and unable to be closed.
    • Fixed the browser showing a New Tab Page after a crash with the HideRestoreDialogEnable policy enabled and configured RestoreOnStartupURL.
    • Policy sidebar_search.disable_search_in_sidebar will now just have 'Search the web for' and not 'Search in sidebar for' in the context menu when set.
    • Remove support for SetTimeoutWithout1MsClampEnabled policy.
Dev Channel update to 109.0.1518.5 is live
Added features:
  • Added Ctrl + Z (Undo), Ctrl + Y (Redo), and Ctrl + S (Save and close) to Screenshot editor in the Send feedback tool.
  • Added On-hover tool options for Smart Explore in the Appearance settings.
  • Added a Site permission request prompt in the Sidebar.
  • Added the option to set a Workspace name and color after clicking Move all tabs to a new workspace.
  • Added the option to set a Workspace name and color after creating a Workspace from a tab group.
  • WebView2:
    • Added keyboard shortcuts support to Winforms and WPF framework methods. (#1216 and #1703)
    • Added keyboard/mouse input filtering API. (#112)
    • Added Experimental LocaleRegion API.
    • Added Experimental Tracking Prevention API.
    • Add support for custom context menu in PDF View (#2607)
  • Enterprise:
    • New policies: (Note: Updates to documentation and administrative templates may not have occurred yet)
      • DefaultAutomaticDownloadsSetting - the default setting for automatic downloads, used by all sites except those specified in the allow/block list.
      • AutomaticDownloadsAllowedForUrls - enable automatic downloads just for the sites in this list.
      • AutomaticDownloadsBlockedForUrls - disable automatic downloads just for the sites in this list.
      • DefaultClipboardSetting - set the default setting for clipboard site permission.
      • ClipboardAllowedForUrls - set a list of URL patterns that specify sites that can use the clipboard site permission.
      • ClipboardBlockedForUrls - set a list of URL patterns that specify sites that can't use the clipboard site permission.
      • DisableSidebarSearch - disable the search in the sidebar.
  • Fixed browser crash related to printing.
  • Fixed browser crash issue with 3rd party Windows Shell namespace extension.
  • Fixed browser crash related to Sidebar awareness prompts.
  • Fixed browser crash when clicking on Hide from toolbar context menu.
  • Fixed two browser crashes issue when closing a Workspace.
  • Fixed browser crash when moving a tab to a Workspace after being idle.
  • Fixed browser crash related to hover card views in a Workspace.
  • Disabled the Rename, cut, and copy context menu from the Favorites Bar due to issues causing it to rename the Workspace instead or the browser to crash.
  • Fixed browser crash when signing out of AAD profile after performing a search query in the address bar.
  • Fixed browser crash related to Collections.
  • Android:
    • Fixed a crash issue when signing into the browser.
    • Fixed browser crash when accessing Password setting.
  • WebView2:
    • Fixed a crash related to audio utility process.
Changed behavior:
  • Fixed the extra blank space after clicking on Open in New Tab in the Sidebar's Game pane.
  • Fixed can't open Smart Explore settings from the image hover menu issue.
  • Fixed the missing nickname when adding or updating passwords issue.
  • Fixed can't view local PDF file issue.
  • Fixed invalid link issue while using Secure VPN.
  • Fixed Follow pane not showing the post after clicking on the See post button from the Following notification.
  • Basic writing assistance will now be used instead of Microsoft Editor when using an InPrivate window.
  • Fixed Workspaces missing from the Workspace list after update.
  • Fixed missing pinned tabs in a Workspace.
  • Fixed back action not getting reflected to other collaborators in a Workspace.
  • Removed Import Favorites on the Favorite bar in Workspaces.
  • Fixed Datalist not filling in the input field when selecting an option.
  • Fixed the favicon icon not loading when adding a site on Sidebar.
  • Fixed PWA shortcut opening a regular window instead of the PWA window after an update.
  • Follow Pinterest creators is now enabled by default.
  • Fixed the Website Typo Protection Proceed button not working correctly on certain typos.
  • Fixed an issue where collab overflow view may not be laid out in Workspaces.
  • Fixed Customize sidebar so it still can be open while the Sidebar is hidden.
  • Fixed showing an arrow instead of an X on some sites under Your Top Sites in the address bar drop-down menu.
  • Fixed PWA getting removed from the Start menu and Apps list issue.
  • Fixed an issue where tabs won't load or be all white due to being unable to launch new processes.
  • Fixed the incorrect last name displayed on the Basic info settings page.
  • Fixed Read Aloud never loading on certain PDFs.
  • Fixed high memory usage with long scanned PDFs.
  • macOS:
    • Fixed sign-in issue.
  • iOS:
    • Fixed restore session failed, the webpage is blank, and click refresh cannot load on iOS 14.x.
    • Fixed unable to view saved passwords.
    • Fixed the back button not working in the Passwords settings.
    • Fixed the Top Site icon size and display.
  • Android:
    • Fixed unable to open the favorite folder from favorites search results.
    • Fixed selected Voice item from getting unselected when swiping up or down in the Read Aloud voice option settings.
    • Fixed a stuck display of the first translated language name after tapping Undo and selecting another language in Immersive Reader.
    • Fixed open tabs from other devices not showing up.
    • Fixed the missing lock icon on the address bar.
  • WebView2:
    • Fixed ProcessCmdKey not triggering. (#1215)
    • Fixed WPF popup does not acquire keyboard focus. (#951 and #1134)
    • Fixed ToolStripMenuItem ShortcutKeys do not work inside the browser. (#1254)
    • We disabled Ctrl/Shift + Click, Ctrl/Shift + Enter, or Middle wheel click by link/button to open a new tab/window popup. (#2652)
  • Enterprise:
    • Quick sign-in no longer shows when the BrowserSignIn policy is set to 0.
    • Fixed SpellcheckEnabled policy not working correctly.
    • Fixed first top site not displaying when more than eight top sites are configured via policy on Android.
    • Fixed profile switching issue when visiting office.com.
    • Fixed the AAD sync setting on sign-in on iOS.
    • Fixed managed Top Sites policy not taking effect on Android.
Dev Channel update to 110.0.1543.0 is live
Added features:  
  • Added forcing dark mode on Sidebar content that doesn't support dark mode when dark mode is enabled.
  • Added the ability to create a share and redeem Workspaces share link in the browser.
  • Recently closed will now show who closed Workspace tabs with timestamps.
  • Mobile:
    • Collections will now show new content inspired by your collections and the web. Your existing collections won't be migrated, but that feature is coming soon, and you can switch back at any time.
  • Enterprise:
    • Adding * support to ExtensionInstallBlocklist policy to block all Sidebar apps.
      • Policy to control scope search feature.
    • WebView2:
      • Edge Remote Tools WDP plug-in is now able to connect to WebView2 UWP processes.
      • HTTPS is now supported for WDP remote debugging.
  • Fixed browser crash when adding or modifying a favorite.
  • Fixed browser crash when a Family Safety setting is updated in some scenarios.
  • Fixed browser crash when opening an InPrivate window.
  • Fixed opening the Search sidebar causes the browser to crash.
  • Fixed unable to launch the browser due to an AAD sync issue.
  • Fixed browser crash when opening Collections in an InPrivate window.
  • Fixed browser freeze issue when dragging a tab.
  • Fixed browser crash when moving a tab.
  • Fixed browser crash when clicking on a PDF form field.
  • macOS:
    • Fixed a hang issue when using Native/Web Accessibility.
  • iOS:
    • Fixed browser crash when switching accounts.
  • Android:
    • Fixed browser crash when signing out of an AAD account.
    • Fixed the AAD account info issue causing the browser to crash.
Changed behavior:
  • Starting with Chromium 110, Windows 7, 8 and 8.1 will no longer be supported (Sunsetting support for Windows 7 / 8/8.1 in early 2023 - Google Chrome Community)
  • Fixed download issue when using Save As.
  • Microsoftsecurityinsights.com is no longer blocked by Website typo protection.
  • Fixed cannot paste in rich text editor boxes on websites like Discord and other sites.
  • Fixed the address bar's follow creator icon to be consistent with the Follow Creator pane.
  • Fixed the media progress bar in Sidebar.
  • Fixed a collection load issue after switching to light or dark mode.
  • Fixed Add tab group to a new collection not working correctly.
  • Fixed Add all tabs to Collections where some tabs didn't get added.
  • Fixed Default profile for external links to use the correct profile.
  • Fixed Ctrl + Shift + T (Reopen closed tab) shortcut keys on Workspaces not restoring the tab correctly.
  • Fixed the settings page opening in a Workspace window when visiting the edge://settings page in an InPrivate window.
  • Fixed the browser not coming to the foreground when clicking on a Windows Spotlight link.
  • Fixed Tab Group sync not updating issue.
  • Improved dragging tabs to reduce accidental tab group creation.
  • Fixed websites ask for authentication to other users on Workspaces.
  • Fixed Workspace functionality not working.
  • Fixed the missing back button on Outlook Sidebar.
  • Fixed the extra blank space after clicking Open in New Tab on the Games pane in Sidebar.
  • Fixed the update issue where it stuck showing the "To finish update, restart Microsoft Edge" message on the About page.
  • Android:
    • Fixed an issue where if upgrade installation fails, the device will display 2 Microsoft Edge icons.
    • Fixed Newsfeed language stuck on English.
    • Fixed the missing bottom bar and the black screen with Recent in the Tab center.
    • Fixed Read aloud not opening.
    • Fixed website crashing when playing media.
    • Fixed Read aloud issues with Wikipedia pages.
  • iOS:
    • Fixed the newsfeed flash on launch.
    • Fixed nonresponding buttons in a popup menu.
    • Fixed gray/blank page when signing out of an MSA/AAD account and clearing all browsing data.
    • Removed the fix for restore session failed, the webpage is blank, and click refresh cannot load on iOS 14.x. due to issues.
    • Fixed stuck issue after selecting Keep data separate when signing in with another account.
    • Fixed Password monitor last scanned displaying the wrong time.
    • Fixed Password monitor not displaying scanned weak passwords.
  • Enterprise:
    • Removed the DisplayCapturePermissionsPolicyEnabled policy.
    • Fixed "500 Something went wrong" error message on Outlook sidebar.
    • Fixed sign in managed AAD account failed issue on Android.
    • Fixed the slow SSO sign-in and the fix account pop-up message iOS issues.
    • Fixed an iOS issue where the user is seeing the "Downloading is disabled by your organization" message when trying to navigate to a site while using Citrix micro VPN.
    • Fixed Citrix micro VPN won't disconnect when using the InPrivate tab on iOS.
    • Fixed the InPrivate switch issue and Search request not being blocked if the managed account is required when using the Search in Edge feature from Outlook on Android.
  • WebView2:
    • Fixed workers WRR events when only document filter is removed.
    • Fixed Custom schemes not working for post requests. (#1825)
    • Fixed PostWebMessage lost messages when the page is broken into DevTools debugger.
    • Fixed HTML5 drag and drop issue.
    • Fixed the missing x64 folder when bootstrapper installs x86 WebView2 on a 64-bit version of Windows. (#2794)
    • Removed Experimental Profile deletion interface.
    • Fixed UserMediaRequestType not working issue.
    • Fixed pressing enter on the Search bar not working issue on Xbox.
Dev Channel update to 110.0.1556.0 is live
Added features:
  • Sidebar pane can now be resized.
  • Sidebar now has mute/unmute menu.
  • Sidebar apps now support push notifications.
  • You can now access Sidebar search in PWAs.
  • WebView2:
    • Gamepad data fetch has been added to the gameinput API from the Microsoft GDK.
    • Added "Toggle Visibility" menu item under "View" tab in WinForms.
  • Enterprise:
    • New policy: (Note: Updates to documentation and administrative templates may not have occurred yet)
      • Added SearchInSidebarEnabled policy.
      • Added WorkspacesNavigationSettings policy.
  • Fixed a crash when playing the Surf game.
  • Fixed a browser crash when adding a 3rd party site to Sidebar.
  • Fixed browser crash related to Sidebar.
  • Fixed browser crash when activating the Mini Menu.
  • Fixed browser crash issue after some period of activity usage.
  • Fixed Restore tabs prompt at every launch due to a crash.
  • iOS:
    • Fixed browser crash related to tooltips window.
    • Fixed browser crash related to the reading list.
  • Android:
    • Fixed browser crash when sharing files.
    • Fixed Read Aloud crash issue when reading some pages.
    • Fixed browser crash related to the sign in to sync button.
  • Enterprise:
    • Fixed browser crash related to PasswordManagerBlocklist policy.
Changed behavior:
  • Fixed the New Tab button not displaying next to tabs.
  • Fixed opening Collection pane affecting the Collection on another browser/machine using the same account.
  • Fixed the overlay scrollbar not displaying correctly.
  • Fixed edge://inspect page not working.
  • Fixed Workspaces opening in a new browser when reconnecting.
  • We replaced local/offline NTP with an error message.
  • Fixed the Error bar not displaying with the login UI.
  • Fixed STATUS_BAD_IMPERSONATION_LEVEL error when running the browser in Windows sandbox.
  • Fixed the issue where the URLs registered with AppsForWebsites open in the browser instead of their UWP app.
  • Sidebar games will now preserve the game state when moving to a new tab.
  • Android :
    • Fixed Read Aloud pausing on Wikipedia pages.
  • iOS:
    • Fixed search box partially obscured in landscape mode.
    • Fixed can't scroll to the bottom on menus.
  • WebView2:
    • Fixed arrow keys not working in combo-box drop-down menus on Xbox.
    • Fixed the .NET out of memory issues due to WebResourceResponseReceived events reporting incorrect size.
  • Enterprise:
    • Removed the Audit option in the BrowserCodeIntegritySetting policy.
    • CertificateTransparencyEnforcementDisabledForCas policy now works with Android.
    • AAD sign in dialog only shows when no AAD account is signed in on Android.
    • Fixed page failed due to no client certificates prompt when visiting from an IE mode page.
Dev Channel update to 110.0.1587.1 is live
Note: From MSEdge Twitter Update
QuoteThe Dev channel rolled out version 110.0.1587.1 today, however we are aware of a "restart loop" the community is seeing. Keep an eye on the Dev channel release notes for updates from us on when this is resolved!The Dev channel rolled out version 110.0.1587.1 today, however we are aware of a "restart loop" the community is seeing. Keep an eye on the Dev channel release notes for updates from us on when this is resolved!
I'll post an update when the "restart loop" issue has been corrected.  In the meantime, below are the changes in the build update released to all platforms except Mac. Mac users will receive the Dev build at a later date. This build includes a range of fixes, new policies, new API, and new features for Android.
Added features:
  • Android:
    • New Ad blocker feature now allows you to block ads with a long press.
    • Now you can change the wallpaper on the New Tab Page.
  • WebView2:
    • Added experimental Permission management API.
  • Enterprise:
    • New policy (Note: Updates to documentation and administrative templates may not have occurred yet)
      • Print preview sticky setting policy.
      • Touch Mode policy.
      • Policy for disabling Immersive Reader's Grammar Tools.
  • Fixed browser crash related to out of memory condition when visiting certain shopping sites.
  • Fixed browser crash related to invalid access in a vector on webpages.
  • Fixed browser crash related to McAfee Drive Encryption.
  • Fixed browser crash by disabling WebAuthn autofill functionality due to issue.
  • macOS:
    • Fixed browser crash when activating Fullscreen mode.
  • iOS:
    • Fixed browser crash when using the translator.
    • Fixed browser crash when viewing New Tab Page.
  • Android:
    • Fixed browser crash when downloading a file.
  • Enterprise:
    • Fixed browser crash due to Conditional Access workflow retries too many times when remediation fails on Android.
Changed behavior:
  • Fixed URLs not being added to the allow list when the flyout is dismissed on Website Typos protection.
  • Fixed favicon not loading properly when installing a site as an app.
  • Prevented browser window from staying open if it only contains a blank tab opened by ClickOnce interaction.
  • Removed recently closed suggestions from the address bar so they will now persist instead only on the current browser session.
  • Fixed can't expand or collapse Tab group while the Tab group menu is showing.
  • ALT + S shortcut no longer triggers the screenshot functionality.
  • Workspace sharing prompt will now close when clicking outside of the UI.
  • Fixed Visual search button appearing outside the image when scrolling.
  • iOS:
    • Fixed can't swipe up on New Tab Page.
    • Fixed page getting squished when using Split View on iPad.
    • Fixed automatic profile switching issue where it keeps switching back to a Work profile from a personal profile.
    • Fixed the issue when trying to sign in from Add account displaying a circle.
  • Android:
    • Fixed Add current page to Favorites button not showing after editing a favorite.
  • WebView2:
    • WebResourceResquested API promoted from experimental stage to public.
    • Fixed DPI mismatch.
    • Disabled native Windows Share option due to not working as expected on HoloLens and in UWP apps.
    • Fixed custom rasterization scale bug. (#2918)
  • Enterprise:
    • Removed the ShadowStackCrashRollbackBehavior policy.
    • Fixed focus fails to work involving showModalDialog and window.open in IE Mode workflows.
    • Fixed an issue where visiting a URL that is on AllowListUrls policy causes to open a New InPrivate tab to a URL that is not on the AllowList on iOS.
The "restart loop" has been repaired with Version 110.0.1587.6.
Dev Channel update to 111.0.1633.0 is live.
Added features:
  • Android:
    • long press on New Tab Page now can enter the Wallpaper center.
  • Fixed browser crash related to the Search sidebar.
  • Fixed browser crash related to Search in the Mini menu.
  • Fixed browser crash on an older version of Windows 10 when trying to use a camera.
  • Fixed browser crash when moving a tab into a separate window.
  • Fixed browser crash when dragging a tab out of a Group Tab.
  • Android:
    • Fixed browser crash related to Read Aloud.
  • WebView2:
    • Fixed crashing issue related to Sandbox.
Changed behavior:
  • Fixed links from PWA so they no longer open in Workspace.
  • Fixed can't add current page in Sidebar in certain scenarios.
  • Fixed duplicated MSA sign-in issue.
  • Fixed can't print on printers with names containing Japanese strings.
  • Fixed Quit App on the context menu for Discover and Search Sidebar not working.
  • macOS:
    • Fixed Default workspace for external links setting that caused external links to open in a window that was not the last active window.
  • iOS:
    • Fixed zooming issue on PDFs.
    • Fixed duplicated quick links.
    • Fixed the Restore prompt showing up when there was no crash.
    • Fixed multi-page PDF showing a different page of the PDF when switching from portrait to landscape and vice versa.
  • Android:
  • Xbox:
    • Fixed video corruption playback issue.
  • WebView2:
    • We disabled preconnect to search to stop the SSL connection when opening about: blank page. (#2978)
    • Fixed the open file dialog box not opening. (#3075)
    • Fixed re-installation fails if WebView2 is running (#3137)
  • Enterprise:
    • Fixed top sites data not clearing after changing identity on iOS.
Dev Channel update to 111.0.1652.0 is live
Added features:
  • Command Palette is a command window feature that allows users to perform common tasks in the browser.
  • Add Show duplicate navigations option in History Hub's more menu.
  • Devtools now has Detached Elements, a new panel that finds memory leaks related to detached DOM elements.
  • WebView2:
    • Added experimental ScriptLocale API.
    • Added experimental WebMessage Object API. (#501)
  • Fixed browser crash related to Followable web.
  • Fixed freezing issue on the New Tab Page.
  • macOS:
    • Fixed browser crash related to Smart Screen.
Changed behavior:
  • Fixed the Share button not displaying after using the Move all tabs to new workspace option.
  • Fixed Image editor can't be closed.
  • Fixed Image editor stuck on loading.
  • Fixed Reopen closed tab not opening recently closed window.
  • Fixed Something went wrong message in the Outlook Sidebar pane.
  • Fixed Text prediction inserting a new line character on some websites.
  • Fixed desktop shortcuts keep getting created.
  • Fixed the edge://policy page not showing the Policy Value correctly.
  • Fixed the missing password reveal button.
  • iOS:
    • Fixed can't copy URL from the address bar.
  • WebView2:
    • Fixed speechSynthesis.getVoices() returns three voices for Win32 but zero voices for UWP. (#3155)
    • Fixed ResultFilePath not reporting the download location (#2596)
  • Enterprise:
    • Fixed duplicated PWA shortcuts being created on every browser launch with WebAppInstallForceList policy.
    • Fixed the missing business justification drop-down and text box options when uploading a zip file to a restricted domain.
