Windows 10 Insider Dev Channel (Fast Ring)
Started by Corrine, December 16, 2019, 10:40:17 PM
Update at Announcing Windows 10 Insider Preview Build 20241 | Windows Insider Blog:
QuoteUPDATE 10/23: We are starting to roll out Cumulative Update Build 20241.1005 (KB4589464). This update does not include anything new and is designed to test our servicing pipeline.
Windows 10 Insider Preview Build 20246 to Windows Insiders in the Dev Channel:  Announcing Windows 10 Insider Preview Build 20246 | Windows Insider Blog.
Note:  Release changed from MN_RELEASE Branch to FE_RELEASE Branch.  As a result of the switch, some features like the updated emoji picker, redesigned touch keyboard, voice typing, theme-aware splash screens, and others have been removed temporarily.
Fixes:
  • We fixed an issue that could result in the Pick Time button in the Windows Update dialog not doing anything.
  • We fixed an issue where hovering over a thumbnail in Task View would display an unexpected border around the item.
  • We fixed an issue where chkdsk could appear to be stuck at 100% due to not printing the message saying it was done.
  • We fixed an issue that could result in a crash when disconnecting certain audio devices while playing audio in recent builds.
  • We fixed an issue where the Windows Update page in Settings could fail to load if connected to a Wi-Fi network with no internet connection.
  • We fixed an issue resulting in Settings crashing sometimes when clicking the Update and Security category.
  • We fixed an issue resulting in Storage Settings unexpectedly showing incorrect category sizes (a higher number than what was visible in File Explorer).
  • We fixed an issue that could lead to a crash when managing partition size in Storage Settings.
  • We fixed an issue that stopped GPU compute scenarios such as CUDA and DirectML not working for some users inside of the Windows Subsystem for Linux.
Windows Insider Build 20251 (FE_RELEASE) Released to the Dev Channel:  Announcing Windows 10 Insider Preview Build 20251 | Windows Insider Blog.
Fixes
  • We fixed an issue resulting in the background of some dialogs to unexpectedly appear grey instead of white in the last couple flights.
  • We fixed an issue resulting in the taskbar occluding the Power button in the Start menu for some Insiders recently.
  • We fixed an issue resulting in some Insiders seeing a SYSTEM THREAD EXCEPTION NOT HANDLED bug check.
  • We fixed a crash with opengl32.dll.
  • We fixed an issue that could result in the Settings app hanging when checking for updates right after upgrade.
  • We fixed an issue that could result in the Settings app sending a notification that just said "new notification".
  • We fixed an issue resulting in the Search Indexer not being able to retrieve metadata from HEIF and WebP files, so you couldn't search for those files using metadata like date taken.
  • We fixed an issue resulting in the Cast to Device option in Movies & TV (and other media playback apps) not taking any action when clicking on a listed device in recent builds.
  • We fixed an issue in recent builds that could result in the screen you were projecting with Miracast freezing shortly after connecting.
Windows Insider Preview Build 20257 (FE_RELEASE) Released to Dev Channel:  Announcing Windows 10 Insider Preview Build 20257 | Windows Insider Blog.
Fixes
  • We fixed an issue starting with Build 20236 where installing games from the Store to a secondary non-OS drive would result in the secondary drive becoming inaccessible.
  • We fixed an issue causing some devices to experience a DPC_WATCHDOG_VIOLATION bugcheck in recent builds.
  • We fixed an issue resulting in some apps crashing on launch in the previous flight, including Microsoft Jigsaw and Microsoft Minesweeper.
  • We fixed an issue resulting in File Explorer having a transparent line across the top when maximized on systems with multiple monitors.
  • We fixed an issue resulting in win32 app titles being unexpectedly highlighted in the title bar after enabling and disabling high contrast.
  • We fixed an issue where the windows.old folder is not completely deleted when performing disk cleanup.
  • We fixed an issue where if you reset your PC then and re-connected your MSA, then your MSA picture might never sync down.
  • We fixed an issue impacting Windows Hello Face recognition if the device was trained in a different orientation than the orientation used at unlock time.
  • We fixed an issue where setting up a kiosk (assigned access) account wouldn't work the first time you tried, only subsequent tries.
  • We fixed a deadlock that could result in unexpected CPU usage. If you continue experiencing other performance issues, please take a moment to file feedback including details about the issue you're seeing, and a performance trace. More info about collecting a repro trace is available here if needed.
  • We fixed an issue resulting in recently some apps being slower to accept keystrokes into text fields.
  • We fixed an issue that could result in links from apps failing to launch the browser.
  • We fixed an issue from the last couple flights that could result in audio playback unexpectedly stopping.
  • We fixed an issue that could result in not hearing audio after streaming certain content then turning your Bluetooth headset off and back on.
  • We fixed an issue that could result in Movies & TV failing to play some recorded HDR videos with error 0x80004001.
Windows Insider Preview Build 20262 (FE_RELEASE) Released to Dev Channel:  Announcing Windows 10 Insider Preview Build 20262 | Windows Insider Blog.
Fixes:
  • We fixed an issue resulting in certain apps launching unexpectedly transparent in recent builds, with no content visible.
  • We fixed an issue where old SleepStudy etls were unexpectedly not being cleaned up.
  • We fixed an issue resulting in no response the first time a pen was clicked after being paired due to an underlying crash.
  • We fixed an issue resulting in touchpad scrolling no longer working on the tab in focus after closing a browser tab using CTRL+W while scrolling on a touchpad.
  • We fixed an issue where the some of the notifications related to block at first sight weren't being localized.
  • We fixed an issue where when using Narrator in scan mode, it wasn't possible to activate the "Sign in with pin or smart card" buttons in the authentication dialog using space or the enter key.
  • We fixed a recent issue where when both Wi-Fi and cellular were connected, if Wi-Fi disconnected the network flyout would say cellular was still connected, but apps wouldn't actually be able to use the internet.
  • We fixed a high hitting DWM crash impacting some Insiders in the last few flights.
  • We fixed an issue that could result in Settings crashing when navigating to Storage Sense.
  • We fixed an issue resulting in app registration issues for some of the in-box apps with the previous flight after upgrading.
Update posted at Announcing Windows 10 Insider Preview Build 20262 | Windows Insider Blog:
UPDATE 11/20: We are starting to roll out Cumulative Update Build 20262.1010 (KB4594431). This update does not include anything new and is designed to test our servicing pipeline.
Windows 10 Insider Preview Build 20270 (FE_RELEASE) to the Dev Channel:  Announcing Windows 10 Insider Preview Build 20270 | Windows Insider Blog.
Fixes
  • We fixed an issue resulting in some dialogs, such as Properties, displaying black text on dark backgrounds in recent flights.
  • We fixed an issue that could result in certain apps unexpectedly closing when clicking the Maximize button in recent builds.
  • We fixed an issue resulting in printers with Japanese characters in their names not displaying correctly in Printers & Scanners Settings.
  • We fixed an issue that could result in some delay logging into your PC on devices with a large number of users.
Windows Insider Preview Build 20277 (FE_RELEASE) to the Dev Channel:  Announcing Windows 10 Insider Preview Build 20277 | Windows Insider Blog.
Important
Quote"Starting today, we are giving Windows Insiders in the Dev Channel the option to receive builds from the RS_PRERELEASE branch. These builds will be offered as an optional update through the "seeker" experience in Windows Update. This means Insiders will have to go and choose to install the currently offered RS_PRERELEASE build. Insiders can choose to install Build 21277. Once they do, they will continue to receive RS_PRERELEASE builds going forward.
Insiders who choose to stay put will continue to automatically get builds from the FE_RELEASE until we move all Insiders in the Dev Channel to receiving RS_PRERELEASE builds sometime after the holidays. We still need Insiders running FE_RELEASE builds and giving us feedback on these builds so its ok if you choose to stay on these builds.
Be sure to check the list of known issues below. The list of fixes and known issues between FE_RELEASE builds and RS_PRERELEASE builds will NOT be the same."
Fixes:
  • We fixed an issue that could result in the WinRE volume label being lost after multiple upgrades.
  •   We fixed an issue that could result in apps failing to update with error code 0x80073D02.
Windows 10 Insider Preview Build 20279 (FE_RELEASE) Released to Dev Channel:  Announcing Windows 10 Insider Preview Build 20279 | Windows Insider Blog.
Note from the blog post:
QuoteThis build is largely the same as Build 20277, but we wanted to test our ability to quickly follow-up a flight with another flight.
Windows Insiders who updated to Build 21277 (RS_PRERELEASE) last week will not be offered this build as they are on a newer build. We are working on getting a new build out to those Insiders soon. We expect to move all Insiders in the Dev Channel back to receiving builds from RS_PRERELEASE sometime after the holidays.
The fixes from Build 20277:
Windows 10 Insider Preview Build 21286 (RS_PRERELEASE) to Windows Insiders in the Dev Channel:  Announcing Windows 10 Insider Preview Build 21286 | Windows Insider Blog.
Note:
QuoteThis build is being offered to ALL Insiders in the Dev Channel. All Insiders in the Dev Channel will now receive the same build going forward.
New features in this build include news and interests on the Windows taskbar, the ability to create and manage Storage Spaces from within the Settings app, run any specified Linux command on startup of a WSL distribution, small adjustments for users of "Set time zone automatically" in Date & Time Settings and more.
Fixes
  • We fixed and issue causing some Insiders to see a popup that says "Your PC ran into a problem and restart in 1 min" after logging in to Windows with either an Azure Active Directory or Active Directory account on Build 21277.
  • We fixed an issue where no drives appeared under Settings > System > Storage > Manage Disks and Volumes.
  • We fixed an issue resulting in some printers getting stuck on connecting when added from Settings.
  • We fixed an issue that could result in sometimes unexpectedly being signed out of apps and websites after rebooting your PC.
  • We fixed an issue where the Windows Security icon would sometimes be unexpectedly large in the context menu when shift-right-clicking taskbar icons.
  • We fixed an issue that could result in MediaTranscoder hanging when transcoding certain files.
  • We fixed an issue where audio playing from UWP apps wasn't ducking after pressing the microphone icon to start Cortana listening.
  • We fixed an issue that could result in VPN entries in the network flyout getting stuck at Action Needed until you pressed Cancel and Connect again.
  • We fixed an issue impacting touch targeting when resizing windows using touch.
  • We've made some fixes to our emoji keyword search results based on feedback, including adding a new keyword so that typing "lgbtq" will now return the rainbow flag emoji. Please continue sharing feedback with us in the Feedback Hub under Input and Language > Emoji Panel.
  • We fixed an issue that could result in the Read Aloud options in Magnifier being unexpectedly greyed out.
  • We fixed an issue where the "Help make Narrator better" toggle in Narrator Settings was disabled for Insiders.
  • We fixed an issue so that Narrator will now read Excel cell contents when verbosity is set to 2.
  • We fixed an issue where Narrator might not announce whether a combo box was in expanded or collapsed state.
  • We fixed an issue impacting Narrator's ability to read the names of certain hyperlinks on websites in Microsoft Edge.
  • We fixed an issue impacting Narrator's ability to read code windows in Visual Studio.
  • We fixed an issue for high contrast users that could result in Settings crashing when going to Ease of Access.
Windows 10 Insider Preview Build 21292 (RS_PRERELEASE) to the Dev Channel:  Announcing Windows 10 Insider Preview Build 21292 | Windows Insider Blog.
The build includes numerous fixes and improvements to news and interests on the taskbar aswell as about the weather experience.
Fixes:
  • We're continuing to work on improving x64 emulation on ARM64 thanks to your feedback. This build fixes issues in several apps, including crashes in Zwift, Serif Affinity Photo, and Your Phone as well as blank pages in Steam.
  • We fixed an issue resulting in an increase in Insiders seeing a message saying "Critical Error: Your Start menu isn't work" in recent builds.
  • We fixed an issue from the last two builds where explorer.exe / the Windows shell was hanging and or crashing, particularly after interacting with audio/video.
  • We fixed an issue where NTFS was logging false positive torn write events.
  • We fixed an issue resulting in Microsoft Teams and certain other apps unexpectedly displaying as just "Program" (instead of the app name) in Task Manager's Startup tab.
  • We fixed an issue where it wasn't possible to sort processes in Task Manager by Status.
  • We fixed an issue that could result in not seeing notifications following WIN + Shift + S shortly after clean installing or resetting your PC.
  • We fixed an issue from the previous build where when Xbox Game Bar was launched from Start or via the Windows key + G when using a text editor, the computer might appear unresponsive.
  • We fixed an issue where when using Windows with scaling greater than 100% in recent builds, if you opened and closed Task View, open windows would appear unexpectedly large in the transition back to the desktop.
  • We fixed an issue where typing "-" on a number pad when using the Japanese IME wasn't taking into consideration whether the IME was in full width or half width mode.
  • We fixed an issue where Hanja word conversion with the Korean IME wasn't working in Excel when the Korean Language pack for Office was installed.
Update to Announcing Windows 10 Insider Preview Build 21292 | Windows Insider Blog.
QuoteUPDATE 1/15/21: We are starting to roll out Cumulative Update Build 21292.1010 (KB4601937). This update does not include anything new and is designed to test our servicing pipeline.
Windows Insider Build 21296 (RS_PRERELEASE) Released Dev CHannel:  Announcing Windows 10 Insider Preview Build 21296 | Windows Insider Blog.
  • The issue that could prevent Call of Duty: Modern Warfare and Call of Duty: Black Ops Cold War from launching has been fixed and is in the process of rolling out. Please update your game(s) to apply the fix.
  • We fixed an issue from the previous flight where Xbox Game Bar was launching on its own for certain games, without pressing WIN + G.
  • We fixed an issue where when the Xbox Game Bar was launched (like when pressing WIN + G), the PC might appear unresponsive.
  • We fixed an issue resulting in the Program Compatibility Assistant sometimes unexpectedly taking up a large amount of CPU resources in the last few flights.
  • We fixed an issue that could result in explorer.exe hanging when mounting ISOs.
  • We fixed an issue where the Windows Security app might show both a check for updates button and link at the same time.
  • We fixed and issue causing some Insiders to experience rendering / graphic issues after resizing certain app windows.
  • Installing this build will restore x64 emulation on ARM64 if it had previously broken after installing Build 21292.1010.
  • For Insiders using x64 apps on ARM64, there is an updated preview of the ARM64 C++ redistributable (version 14.28.29812) now available to install from https://aka.ms/arm64previewredist. This updated redist adds vcruntime140_1.dll and fixes crashes occurring in a number of CAD applications.
Update to Announcing Windows 10 Insider Preview Build 21296 | Windows Insider Blog:
QuoteUPDATE 1/25/21: We are starting to roll out Cumulative Update Build 21296.1010 (KB4602812). This update does not include anything new and is designed to test our servicing pipeline.
Windows Insider Preview Build 21301 Released to Dev Channel:  Announcing Windows 10 Insider Preview Build 21301 | Windows Insider Blog.
See the blog post for the refinements rolling out for the touch keyboard based on feedback.  Also see a new password feedback icon and updates to the default keyboard layout on 12" or larger screens.
Fixes
  • We fixed an issue so that the taskbar context menu and news and interests should no longer overlap.
  • We fixed an issue where in certain circumstances, news and interests would use 100% of CPU when it is first launched.
  • We fixed an issue that could result in Task Manager crashing when switching to the Details tab.
  • We fixed a recent issue for some Insiders related to the Clock and Calendar flyout that could result in ShellExperienceHost using an unexpectedly high amount of CPU.
  • We fixed an issue resulting in the State Repository Service being prematurely terminated during service startup. If you were impacted, one possible symptom was it taking longer to load the desktop when signing in. If you're continuing to experience performance issues when logging in, please file them with a trace under Install and Update > Logon hangs.
  • We fixed an issue where if you searched for "change your password" and used the result to launch Settings, Settings would crash.
  • We fixed an issue where Aero Shake was unexpected disabled in the last few flights.
  • We fixed an issue where when moving a window between mixed DPI monitors it could result in the window margins being calculated with the wrong DPI, leading to the window overflowing on the other monitor when maximized.
  • We fixed an issue that could result in certain HEIF files not rendering although the correct codecs were installed.
  • We fixed an issue resulting in pinning a website to your taskbar from Microsoft Edge not working in the last few flights.
  • We fixed an issue that could result in VPN repeatedly connecting and disconnecting in a loop.
  • We fixed an issue resulting in some 32-bit systems losing the network connection in recent flights.
  • We fixed an issue resulting sometimes in nothing happening after clicking a "Wi-Fi password needed" notification.
  • We fixed an issue where certain games like State of Decay 2, or Assassin's Creed, may hang or crash when launching.
  • We fixed a few issues resulting in Narrator not reading elements of our troubleshooters when in Scan Mode.
