Announcing Windows 11 Insider Preview Build 26300.7965 (Dev Channel)
New features gradually being rolled out with toggle on
[Administrator Protection]
Administrator protection is being re-enabled and aims to protect free floating admin rights for administrator users, allowing them to still perform all admin functions with just-in-time admin privileges. This feature is OFF by default and can be enabled via OMA-URI in Intune or via group policy.
Changes and Improvements gradually being rolled out with toggle on
[Sharing]
Based on feedback we're making some refinements to drag tray, using a smaller peek view to reduce accidental invocation and make it easier to dismiss when interacting near the top of the screen.
[File Explorer]
  • You can now use voice typing (Windows key plus H) when renaming files in File Explorer.
  • Removed white flash when launching new File Explorer windows or tabs when File Explorer was set to open to This PC. Also removed white flashes when resizing elements of File Explorer.
  • Improved reliability of unblocking files downloaded from the internet in order to preview them in File Explorer.
[UPDATE 3/11/26]: Rolling out standalone Update Build 26300.7966 (KB5082257). This update does not include anything new and is designed to test the servicing pipeline for builds in the Dev Channel. A restart will be required; device build version will not change post update.
Announcing Windows 11 Insider Preview Build 26300.8068 (Dev Channel)
[Policy-Based Removal of Preinstalled Microsoft Apps]
  • We have updated the "Remove Default Microsoft Store packages" policy for Windows ENT/EDU to include a dynamic app removal list. IT administrators can now remove MSIX/APPX apps by adding their app package family name (PFNs) to a dynamic list.
  • To access the policy in Group Policy settings, open the local Group Policy Editor (gedit.msc) and navigate to Computer Configuration > Administrative Templates > Windows Components > App Package Deployment > Remove Default Microsoft Store packages from the system.
  • To remove an app via the dynamic list, add its app family package name to the multi-text list under "Specify additional package family names to remove."
  • To find app family package names, run the Get-AppxPackage command in a terminal. For example, here's a command to get the package family name for Notepad.
    • Get-AppxPackage *Notepad* | Select-Object PackageFamilyName
  • The dynamic list is currently unavailable in the corresponding Intune CSP. When this feature becomes generally available, you can search for Remove Default Microsoft Store packages settings in the Settings picker.
    • Known Limitation – OMA-URI and Multi-Entry Validation: OMA-URI cannot be used to validate multi-entry ADMX multi-Text policies; therefore, validation for the dynamic list must be done via Settings Catalog in Intune or Group Policy. Given that the Intune setting is not yet available in WIP, you will need to test using Group Policy.
  • For information on the generally available policy, visit Policy-based in-box app removal.
Feedback: Share your thoughts in Feedback Hub (WIN + F) under Developer Platform > App Deployment.
[Windows Setup Experience]
  • Expanding on our work which started rolling to Insiders last fall, you can now choose a custom name for your user folder on the Device Name page when going through Windows setup. This most recent update now makes it easier to choose a custom name. The naming option is available during setup only. If you skip this step, Windows will use the default folder name and continue setup as usual.
Note: User folder names must follow standard Windows naming requirements.
Feedback: Share your thoughts in Feedback Hub (WIN + F) under Install and Update > Initial out of box setup.
[Windows Driver Policy update]
  • The Windows kernel has historically allowed 3rd party kernel drivers from the now- deprecated cross-signed root program and the Windows Hardware Compatibility Program (WHCP). The WHCP program is a major step up in security compared to the cross-signed driver program, requiring driver compatibility testing, identity vetting and verification and virus scanning.
  • Starting with this update, the Windows kernel will enforce a new policy removing default trust for cross-signed drivers. The policy allows 3rd party drivers from the WHCP program by default, with an allow list of trustworthy publishers and drivers from the cross-signing program.
  • The feature is enabled in audit mode for a minimum of 100 hours and 3 reboots. If Windows determines that the drivers loaded during this time are compatible with the new policy, the feature is enabled. Otherwise, the system stays in audit mode.
  • After enablement, while unlikely, some users running in enforcement mode may see cross-signed drivers blocked:
Feedback: Share your thoughts in Feedback Hub (WIN + F) under Security and Privacy > Application Control.
[Point-in-time restore updates]:
  • When you launch point-in-time restore, local admins will see a settings dialog (behind a User Account Control (UAC) prompt) where they can view or change the default restore settings.
  • This experience also now shows a list of restore points available on the device.
Updated messaging in the WinRE restore experience:
  • Added a recommendation to plug your device into a power source during the restore.
  • The OS version number is now shown in a 4-part format (instead of 2-part).
Feedback: Share your thoughts in Feedback Hub (WIN + F) under Recovery and Uninstall > Point-in-time restore.
[Account Settings]
Microsoft 365 Family subscribers will find an option to upgrade to a different 365 plan on the Accounts page within the Settings app. You can also remove the upgrade option by turning off suggested content in settings.
Feedback: Share your thoughts in Feedback Hub (WIN + F) under Settings > Settings Homepage.
[Drag Tray > Drop Tray]
  • Expanding on our work last week, Drag Tray has been now renamed to Drop Tray. We're also moving the corresponding settings for Drop Tray from Nearby Sharing to now be under System > Multitasking.
[Input]
  • Pen settings: we have made refinements to the Pen settings page including small changes to the options for the pen tail button. A new option, "Same as Copilot key", enables the pen tail button to launch the same app as the Copilot key.
Feedback: Share your thoughts in Feedback Hub (WIN + F) under Devices and Drivers > Bluetooth – Keyboards, Mice, and Pens.
[File Explorer]
  • Improved reliability of setting and using preferred display language.
  • Removed extraneous unexpected error from sfc/scannow.
Announcing Windows 11 Insider Preview Build 26300.8085 (Dev Channel)
[Pointer Indicator: Accessibility setting for low vision Windows users]
We are resuming the rollout of the Point Indicator Accessibility setting. This feature enables low vision users on Windows to easily locate and use their cursor to increase productivity and efficiency when using a Windows device.
To enable this experience, go to Settings > Accessibility > Mouse pointer and touch and enable the Pointer indicator setting. You can also search for the setting by name. When the setting is enabled, you can toggle it on/off with the keyboard shortcut, Win + Ctrl + Shift + X.
We welcome your feedback about the cursor and crosshair experience with this accessibility setting.
FEEDBACK: Please file feedback in Feedback Hub (WIN + F) under Accessibility > Accessibility Settings.
[Windows Magnifier]
  • Windows magnifier can now magnify protected content.
[Network and Sharing]
  • We fixed an issue where the Network and Sharing Center could incorrectly display two active Wi-Fi connections after switching from one Wi-Fi network to another. The Network and Sharing Center now correctly reflects a single active Wi-Fi connection when you connect to a new network.
[Input]
  • Improved explorer.exe reliability when closing the input flyout.
  • Improved reliability of configuring fluid dictation option in voice typing (Windows key plus H) settings.
[Feedback Hub]
Introducing the new Feedback Hub, bringing a refreshed, modernized experience available as an app update today for Insiders in Dev and Canary.
What's new in Feedback Hub
  • Simpler feedback submission flow: Feedback is now submitted using a single unified template, with the added ability to search categories. The feedback form itself has been modernized enabling for faster iteration and future improvements.
  • Simpler navigation: My Feedback now lives directly in the navigation pane, and Community feedback (formerly All feedback) makes it easier to discover and engage with feedback from others. The Announcements page has been removed to focus more on giving and exploring feedback. You can still find announcements on the Windows Insider Blog.
  • New compliment feedback type: Call out what's working well.
  • Private or public feedback: Choose whether your feedback is visible to the Insider community.
  • New focused feedback experience: a new smaller Feedback Hub surface, making it easier to provide quick, in-the-moment feedback. You can expand to the full Feedback Hub experience by pressing the button in the upper right corner.
  • Improved screenshot capture and review tooling: making it easier to capture and include visuals when sharing feedback.
Feedback: Your feedback helps shape what comes next, so try out the new experience and share your thoughts in Feedback Hub (WIN + F) under Apps > Feedback Hub.
Announcing Windows 11 Insider Preview Build 26300.8155 (Dev Channel)
[Input]
  • Users will be able to feel haptic feedback effects on compatible input devices while performing certain actions, such as aligning objects in PowerPoint, window snapping, resizing, or hovering over the Close button. These haptic effects can be configured in Settings under Bluetooth & devices > Mouse > Haptic signals.
Feedback: Share your thoughts in Feedback Hub (WIN + F) under Input and Language > Mouse.
[Xbox mode]
  • Xbox full screen experience is now Xbox mode
  • We've added an improved first run experience when entering Xbox mode
Feedback: Share your thoughts in Feedback Hub (WIN + F) under Gaming and Xbox > Gaming Full Screen Experience.
  • Improved performance of launching startup apps after boot (apps which display under Settings > Apps > Startup).
  • Fixed an issue resulting in certain apps not being able to sign in recently, citing an internal connection issue when internet was actually connected.
  • Fixed an underlying crash impacting some Insiders' ability to print with the latest flights.
Announcing Windows 11 Insider Preview Build 26300.8170 (Dev Channel)
[Storage]
  • We're increasing the size limit for formatting FAT32 volumes via the command line from 32GB to 2TB.
  • Improved the performance when navigating to see storage on large volumes via Settings > System > Storage > Advanced Storage Settings > Disks & Volumes.
  • Updated Settings > System > Storage, so rather than seeing a UAC prompt immediately when you go to the page, you'll only see it when going to view temporary files.
[Network]
  • Fixed issue causing Settings > Network & Internet > Data Usage to show large unrealistic values in recent Insider builds.
[Windows Security app]
  • We have recently started to roll out enhancements to the Windows Security app > Device security > Secure Boot experience, which shows green, yellow, and red icon badges as well as new text that reflects your device's Secure Boot state and certificate status. Microsoft is updating Secure Boot certificates on consumer devices and some business PCs, and you can now check your certificate status with this new feature. This experience is disabled by default on enterprise IT managed devices and servers.
Feedback: Share your thoughts in Feedback Hub (WIN + F) under Apps > Windows Security.
[Feedback Hub Improvements]
  • Thanks Windows Insiders who have been sharing such great feedback about the new Feedback Hub version. As some of you may have already noticed, we're currently rolling out version 2.2604.101.0 to Dev and Canary. This includes design refinements based on your feedback, such as:
    • Improved the default window size, and now it will remember window size across session.
    • You can now use the mouse back button to go back between pages.
    • If you were seeing less community feedback than usual, that should be addressed now.
    • Upvote buttons for feedback should display correctly for Insiders using the Chinese display language now, ... and more.
Please keep the feedback coming! You can share your thoughts under Feedback Hub (WIN + F) under Apps > Feedback Hub.
Announcing Windows 11 Insider Preview Build 26300.8276 (Dev Channel)
[Settings]
  • Based on feedback, we're providing clarity regarding location options in Settings > Privacy & Security > Location. When Location services is turned off, options like Default location and Allow location override are unavailable because apps and services aren't receiving location info. To make that clearer, these options will now appear disabled (greyed out) until Location services is turned back on.
  • We have improved the reliability of navigating to Settings > Apps > Installed apps.
[File Explorer]
  • We have updated iconography placement in the File Explorer search box to be more consistent across different PCs.
  • Improved File Explorer reliability.
  • Improved navigation pane usage for Voice Access users.
[Windows Hello]
  • Improved reliability and performance of Windows Hello fingerprint after your PC wakes from sleep.
[Input]
  • Improved performance of opening clipboard history.
[Fonts]
  • We've made some font improvements, including updating the Leelawadee UI font family for the Thai, Lao, Khmer, and Lontara scripts to help improve glyph sequencing, positioning, and rendering for these scripts.
