Windows 11 Insider Release Preview Channel
Started by Corrine, September 23, 2021, 05:53:19 PM
0 Members and 8 Guests are viewing this topic.
Releasing Windows 11 Build 26100.3321 to the Release Preview Channel
Gradual rollout
The following features and improvements might not be available to all users because they will roll out gradually. Text bolded in brackets indicate the area of the change being documented.
  • [Battery] New! Improved icons show your battery status with just a quick glance. When your battery icon is green, your PC is charging and in a good state. Yellow means that your PC battery is in energy saving mode. Windows makes this change for you when your battery power is less than or equal to 20%. Red means battery power is low, and you must plug in your PC as soon as possible. We're also introducing the ability to show your battery percentage next to the battery icon in the system tray which can be enabled via Settings > Power & battery and toggling on the "Battery Percentage" setting.
  • [Taskbar]
    • New! You can now share files directly from a jump list on the taskbar. Jump lists appear when you right-click an app that has a jump list.
    • Fixed: It might identify an HDD as an SSD.
  • [Windows Spotlight]
    • New! There's a quick and easy way to find out more information about a background image. Simply hover over the image or click the "Learn about this picture" icon.
    • New! This update makes Windows Spotlight easier to find. You'll notice changes to the icon color and background. Also, the icon will show at the lower right area on your desktop.
  • [Lock screen] New! This update makes it easier to learn more about the image on your lock screen when you click the "Like" icon.
  • [Narrator] New! There are new functions for Narrator scan mode. Skip past links (n) allows you to go to the text after a link. Use the comma (,) to jump to the start of an item (large table, long list, or another item.) Use the period (.) to jump to the end of an item. This is most helpful when you read long emails, news articles, and wiki pages. Jump to lists (l) allows you to quickly access a list on a web page or in a document. To use these new functions, turn on Narrator first (Windows logo key + Ctrl + Enter). Then turn scan mode on by pressing Caps lock + Spacebar. Note that scan mode is on by default on most web pages (like news articles, wiki page, and so on).
  • [Game Pass Ultimate and PC Game Pass subscribers] New! Some of you might see a new referral card for a PC Game Pass subscription on the Settings home page. With it, you can invite friends and family to try a PC Game Pass for free. If you qualify, the card only appears when you sign in to your PC using your Microsoft account.
  • [File Explorer]
    • New! You can now snooze or turn off the "Start backup" reminder in the File Explorer address bar. This only applies if you are not already backing up your files and folder. To view this new option, right-click Start backup.
    • Fixed: Improves performance when it loads folders that have a large number of media files.
    • Fixed: When you enter a URL in the address bar, it might not go to the location.
    • Fixed: The address bar overlaps files when you use the F11 full-screen mode.
    • Fixed: The context menu opens slowly when you right-click cloud files.
    • Thumbnails for cloud files display more consistently in search results.
  • [HTML Help Viewer] New! This update adds text scaling support.
  • [Start menu] Fixed: The colors are wrong when you open the account manager flyout menu. This occurs when you use a mixed dark and light custom mode in Settings > Personalization > Colors.
  • [Scanners] Fixed: Apps might not recognize a scanner is available when it is connected.
  • [Audio]
    • Fixed: The volume might increase to 100% when you wake your PC from sleep.
    • Fixed: You might hear a mute and unmute sound several times.
    • Fixed: A USB audio device might stop working after your PC is idle for a short time.
  • [GDI+] Fixed: After you use GDI+ to shrink an image, the colors of the image might be wrong.
  • [Mouse] Fixed: In Settings > Accessibility > Mouse pointer and touch, you can choose a color for the mouse that is not the default. When you choose a color, it reverts to white after the User Account Control (UAC) dialog appears.
Normal rollout
This update includes the following features and improvements that are rolling out as part of this update. Text bolded in brackets indicates the area of the change being documented.
  • [Daylight saving time (DST)] This update supports (DST) changes in Paraguay.
  • [Open Secure Shell (OpenSSH) (known issue)] Fixed: The service fails to start, which stops SSH connections. There is no detailed logging, and you must run the sshd.exe process manually.
  • [Get Help app] Fixed: It fails to open on Windows Server 2025.
  • [Remote Desktop]
    • Fixed: There are display rendering issues when you connect to certain PCs.
    • Fixed: It stops responding.
  • [Live captions] Fixed: If you disconnect an external monitor, the live captions window might not show.
Releasing Windows 11 Build 22631.5116 to the Release Preview Channel
Below is a summary of the new features and improvements included as part of this update separated into two sections: gradual rollout and normal rollout. The bold text within the brackets indicates the item or area of the change we are documenting.
Gradual rollout
  • [File Explorer]
    • New! As part of our ongoing commitment to improving File Explorer accessibility, this release includes increased support for the text scaling (Settings > Accessibility > Text size) across File Explorer, File Open/Save dialogs, and the copy dialogs.
    • New! Context menu labels.
  • [Settings]
    • New! Enable Settings Home Page on Commercial Devices with "Your Accounts" Card.
    • New! "Top cards" (such as storage, graphics, RAM, etc.) at the top of the About settings page.
    • Fixed: For Japanese users, the name displaying at the top of Settings > Accounts shows "First Name" "Last Name" instead of "Last Name" "First Name".
  • [Input]
    • New! We have enabled the Gamepad keyboard layout for the touch keyboard in Windows 11. This change introduces the ability to use your Xbox controller to navigate and type. This includes button accelerators (example: X button for backspace, Y button for spacebar) additionally the keyboard keys have been vertically aligned for better controller navigation patterns.
    • New! New experience to improve the discoverability of the emoji and more panel in Windows 11 with the introduction of a new system tray icon on the taskbar.
    • Fixed: ctfmon.exe may restart when copying data from certain applications.
  • [Task Manager] New! We are changing the way Task Manager calculates CPU utilization for the Processes, Performance, and Users pages. Task Manager will now use the standard metrics to display CPU workload consistently across all pages and aligning with industry standards and third-party tools. For backward compatibility, a new optional column called CPU Utility is available (hidden by default) on the Details tab showing the previous CPU value used on the Processes page.
Normal rollout
  • [File Systems (Filters)] This update adds support for a new function in Filter Manager that enhances the system's ability to notify applications of directory changes while minimizing I/O operations.
  • [Noto Fonts] This update enhances text quality and customer experience in web browsing for Chinese, Japanese, and Korean languages by introducing the Noto font family. This provides modern, comprehensive font support for these languages.
  • [Remote Desktop] Fixed: Certain Get-Help troubleshooters might not run in a Remote Desktop session.
  • [COSA] Updated: This update addresses an issue affecting mobile connectivity configurations for Connected PCs. It resolves incorrect Internet of Things (IOT) Access Point Name (APN) settings that were previously applied.
  • [Printers] Fixed: Printers using Independent Hardware Vendor (IHV) drivers might unexpectedly output incorrect or unwanted text.
  • [File System Fixed: This update resolves an issue for users with profiles redirected to a network Virtual Hard Disk (VHD or VHDX), where a specific failure could lead to a system crash.
  • [File System Filter] Fixed: Addresses an issue where a stop error may occur during normal usage with a user profile redirected to a network VHD(X).
  • [Deprecation] Suggested actions that appear when you copy a phone number or future date in Windows 11 are now deprecated and being removed.
Releasing Windows 11 Build 26100.3613 to the Release Preview Channel
Gradual rollout
  • [Live Captions]
    • New! We are enhancing communication on AMD and Intel®-powered Copilot+ PCs with live captions and real-time translation. This change brings the ability in live captions to translate more than 44 languages into English, including speakers in real-time video calls, recordings and streamed content.
    • New! On Snapdragon-powered Copilot+ PCs, we're bringing the ability to do real-time translation to Chinese (Simplified). Supported languages include Arabic, Bulgarian, Czech, Danish, German, Greek, English, Estonian, Finnish, French, Hindi, Hungarian, Italian, Japanese, Korean, Lithuanian, Norwegian, Dutch, Polish, Portuguese, Romanian, Russian, Slovak, Slovene, Spanish, and Swedish.
  • [Settings]
    • New! With this update, we will gradually make available the Settings homepage for commercial customers on PCs managed by an IT administrator. The feature will show some existing cards relevant to enterprise-managed PCs like "Recommended settings" and "Bluetooth devices" as well as two new enterprise-specific device info and accessibility preferences cards
    • New! We are rolling out "top cards" under Settings > System > About. These top cards provide an easy way to view your PC's key specifications—processor, RAM, storage, and GPU—helping you understand your PC's capabilities at-a-glance.
    • Fixed: For Japanese users, the name displaying at the top of Settings > Accounts shows First Name Last Name instead of Last Name First Name.
  • [Input]
    • New! A new experience to improve the discoverability of the emoji and more panel in Windows 11 with the introduction of a new system tray icon on the taskbar.
    • Fixed: Improved ctfmon.exe reliability, by addressing a system restart which could impact the ability to type.
    • Fixed: ctfmon.exe may restart when copying data from certain apps.
  • [Voice access]
    • New! Natural Language Commanding in voice access provides users with the flexibility to speak commands naturally, using filler words and synonyms, rather than rigid, predefined commands. Available initially on Snapdragon-powered Copilot+ PCs.
    • New! We are introducing Chinese support for voice access. You can now use Voice access to navigate, dictate, and interact with Windows using voice commands in Simplified Chinese (zh-cn) and Traditional Chinese (zh-tw).
  • [Task Manager]New! We are changing the way Task Manager calculates CPU utilization for the Processes, Performance, and Users pages. Task Manager will now use the standard metrics to display CPU workload consistently across all pages and aligning with industry standards and third-party tools. For backward compatibility, a new optional column called CPU Utility is available (hidden by default) on the Details tab showing the previous CPU value used on the Processes page.
  • [Widgets]
    • New! Introducing the ability for web developers to easily utilize their existing web content to build dynamic and interactive widgets that can be added to the widgets surfaces in Windows 11. For more information, click here.
    • New! We're bringing support for lock screen widgets (previously referred to as "Weather and more") to devices in the European Economic Area (EEA). You can add, remove, and rearrange lock screen widgets such as Weather, Watchlist, Sports, Traffic, and more. Any widget that supports the small sizing option can be added here. To customize your lock screen widgets, navigate to Settings > Personalization > Lock screen.
  • [File Explorer] Fixed: The "see more" (...) menu in the File Explorer command bar opens in the wrong direction in some cases.
  • [Remote Desktop] Fixed: Remote Desktop won't use UDP, only TCP.
  • [Screen orientation] Fixed: Screen may unexpectedly change orientation coming out of sleep on 2-in-1 devices.
  • [Application Installation] Fixed: The MsiCloseHandle API experiences prolonged execution time when handling MSI files containing a large number of files.
  • [Boot menu] Fixed: If an update fails and rolls back, it may result in an extraneous and non-functional boot menu entry. This fix stops devices from newly encountering this. Extra boot entries can be managed in the Boot section of System Configuration (msconfig), if you have encountered this issue already.
  • [Authentication]
    • Fixed: Kerberos authentication fails in certain scenarios when RC4 is used for encryption
    • Fixed: FIDO Cached Credential Logon may fail in certain cases when device is Hybrid Domain Joined.
    • Fixed: Opening certain apps after a password change could unexpectedly lead to lockout, if account lockout policy is enabled.
  • [General Reliability] Fixed: An underlying issue may lead to your PC experiencing a bugcheck (blue screen) with PDC_WATCHDOG_TIMEOUT when resuming from sleep.
  • [Network] Fixed: The description of the virtual NIC doesn't display correctly in Network Connections (ncpa.cpl), showing garbage characters.
  • [Color Profile] Fixed: Under Settings > System > Display > Color Management, it might not display the expected color profile list for the selected monitor.
  • [Color Profile] Fixed: The color profile settings may not be applied after resuming from sleep.
  • [Deprecation]
    • Suggested actions that appear when you copy a phone number or future date in Windows 11 are now deprecated and being removed.
    • We are removing the Location History feature, an API used by Cortana to access 24 hours of device history when location was enabled. With the removal of the Location History feature, location data will no longer be saved locally, and the corresponding settings are also being removed from Settings > Privacy & security > Location page.
Normal rollout
  • [Display Kernel] Fixed: This update addresses an issue affecting High Dynamic Range (HDR) content playback on Dolby Vision capable displays, where users may see regular HDR instead of Dolby Vision, missing specific content indicators.
  • [TULIP] Fixed: This update addresses an issue where window captions may be truncated on an ANSI window.
  • [PowerShell] Fixed: This update resolves an issue where critical PowerShell modules required for device configuration were not executed under Windows Defender Application Control (WDAC) policies.
  • [OOBE] Fixed: Addresses an issue that prevents the ESP from running every time a new user logs onto the device even when configured by policy.
  • [Cryptography] Fixed: This update addresses an issue affecting Credential Roaming resulting in certificates and keys not being roamed into Active Directory and not being made available users' machines.
  • [File Systems (Filters)] Fixed: This update resolves an issue for users with profiles redirected to a network Virtual Hard Disk (VHD or VHDX), where a specific failure could lead to a system crash.
  • [Graphics] Fixed an issue where certain 3rd party apps could cause a Settings crash from the graphics settings page.
Releasing Windows 11 Build 26100.3624 to the Release Preview Channel
This update includes all of the same improvements and fixes from Build 26100.3613 plus the additional features gradually rolling out for Snapdragon-powered Copilot+ PCs.
Gradual rollout
[Improved Windows Search]
  • New! Finding your documents, photos, and settings across Windows 11 is easier on Copilot+ PCs with improved Windows Search, powered by semantic indexing models along with traditional lexical indexing. Whether it's searching in File Explorer, in the Windows Search on your taskbar, or in Settings – just type what's on your mind to find it on your Copilot+ PC. You no longer need to remember file names, exact words in file content, or settings names. Searching for settings like "change my theme" will work within the Settings app for now. Thanks to the power of the 40+ TOPS NPU onboard Copilot+ PCs, these search improvements work even when you're not connected to the internet. For more info, see semantic search on Copilot+ PCs. Available on Snapdragon-powered Copilot+ PCs, with support for AMD and Intel-powered Copilot+ PCs coming soon.
  • New! Locating your photos stored and saved in the cloud is getting simpler on Copilot+ PCs  You can use your own words in the search box at the top right corner of File Explorer like "summer picnics". In addition to photos stored locally on your Copilot+ PC, photos from the cloud will now show up in the search results together. Exact matches for your keywords within the text of your cloud files will also show in the search results. You can try this experience out today with your personal OneDrive when signed in with your Microsoft account and connected to the internet. To learn more, see semantic search on Copilot+ PCs. Available on Snapdragon-powered Copilot+ PCs, with support for AMD and Intel-powered Copilot+ PCs coming soon.
    Releasing Windows 11 Build 26100.3902 (KB5055627) to Insiders in the Release Preview Channel on Windows 11, version 24H2 (Build 26100).Gradual rolloutThe following features and improvements might not be available to all users because they will roll out gradually. Text bolded in brackets indicate the area of the change being documented.
      • [Recall (preview)1] New! You work across so many apps, sites, and documents it can be hard to remember where you saw something you want to get back to. Recall (preview)* saves you time by offering an entirely new way to search for things you've seen or done on your PC securely. With the AI capabilities of Copilot+ PCs, it's now possible to quickly find and get back to any app, website, image, or document just by describing its content. To use Recall, you will need to opt-in to saving snapshots, which are images of your activity, and enroll in Windows Hello to confirm your presence so only you can access your snapshots. You are always in control of what snapshots are saved and can pause saving snapshots at any time. As you use your Copilot+ PC throughout the day working on documents or presentations, taking video calls, and context switching across activities, Recall will take regular snapshots and help you find things faster and easier. When you need to find or get back to something you've done previously, open Recall and authenticate with Windows Hello. When you've found what you were looking for, you can reopen the application, website, or document, or use Click to Do to act on any image or text in the snapshot you found. You can learn more about using Recall (preview) here.
      • [Click to Do (preview)2] New! Click to Do (preview) makes it easier than ever to take immediate action on whatever catches your eye on-screen on your Copilot+ PC, saving you time by helping complete tasks inline, and quickly getting you to the app that can best complete the job for you. For example, select an image using Click to Do to take actions like erasing objects using the Photos app or remove the background using Paint. To use Click to Do, simply press WIN key + mouse-click, WIN + Q, through the Snipping Tool menu and print screen, or searching "Click to Do" in the search box on the Windows taskbar. You can learn more about using Click to Do (Preview) here.
      • [Improved Windows Search3]
        • New! Finding your documents, photos, and settings across Windows 11 is easier on Copilot+ PCs with improved Windows Search, powered by semantic indexing models along with traditional lexical indexing. Whether it's searching in File Explorer, in the Windows Search on your taskbar, or in Settings – just type what's on your mind to find it on your Copilot+ PC. You no longer need to remember file names, exact words in file content, or settings names. Searching for settings like "change my theme" will work within the Settings app for now. Thanks to the power of the 40+ TOPS NPU onboard Copilot+ PCs, these search improvements work even when you're not connected to the internet. You can learn more about semantic search on Copilot+ PCs here. Now available on AMD and Intel-powered Copilot+ PCs.
        • New! Locating your photos stored and saved in the cloud is getting simpler on Copilot+ PCs You can use your own words in the search box at the upper-right corner of File Explorer like "summer picnics". In addition to photos stored locally on your Copilot+ PC, photos from the cloud will now show up in the search results together. Exact matches for your keywords within the text of your cloud files will also show in the search results. You can try this experience out today with your personal OneDrive when signed in with your Microsoft account and connected to the internet. Now available on AMD and Intel-powered Copilot+ PCs.
      • [Narrator] New! Keep track of what Narrator has spoken and access it for quick reference. With speech recap, you can quickly access spoken content, follow along with live transcription, and copy what Narrator last said—all with simple keyboard shortcuts.
      • [Phone Link] New! You can do even more with your Windows PC and your mobile devices with direct access to cross-device features from the Start menu. For example, you can make phone calls, send SMS messages, access your photos, or share content between your mobile devices and PC.
      • [Widgets] New! Web developers can use their existing content to create interactive widgets that can be added to multiple widgets surfaces. For more information, click here.
      • [File Explorer]
        • New! Pivot-based curated views on File Explorer Home that support ease of access of Microsoft 365 content on Windows. Be more productive and get highly relevant content at your fingertips on File Explorer Home.
        • Fixed: As part of our ongoing commitment to improving File Explorer accessibility, this release includes increased support for the text scaling (Settings > Accessibility > Text size) across File Explorer, File Open/Save dialogs and the copy dialogs.
        • Fixed: Improved the performance of extracting zipped, particularly in the case where you're unzipping a large number of small files.
        • Fixed: The address bar in File Explorer might unexpectedly not show a path after opening.
      • [Settings] New! You can manage which apps Windows can recommend actions from under Settings > Apps > Actions on Copilot+ PCs.
      • [Windows Share] New! Make last-minute edits such as cropping, rotating, and adding filters to images shared through the Windows Share window.
      • [Windows Studio Effects] New! The Studio Effects automatic framing filter will be enabled when the camera is used for the first time if your PC supports Studio Effects.
      • [Start]
        • Fixed: If you have multiple pages of apps pinned to Start menu, you cannot use touch to switch pages.
        • Fixed: The "Sign out" and "More options" buttons in the Start menu account manager might not be visible with increased text size.
      • [Taskbar]
        • Fixed: The underlines under app icons in the taskbar might remain and stay visible even if the app has been closed.
        • Fixed: If you use the arrow keys after pressing the Windows key plus T, the arrows move in the wrong direction for Arabic and Hebrew display languages.
      • [Desktop icons] The logic for apps pinned to the desktop has been updated, so that packaged apps no longer show an accent colored backplate. For example, if you were to drag and drop Snipping Tool from the apps list in Start to the desktop the icons should be bigger and easier to see now.
      • [Display] Fixed: You may need to press the WIN + P keyboard shortcut twice to switch topologies.
      • [ExtFloodFill] Fixed: There is an uncommon issue with ExtFloodFill where a horizontal line might appear in the incorrect location in Win32 applications.
      • [Graphics]
        • Fixed: External graphics cards connected over Thunderbolt might unexpectedly not be discoverable in some cases.
      • [Hyper-V Manager] Fixed: Hyper-V Manager unexpectedly shows 0% CPU usage for VMs.
  • 1 Recall (preview) will be available starting early 2025 in most markets, rolling out to the European Economic Area later this year. Optimized for select languages (English, Chinese (Simplified), French, German, Japanese, and Spanish). Content-based and storage limitations apply. Requires Windows Hello Enhanced Sign-in Security. See aka.ms/copilotpluspcs.
    2 Coming later to Copilot+ PCs in the European Economic Area.  Functionality will vary by device and market; text actions will be available across markets in select character sets. See aka.ms/copilotpluspcs.
    3 Works with specific text, image, and document formats only; optimized for select languages (English, Chinese (Simplified), French, German, Japanese, and Spanish). See aka.ms/copilotpluspcs.
    Normal rollout
    • [Windows Update] We now provide an estimated time for how long your PC will be offline to install updates from Windows Update. This estimate will be shown on the Windows Update settings page and via the Start menu power button.
    • [Dynamic Host Configuration Protocol (DHCP Client)] Fixed: This update addresses an issue affecting internet connectivity on devices after resuming from sleep mode. Users might experience intermittent internet connections.
    • [File Systems] Fixed: This update addresses an issue when the operating system stops unexpectedly, and an error message appears on a blue screen during normal usage with a user profile redirected to a network VHD(X).
    • [Imaging] Fixed: This update addresses an issue where some content pages with JPEG images were not displaying.
Releasing Windows 11 Build 22631.5261 to the Release Preview Channel
Gradual rollout
  • [File Explorer]
    • Fixed: Improved the performance of extracting zipped files, particularly in the case where you're unzipping a large number of small files.
  • [Start]
    • Fixed: You can't use touch gestures to view the list of apps pinned in the Start menu.
    • Fixed: The Sign out and More options in the Start menu account manager might not be visible with increased text size.
  • [Taskbar] Fixed: If you use the arrow keys after pressing the Windows key + T, the arrows move in the wrong direction for Arabic and Hebrew display languages.
Normal rollout
  • [Sign-In Impact] Fixed: This update addresses an issue affecting the USBxHCI controller and all devices that connect using a USB port on PCs based on Intel's newest CPU architecture. The built-in USB camera won't work with Windows Hello sign-in unless you manually disable Enhanced Sign-in Security (ESS). To turn off ESS, go to Settings > Accounts > Sign-in options > Additional settings > Sign in with an external camera or fingerprint reader > toggle switch ON. If you create a Windows Hello container while using the Windows 11, version 23H2, it might prevent you from using ESS after you upgrade to Windows 11, version 24H2.
  • [Server Message Block (SMB)] Fixed: An issue where an Excel file, hosted on a SMB file share with Access Based Enumeration enabled, containing links to multiple other files hosted on network shares, might take longer to open.
  • [Xbox]
    • Fixed: This update addresses an issue affecting Xbox Elite Wireless Controllers with certain firmware versions, where the keyboard might not function and displays an error indicator in the device manager
    • Fixed: The driver verifier stops responding during gamepad controller driver certification, affecting Windows Hardware Quality Labs testing.
  • [Windows Kernel Vulnerable Driver Blocklist file (DriverSiPolicy.p7b)] Fixed: This update adds to the list of drivers that are at risk for Bring Your Own Vulnerable Driver (BYOVD) attacks.
Releasing Windows 11 Build 26100.3902 to the Release Preview Channel
[UPDATE 4/18] Build 26100.3909 (KB5055627) was released as a small update to Windows 11 Build 26100.3902 (KB5055627), released April 10, 2025.  The update addresses some issues with the update itself.
The following items originally slated for Gradual Rollout have been delayed:
The changes to Normal Rollout are as follows:
  • [Windows Share] New! Make last-minute edits such as cropping, rotating, and adding filters to images shared through the Windows Share window. UPDATE 4/16: This change will roll out at a later date.
  • [ADDED 4/18] New! There are some new updates to the new Widgets on Lock experience for devices in the European Economic Area (EEA). In addition to accessibility and craftsmanship improvements, the Lock screen weather widget now supports customization. To configure your weather widget, go to Settings > Personalization > Lock screen and select the "Customize widget" option from the weather widget more options menu. More widgets will be customizable in the future.
Releasing Windows 11 Build 22631.5409 to the Release Preview Channel
This Build is for Insiders in the Release Preview Channel on Windows 11, version 23H2 (Build 22631).
Gradual rollout
  • [Copilot]
    • New! You can open Copilot on Windows with Win + C. You can personalize your Copilot key and Win + C experience at any time with the existing "Customize Copilot key on keyboard" under Settings > Personalization > Text input. For Enterprise users, see Updated Windows and Microsoft 365 Coplot Chat experience.
    • New! To press to talk with Copilot on Windows, hold the Copilot key or Win + C for two seconds if you don't have a Copilot key. Press Esc or stay silent for a few seconds to end the call. You can also use Alt + Spacebar to talk with Copilot on Windows. This feature enables you to interact with Copilot using your voice, providing instant responses while you continue your tasks
  • [Search on Taskbar] Improved support for web search providers in Windows Search for the EEA, including with increased discoverability.
  • [Settings] New! Find answers to commonly asked questions about your PC and Windows 11 in the new FAQs section on the Settings > System > About. It covers topics like system setup, performance, and compatibility – all in one place.
  • Taskbar] New! Admins can configure taskbar policies so users can unpin specific apps, ensuring they are not repinned during the next policy refresh. To turn on this feature, use the new PinGeneration option.
  • [Voice access] Fixed: Voice access may freeze with error "working on it" when dictating.
  • [Widgets] New! There are some new updates to the new Widgets on Lock experience for devices in the European Economic Area (EEA). In addition to accessibility and craftsmanship improvements, the Lock screen weather widget now supports customization. To configure your weather widget, go to Settings > Personalization> Lock screen and select the "Customize widget" option from the weather widget more options menu. More widgets will be customizable in the future.
  • [Windows Share]
    • New! When you drag a local file from File Explorer or your desktop, a tray appears at the top of your screen. Drop the file into a suggested app or select More... to open the Windows share window.
  • [Input]
    • Fixed: Voice typing won't start from the touch keyboard when using the Chinese (Simplified) narrow layout.
    • Fixed: When using the Symbols section of the touch keyboard, pressing the key to change pages may unexpectedly insert a character into password fields.
Normal rollout
  • [Blue screen error] Fixed: This update addresses an issue where devices encounter a blue screen exception with error code SYSTEM_SERVICE_EXCEPTION (win32kfull.sys).
  • [HoloLens] Fixed: An issue that stopped the HoloCamera app from saving pictures on HoloLens due to incorrect folder access and a related problem with Mixed Reality Capture.
  • [Memory leak] Fixed: This update addresses an issue in the Input Service that causes increased memory usage, potentially impacting performance in multi-user, multi-lingual, and remote desktop usage.
  • [Country and Operator Settings Asset (COSA)] Fixed: This update brings profiles up to date for certain mobile operators.
  • [Windows Shell] Fixed: This update addresses an issue when Explorer and the Start Menu stop working when a device is connected to an AAD account.
  • [Windows Update & Servicing] Fixed: The Windows Update service stopped working when devices running Windows 11 22H2 or 23H2 tried to download the Windows 24H2 feature update through Windows Server Update Services (WSUS).
Releasing Windows 11 Build 26100.4188 to the Release Preview Channel
Gradual rollout
  • [Click to Do (preview)]
    • New! We're introducing more intelligent text actions to enhance your Click to Do experience even further on AMD and Intel™-powered Copilot+ PCs. Use WIN key + mouse-click or WIN + Q to select a text block and then drag to select the text that you want. You'll see options to Summarize, Create a bulleted list, or to help you Rewrite your text, so it sounds more causal, more formal, or more polished.
    • New!1Ask Copilot is a new action within Click to Do. When you highlight text or an image, Click to Do offers the Ask Copilot Selecting it opens Microsoft Copilot with your content in the prompt box. You can send the selected text or image directly to the Copilot app to complete your prompt.
    • New! If your PC has pen and inking capabilities, you can configure the shortcut button to open Click to Do with a single-click, double-click, or press and hold through Settings > Bluetooth & devices > Pen & Windows Ink.
    • New! You can add Click to Do as one of the four apps in the pen menu on your PC. If all slots for the pen menu are full, you might need to replace one app with Click to Do in the menu settings.
    • New! Click to Do can now perform intelligent text actions in Spanish and French.
  • [Copilot]
    • New! To press to talk with Copilot on Windows, hold the Copilot key or Win + C for two seconds if you don't have a Copilot key. Press Esc or stay silent for a few seconds to end the call. You can also use Alt + Spacebar to talk with Copilot on Windows. This feature enables you to interact with Copilot using your voice, providing instant responses while you continue your tasks.
  • [Cross Device Resume] New! Seamlessly resume working on OneDrive files from your phone (iOS and Android) on your Windows 11 PC with a single click. With this feature, you will get a notification asking you if you want to pick up where you left off editing a OneDrive file like a Word doc that you last viewed or edited on your phone within a 5-minute time window preceding unlocking your PC.
  • [Energy saver] New! IT admins can manage Energy saver settings on Windows 11 PCs through group policies and MDM configurations using Microsoft Intune. This feature helps extend battery life by limiting background activity, dimming the screen, and contributing to environmental sustainability. To configure the policy, go to the Local Group Policy under Computer Configuration > Administrative Templates > System > Power Management > Energy Saver Settings and "Enable Energy Saver to Always Be On."
  • [Graphics] New! Manage your PC's HDR features under Settings > System > Display > Updates include: A clearer label for "Use HDR" that better explains which media types are supported. The ability to stream HDR video even when HDR is turned off. On PCs with Dolby Vision, a new toggle lets you turn Dolby Vision on or off independently of HDR—giving you more control over your viewing experience.
  • [Narrator] New! Enhance digital accessibility with AI-powered image descriptions in Narrator on Copilot+ PCs. This feature provides detailed descriptions of images, charts, and graphs for blind and low-vision users. To turn on Narrator, press Ctrl + Windows key + Enter or search for 'Narrator' in Windows search. Use Narrator key + Ctrl + D for image descriptions.
  • [Improved Windows Search]
    • New! As part of improving Windows Search on Copilot+ PCs, we're beginning to roll out the ability to type a setting you're looking for in the Windows search box on your taskbar without needing to remember the exact setting name. For example, you can use your own words to find settings like "change my theme" or "about my PC". You no longer need to remember the exact setting name you are looking for.
    • New! In the European Economic Area (EEA), you can now find cloud photos using improved Windows Search on the taskbar. Describe the photos, like 'European castles' or 'summer picnics,' in the search box. Photos from the cloud and your Copilot+ PC appear in the search results. Exact keyword matches within your cloud files will also show up. This feature is gradually rolling out to Snapdragon-powered Copilot+ PCs, with support for AMD and Intel-powered PCs coming soon.
  • [Search on Taskbar] New! Improved support for web search providers in Windows Search for the EEA, including with increased discoverability.
  • [Settings]
    • New! Find answers to commonly asked questions about your PC and Windows 11 in the new FAQs section on the Settings > System > About It covers topics like system setup, performance, and compatibility – all in one place.
    • New! The dialog to rename your printer under Settings > Bluetooth & devices > Printers & scanners now matches the Windows 11 look and feel.
    • New! Mouse settings are now easier to access under Settings > Accessibility > Mouse and Mouse pointer and touch, with no need to open Control Panel. You'll find updated icons for Mouse pointer speed and Enhance mouse pointer precision, plus options for customizing the mouse indicator, pointer trails, and hover activation time.
  • [Taskbar]
    • New! Admins can configure taskbar policies so users can unpin specific apps, ensuring they are not repinned during the next policy refresh. To turn on this feature, use the new PinGeneration option.
    • Fixed: When using Tab and Shift + Tab to move keyboard focus around the taskbar, if you go backwards at least once you can get keyboard focus stuck on the taskbar frame, which could lead screen readers to just say "pane".
    • Fixed: Keyboard focus may be unexpectedly set to widgets in the taskbar on login, which can make widgets invoke
  • [Voice access]
    • New! Voice access now includes an in-product experience that highlights new features and improvements. Use the settings menu to open or dismiss it anytime.
    • New! You can find voice access under Accessibility in Quick Settings at the lower-right corner of your screen near the clock. To open Quick Settings, select the network, volume, or battery icon.
    • Fixed: Voice access may freeze with error "working on it" when dictating.
  • [Voice typing] New! You control the profanity filter. When you turn it on, it masks profanity with asterisks. When you turn it off, words appear as spoken. To change the setting, open voice typing (Win + H), select the settings icon, and turn on the Filter profanity switch.
  • [Windows Share]
    • New! Make last-minute edits such as cropping, rotating, and adding filters to images shared through the Windows Share window.
    • New! Add apps that support sharing directly to the right-click menu for local files in File Explorer or on the desktop.
  • [Audio] Fixed: The startup sound may not play on boot, although it is enabled.
  • [MMC] Fixed: Improved the colors used in MMC when items are selected, both generally, and when contrast modes are enabled.
  • [USB] Fixed: Certain USB devices may become disconnected after sleep, until you reboot your PC.
  • [Input]
    • Fixed: Typing in some apps may stop working after disconnecting from a remote desktop session.
  • [JPG] Fixed: When using CopyPixels the pixels may be unexpectedly inverted in certain cases.
    • [Bluetooth] Fixed: Settings may crash when loading information about Bluetooth devices.
    • [Display] Fixed: Unexpected scaling and window position changes may occur after sleep/resume for some devices.
    • [Print] Fixed: Non-admin users can't uninstall printers that they've added.
    • [Windows Hello] Fixed: When using [URL=https://learn.microsoft.com/windows/security/identity-protection/hello-for-business/]Windows Hello for Business[/URL] facial recognition, the camera may unexpectedly fail after waking the PC from sleep, blocking login using this method.
    • [Camera] Fixed: Settings may crash when interacting with content under Settings > Bluetooth & Devices > Cameras.
    • [File Explorer] Fixed: If you have disconnected network drives when doing a search from Home it may prevent searches from executing and you remain on Home.
    • [UHF Tuning] Fixed: Tuning scan for UHF channels doesn't work, and only VHF channels are returned.
    Coming later to the European Economic Area. Functionality will vary by device and market. See aka.ms/copilotpluspcs.
    Normal rollout
    • [BitLocker] Fixed: This update addresses an issue where devices with BitLocker on removable drives could encounter a blue screen error after resuming from sleep or hybrid-booting.
    • [Boot menu screens] Fixed: This update addresses the issue where early boot screens, such as BitLocker PIN, BitLocker Recovery key, and boot menu screens, render slowly.
    • [Graphics kernel] Fixed: An issue where some game titles become unresponsive after upgrading to Windows 11, version 24H2.
    • [Multimedia] Fixed: If you turn on multi-app mode or basic camera mode in advanced camera settings, the Windows Hello Face Enrollment might not work and show a bad camera preview.
    • [Network] Fixed: This update addresses an issue where Windows Server 2025 always shows the network as "public" on new domain controllers. It now checks for a domain controller name before using loopback addresses to ensure proper Lightweight Directory Access Protocol (LDAP) binding.
The referenced Build is being released as a small update that addresses some issues with the above May 19th Build 26100.4188 (KB5058499) update itself.  See the above post for what is included in the release.
Releasing Windows 11 Build 22631.5545 to the Release Preview Channel
Below is a summary of the new features and improvements included as part of this update separated into two sections: gradual rollout and normal rollout. The bold text within the brackets indicates the item or area of the change documented.
Gradual rollout
The following features and improvements might not be available to all users because they will roll out gradually. Text bolded in brackets indicates the area of the change being documented. Please note that features and improvements that gradually roll out may not begin rolling out right away nor will they immediately show up right away.
  • App defaults] New! We are rolling out some small changes in the EEA region for default browsers via the Set default button in Settings > Apps > Default apps:
    • Additional file and link types will be set for the new default browser, if it registers them.
    • The new default browser will be pinned to the Taskbar and Start menu unless you choose not to pin it by clearing the checkboxes.
    • There is now a separate one-click button for browsers to change your .pdf default, if the browser registers for the .pdf file type.
  • [Windows Share] New! When you share links or web content using the Windows share window, you will see a visual preview for that content.
Normal rollout
  • [Audit] Fixed: An issue with auditing privilege use created too many security event logs. These logs filled up the system drive and prevented users from signing in.
  • [Authentication] Fixed: This update fixes an issue where domain-joined machines running Windows 11 22H2 or 23H2 couldn't update their account passwords on Windows Server 2025 domain controllers, which led to trust relationship issues.
  • Country and Operator Settings Asset (COSA)] Fixed: This update brings profiles up to date for certain mobile operators.
  • [Display Kernel] Fixed: An issue that prevented Remote Desktop Protocol (RDP) connections until you restarted your device.
  • [Network file sharing] Fixed: This update fixes an issue where workstations and servers might stop responding when connecting to resources located on Server Message Block (SMB) shares.
  • [Performance] Fixed: This update addresses an issue that prevented the complete removal of unused language packs and Feature on Demand packages, which previously led to unnecessary storage use and longer Windows Update installation times.
  • [Shell] Fixed: This update resolves an issue where kiosk devices might stop responding after being locked and unlocked by an administrator.
  • Windows Hello] Fixed: This update fixes an issue that prevented the automatic renewal of expiring certificates in Windows Hello for Business.
  • [Windows Search] Fixed: Windows Search responds very slowly—the Search Box can take over 10 seconds to load before you can use it.
Releasing Windows 11 Build 26100.4482 to the Release Preview Channel
Gradual rollout
The following features and improvements might not be available to all users because they will roll out gradually. Text bolded in brackets indicate the area of the change being documented. Please note that features and improvements that gradually roll out may not begin rolling out right away nor will they immediately show up right away.
  • [App defaults] New! We are rolling out some small changes in the EEA region for default browsers via the Set default button in Settings > Apps > Default apps:
  • [Start menu] New! For Admins, the Configure Start Pins policy now includes an option to apply Start menu pins only once. This means users will receive the admin Start menu pins on their first sign-in (day 0), but afterward, they can personalize their pinned layout, and those changes will be retained. This policy can also be applied through group policy, in addition to the existing configuration service provider (CSP) method.
  • [Taskbar & System Tray]
    • New! The taskbar now resizes icons to fit more apps when space runs low, keeping everything visible and easy to access. You can adjust how icons appear in settings—reduce icon size only when the taskbar is full (default), keep icons at their original size at all times by selecting Never, or use smaller icons all the time by selecting Always. To change this setting, right-click an empty area on the taskbar, select Taskbar settings, expand the Taskbar behaviors section, and choose your preference under Show smaller taskbar buttons.
    • New! In addition to the new grouping of the Accessibility menu in Quick settings, there are text descriptions for the assistive technologies like Narrator, Voice access, and more for easier identification and learning.
    • New! Adjusted the indicator (pill) under taskbar apps to make it wider and more visible.
    • Fixed: Clicking the top third of the buttons in the top row doesn't work to enable or disable the button.
    • Fixed: WIN + CTRL + Number doesn't work anymore for switching windows of an open app in the taskbar
    • Fixed: When using taskbar in Windows, the media controls that appear in the preview windows for apps might unexpectedly flicker.
  • [Windows Share]
    • New! When you share links or web content using the Windows share window, you will see a visual preview for that content.
    • New! In the Windows share window, you can select a compression level—High, Medium, or Low Quality—when editing and sharing images, instead of selecting from a 0–100 scale.
  • [PC Migration] We're beginning the rollout of a new PC-to-PC migration experience in Windows. You'll start to see the landing and the pairing page in the Windows Backup app, giving you a first look at what's coming. In the full experience, you will be able to transfer your files and settings from your old PC to the new one during the PC setup process. Support during the PC setup will be available in a future update. We are releasing in phases for a smooth experience and will provide more details soon.
  • [File Explorer] Improved: Performance has been enhanced when extracting archive files – this will particularly help in the case of copy pasting large numbers of files out of large 7z or .rar archives.
  • Narrator
    • New! The Screen Curtain feature in Narrator helps protect your privacy and improve focus by blacking out the screen while Narrator reads content aloud. This is especially helpful in public or shared spaces, where you can work with sensitive information without others seeing your screen. To turn on Narrator, press Ctrl + Windows + Enter. Then press Caps Lock + Ctrl + C to enable Screen Curtain. While it's on, you can use Narrator as usual with the screen hidden. Press Caps Lock + Ctrl + C again to turn it off.
    • New! Narrator makes it easier to discover and learn about its features directly within the experience. Whether you're new or exploring advanced options, Narrator will guide you through the latest updates using a series of steps and prompts that explain each new feature and change.
  • [Voice Access]
    • New! You can now use voice access to navigate, dictate, and interact with Windows using voice commands in Simplified Chinese and Traditional Chinese.
    • New! You can add custom words to the dictionary in voice access. The feature will be available in all the currently supported voice access languages.
  • [Settings]
    • New! The Settings homepage on PCs managed by IT administrators now includes cards tailored for enterprise use. These include familiar options like "Recommended settings" and "Bluetooth devices," along with two cards for device info and accessibility preferences. If a user signs in with both a work or school account and a Microsoft account, an additional accounts card appears to show both account types.
    • New! Added the country or region selected during device setup under Settings > Time & language > Language & region.
    • Fixed: The storage card in Settings > System > About shows an incorrect or unreadable character instead of the proper disk size.
  • [Windowing]
    • Fixed: When you ALT + Tab out of a full screen game, other windows (like Windows Terminal might stop responding.
    • Fixed: An underlying issue might lead to unexpected window size and position changes after sleep/resume for some devices.
    • Fixed: Explorer.exe might stop working unexpectedly when dragging a window if window snapping is enabled.
  • [Scripting] Fixed: Running a script on a remote SMB share might take an unexpectedly long time if the share was an older Windows Server version like Windows Server 2019.
  • [Graphics]
    • Improved: Made some underlying changes to help improve display related user experiences, including reducing screen flashing in some display configuration transitions and removing unnecessary display resets which was happening in some cases.
    • Fixed: Certain displays might be unexpectedly green.
    • Fixed: If User Account Control (UAC) is set to Always Notify and the button under Settings > System > Display for color calibration is selected for your display and canceled, Settings  will stop responding.
  • [Color Filters] Improved: Adjusted the location of the intensity and color boost sliders under Settings > Accessibility > Color Filters, so the color previews at the top of the page are visible while adjusting the sliders.
  • [Input] Fixed: Typing Japanese with the touch keyboard may stop working after switching to typing with an English keyboard and back.
  • [Printing] Fixed: Printed lines might be unexpectedly thicker than expected.
  • [MSFTEdit.dll] Fixed: Some apps like Sticky Notes and dxdiag might stop working when the display language is set to Arabic or Hebrew.
Normal rollout
  • [Copilot] Fixed: Improved the Copilot key's reliability and resolved an issue that prevented users from restarting Copilot after using the key.
  • [Performance] Fixed: This update addresses an issue to maintain efficiency of Storage Spaces Direct (S2D). When running complex software defined data center (SDDC) related workflows, it's possible the system might become unresponsive.
  • [Storage optimization] Fixed: An issue that prevented unused language packs and Feature on Demand packages from being fully removed, which led to unnecessary storage use and longer Windows Update installation times.
  • [Windows Search]
    • Fixed: Windows Search responds very slowly—the Search Box can take over 10 seconds to load before you can use it.
    • Fixed: This update enhances the reliability of Windows Search and resolves an issue that prevented users from typing in Windows Search in some cases.
Releasing Windows 11 Build 22631.5696 to the Release Preview Channel
Releasing to Insiders in the Release Preview Channel on Windows 11, version 23H2 (Build 22631).
Normal rollout
  • [File systems]
    • Fixed: This update addresses an issue in the Resilient File System (ReFS) where using backup applications on large files could occasionally result in system memory becoming fully exhausted.
    • Fixed: An issue where searching for PDF files in a shared folder could return incorrect error messages—such as "No More Files" or "STATUS_NO_MORE_FILES." These errors disrupted output to the virtual PDF printer and interfered with backup processes.
  • [Networking] Fixed: An issue where peripheral devices could take longer to work after resuming from hibernation on some devices with active cellular connections.
  • [Printer] Improved: Printer names now appear more clearly when using IPP Directed Discovery, making it easier to identify printers during setup.
  • [Stability issue] Fixed: This update addresses an issue observed in rare cases after installing the May 2025 security update and subsequent updates causing devices to experience stability issues. Some devices became unresponsive and stopped responding in specific scenarios.
Releasing Windows 11 Build 26100.4762 to the Release Preview Channel
Releasing to Insiders in the Release Preview Channel on Windows 11, version 24H2 (Build 26100).
Gradual rollout
  • [Recall]
    • New! In the European Economic Area (EEA), Recall now supports exporting snapshots to share with trusted third-party apps and websites. When saving snapshots is turned on for the first time, a unique Recall export code appears. This code is required to decrypt exported snapshots and is shown only once during initial setup. Microsoft doesn't store or recover this code. To export, go to Settings > Privacy & Security > Recall & Snapshots > Advanced Settings and authenticate with Windows Hello. Choose to export past snapshots (from the last 7 days, 30 days, or all) or start a continuous export. Third-party apps can access exported snapshots only when both the export code and folder path are provided. If you lose or compromise the export code, reset Recall to generate a new one.
    • New! We are adding the ability to reset Recall and all its data. You will now see an advanced settings page under Settings > Privacy & Security > Recall & Snapshots. Under this new advanced settings page, we have included a reset button that will delete all your snapshots and reset your settings for Recall.
  • [Click to Do]
    • New!1 Practice in Reading Coach is a new Click to Do text action that helps you improve reading fluency and pronunciation. Select text on your screen, choose Practice in Reading Coach, and read the text aloud. Reading Coach gives you feedback and shows where to improve. To use this feature, install the free Microsoft Reading Coach app from the Microsoft Store.
    • New!1 Read with Immersive Readeris a new text action in Click to Do that displays text in a focused, distraction-free environment. It helps improve reading and writing for all skill levels and abilities. You can adjust text size, spacing, font, and background theme, have text read aloud, break words into syllables, and highlight parts of speech. The picture dictionary shows images for unfamiliar words. To use this feature, install the free Microsoft Reading Coach application from the Microsoft Store.
    • New!1 With the Draft with Copilot in Word text action, you can quickly turn any recognized text into a full draft. Whether it's a sentence in an email or a snippet on your screen, press Win + Click on the recognized text, then select Draft with Copilot in Word. No more blank pages. No more writer's block. Just momentum. For "Draft with Copilot in Word" – a Microsoft 365 Copilot subscription is required.
    • New!1 Click to Do on Copilot+ PCs now supports actions through Microsoft Teams. When you select an email address recognized by Click to Do on your screen, you can choose to send a Teams message or schedule a Teams meeting. These options make it easy to ask a question or set up time to talk without interrupting your workflow.
  • [Settings]
    • New!1 The new agent in Settings is part of the Copilot+ PC experience and is designed to help solve one of the most common frustrations: finding and changing settings on your PC. You can describe what you need help with, such as "how to control my PC by voice" or "my mouse pointer is too small," and the agent will suggest steps to resolve the issue. An agent uses AI on your PC to understand your request and, with your permission, can automate and complete tasks for you. This experience is rolling out to Snapdragon-powered Copilot+ PCs, with support for AMD and Intel™-powered PCs coming soon. It currently works only if your primary display language is set to English.
    • New! On non-Copilot+ PCs, the search box in Settings will now be located at the top center to deliver a more consistent and better search experience.
    • Fixed: If your PC is set to 'Do nothing' on 'Closing the lid' in Settings > System > Power and Battery and the Settings window is left open when you close the lid, upon opening the lid again Settings window might hang and become unresponsive to input or resizing (instead, just showing your accent color).
    • Fixed: Settings may hang when attempting to save credentials for Wi-Fi network
  • [Windows Resiliency Initiative] The following changes are part of the Windows Resiliency Initiative announced at Ignite 2024:
    • New! Quick machine recovery is now available. When enabled, it automatically detects and fixes widespread issues on Windows 11 devices using the Windows Recovery Environment (WinRE). This reduces downtime and avoids the need for manual fixes. If a device experiences a widespread boot issue, it enters WinRE, connects to the internet, and Microsoft can deliver a targeted fix through Windows Update. IT admins can enable or customize this experience for their organization through the Intune Settings Catalog UI using the RemoteRemediationCSP. There is also a dedicated quick machine recovery settings page available under System > Recovery > Quick machine recovery. Today it's enabled by default for home users.
    • New! A more streamlined interface appears during an unexpected restart This updated design aligns with Windows 11's visual style and helps you return to work faster. The screen displays a more readable layout while keeping the technical details visible. This screen appears with a black background.
  • [Start menu] New! For admins, the Configure Start Pins policy now includes an option to apply Start menu pins only once. This means users will receive the admin Start menu pins on their first sign-in (day 0), but afterward, they can personalize their pinned layout, and those changes will be retained. This policy can also be applied through group policy, in addition to the existing Configuration Service Provider (CSP).
  • [Snap] New! Improvements make it easier to learn and use Snap in Windows 11. Inline messages now appear when you accidentally open the Snap Bar by dragging an app to the upper center of your desktop or open the Snap menu by hovering over the Minimize or Maximize button. These messages provide helpful tips on Snap app windows and show keyboard shortcuts.
  • [Windows Search] New! Windows Search settings are now easier to find. Instead of two separate pages for settings ("Search permissions" and "Searching Windows"), you'll now find everything in one place under Settings > Privacy & security > Search. This new page has a modern look and a better layout, so you can quickly view and manage all your Windows Search settings.
  • [File Explorer]
    • Fixed: If you opened the "..." menu in the File Explorer address bar to show the full list of folders for the current path, the dropdown may be cut off and the bottom of it inaccessible.
    • Fixed: File operation progress dialogs may stop appearing when displayed from apps.
    • Fixed: The more SharePoint sites are synced to File Explorer, File Explorer may start to show noticeable performance degradation when navigating through folders and opening the context menu. In this state it may also impact the performance of launching files.
  • [Input] New! The Gamepad layout of the Windows touch keyboard now includes enhanced controller navigation and improved focus handling for child keys, menus, word suggestions, language switching, and settings. A new Gamepad keyboard, designed for gaming, also supports PIN sign-in on the Windows lock screen. It offers controller shortcuts for quick PIN entry and full navigation for those who prefer not to use shortcuts.
  • [Desktop icons] Fixed: If you have an app pinned to your desktop, and the app updates, the app icon may no longer display correctly and instead show a white page.
  • [Notifications] Fixed: Clicking a Windows notification toast may unexpectedly not bring the relevant app into the foreground, for example when interacting with Outlook notifications.
1Functionality will vary by device and market; text actions will be available across markets in select character sets. See aka.ms/copilotpluspcs.
Normal rollout
  • [Authentication] Fixed: This update addresses an issue that affects the Local Security Authority Subsystem Service (LSASS). LSASS might stop responding during machine password changes with specific audit settings.
  • [File Explorer] Fixed: File Explorer Home might unexpectedly only display a single folder (for example, Desktop), rather than the expected content with recent files and more.
  • [File system] Fixed: This update addresses an issue in the Resilient File System (ReFS) where using backup applications on large files could occasionally result in system memory becoming fully exhausted.
[UPDATE 7/15] Releasing Build 22631.5699 (KB5062663) today which is a small update that addresses some issues with the update itself.
Normal rollout
  • [File systems]
