Windows 11 Insider Release Preview Channel
Started by Corrine, September 23, 2021, 05:53:19 PM
Releasing Windows 11 Build 26100.4762 to the Release Preview Channel
[UPDATE 7/17] We are releasing Build 26100.4767 (KB5062663) today which is a small update that adds some additional fixes. See the linked blog post for the fixes in this release.
Releasing Windows 11 Build 26100.5061 to the Release Preview Channel
This update is for Windows Insiders in the Release Preview Channel on Windows 11, version 24H2 (Build 26100).
Gradual rollout
The following features and improvements might not be available to all users because they will roll out gradually. Text bolded in brackets indicate the area of the change being documented. Please note that features and improvements that gradually roll out may not begin rolling out right away nor will they immediately show up right away.
  • [Recall] New! Recall opens to a personalized homepage that puts your recent activity and top-used apps and websites front and center, making it easy to pick up where you left off. After turning on snapshot collection, the homepage highlights key productivity features like Recent Snapshots, which show the latest snapshots to help you quickly resume tasks, and Top Apps and Websites, which display the three apps and websites you've used most in the past 24 hours. You can set filters in Settings to control which apps and websites are saved in snapshots. A new navigation bar on the leftmost side of the screen provides quick access to Home, Timeline, Feedback, and Settings.
  • [Click to Do] New! When you launch Click to Do for the first time, you'll see a quick interactive tutorial. It shows how to complete tasks faster by demonstrating actions on both text and images—such as summarizing large blocks of text or removing image backgrounds. To revisit the tutorial later, select More options ... > Start tutorial.
  • [General] New! When an app requests access to location, camera, microphone, or other device capabilities, Windows shows a redesigned system dialog box. The screen dims slightly, and the privacy prompt appears centered on the screen.
  • [Taskbar]
    • New! The larger clock with seconds is now back in the notification center, displayed above the date and calendar. To turn this option on, go to Settings > Time & language > Date & time, and turn on Show time in the Notification Center.
    • Fixed: If you accidentally click down and slide your mouse on the taskbar preview thumbnail, clicking it may stop working.
    • Fixed: File Explorer preview windows may appear when hovering over unrelated app icons in the taskbar.
  • [Search on the Taskbar]
    • New! When you use Search from the Windows taskbar, a new grid view will help you more quickly and accurately identify the desired image within your search.
    • New! Search on the taskbar now provides clearer status information. If your search results are incomplete while your PC is organizing files in the background, Windows shows a notice with a link to check progress. You can dismiss the notice when you're done. There is also a status for files and folders, so you can easily tell whether they're available online (cloud) or stored on your device.
  • [Lock screen] New! After rolling this experience out to Windows Insiders in the EEA, we are now beginning to roll out more widget options on the lock screen as well as support for lock screen widget personalization (previously referred to as "Weather and more") with Insiders in all regions. You can add, remove, and rearrange lock screen widgets such as Weather, Watchlist, Sports, Traffic, and more. Any widget that supports the small sizing option can be added here. To customize your lock screen widgets, navigate to Settings > Personalization > Lock screen.
  • [File Explorer]
    • New! Use AI actions in File Explorer to edit images or summarize documents. Just right click (or Press Shift+F10) on a file and select AI Actions.
      • Image actions: You can now use four AI-powered image actions with .jpg, .jpeg, and .png files. Visual Search searches the web using an image instead of text. Blur Background opens the Photos app to highlight the subject and blur the background. Erase Objects removes unwanted elements from your photo. Remove Background uses Paint to change any image leaving a smooth cut out of the subject.
      • AI actions for Microsoft 365 makes it easier to work with your documents. With the Summarize action in Copilot, you can quickly generate summaries of files stored in OneDrive and SharePoint—no need to open each one. This AI action requires an active Microsoft 365 subscription and a Copilot license (Microsoft account and Microsoft Entra ID supported).New! Dividers now appear between top-level icons in the File Explorer context menu.
    • New! When you're signed in with a work or school account (Entra ID), File Explorer will display people icons in the Activity column and the Recommended section at the top of File Explorer Home. Hover over or select a person's icon to open their Microsoft 365 Live Persona Card, which shows who they are and how they're connected to the file.
    • Fixed: If you try to use the unblock open in Properties for a file, it still shows as blocked when you open Properties the next time.
  • Windows Hello]
    • New! As part of the enhanced passkey features released in September 2023, you'll see a redesigned Windows Hello interface. These modernized visual updates support fast, clear communication that appear across multiple authentication flows, including the Windows sign-in screen, passkey, Recall, the Microsoft Store, and more. The Windows  security credential experience for passkey offers a cleaner, more intuitive interface designed to support fast, secure sign-in. You can now easily switch between authentication options such as passkeys or connected devices.
    • Fixed: Windows Hello may recognize your face on the login screen, however it would still fail and then prompt you to enter your pin. If you continue experiencing issues, you may need to go to the Facial Recognition section under Settings > Accounts > Sign-in options, and select Improve recognition.
    • Improved: Fingerprint login after standby is now more robust.
  • [Advanced Settings] New! The redesigned Advanced settings page under Settings > System > Advanced is an update of the For Developers page and makes it easier to find key options. New settings include Enable long paths, which removes MAX_PATH limitations; Virtual workspaces, which let you turn environments like Hyper-V and Windows Sandbox on or off; and File Explorer + version control, which shows Git details such as branch, diff count, and last commit message directly in File Explorer when you select a repository folder.
  • [Settings]
    • New! Windows activation and expiration prompts match the Windows 11 design and appear as system notifications when action is required. There also have been improvements to messaging under Settings > System > Activation.
    • New! You can go to Settings > Privacy & security > Text and Image Generation to see which third-party apps have recently used generative AI models provided by Windows. You can also choose which apps are permitted to use them—putting you in charge of your device's AI experience.
    • New! You can view the Device Card on the Settings home page. It shows key specifications and usage details of your PC. From the card, go directly to Settings > About page for more detailed information about your PC. This card will show when signed in with your Microsoft account and in the U.S. only.
    • New! More time, language, and keyboard settings have moved from Control Panel to Settings. You can now add additional clocks, change your time server, and customize date and time formatting—including AM/PM symbols—directly from Settings > Time & language > Date & time. Number and currency formats, Unicode UTF-8 support, and options to copy language and region settings to other accounts are now under Settings > Time & language > Language & region. Keyboard character repeat and cursor blink rate settings are now easier to find under Settings > Accessibility.
    • New! As part of the Copilot+ PC experience, the agent in Settings helps you quickly find and change settings. Initially available on Snapdragon®-powered Copilot+ PCs, agent in Settings now supports AMD- and Intel™-powered Copilot+ PCs. It currently works only when your primary display language is set to English.
    • Fixed: Settings may crash if you attempt to add a security key under Settings > Account > Sign-in options.
  • [Task Manager] New! Task Manager now uses standard metrics to show CPU workload consistently across all pages, aligning with industry standards and third-party tools. If you prefer the previous view, you can enable a new optional column called CPU Utility in the Details tab to display the earlier CPU usage value shown on the Processes page.
  • [Windows Backup for Organizations] New! Windows Backup for Organizations is now generally available! Experience seamless device transitions with enterprise-grade backup and restore. Whether you're refreshing your organization's devices, upgrading to Windows 11, or deploying AI-powered PCs, this solution helps sustain productivity with minimal disruption, ensuring business continuity and organizational resilience.
  • [PowerShell 2.0] Starting in August 2025, Windows 11, version 24H2, will no longer include Windows PowerShell 2.0.This  legacy component was  introduced in Windows 7 and officially deprecated in 2017. Most users won't be affected, as newer versions such as PowerShell 5.1 and PowerShell 7.x remain available and supported. If you use older scripts or tools that depend on PowerShell 2.0, update them to avoid compatibility issues.
  • [Live captions] Fixed: Changing the opacity of live captions in Settings > Accessibility > Captions > Caption Style, has no effect.
  • [Input]
    • Fixed: Attempting to type Chinese with an IME after copying something with CTRL + C can result in the first character not displaying.
    • Fixed: An underlying issue related to textinputframework.dll could result in certain apps like Sticky Notes and Notepad crashing.
  • [Kerberos] Fixed: There may be an underlying crash in Kerberos when attempting to access a cloud file share.
  • [Login] Improved: Addressed some underlying cases which could lead to you seeing a blank white screen, or a screen saying, "just a moment", for a few minutes when logging in to your PC.
  • [dbgcore.dll] Fixed: An underlying issue with dbgcore.dll could result in certain apps, including explorer.exe, crashing.
  • [Audio] Improved: Addressed an underlying audio service hang which could impact the ability to play audio in certain cases.
Normal rollout
This update includes the following features and improvements that are rolling out as part of this update. Text bolded in brackets indicates the area of the change being documented.
  • [Device management] Fixed: This update addresses an issue that prevented some system recovery features from working properly due to a temporary file sharing conflict. This affected certain device management tools and disrupted key functions on some devices.
  • [File system] Fixed: An issue in Resilient File System (ReFS) where using backup apps with large files could sometimes exhaust system memory.
  • [Input]
    • Fixed: This update addresses an issue with the Chinese (Simplified) Input Method Editor (IME) where some extended characters appear as empty boxes.
    • Fixed: This update addresses an issue that prevents typing on the touch keyboard when using the Microsoft Changjie, Microsoft Bopomofo, or Microsoft Japanese Input Method Editors (IMEs). The issue occurs after switching to a previous version of the IME.
  • [Performance] Fixed: This update addresses an issue that slows application installation on ARM64 devices. Some installers might take longer to complete.
Releasing Windows 11, version 25H2 to the Release Preview Channel
This year's annual feature update Windows 11, version 25H2 (Build 26200.5074) is available in the Release Preview Channel for customers to preview ahead of general availability later this calendar year.
Windows 11, version 25H2 will be delivered as an enablement package (eKB). This means that Windows 11, version 24H2 and version 25H2 use a shared servicing branch. It also means that they also share the same new features and enhancements delivered through our continuous innovation efforts. Windows 11, version 25H2 also includes some feature removals such as PowerShell 2.0 and Windows Management Instrumentation command-line (WMIC). And for our commercial customers, Windows 11, version 25H2 includes the ability for IT admins to remove select pre-installed Microsoft Store apps via Group Policy/MDM CSP on Enterprise/EDU devices. For more details on Windows 11, version 25H2, see this blog post.
Windows Insiders in the Release Preview Channel can install Windows 11, version 25H2 via our "seeker" experience in Windows Update. This means if you are an Insider currently in the Release Preview Channel on a PC that meets the Windows 11 hardware requirements, you can go to Settings and Windows Update and choose to download and install Windows 11, version 25H2 if you want. Once you update your PC to Windows 11, version 25H2, you will continue to automatically receive new servicing updates through Windows Update (the typical monthly update process). For instructions on how to join the Windows Insider Program and join your PC to the Release Preview Channel, click here.
Commercial* customers enrolled in the Windows Insider Program for Business can begin validating Windows 11, version 25H2 on PCs in their organizations. For these customers, the Windows 11, version 25H2 is available through Windows Update for Business (WUfB) and Windows Server Update Service (WSUS). Azure Marketplace will be available later today. You can learn more about deploying pre-release feature updates using these deployment methods here. Should any issues arise, IT admins in organizations deploying Release Preview updates can request Microsoft Support.
And finally – ISOs will be available for download for Windows 11, version 25H2 via the Windows Insider ISO download page next week.
Releasing Windows 11 Build 22631.5982 to the Release Preview Channel
This Build is for Insiders in the Release Preview Channel on Windows 11, version 23H2 (Build 22631).
  • [Authentication] Fixed: An issue that caused Windows sign-in screen to stop responding after a user enters the SIM PIN during sign-in using a mobile broadband connection.
  • [Country and Operator Settings Asset (COSA)] Fixed: This update brings profiles up to date for certain mobile operators.
  • [Display Kernel] Fixed: This update addresses an issue that affects display configuration changes during Remote Desktop Protocol (RDP) sessions with multiple monitors. The system might shut down unexpectedly when disconnected from a docking station during a streaming session.
  • [Input]
    • Fixed: An issue where some characters didn't display correctly when using the Chinese Input Method Editor (IME).
    • Fixed:  This update addresses an issue where certain Chinese characters appeared as empty boxes in some text fields, such as those used in Connection Manager Administration Kit, when a character limit was set.
  • [Printer] Fixed: An issue where viewing the printer queue in Settings for a shared printer caused the Print Queue user interface to stop working.
  • [System services and reliability] Fixed: Addresses an issue that caused McpManagement service to appear without a description on Windows.
Releasing Windows 11 Build 22631.5984 (KB5065790) to the Release Preview Channel
This is an update to the previous release which had some issues with the update and is forInsiders in the Release Preview Channel on Windows 11, version 23H2 (Build 22631).
  • [Input]
Releasing Windows 11 Builds 26100.6718 and 26200.6718 KB5065789 to the Release Preview Channel
This is a small update to Insiders in the Release Preview Channel on Windows 11, version 24H2 (Build 26100) and version 25H2 (Build 26200) that includes some additional changes noted below.
Gradual rollout
[Click to Do]
  • New! Click to Do can now detect tables. You can now highlight any simple table and send it to Excel, copy or share it. With a table in any application, you can press Win + Click to invoke Click to Do, or Win + Q or right swipe and tap to select the table. Once selected, you'll see the actions you can take like Convert to table with Excel. Just click, capture and continue. This is available on Snapdragon-powered Copilot+ PCs, with support for AMD and Intel-powered Copilot+ PCs coming soon. You'll need the latest Microsoft Excel application installed on your PC to see Convert to table with Excel and a Microsoft 365 Subscription. This change is not yet rolling out to Windows Insiders in the EEA (European Economic Area). [UPDATE 9/17] This feature will roll out in a future update.
Normal rollout
The following fixes were added on 9/17:
  • [Media] Fixed: This update addresses an issue that affects playback of protected content in certain Blu-ray, DVD, and digital TV apps. This can occur after installing KB5064081.
  • [Performance] Improved: Added support for Certificate Revocation List (CRL) partitioning in Windows Certificate Authorities.
  • [Battery] Fixed: The battery icon in the taskbar may not display a charging state even though your PC is charging.
  • [Settings] Fixed: Settings may crash when attempting to access drive information under Settings > System > Storage. This also impacts trying to launch these pages from File Explorer drive properties.
  • [Windows Update] Fixed: Some Insiders see error 0x80070002 when attempting to install the build.
Releasing Windows 11 Builds 26100.7015 and 26200.7015 to the Release Preview Channel
Gradual rollout
  • [Start menu] New! The redesigned Start menu, built to help you access your apps more quickly and smoothly. Its redesigned layout makes it easier than ever to find what you need.
    • Scrollable 'All' section: The main page now includes a scrollable "All" section, making it easier to find apps.
    • Category and grid views: Switch between two new views—category view, which groups apps by type and highlights frequently used ones, and grid view, which lists apps alphabetically with more horizontal space for easier scanning. The menu remembers your last selected view.
    • Responsive layout: The Start menu adapts to your screen size. Larger displays show more pinned apps, recommendations, and categories by default. Sections like Pinned and Recommended expand or collapse based on content. You can customize these views under Settings > Personalization > Start.
    • Phone Link integration: A new mobile device button next to Search lets you expand or collapse content from your connected phone. This feature supports Android and iOS devices in most markets and will roll out to the European Economic Area (EEA) in 2025.
  • [Voice access]
    • New! Fluid Dictation in voice access makes voice-based dictation smoother and smarter. It helps correct grammar, punctuation, and filler words in real time. Powered by on-device small language models (SLMs), it offers fast and private processing. Fluid Dictation is on by default—just open the voice access app to start. To turn it on or off, go to Settings or say Turn on Fluid Dictation or Turn off Fluid Dictation. You can use it in most text input apps, but it's disabled in secure fields like passwords or PINs Fluid Dictation is available in all English locales on Copilot+ PCs.
    • New! You can now configure a delay before a voice command is executed. To set this up, go to Voice access settings > Wait time before acting, and select the option that best matches your preferences.
    • New! Voice Access now supports Japanese, expanding accessibility for more users. You can now navigate, dictate, and interact with Windows using voice commands.  With this update, Windows users who speak Japanese can enjoy a hands-free, voice-powered PC experience.
    • Fixed: Voice access unexpectedly stops working, showing error code 9001.
  • [Agent in Settings] New! The new agent in the Settings experience now supports French.
  • [Settings] New! The "Email & accounts" section is now called "Your accounts." You manage all your accounts under Settings > Accounts.
  • [Click to Do]
    • New! The prompt box in Click to Do streamlines interaction with Copilot, helping you work more efficiently. You can type a custom prompt directly into the text box, which sends your prompt and selected on-screen content to Copilot. Suggested prompts appear below the text box and are powered locally by https://learn.microsoft.com/en-us/windows/ai/apis/phi-silica. These suggestions are available for text selections in English, Spanish, and French. This feature isn't currently available in the European Economic Area (EEA) or China.
    • New! You can now translate on-screen text with Microsoft Copilot with Click to Do. When you select text that is in a different language from your Windows display language or preferred language setting, a translation suggestion appears. After selecting the option to translate the text, the translated text will appear in the Copilot app. You can see the supported regions and languages in Microsoft Copilot. This experience is not yet available for customers in the EEA (European Economic Area) or China.
    • New! Click to Do provides unit conversions for length, area, volume, height, temperature, and speed. When you hover over a number + unit, a floating tooltip will show you the conversation. When you select the number + unit, the context menu opens with additional conversation options. You can also access more conversions via the Copilot app. This experience is not yet available for customers in the EEA (European Economic Area) or China.
    • New! By pressing and holding two fingers anywhere on your Copilot+ PC with a touch screen, you can simultaneously launch Click to Do, select the entity under your finger and see relevant actions.
    • New! You can now select objects in Click to Do using Freeform Selection, Rectangle Selection and Ctrl + Click. To use Freeform Selection Mode, select the Freeform button on the toolbar. Then use your pen or finger to draw freely around the items you want to select. To use the Rectangle Selection Mode, select the Rectangle Selection button on the toolbar. Then drag a box around the items. Everything inside the rectangle will be selected. You can also use Ctrl + Click to select multiple types of items—such as text and images—by holding down the Ctrl key and selecting each item.
    • New! Live Persona Cards from Microsoft 365 now appears in Click to Do. To view a profile card, press Win + Click on an email address from your organization.
    • New! Visual cues now make key items, such as emails, tables, and more, light up on your screen as you launch Click to Do.
    • Fixed: Click to Do may unexpectedly invoke sometimes when pressing Windows key + P.
  • [File Explorer]
    • New! Recommended files in File Explorer Home are now available in personal Microsoft accounts and local accounts. Recommended files show content such as files you frequently used, have recently downloaded, or added to your File Explorer Gallery. This change is not yet rolling out in the EEA (European Economic Area). If you would prefer not to see the recommended section in File Explorer Home, this can be turned off in File Explorer Folder Options. When turned off, folders pinned to Quick Access will display instead.
    • New! When you hover over a file in File Explorer Home, commands such as Open file location or Ask Copilot This experience is available if you're signed in with a Microsoft account. Support for work and school account (Entra ID) will be available in a future update. This change is not available in the EEA (European Economic Area).
    • New! StorageProvider APIs are now available for cloud providers to integrate with File Explorer Home. Developers can learn to enable the system to query for suggested files.
    • Fixed: The File Explorer context menu may unexpectedly switch back and forth between the normal view and Show More Options on each right click.
    • Fixed: When opening a folder from another app (for example, opening the Downloads folder from a browser), your custom view — including sorting files by name, changing the icon size, or removing grouping — unexpectedly resets back to default.
    • Fixed: The body of the File explorer window may no longer respond to mouse clicks after invoking the context menu.
    • Fixed: Extracting very large archive folders (1.5gb+) may fail with a Catastrophic Error (0x8000FFFF).
    • Fixed: File Explorer may become unresponsive when opening Home.
  • [Taskbar]
    • New! The battery icons are now improved to display colored icons to indicate charging states, simplified overlays that don't block the percentage bars, and an option to turn on battery percentage. A green battery icon shows that your PC is charging and is in a good state. A yellow icon indicates your battery is less than or equal to 20%. You can also enable the ability to see the battery percentage next to the battery icon in the system tray. To turn on this feature, go to Settings > Power & battery and toggle on the "Battery Percentage"
    • New! When you hover over an open app icon on the taskbar, a thumbnail preview of the app window appears with a new "Share with Copilot" button beneath this preview. Selecting it allows Copilot Vision to scan, analyze, and offer insights on the content displayed by the app at that time. This option can be turned off if preferred under Settings > Personalization > Taskbar > Taskbar behaviors, using the checkbox "Share any window from my taskbar".
    • Fixed: If you hover over an app icon on the taskbar, and then click the window preview, the preview may dismiss and not bring the window to the foreground.
  • [Lock screen] New! The new battery icons, featuring color indicators and battery percentage, now appear in the lower-right corner of the lock screen.
  • [Microsoft 365 Copilot] New! A new Microsoft 365 Copilot page is added to the Get Started experience for commercial devices managed with an active Microsoft 365 subscription. This page helps you discover and engage with Microsoft 365 Copilot more easily.
  • [Windows Setup Experience] New! You can now name your default user folder during set up. On the Microsoft account sign in page, press Shift + F10 to open Command Prompt. Type the following command: "cd oobe", press Enter. Then type ""SetDefaultUserFolder.cmd ". Enter a folder name of your choice and proceed with the MSA sign-in. The folder name cannot be more than 16 characters and only Unicode characters are supported. The custom folder name will be applied if valid. If not, Windows will automatically generate a profile folder name from your Microsoft email address.
  • [Logging into your PC] Improved: Made underlying changes to help improve the performance of loading the taskbar when unlocking your PC after coming out of sleep. This should also help with cases where the password field and other login screen contents didn't render when transitioning from lock screen to login screen after sleep.
  • [Windows Update]
    • Improved: Addressed underlying issue which can cause "Update and shutdown" to not actually shut down your PC after updating.
    • Improved: Addressed underlying issue which can cause Windows Update to fail to install with error 0x800f0983.
  • [Remote Credential Guard] Fixed: Remote Credential Guard scenarios between the latest Windows 11 builds and Server 2022 (and below) may unexpectedly fail.
  • [Display and Graphics]
    • Fixed: Apps and browsers may have partially stuck onscreen content when other maximized / full screen apps are updating in the background. This is noticeable particularly when trying to scroll the window content, as only some parts update.
    • Fixed: After recent updates, some videos and games may be unexpectedly red.
    • Fixed: If Connected Devices Platform Service has been disabled, Settings may crash when trying to open Settings > System > Display (including if launched using the menu when right clicking the desktop.
  • [Input] Fixed: An issue related to microsoft.ink.dll and relevant APIs can result in pen and handwriting not working correctly in apps or app crashes recently due to unexpected exceptions being thrown.
  • [Open and Save Dialog] Fixed: Certain apps may become unresponsive when launching the Open or Save Dialog.
  • [Administrator Protection Preview] Administrator protection aims to protect free floating admin rights for administrator users allowing them to still perform all admin functions with just in time admin privileges. This feature is off by default and needs to be enabled via OMA-URI in Intune or via group policy.
Normal rollout
  • [Authentication] Fixed: An issue that caused an ACCESS_DENIED error when users attempted to change passwords remotely on member servers or workgroup devices, even when they had the required permissions.
  • [Media] Fixed: This update addresses an issue where protected content playback fails on some machines after installing KB5064081.
