Windows 10 Release Preview
Started by Corrine, July 28, 2022, 05:19:30 PM
Releasing Windows 10 Build 19045.4474 to Release Preview Channel
This update includes the following features and improvements:
  • This update addresses an issue that affects a Microsoft Entra ID account. Devices cannot authenticate a second one. This occurs after you install the Windows update, dated November 13, 2023
  • This update addresses an issue that affects a server after you remove it from a domain. The Get-LocalGroupMember cmdlet returns an exception. This occurs if the local groups contain domain members.
  • This update addresses an issue that affects a Windows Presentation Foundation (WPF) app. It stops responding.
  • This update addresses an issue that displays a hidden window. Its title bar has no content and no client area. This occurs when you share your screen using certain apps.
  • This update addresses an issue that affects an IPP-over-USB printer. After you delete it, it still appears as not available in Control Panel.
  • This update addresses an issue that affects TWAIN drivers. They might stop responding when you use them in a virtual environment.
  • This update brings Country and Operator Settings Asset (COSA) profiles up to date for certain mobile operators.
  • This update addresses an issue that affects the Share button on USB controllers. It might not work with Game Bar.
  • This update addresses an issue that affects Unified Write Filter (UWF) Windows Management Instrumentation (WMI) API calls. Calls to shut down or restart the system throw an access denied exception.
Releasing Windows 10 Build 19045.4593 to Beta and Release Preview Channels
Going forward, the Beta Channel and Release Preview Channel will receive the same Windows 10 builds; however, the Beta Channel is where new features will be tiried out with Insiders that are not yet ready for all Windows 10 customers.
For Windows Insiders on Windows 10 in the Beta Channel, we're beginning to roll out the following improvements:
[Search on the Taskbar]
  • We're made some fixes to improve the overall stability of searching for apps in the search box on the taskbar.
[Windows Backup]
  • You will be able to seamlessly backup and restore personalization preferences of Activity History and Printer Device Settings that are not hardware or accessory dependent such as "Let Windows manager my default printer" and "Store my activity history on this device". The goal is to ensure that the most used preferences of these settings are backed up, while avoiding those that are tied to specific hardware, to facilitate a seamless transition to a new PC.
  • We are making some important bug fixes to enhance the backup and restore functionality. As part of this work, the issue causing backup failures when desktop and lock screen backgrounds were backed up twice has been resolved.
Insiders in the Beta Channel on Windows 10 who want to be the first to get features gradually rolled out to you can turn ON the toggle to get the latest updates as they are available via Settings > Updated & Security > Windows Update. Over time, we will increase the rollouts of features to everyone with the toggle turned on. Should you keep this toggle off, new features will gradually be rolled out to your device over time once they are ready.
This update includes the following features and improvements for Windows Insiders in BOTH the Beta and Release Preview Channels:
  • This update addresses an issue that affects MSIX applications. When you install them from an HTTPS URI, they fail to open. This issue occurs when the download of the application is not complete. This damages the package.
  • This update affects mobile device management (MDM). When you enroll a device, the MDM client sends more details about the device. The MDM service uses those details to identify the device model and the company that made it.
  • This update addresses an issue that affects the default Japanese Input Method Editor (IME). The candidate window stops responding when you do not expect it. Then, it goes back to a former composition state at random.
  • This update addresses an issue that affects Direct Composition batched presentations. A brief flash of triangles or boxes show on the screen. This issue affects browsers, like Microsoft Edge, and other apps.
  • This update addresses an issue that might stop your system from resuming from hibernate. This occurs after you turn on BitLocker.
  • This update addresses an issue that affects Windows Defender Application Control (WDAC). The issue copies unsigned WDAC policies to the Extensible Firmware Interface (EFI) disk partition. It is reserved for signed policies.
  • This update addresses an issue that affects an app's jump list on the taskbar. Completing actions from that list might fail. A jump list is a menu that appears when you right-click an app on the taskbar or Start menu. It gives you quick access to recently or frequently used app items.
  • This update addresses an issue that affects a folder context menu. When you choose the command that removes items, the command adds items instead. This occurs when a third-party service implements a sync feature.
ADDED 6/19:
*New! We are advancing the Copilot experience on Windows. It is now pinned to the taskbar and will behave like an app. This gives you the benefits of a typical app experience. For example, you can do things like resize, move, and snap the window. PLEASE NOTE: Managed commercial devices will not receive this new experience. This includes devices not running Windows 10 Home and are managed by an IT administrator.
Releasing Windows 10 Build 19045.4713 to Beta and Release Preview Channels
The Beta Channel and Release Preview Channel will receive the same Windows 10 builds; however, the Beta Channel is where new features will be tried out with Insiders that are not yet ready for all Windows 10 customers. You can read ther announcement for opening the Beta Channel for Windows Insiders on Windows 10 here.
Items bolded in brackets indicate the area of the change being documented:
  • [FrameShutdownDelay] The browser ignores its value in the "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" registry key.
  • [Wi-Fi Protected Access 3 (WPA3)] In the Group Policy editor, HTML preview rendering fails.
  • [Group Policy Preferences Item Level Targeting (ILT) and Local Users and Groups] You cannot choose a group from the target domain for ILT. Also, you cannot choose an account from Local Users and Groups. The forest does not appear. This issue occurs when you deploy multiple forests, and the target domain has a one-way trust with the domain of the admin. This issue affects Enhanced Security Admin Environment (ESAE), Hardened Forests (HF), or Privileged Access Management (PAM) deployments.
  • [Transmission Control Protocol (TCP)] The TCP send code often causes a system to stop responding during routine tasks, such as file transfers. This issue leads to an extended send loop.
  • [Print Support App] When you use the app with a USB device, the app stops responding and does not print. This issue also limits the functions of the user interface.
  • [Universal Print clients] They fail to communicate with the Universal Print service. This affects printing functions. This issue occurs when you turn on Web Proxy Auto Discovery (WPAD).
  • [Windows Defender Application Control (WDAC)]
    • This update prevents a stop error that occurs when you apply more than 32 policies.
    • A memory leak occurs that might exhaust system memory as time goes by. This issue occurs when you provision a device.
    • WDAC fails to verify the policies of some apps.
  • [Windows Kernel Vulnerable Driver Blocklist file (DriverSiPolicy.p7b)] This update adds to the list of drivers that are at risk for Bring Your Own Vulnerable Driver (BYOVD) attacks.
  • [Windows Backup] Backup sometimes fails. This occurs when a device has an Extensible Firmware Interface (EFI) system partition (ESP).
  • [DHCP Option 235 (known issue)] Some Windows devices use this option to find Microsoft Connected Cache (MCC) nodes in their network. But you might not be able to use these nodes when you find them. Instead, these devices download updates and apps from the public internet. Because of this, download traffic increases.
Windows 10 22H2 Build 19045.4842 (KB5041582) is being released to BOTH the Beta Channel and Release Preview Channel for Insiders who are on Windows 10, version 22H2.
  • [Input Method Editor (IME)] When a combo box has input focus, a memory leak might occur when you close that window.
  • [Country and Operator Settings Asset] This update brings COSA profiles up to date for certain mobile operators.
  • [Bluetooth] An app stops responding because of a memory leak in a device.
  • [Bind Filter Driver] Your system might stop responding when it accesses symbolic links.
  • [Unified Write Filter (UWF) and Microsoft System Center Configuration Manager (SCCM)] An SCCM task to re-enable UWF fails because of a deadlock in UWF. This stops the device from restarting when you expect it.
Windows 10 22H2 Build 19045.4955 (KB5043131) released to BOTH the Beta Channel and Release Preview Channel for Insiders who are on Windows 10, version 22H2.
  • [Microsoft Entra single sign-on (SSO)] The SSO notice that the European Digital Markets Act (DMA) requires prompts too often. This occurs when you authenticate using a certificate. To learn more, see: Upcoming changes to Windows single sign-on.
  • [IE mode] Microsoft Edge sometimes stops responding when you use IE mode.
  • [Media playback] Playback of some media might stop when you use certain surround sound technology.
  • [File Explorer and taskbar] Windows server stops responding when you use apps like File Explorer and the taskbar.
  • [Windows Update opt-in notifications] They now appear when you sign in.
  • [Directory enumeration] This might fail if a directory has symbolic links that have long target names.
Releasing Windows 10 Build 19045.5070 to Beta and Release Preview Channels
Windows 10 22H2 Build 19045.5070 (KB5045594) to BOTH the Beta Channel and Release Preview Channel for Insiders who are on Windows 10, version 22H2.
The Beta Channel and Release Preview Channel will receive the same Windows 10 builds; however, the Beta Channel is new features will be tried out with Insiders that are being worked on that are not yet ready for all Windows 10 customers.
[Settings]
  • Under Settings > System > About, you will now find a refreshed experience with new top cards that highlight key hardware specifications of your device. These cards are designed to keep you informed about the most important details of your device's hardware that matter to you. We've also added FAQs directly within this settings page to help you better understand your device. These FAQs will explain your current hardware specifications and how they impact the performance of your device, making it easier to get the most out of your system.
  • [Start menu] New! This update starts the roll out of the new account manager on the Start menu. The new design makes it easy to view your account and access account settings. To change to a different user, select the ellipses (...) next to Sign out. The Lock command is now on the power menu. Note: This change might not be available to all users because it will roll out gradually.
  • [vmswitch] Fixed: A vmswitch triggers a stop error. This occurs when you use Load Balancing and Failover (LBFO) teaming with two virtual switches on a virtual machine (VM). In this case, one virtual switch uses single root Input/Output virtualization (SR-IOV).
  • [Upgrade to Windows 11] Fixed: A race condition causes stop error 0x3B. This might occur when you upgrade from Windows 10 to Windows 1.
  • [Product activation phone numbers] Fixed: This adds new phone numbers for several regions.
  • [Multi-Function Printer (MFP)]
    • Fixed: When you use a USB cable to connect to it, it prints specific network command text when you do want it to.
    • Fixed: A scanner driver fails to install when you use a USB cable to connect to an MFP.
  • [Country and Operator Settings Asset (COSA)] Fixed: This update brings profiles up to date for certain mobile operators.
  • [WebView2 apps] Fixed: They do not detect input from Xbox 360 and Bluetooth controllers.
Releasing Windows 10 Build 19045.5194 to Beta and Release Preview Channels
Windows 10 22H2 Build 19045.5194 (KB5046714) is being released to BOTH the Beta Channel and Release Preview Channel for Insiders who are on Windows 10, version 22H2.
Note: This will be the last release of a Windows 10 build to the Beta Channel as the Beta Channel for Windows 10 will be shutting down. Insiders on Windows 10 in the Beta Channel will be moved over to the Release Preview Channel.  Although it is recommended to move to Windows 11, Insiders on Windows 10 today in the Beta Channel can also move to the Release Preview Channel on their own via Settings > Update & Security > Windows Insider Program and choosing the Release Preview Channel.
  • [Start menu] New! The Recommended section of the Start menu will show some Microsoft Store apps. These apps come from a small set of curated developers. This will help you to discover some of the great apps that are available. If you want to turn this off, go to Settings > Personalization > Start. Turn off the toggle for Show suggestions occasionally in Start.
  • [App list backup] Fixed: Win32 shortcuts might not back up to the cloud.
  • [Copy cloud files] Fixed: When you drag and drop files from a cloud files provider folder, it might result in a move instead of a copy.
  • [Motherboard replacement] Fixed: Windows does not activate after you replace a motherboard.
  • [Internet Printing Protocol (IPP) printer] Fixed: Windows stops responding when you use an IPP USB printer.
Releasing Windows 10 Build 19045.5435 to the Release Preview Channel
This update includes the following features and improvements (items bolded in brackets indicate the area of the change being documented) for Insiders who are on Windows 10, version 22H2:
  • [Calendar] New! Stay informed and informed with the new calendar. See the weather forecast and learn about the holidays and events that are coming up.
  • [Mail] New! You now have the new Outlook for Windows app as the free default mail app. A new app icon appears on the Start menu. If you have pinned the former mail app to the taskbar, the new icon replaces the pinned app icon.
  • [GB18030-2022] This update adds support for this amendment.
  • [Virtual memory] Fixed: An issue depletes virtual memory, which might cause some apps to fail.
  • [Chinese Pinyin input method editor (IME)] Bing will stop giving automatic suggestions in the search box for search engine sites, like Baidu. To get manual suggestions, use Ctrl + Tab or the chevron button (>).
  • [Near Field Communication (NFC) readers] Fixed: At times, they fail to read card Universal Unique Identifiers (UUID). This occurs after many point-of-sale (POS) app scans.
  • [USB Print and IPP Over USB] Fixed: An installed printer fails when the spooler initializes.
  • [Screen capture] Fixed: The Capture Service and Snipping Tool stop responding. This occurs when you press Windows logo key + Shift + S several times while Narrator is on.
Releasing Windows 10 Build 19045.5552 to the Release Preview Channel
This Build is for Insiders who are on Windows 10, version 22H2.
This update includes the following features and improvements (items bolded in brackets indicate the area of the change being documented):
  • [Daylight saving time (DST)] This update supports (DST) changes in Paraguay.
    • Fixed: The Chinese IME stops responding when you change the font family or font size.
    • Fixed: The color contrast ratio of the Chinese IME search suggestion panel is less than you expect.
  • [dwm.exe] Fixed: It stops responding many times.
  • [Narrator]
    • Fixed: It fails to say the Chinese IME candidate window quick action buttons right.
    • Fixed: It does not say the control type for the Chinese IME suggestion opt-in item.
    • Fixed: It does not say the heading of the Chinese IME suggestion opt-in panel.
  • [Open Secure Shell (OpenSSH) (known issue)] Fixed: The service fails to start, which stops SSH connections. There is no detailed logging, and you must run the sshd.exe process manually.
Releasing Windows 10 Build 19045.5674 to the Release Preview Channel
  • [Noto Fonts] This update provides Noto CJK (Chinese, Japanese, and Korean) fonts in Windows.
  • [Mobile Operator Profiles] Updated: Country and Operator Settings Asset (COSA) profiles are updated.
  • [Thumbnails] Fixed: Thumbnails in File Explorer may crash resulting in white pages appearing instead of the actual thumbnail.
  • [Temporary files] This update enables system processes to store temporary files in a secure directory "C:\Windows\SystemTemp" via either calling GetTempPath2 API or using .NET's GetTempPath API, thereby reducing the risk of unauthorized access.
  • [Remote Desktop] Fixed: Certain Get-Help troubleshooters might not run in a Remote Desktop session.
  • [Web Search Providers] This update introduces improved support in Windows Search for the European Economic Area (EEA), including increased discoverability.
  • [Printers] Fixed: Printers using Independent Hardware Vendor (IHV) drivers might unexpectedly output incorrect or unwanted text.
March 2025 Microsoft Photos update now rolling out to Windows Insiders
Today we are beginning to roll out a Microsoft Photos app update to Windows Insiders on Windows 11 across all Insider Channels and also to Windows Insiders on Windows 10 in the Release Preview Channel. Not all Insiders will see this update right away or the features noted below as we roll things out to more Insiders over time. Here are some highlights of what is new and improved in this update!
Search the web with OCR-extracted text
The Photos app now comes with a powerful Optical Character Recognition (OCR) feature which supports over 160 languages, which began rolling out again for Windows Insiders on Windows 11 and Windows 10 at the end of January. To use OCR, simply click the Scan Text button in the Photos Viewer. The app will highlight the recognized text with an overlay, allowing you to easily select and copy it to your clipboard. With this update, we're adding "Search in Web" functionality so you can quickly search for any selected text from your images right from the app.
This enhancement makes it easier than ever to extract and find online results of text from documents, notes, screenshots, and more. Whether you're capturing text from a document or simply exploring the contents of an image, the Photos app's OCR and online search features streamline your workflow and boost your productivity.
Quick access to AI editing and visual search from File Explorer and your desktop
Introducing new File Explorer shortcuts that give you direct access to AI editing and Visual Search without needing to open the Photos app.
Right-click an image in File Explorer and select "Create with Designer" to add rich text, adjust composition with object selection, or enhance colors with color pop.
Plus, use the "Erase Object" shortcut to quickly remove unwanted elements. And with "Visual Search with Bing" shortcut, you can easily look up similar images, related products, and more right from your desktop.
Show subfolder images and videos in the Photos Gallery
Now you can use filters to adjust how your subfolder and gallery content show up. By enabling "Show subfolders", you can now see all the images and videos from subfolders in the Gallery, making it a richer navigation experience.
Introducing the new Copilot button in the Photos app
We are excited to unveil the Copilot button in the Photos app that brings AI directly to your fingertips.
This Copilot integration is rolling out soon and with this new feature, you can effortlessly share your photos with AI to receive:
  • Photo Editing Tips: Get expert advice on enhancing your images.
  • Image Insights: Discover interesting details about your photos.
  • Framing Suggestions: Improve your photography skills with personalized recommendations.
New Copilot button at the top of Photos Viewer highlighted in a red box.
Other fixes and improvements
  • Due to popular requests, the Photos app now supports JXL files.
  • We implemented bug fixes for the Image Creator and Restyle Image features on Copilot+ PCs to improve overall quality and performance. This includes successfully loading Image Creator in the Photos app on the initial launch of Photos and being able to Save generated images under a different file name.
To get these new features, update your app to version 2025.11030.20006.0 or higher via the Microsoft Store. This update is currently rolling out, so it may not be available right away. As always, we love getting your feedback so please share your thoughts in Feedback Hub (Win + F) under Apps > Photos.
Releasing Windows 10 Build 19045.5794 to the Release Preview Channel
  • [Graphics] Fixed: The check for GPU paravirtualization was case-sensitive in Windows Subsystem for Linux 2 (WSL2). This issue might potentially cause GPU paravirtualization support to fail.
  • [OS Security] Fixed: Updates to the Windows Kernel Vulnerable Driver Blocklist (DriverSiPolicy.p7b). Additions have been made to blocklist drivers with security vulnerabilities that have been used in Bring Your Own Vulnerable Driver (BYOVD) attacks.
Releasing Windows 10 Build 19045.5912 to the Release Preview Channel
[Calendar flyout]
  • Brings back the clock view that displays seconds onto the calendar that was once removed.
  • Enhances the Rich Calendar feature by extending the upcoming events period to 30 days.
  • Adds description text for the weather button on the rich calendar.
[GDI/GDI+]
  • Fixed: Some GB18030-2022 characters in plane 2 are not rendered.
  • Fixed: Some GB18030 characters are rendered wider. Additionally, the sample paragraph is not rendered correctly.
  • Updated: Country and Operator Settings Asset (COSA) profiles are updated.
[WinSaS]
  • Fixed: An issue affecting the Windows Account Sync Consent system in European Economic Area markets, where secondary accounts were not acknowledged, leading to increased server load.
Releasing Windows 10 Build 19045.6029 to the Release Preview Channel
Releasing Windows 10 22H2 Build 19045.6029 (KB5061087) to the Release Preview Channel for Insiders who are on Windows 10, version 22H2.
  • [Mobile Operator Profiles] Updated: Country and Operator Settings Asset (COSA) profiles.
  • [App Platforms and Frameworks]
    • Fixed: An issue affecting Component Object Model (COM) functionality on Windows platforms, where remote COM activations were failing with error 0x8001011.
    • Upgraded the version of the curl tool included in Windows to v8.13.0.
  • App defaults] New! We are rolling out some small changes in the EEA region for default browsers via the Set default button in Settings > Apps > Default apps:
    • Additional file and link types will be set for the new default browser, if it registers them.
    • The new default browser will be pinned to the Taskbar and Start menu unless you choose not to pin it by clearing the checkboxes.
    • There is now a separate one-click button for browsers to change your .pdf default, if the browser registers for the .pdf file type.
  • [Authentication Platform] Fixed: An issue affecting the device registration in Entra ID Windows Account Manager (WAM) plugin.
  • [Input and Composition] Fixed: An issue affecting the complete removal of unused language packs and Feature on Demand (FOD) packages. This led to unnecessary storage use and increase in Windows Update installation time.
  • [Print and Peripherals] Fixed: An issue affecting USB-connected Multi-Function printers with dual protocol interfaces, where scanning may fail and prevent use of the OS's built-in scanning functionality.
  • [Start Menu]
    • Fixed: An issue causing jump lists to disappear from the Start Menu.
    • Fixed: An issue where the Start Menu was not starting after installing an update.
  • [Settings] Fixed: Settings > System > About unexpectedly shows version 2009 instead of version 22H2.
  • [Servicing] Fixed: An issue where Kiosk devices using the ForceAutoLogon configuration and Shift Override might stop responding with a blue screen after being locked and unlocked by support administrators.
  • [File Server] Fixed: An issue where the system may hang when acknowledging an Oplock break on resources located on SMB shares.
