April 2024 Windows 11 Non-Security Preview Update
Started by Corrine, April 24, 2024, 02:19:59 AM
Microsoft released KB5036980 (OS Builds 22621.3527 and 22631.3527 today for Windows 11 23H3 and Windows 11 22H2.
IMPORTANT: The date for optional, non-security preview releases for Home and Pro versions of Windows 11, version 22H2 has been extended from February 27, 2024 to June 26, 2024.
Highlights included in the update:
  • New! The Recommended section of the Start menu will show some Microsoft Store apps. These apps come from a small set of curated developers. This will help you to discover some of the great apps that are available. If you want to turn this off, go to Settings > Personalization > Start. Turn off the toggle for Show recommendations for tips, app promotions, and more.
  • New! In the coming weeks, your most frequently used apps might appear in the Recommended section of the Start menu. This applies to apps that you have not already pinned to the Start menu or the taskbar.
  • New! This update improves the Widgets icons on the taskbar. They are no longer pixelated or fuzzy. This update also starts the rollout of a larger set of animated icons.
  • New! This update affects Widgets on the lock screen. They are more reliable and have improved quality. This update also supports more visuals and a more customized experience for you.
  • This update affects the touch keyboard. It makes the Japanese 106 keyboard layout appear as expected when you sign in.
  • This update addresses an issue that affects Settings. It stops responding when you dismiss a flyout menu.
See the KB article for a separate list of quality improvements included in the update for Windows 11 23H3 and Windows 11 22H2.
References:
Windows 11 update history
