computer hacked
Sorry, Mary Ann, but you continue not carefully reading my instructions. I feel that the only thing I do here is repeating and repeating the same things, and you just jump or ignore instructions. I clearly said SELECT ALL THE DETECTED ITEMS AND CLICK ON QUARANTINE/REMOVE. You didn't do that.
You must read the instructions carefully and ask if you have a question before reaching to the end and post something extremely irrelevant.
Once again, I'll post the instructions for running Malwarebytes. Sorry, I can't be clearer than that.
  • Open Malwarebytes.
  • Click the little gear on the top right (Settings) and when it opens, click the General tab. Under the title Windows Security Center, make sure the option is disabled.
  • Click the Scan and Detections tab and under the Scan options title, enable Scan for rootkits option. Do not change any other option.
  • Return to the Dashboard and choose Scan.
  • When finished, you will see the Threat Scan Summary window open.
    If threats are found (and in your case threats were found), make sure that all threats are selected, and click on Quarantine/Remove selected. When it finishes, restart the computer.
    • Open Malwarebytes again, click on the Scanner, and then on the Reports tab.
    • Find the report with the most recent date and double click on it.
    • Click on Export and then Copy to Clipboard.
    • Paste its content here, in your next reply.
mare_wbpa
I thought I did all of that. I'll try again
mare_wbpa
When I click export, do I  choose computer or txt
When you click on Export, there are two options, correct?
Copy to Clipboard
Export to TXT
Click on Copy to Clipboard. Then, come here, right click and paste.
mare_wbpa
mare_wbpa
Malwarebytes
www.malwarebytes.com
-Log Details-
Scan Date: 7/7/2024
Scan Time: 1:00 PM
Log File: 6b476e0c-3c82-11ef-b556-cc5ef8f272ec.json
-Software Information-
Version: 5.1.6.117
Components Version: 1.0.1270
Update Package Version: 1.0.86619
License: Trial
-System Information-
OS: Windows 11 (Build 22631.3737)
CPU: x64
File System: NTFS
User: LAPTOP-4EQFBMN3\mary ann
-Scan Summary-
Scan Type: Threat Scan
Scan Initiated By: Manual
Result: Completed
Objects Scanned: 239306
Threats Detected: 0
Threats Quarantined: 0
Time Elapsed: 5 min, 0 sec
-Scan Options-
Memory: Enabled
Startup: Enabled
File system: Enabled
Archives: Enabled
Rootkits: Enabled
Heuristics: Enabled
PUP: Detect
PUM: Detect
-Scan Details-
Process: 0
(No malicious items detected)
Module: 0
Registry Key: 0
Registry Value: 0
Registry Data: 0
Data Stream: 0
Folder: 0
File: 0
Physical Sector: 0
WMI: 0
(end)
Perfect, Mary Ann! See? You followed the instructions and you did it! Well done!
The last log is clean. Everything bad is removed.
Is there any remaining issue/question/concern regarding this computer?
mare_wbpa
/What I didn't understand was that when you click clipboard the log is automatically copied and I just had to click paste once I got here. I was looking for a log in a clipboard folder. It's easy once it clicks in my brain.
So, my computer is clean of malware and other threats and I'm not susceptible to being hacked again? is there anything I can do to keep it clean?
mare_wbpa
By the way, THANK YOU very much!
Yes, imagine the Clipboard is "somewhere in the air". :)
Before I give you some security tips, lets remove the tools we used and create a new restore point. This is the last set of instructions for you. Remember: careful reading first. ;)
Download KpRm by kernel-panik and save it to your desktop.
  • Right-click kprm_(version).exe and select Run as Administrator.
  • Read and accept the disclaimer.
  • When the tool opens, ensure all boxes under Actions are checked.
  • Under Delete Quarantines select Delete Now, then click Run.
  • Once complete, click OK.
  • A log will open in Notepad titled kprm-(date).txt.
  • Please copy and paste its contents in your next reply.
Note: If there is a warning about this tool, go on to download it, since it is a false/positive. Choose More info and continue from there.
mare_wbpa
Before I start the above I want to mention that I'm getting a window every time I start my computer, it says.
ONENOTEM.EXE-B;ad Image
C:\Program file\Microsoft
Office\iod\Office 16\AppVlsvsystem64.dll is either not designed to run in Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status Oxc0000020
Hi, Mary Ann.
Is this something new or it was something you had before we start the cleaning procedure here?
mare_wbpa
Something new means yesterday?
mare_wbpa
before that, about a week
