October 2024 Windows 11 Non-Security Preview Update
Started by Corrine, October 23, 2024, 09:04:56 PM
Microsoft released KB5044380 (OS Builds 22621.4391 and 22631.4391 for Windows 11 23H3 and Windows 11 22H2. The non-security preview update for Windows 11, version 24H2 will be available soon.
Highlights
These might not be available to all users because they will roll out gradually.
  • [Gamepad keyboard]New! This update starts the roll out of a new Gamepad keyboard layout for the on-screen keyboard. With it, you can use your Xbox controller to move around the screen and type. Button accelerators are also available; these include the X button for backspace and the Y button for the spacebar. For better movement patterns, the keyboard keys are aligned vertically.
  • [Notifications] New! You can now stop the suggestions to turn off notifications from certain apps. Select the ellipses (...) in the notification and turn it off. You can also go to Settings > System > Notifications and turn it off from there. Look for "Notification Suggestions" in the senders list. An entry will only appear in the list after you receive a notification.
  • [Start menu] New! "All apps" has the new name, "All."
  • [Narrator]
    • New! This update adds a new Narrator shortcut. Press the Narrator key + Ctrl + X to copy what Narrator last spoke to the clipboard. This shortcut is useful when you want to quickly copy some content, like codes or numbers for use.
    • New! It will now auto read the contents of an email message in the new Outlook. This is like the behavior in Outlook classic.
Normal rollout
  • [Copilot key settings] New! You can configure the Copilot key on the keyboard. On new devices, the key opens the Copilot app. If you sign in to your account using a Microsoft Entra ID, the key opens the M365 app. You can make the key open a different app or open Search. To do this, go to Settings > Personalization > Text input. To make the key open a different app, the app must be in a signed MSIX package. This ensures that the app meets security and privacy standards to keep you safe. If your PC's keyboard does not have a Copilot key, changing this setting will do nothing.
  • [Battery use] Fixed: A device uses too much battery power while the device is in Modern Standby.
  • [Microsoft Teams] Fixed: The issue stops you from joining Teams meetings when you select an Outlook meeting reminder.
  • [Product activation phone numbers] Fixed: This adds new phone numbers for several regions.
  • [Multi-Function Printer (MFP)] Fixed: When you use a USB cable to connect to it, it prints specific network command text when you do want it to.
References: Windows 11 update history
