Win32:Zlob-BN(Trj) HELP
Started by emilyw, June 20, 2006, 10:54:31 PM
emilyw
I used Symantec scanner, here is what they gave me
C:\WINDOWS\NDNuninstall4_50.exe is infected with Adware.NDotNet
C:\WINDOWS\NDNuninstall4_80.exe is infected with Adware.NDotNet
C:\WINDOWS\SYSTEM32\ld100.tmp is infected with Trojan.Emcodec
C:\WINDOWS\SYSTEM32\regperf.exe is infected with Trojan.Zlob
Hi, Emily.
C:\WINDOWS\system32\hp100.tmp
That definitely means the SmitRem infection.  Emily, can you recall exactly what program wouldn't let you open S!Ri's SmitfraudFix?  We will need to find a way around that to get your system clean.
I'll get the instructions together for you and be right back  :)
    Ok, Emily, here goes.  Please be sure to ask questions or let us know if you are having a problem.  If Avast or another security program asks if you shoudl run the SmitfraudFix, tell it YES:
process.exe is detected by some antivirus programs (AntiVir, Dr.Web, Kaspersky) as a "RiskTool". It is not a virus, but a program used to stop system processes. Antivirus programs cannot distinguish between "good" and "malicious" use of such programs, therefore they may alert the user. (See  ttp://www.beyondlogic.org/consulting/processutil/processutil.htm  )
PRINT or SAVE these instructions to text where you can access them in safe mode.
Please follow the instructions in the order given.
INSTRUCTIONS:
A.  Download and/or update the following programs.  Install them but do NOT run them yet.
  • Download SmitfraudFix (© S!Ri) to your Desktop from http://siri.urz.free.fr/Fix/SmitfraudFix.zip .  Extract all the files to your Desktop and a folder named SmitfraudFix will be created on your Desktop.
  • Download CCleaner from Download CCleaner from this direct link:  http://www.ccleaner.com/downloadbin.asp?f=2
  • Download ewido AntiMalware.  It is a free version of the program.
    • Install ewido AntiMalware[list=a]
    • Launch ewido, there will be a large yellow [size=18]e[/size] icon on your desktop, double-click it.
    • The program will prompt you to update.  Click the OK button.
    • The program will now open to the main screen
    • On the left-hand side of the main screen, click on Update
    • Click on Start. The update will start and a progress bar will show the updates being installed.
    • When complete, the status bar at the bottom will display "Update successful".
  • Do not scan yet.
  • If you have problems with the updater, you can use this link to manually update Ewido --   Ewido manual updates
[/list]
B.  Restart your computer in Safe Mode.
  • If the computer is running, shut down Windows, and then turn off the power.
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu will appear. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe Mode option is selected.
  • Press Enter. The computer then begins to start in Safe Mode.
  • Login on your usual account.
    If you need further assistance with Safe Mode, see Symantec
C.  Open the SmitfraudFix folder
  • Double-click smitfraudfix.cmd file to start the tool.
  • Select option #2 - Clean by typing 2 and press Enter.
    Warning : running option #2 on a uninfected computer will remove your Desktop background.
  • Wait for the tool to complete and disk cleanup to finish.
  • You will be prompted : "Registry cleaning - Do you want to clean the registry?"
    • Answer Yes by typing Y
    • Hit Enter.
  • The tool will also check if wininet.dll is infected. If a clean version is found, you will be prompted to replace wininet.dll.
    • Answer Yes to the question "Replace infected file?" by typing Y
    • Hit Enter.
  • A reboot may be needed to finish the cleaning process.  If your computer does not restart automatically please do it yourself manually.
  • Restart in Safe Mode as instructed above.
  • The tool will create a log named rapport.txt in the root of your drive, eg: Local Disk C: or partition where your operating system is installed. Please post that log along with all others requested in your next reply.
D. Clean Temporary Internet files with CCleaner as follows:
  • Close all open programs, including Internet Explorer, Fire Fox and any instances of Windows Explorer.
  • Launch CCleaner and under Options > Advanced > UNcheck "Only delete files in Windows Temp folder older than 48 hours".
  • A pop up box will appear advising this process will permanently delete files from your system.
  • To protect logon cookies that you wish to retain, under Options > Cookies.  Select and using the arrow move those cookies to the "Cookies to keep" column.
  • Then select the items you wish to clean up.
    • In the Windows Tab:
      • Clean all entries in the "Internet Explorer" section.
      • Clean all the entries in the "Windows Explorer" section.
      • Clean all entries in the "System" section except Windows Log Files.
    • In the Applications Tab:
      • Clean all in the Firefox/Mozilla section if you use it.
      • Clean all in the Opera section if you use it.
      • Clean Sun Java in the Internet Section.
      • Please UNcheck "Utilities" (i.e., Ad-Aware, ewido and other security program logs.)
  • Click the "Run Cleaner" button and it will scan and clean your system.
  • Click exit.
E.  Run ewido:
  • Open ewido and click on scanner
  • Click on Complete System Scan and the scan will begin.
  • While the scan is in progress, you will be prompted to clean files, click OK
  • When prompted to clean the first file, put a check in the lower left corner of the box that says "Perform action on all infections" then choose clean and click OK.
  • Checkmark the box:  *Create encrypted backup in the quarantine* (recommended).  Click OK.
  • Once the scan has completed, there will be a button located on the bottom of the screen named Save report
  • Click Save report.
  • Save the report .txt file to your desktop, or any other easily accessible location.
Now close ewido.
F.Restart in Normal Mode
G. Optional: To restore IE Trusted & Restricted Zone, open the SmitfraudFix folder
  • Select option #3 - Delete Trusted zone by typing 3 and press Enter
    • Answer Yes to the question "Restore Trusted Zone ?" by typing Y
    • Hit Enter.
    Note: If you use SpywareBlaster and/or IE-SPYAD, it will be necessary to re-install the protection both afford. For SpywareBlaster, run the program and re-protect all items. For IE-SPYAD, run the batch file and reinstall the protection.
H.  Double-click the HijackThis icon on your desktop.  Choose "Do a system scan and save logfile".  Include the logfile with your post.
I.  Create a topic of your own (or a reply if you have an existing topic) and post the following logs:
  • C:\rapport.txt
  • ewido log
  • HijackThis log
Please let us know if any problems persist.
emilyw
Thank you so much
I am going to give this a try!!  Wish me luck!!
You can do it, Emily!!!  :rose:
You'll be fine.  We are scattered around the globe, so someone should be here to answer any questions within a reasonable amount of time.
Corrine's instructions should eliminate the rascal.
emilyw
I don't have ewido AntiMalware
How do I d/l this?? and what is it?
Sorry, Emily.  I must have removed the download link line when I was converting the instructions from Freedomlist to post here.  For some reason, the formatting gets messed up when going from phpBB software to SMF forum software.
I edited my post above to put it in the instructions in order.
Oh, and ewido is an excellent antimalware software, includes trojans and more.
emilyw
Thanks ill do that now,  Had to take a break from this comp. and while I was gone no pop ups saying I have  trojan horse :D
so far so good
Great, we're making progress!  You'll get rid of it, don't worry.
emilyw
Thank you very much!! So far nothing has popped up in almost a day  :)
Okay here are the logs!!
Take your time and let me know how it appears!!
SmitFraudFix v2.62
Scan done at 19:21:37.92, 23/06/2006
Run from C:\Documents and Settings\Emily\My Documents\SmitfraudFix\SmitfraudFix
OS: Microsoft Windows XP [Version 5.1.2600] - Windows_NT
Fix ran in safe mode
»»»»»»»»»»»»»»»»»»»»»»»» Before SmitFraudFix
!!!Attention, following keys are not inevitably infected!!!
SrchSTS.exe by S!Ri
Search SharedTaskScheduler's .dll
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler]
"{05a91164-3c96-47d6-aa74-2c855791b2d0}"="incaged"
[HKEY_CLASSES_ROOT\CLSID\{05a91164-3c96-47d6-aa74-2c855791b2d0}\InProcServer32]
@="C:\WINDOWS\system32\ofcukiz.dll"
[HKEY_CURRENT_USER\Software\Classes\CLSID\{05a91164-3c96-47d6-aa74-2c855791b2d0}\InProcServer32]
»»»»»»»»»»»»»»»»»»»»»»»» Killing process
»»»»»»»»»»»»»»»»»»»»»»»» Deleting infected files
C:\WINDOWS\system32\dcomcfg.exe Deleted
C:\WINDOWS\system32\hp???.tmp Deleted
C:\WINDOWS\system32\ld????.tmp Deleted
C:\WINDOWS\system32\ot.ico Deleted
C:\WINDOWS\system32\regperf.exe Deleted
C:\WINDOWS\system32\simpole.tlb Deleted
C:\WINDOWS\system32\stdole3.tlb Deleted
C:\WINDOWS\system32\ts.ico Deleted
C:\WINDOWS\system32\1024\ Deleted
C:\DOCUME~1\ALLUSE~1\Desktop\Online Security Guide.url Deleted
C:\DOCUME~1\Emily\FAVORI~1\Antivirus Test Online.url Deleted
C:\Program Files\MalwareWipe\ Deleted
»»»»»»»»»»»»»»»»»»»»»»»» Generic Renos Fix
GenericRenosFix by S!Ri
C:\WINDOWS\system32\ofcukiz.dll -> Missing File
»»»»»»»»»»»»»»»»»»»»»»»» Deleting Temp Files
»»»»»»»»»»»»»»»»»»»»»»»» Registry Cleaning
Registry Cleaning done.
»»»»»»»»»»»»»»»»»»»»»»»» After SmitFraudFix
SrchSTS.exe by S!Ri
»»»»»»»»»»»»»»»»»»»»»»»» End
ewido anti-spyware - Scan Report
+ Created at:   11:39:16 PM 23/06/2006
+ Scan result:
HKLM\SOFTWARE\Altnet -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Altnet\ADM -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Altnet\Dashboard -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Altnet\Dashboard\Settings -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Altnet\Dashboard\Setup -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Altnet\Dashboard\Temp Internet Shares -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Altnet\DownloadManager -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Altnet\LocalFiles -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Altnet\TopSearch -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\AppID\Altnet Signing Module.EXE -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\AppID\adm.EXE -> Adware.Altnet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DelFin Media Viewer -> Adware.Delfin : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MediaLoads Enhanced -> Adware.Downloadware : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\HbToolbar.HbHtmlMenuUI -> Adware.HotBar : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\HbToolbar.HbHtmlMenuUI.1 -> Adware.HotBar : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\HbToolbar.HbHtmlMenuUI\CLSID -> Adware.HotBar : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\HbToolbar.HbHtmlMenuUI\CurVer -> Adware.HotBar : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\Hotbar.HbTravelCompareBar -> Adware.HotBar : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\Hotbar.HbTravelCompareBar.1 -> Adware.HotBar : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\Hotbar.HbTravelCompareBar\CLSID -> Adware.HotBar : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\Hotbar.HbTravelCompareBar\CurVer -> Adware.HotBar : Cleaned with backup (quarantined).
HKU\S-1-5-21-1538417202-3207847200-972506294-1006\Software\Updater -> Adware.KeenValue : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\MP.MediaPops -> Adware.NetworkEssentials : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\MP.MediaPops.1 -> Adware.NetworkEssentials : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\MP.MediaPops\CLSID -> Adware.NetworkEssentials : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\MP.MediaPops\CurVer -> Adware.NetworkEssentials : Cleaned with backup (quarantined).
C:\WINDOWS\NDNuninstall4_50.exe -> Adware.NewDotNet : Cleaned with backup (quarantined).
C:\WINDOWS\NDNuninstall4_80.exe -> Adware.NewDotNet : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\WebP2PInstaller.Installer -> Adware.P2PNetworking : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\WebP2PInstaller.Installer.1 -> Adware.P2PNetworking : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\WebP2PInstaller.Installer\CLSID -> Adware.P2PNetworking : Cleaned with backup (quarantined).
HKLM\SOFTWARE\Classes\WebP2PInstaller.Installer\CurVer -> Adware.P2PNetworking : Cleaned with backup (quarantined).
C:\System Volume Information\_restore{11B4CBB0-31B0-483C-A4FE-D6E9E8C1A928}\RP1166\A0059913.exe -> Downloader.Zlob.th : Cleaned with backup (quarantined).
C:\WINDOWS\Downloaded Program Files\popcaploader.dll -> Not-A-Virus.Downloader.Win32.PopCap.b : Ignored.
::Report end
Logfile of HijackThis v1.99.1
Scan saved at 11:42:31 PM, on 23/06/2006
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb04.exe
C:\WINDOWS\system32\hkcmd.exe
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\Program Files\ewido anti-spyware 4.0\guard.exe
C:\Program Files\ewido anti-spyware 4.0\ewido.exe
C:\Program Files\Hijackthis\HijackThis.exe
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: Nothing - {5f4c3d09-b3b9-4f88-aa82-31332fee1c08} - C:\WINDOWS\system32\hp100.tmp (file missing)
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O2 - BHO: ST - {9394EDE7-C8B5-483E-8773-474BF36AF6E4} - C:\Program Files\MSN Apps\ST\01.03.0000.1005\en-xu\stmain.dll
O2 - BHO: MSNToolBandBHO - {BDBD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\MSN Apps\MSN Toolbar\MSN Toolbar\01.02.5000.1021\en-ca\msntb.dll
O3 - Toolbar: MSN - {BDAD1DAD-C946-4A17-ADC1-64B5B4FF55D0} - C:\Program Files\MSN Apps\MSN Toolbar\MSN Toolbar\01.02.5000.1021\en-ca\msntb.dll
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb04.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [!ewido] "C:\Program Files\ewido anti-spyware 4.0\ewido.exe" /minimized
O4 - HKCU\..\Run: [Microsoft Works Update Detection] C:\Program Files\Microsoft Works\WkDetect.exe
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [MoneyAgent] "C:\Program Files\Microsoft Money\System\Money Express.exe"
O4 - Startup: PowerReg Scheduler.exe
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\System32\Shdocvw.dll
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/sscv6/SharedContent/vc/bin/AvSniff.cab
O16 - DPF: {41F17733-B041-4099-A042-B518BB6A408C} - http://a1540.g.akamai.net/7/1540/52/20021205/qtinstall.info.apple.com/borris/us/win/QuickTimeInstaller.exe
O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - http://spaces.msn.com//PhotoUpload/MsnPUpld.cab
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsClient.cab31267.cab
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (ZoneIntro Class) - http://cdn2.zone.msn.com/binFramework/v10/ZIntro.cab34246.cab
O16 - DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} (PopCapLoader Object) - http://zone.msn.com/bingame/dim2/default/popcaploader_v6.cab
O16 - DPF: {EF791A6B-FC12-4C68-99EF-FB9E207A39E6} (McFreeScan Class) - http://download.mcafee.com/molbin/iss-loc/mcfscan/2,1,0,4790/mcfscan.cab
O16 - DPF: {F04A8AE2-A59D-11D2-8792-00C04F8EF29D} (Hotmail Attachments Control) - http://by104fd.bay104.hotmail.msn.com/activex/HMAtchmt.ocx
O16 - DPF: {F6BF0D00-0B2A-4A75-BF7B-F385591623AF} (Solitaire Showdown Class) - http://messenger.zone.msn.com/binary/SolitaireShowdown.cab31267.cab
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - "C:\PROGRA~1\MSNMES~1\msgrapp.dll" (file missing)
O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxsrvc.dll
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: ewido anti-spyware 4.0 guard - Anti-Malware Development a.s. - C:\Program Files\ewido anti-spyware 4.0\guard.exe
O23 - Service: PACSPTISVR - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\Pacsptisvr.exe
O23 - Service: Sony SPTI Service (SPTISRV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\Sptisrv.exe
Fantastic, Emily!!!  Great job.  Now to clean up the remnant:
Scan with HijackThis, select the following and click "fix checked"
See this thread about updating Sun Java:  http://www.landzdown.com/index.php?topic=7887.0 .  For additional information on protecting your PC, please see Tony Klein's "So how did I get infected in the first place?" for important tips on how to prevent future infections.  There is also a lot of helpful information in "Mitch's Good Stuff" linked from here.
Install and update both SpywareBlaster & SpyGuard to prevent the installation of spyware and other potentially unwanted software:
SpywareBlaster -- http://www.javacoolsoftware.com/spywareblaster.html
SpywareGuard --  http://www.javacoolsoftware.com/spywareguard.html
If you use Internet Explorer, IE-Spyad will add thousands of sites into your IE restricted zone:  http://www.spywarewarrior.com/uiuc/resource.htm
Another useful program is StartupMonitor, which will warn you when somethings tries to sneak in:  http://www.mlin.net/StartupMonitor.shtml
Regards,
Corrine :rose:
emilyw
You were very helpful and now my computer is free from that stupid trojan!!
:thumbsup:
You're very welcome.  I'm glad we were able to assist.
Now that you're a member here, feel free to stick around, check the Lounge, see the jokes forum, subscribe to an update thread.  :)
zoduVIE
Hi !
I have the same problem with the Zlob-BN(trj) i have downloded the HijackThis ande here is the report i have become !
Pleace hallp me to remove this Zlob-BN.
Scan saved at 10:33:47, on 09.07.2006
Running processes:
C:\WINDOWS\system32\LEXBCES.EXE
C:\WINDOWS\system32\LEXPPS.EXE
C:\Programme\Alwil Software\Avast4\aswUpdSv.exe
C:\Programme\Alwil Software\Avast4\ashServ.exe
C:\Programme\Gemeinsame Dateien\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\Programme\Alwil Software\Avast4\ashMaiSv.exe
C:\Programme\Alwil Software\Avast4\ashWebSv.exe
C:\Programme\Logitech\Video\LogiTray.exe
C:\WINDOWS\system32\LXSUPMON.EXE
C:\Programme\Gemeinsame Dateien\Real\Update_OB\realsched.exe
C:\Programme\Java\jre1.5.0_06\bin\jusched.exe
C:\WINDOWS\system32\pupxpman.exe
C:\Programme\Winamp\winampa.exe
C:\Programme\CursorXP\CursorXP.exe
C:\Programme\NoAds\NoAds.exe
C:\WINDOWS\system32\LVComS.exe
C:\Programme\SAMSUNG\Samsung Internet Keyboard\MMKbd.exe
C:\Programme\Second Nature\Snsicon.exe
C:\Programme\Windows Media Player\wmplayer.exe
C:\Programme\Avant Browser\avant.exe
C:\Programme\Hijackthis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://us.rd.yahoo.com/customize/ie/defaults/sb/msgr7/*http://www.yahoo.com/ext/search/search.html
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://us.rd.yahoo.com/customize/ie/defaults/sp/msgr7/*http://www.yahoo.com
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.gayromeo.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.yahoo.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://us.rd.yahoo.com/customize/ie/defaults/su/msgr7/*http://www.yahoo.com
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://us.rd.yahoo.com/customize/ie/defaults/sb/msgr7/*http://www.yahoo.com/ext/search/search.html
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://us.rd.yahoo.com/customize/ie/defaults/sp/msgr7/*http://www.yahoo.com
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.yahoo.com/
R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://us.rd.yahoo.com/customize/ie/defaults/su/msgr7/*http://www.yahoo.com
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Window Title = Microsoft Internet Explorer von chello broadband
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = localhost
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Programme\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Programme\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - (no file)
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Programme\Yahoo!\Common\yiesrvc.dll
O3 - Toolbar: ICQ  Toolbar - {855F3B16-6D32-4fe6-8A56-BBB695989046} - C:\Programme\ICQToolbar\toolbaru.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Programme\Yahoo!\Companion\Installs\cpn0\yt.dll
O4 - HKLM\..\Run: [LogitechVideoRepair] C:\Programme\Logitech\Video\ISStart.exe
O4 - HKLM\..\Run: [LogitechVideoTray] C:\Programme\Logitech\Video\LogiTray.exe
O4 - HKLM\..\Run: [LXSUPMON] C:\WINDOWS\system32\LXSUPMON.EXE RUN
O4 - HKLM\..\Run: [TkBellExe] "C:\Programme\Gemeinsame Dateien\Real\Update_OB\realsched.exe"  -osboot
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Programme\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [QuickTime Task] "C:\Programme\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [mspwr] C:\WINDOWS\system32\pupxpman.exe
O4 - HKLM\..\Run: [PwrUpTweakMe] C:\WINDOWS\system32\PUPXPTWK.EXE /TWEAK
O4 - HKLM\..\Run: [WinampAgent] C:\Programme\Winamp\winampa.exe
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [CursorXP] C:\Programme\CursorXP\CursorXP.exe
O4 - HKCU\..\Run: [LDM] C:\Programme\Logitech\Desktop Messenger\8876480\Program\BackWeb-8876480.exe
O4 - HKCU\..\Run: [NoAds] "C:\Programme\NoAds\NoAds.exe"
O4 - HKCU\..\Run: [eMuleAutoStart] C:\Programme\eMule.de\emule.exe -AutoStart
O4 - HKCU\..\Run: [Octoshape Streaming Services] "C:\Programme\Octoshape Streaming Services\Zoran\OctoshapeClient.exe" -inv:bootrun
O4 - Global Startup: Internet Keyboard.lnk = ?
O4 - Global Startup: Snsicon.lnk = C:\Programme\Second Nature\Snsicon.exe
O8 - Extra context menu item: &ICQ Toolbar Search - res://c:\Programme\ICQToolbar\toolbaru.dll/SEARCH.HTML
O8 - Extra context menu item: &Yahoo! Search - file:///C:\Programme\Yahoo!\Common/ycsrch.htm
O8 - Extra context menu item: Alle Bilder von gleichem Server filtern - C:\Programme\Avant Browser\AddAllToADBlackList.htm
O8 - Extra context menu item: Blokiraj sve slike sa istog servera - C:\Programme\Avant Browser\AddAllToADBlackList.htm
O8 - Extra context menu item: Dodaj na AD Crnu Listu - C:\Programme\Avant Browser\AddToADBlackList.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://c:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Hervorheben - C:\Programme\Avant Browser\Highlight.htm
O8 - Extra context menu item: In neuem Avant Browser öffnen - C:\Programme\Avant Browser\OpenInNewBrowser.htm
O8 - Extra context menu item: Nach Microsoft &Excel exportieren - res://c:\PROGRA~1\MICROS~2\Office10\EXCEL.EXE/3000
O8 - Extra context menu item: Najtraženiji - C:\Programme\Avant Browser\Highlight.htm
O8 - Extra context menu item: Otvori sve linkove na ovoj stranici... - C:\Programme\Avant Browser\OpenAllLinks.htm
O8 - Extra context menu item: Suchen - C:\Programme\Avant Browser\Search.htm
O8 - Extra context menu item: Traži - C:\Programme\Avant Browser\Search.htm
O8 - Extra context menu item: Yahoo! &Dictionary - file:///C:\Programme\Yahoo!\Common/ycdict.htm
O8 - Extra context menu item: Yahoo! &Maps - file:///C:\Programme\Yahoo!\Common/ycmap.htm
O8 - Extra context menu item: Yahoo! &SMS - file:///C:\Programme\Yahoo!\Common/ycsms.htm
O8 - Extra context menu item: Zur Werbebanner-Filterliste hinzufügen - C:\Programme\Avant Browser\AddToADBlackList.htm
O8 - Extra context menu item: Öffne alle Links auf dieser Seite... - C:\Programme\Avant Browser\OpenAllLinks.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programme\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Konsole - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programme\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Programme\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Programme\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Programme\Messenger\msmsgs.exe
O12 - Plugin for .m3u: C:\Programme\Internet Explorer\PLUGINS\npqtplugin7.dll
O14 - IERESET.INF: START_PAGE_URL=http://www.chello.at/
O16 - DPF: ConferenceRoom Java Client - http://chat.rainbow.or.at/java/cr.cab
O16 - DPF: {62475759-9E84-458E-A1AB-5D2C442ADFDE} - http://appldnld.m7z.net/qtinstall.info.apple.com/pthalo/de/win/QuickTimeFullInstaller.exe
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1126213112562
O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://acs.pandasoftware.com/activescan/as5free/asinst.cab
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - http://messenger.msn.com/download/msnmessengersetupdownloader.cab
O18 - Protocol: bw+0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw+0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw-0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw-0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw00 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw00s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw10 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw10s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw20 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw20s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw30 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw30s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw40 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw40s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw50 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw50s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw60 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw60s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw70 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw70s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw80 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw80s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw90 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bw90s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwa0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwa0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwb0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwb0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwc0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwc0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwd0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwd0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwe0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwe0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwf0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwf0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwfile-8876480 - {9462A756-7B47-47BC-8C80-C34B9B80B32B} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\GAPlugProtocol-8876480.dll
O18 - Protocol: bwg0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwg0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwh0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwh0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwi0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwi0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwj0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwj0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwk0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwk0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwl0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwl0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwm0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwm0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwn0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwn0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwo0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwo0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwp0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwp0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwq0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwq0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwr0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwr0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bws0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bws0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwt0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwt0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwu0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwu0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwv0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwv0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bww0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bww0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwx0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwx0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwy0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwy0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwz0 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: bwz0s - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Protocol: offline-8876480 - {104F9980-4F70-4364-A43B-F1D93AE60AB7} - C:\Programme\Logitech\Desktop Messenger\8876480\Program\BWPlugProtocol-8876480.dll
O18 - Filter: text/html - (no CLSID) - (no file)
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - Unknown owner - C:\Programme\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - Unknown owner - C:\Programme\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Programme\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Programme\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: AVP-SE - Unknown owner - C:\WINDOWS\System32\avp-32.exe" -service (file missing)
O23 - Service: LexBce Server (LexBceS) - Lexmark International, Inc. - C:\WINDOWS\system32\LEXBCES.EXE
