trojan downloader
Started by morpheus, July 27, 2006, 09:10:57 PM
morpheus
hi,
kapersky found this
C:\inst.hta Infected: Trojan-Downloader.VBS.Small.ae
C:\WINDOWS\system32\i Infected: Trojan-Downloader.BAT.Ftp.ab
I tried dozen scans an other  and only kaspersky found something ....
The problem with my pc is that he is very unstable at moment.
When i surf it goes slow.
When i search something in google, i can can try maybey 10 pages and then it blocks,
and when I want to shut down the page, the pc reboots ....
What could this be
morpheus,
Please can you try at least two if not more of these  On-line scans
Panda
TrendMicro
Bit Defender
Kaspersky
Symantec
McAfee
CommandonDemand
Computer Associates
CyberTechHelp
PC Pitstop
Stinger
Also please use one or both of  these Trojan scanners
a2
or download and try
TrojanHunter (Note Trojan Scanner 30 day Trial)
Then once you have done clear out your cache folder again ie: Run
CCleaner
(Note in CCleaner: go to >options > advanced > Uncheck "Only delete files in Windows Temp folders older than 48 hours"). but see CCleaner Set up
  also in the settup of CCleaner The LS Staff would prefer if you un-tick (un-check) "Utilities" (i.e., Ad-Aware, ewido and other security program logs.)at leat till your pc is clean of spyware/malware
then rescan with Ad-aware doing a  "Full Scan"  and post your logfile here by using the "Add-reply" feature
If needed here's how to post your Ad-aware  Logfile ;)
Here's how to copy your Ad-aware log
click my computer
click local C Drive
then Click Program Files
then Click Lavasoft
then click Ad-aware SE
and then Logs,
find the latest one that you have
(by date & time)
morpheus
hi,
what a job with an unstable pc ....
Bit defender was the only one who found someting
C:\WINDOWS\system32\i     Infected with: Backdoor.BotGet.FtpB.Gen
and deleted it ...
here is the ad aware log
Ad-Aware SE Build 1.06r1
Logfile Created on:vrijdag 28 juli 2006 20:34:36
Using definitions file:SE1R116 24.07.2006
MRU List(TAC index:0):3 total references
Ad-Aware SE Settings
Set : Scan active processes
Set : Scan registry
Set : Deep-scan registry
Set : Scan my Hosts file
Extended Ad-Aware SE Settings
28-7-2006 20:34:36 - Scan started. (Full System Scan)
MRU List Object Recognized!
    Location:          : C:\Documents and Settings\cedric\Application Data\microsoft\office\recent
    Description        : list of recently opened documents using microsoft office
    Location:          : S-1-5-21-1390067357-839522115-1060284298-1003\software\macromedia\dreamweaver 4\recent file list
    Description        : list of recently used files in macromedia dreamweaver
    Location:          : S-1-5-21-1390067357-839522115-1060284298-1003\software\microsoft\windows media\wmsdk\general
    Description        : windows media sdk
Listing running processes
#:1 [smss.exe]
    FilePath           : \SystemRoot\System32\
    ProcessID          : 384
    ThreadCreationTime : 28-7-2006 17:52:10
    BasePriority       : Normal
#:2 [csrss.exe]
    FilePath           : \??\C:\WINDOWS\system32\
    ProcessID          : 452
    ThreadCreationTime : 28-7-2006 17:52:11
#:3 [winlogon.exe]
    ProcessID          : 476
    ThreadCreationTime : 28-7-2006 17:52:12
    BasePriority       : High
#:4 [services.exe]
    ProcessID          : 520
    FileVersion        : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
    ProductVersion     : 5.1.2600.2180
    ProductName        : Besturingssysteem Microsoft® Windows®
    FileDescription    : Services en controllertoepassingen
    LegalCopyright     : © Microsoft Corporation. Alle rechten voorbehouden.
#:5 [lsass.exe]
    ProcessID          : 540
#:6 [svchost.exe]
    ProcessID          : 704
    ThreadCreationTime : 28-7-2006 17:52:14
#:7 [svchost.exe]
    ProcessID          : 752
#:8 [svchost.exe]
    ProcessID          : 788
#:9 [spoolsv.exe]
    ProcessID          : 1024
    ThreadCreationTime : 28-7-2006 17:52:23
    FileVersion        : 5.1.2600.2696 (xpsp_sp2_gdr.050610-1519)
    ProductVersion     : 5.1.2600.2696
#:10 [explorer.exe]
    ProcessID          : 1188
    ThreadCreationTime : 28-7-2006 17:52:25
    FileVersion        : 6.00.2900.2180 (xpsp_sp2_rtm.040803-2158)
    ProductVersion     : 6.00.2900.2180
    FileDescription    : Windows Verkenner
    InternalName       : explorer
#:11 [snmp.exe]
    ProcessID          : 1380
    ThreadCreationTime : 28-7-2006 17:52:26
    FileDescription    : SNMP-service
    InternalName       : snmp.exe
    OriginalFilename   : snmp.exe
#:12 [svchost.exe]
    ProcessID          : 1400
    ThreadCreationTime : 28-7-2006 17:52:27
#:13 [spysweeper.exe]
    FilePath           : C:\Program Files\Webroot\Spy Sweeper\
    ProcessID          : 1464
    FileVersion        : 3,0,5,1286
    ProductVersion     : 3, 0
    ProductName        : Spy Sweeper SDK
    CompanyName        : Webroot Software, Inc.
    FileDescription    : Spy Sweeper Engine
    LegalCopyright     : Copyright (C) 2002 - 2006, All Rights Reserved.
    LegalTrademarks    : Spy Sweeper is a trademark of Webroot Software, Inc.
    OriginalFilename   : SpySweeper.exe
#:14 [delttray.exe]
    ProcessID          : 868
    ThreadCreationTime : 28-7-2006 17:52:51
    FileVersion        : 5.1.0.01
    ProductVersion     : 5.1.0.01
    ProductName        : M Audio Delta Control Panel Interface System Tray Applet
    CompanyName        : Doug Fetter Software Wizardry
    FileDescription    : M Audio Delta Control Panel Interface System Tray Applet
    InternalName       : Delta Panel System Tray Applet
    LegalCopyright     : Copyright © 2002 Midiman, Inc. All rights reserved.
    LegalTrademarks    : M Audio (TM) is a legal trademark of MIDIMAN, Inc.
    OriginalFilename   : DeltTray.EXE
    Comments           : Developed by Doug Fetter Software Wizardry
#:15 [gsicon.exe]
    ProcessID          : 968
    ThreadCreationTime : 28-7-2006 17:52:52
    FileVersion        : 3.1.0
    ProductVersion     : 3.1.0
    ProductName        : ADSL Modem
    CompanyName        : Eicon Networks
    FileDescription    : ADSL Modem Monitor
    InternalName       : GSICON.EXE
    LegalCopyright     : Copyright © 2001 Eicon Networks
    OriginalFilename   : GSICON.EXE
#:16 [dslagent.exe]
    ProcessID          : 908
#:17 [ashdisp.exe]
    FilePath           : C:\PROGRA~1\ALWILS~1\Avast4\
    ProcessID          : 1048
    ThreadCreationTime : 28-7-2006 17:52:53
    FileVersion        : 5, 0, 0, 0
    ProductVersion     : 5, 0, 0, 0
    ProductName        : avast! Antivirus
    FileDescription    : avast! service GUI component
    InternalName       : aswDisp
    LegalCopyright     : Copyright (c) 2006 ALWIL Software
    OriginalFilename   : aswDisp.exe
#:18 [e_aicn03.exe]
    FilePath           : C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\
    ProcessID          : 1128
    ThreadCreationTime : 28-7-2006 17:53:06
    FileVersion        : 1.12
    ProductVersion     : 1.12
    ProductName        : EPSON Status Monitor 3
    CompanyName        : SEIKO EPSON CORPORATION
    FileDescription    : EPSON Status Monitor 3
    InternalName       : E_SICN03
    LegalCopyright     : Copyright (C) SEIKO EPSON CORP. 1999
    OriginalFilename   : E_SICN03.EXE
#:19 [ewido.exe]
    FilePath           : C:\Program Files\ewido anti-spyware 4.0\
    ProcessID          : 3284
    ThreadCreationTime : 28-7-2006 18:15:40
    FileVersion        : 4, 0, 0, 172
    ProductVersion     : 4, 0, 0, 172
    ProductName        : ewido anti-spyware
    CompanyName        : Anti-Malware Development a.s.
    FileDescription    : ewido anti-spyware
    InternalName       : ewido anti-spyware
    LegalCopyright     : Copyright © 2005 Anti-Malware Development a.s.
    OriginalFilename   : ewido.exe
#:20 [wmiprvse.exe]
    FilePath           : C:\WINDOWS\System32\wbem\
    ProcessID          : 940
    ThreadCreationTime : 28-7-2006 18:33:35
    FileDescription    : WMI
    InternalName       : Wmiprvse.exe
    OriginalFilename   : Wmiprvse.exe
#:21 [ad-aware.exe]
    FilePath           : C:\Program Files\Lavasoft\Ad-Aware SE Personal\
    ProcessID          : 1740
    ThreadCreationTime : 28-7-2006 18:34:20
    FileVersion        : 6.2.0.236
    ProductVersion     : SE 106
Memory scan result:
New critical objects: 0
Objects found so far: 3
Started registry scan
Registry Scan result:
Started deep registry scan
Deep registry scan result:
Started Tracking Cookie scan
Tracking cookie scan result:
Disk Scan Result for C:\
Deep scanning and examining files (F:)
Disk Scan Result for F:\
Deep scanning and examining files (G:)
Disk Scan Result for G:\
Deep scanning and examining files (H:)
Disk Scan Result for H:\
Deep scanning and examining files (I:)
Disk Scan Result for I:\
Deep scanning and examining files (J:)
Disk Scan Result for J:\
Deep scanning and examining files (K:)
Disk Scan Result for K:\
Scanning Hosts file......
Hosts file scan result:
1 entries scanned.
New critical objects:0
Conditional scan result:
20:54:38 Scan Complete
Summary Of This Scan
Total scanning time:00:20:01.578
Objects scanned:240483
Objects identified:0
Objects ignored:0
regards
morpheus
hi,
after deleting C:\WINDOWS\system32\i   by bitdefender and after rebooting everything is ok
.... hopely for a long time
was this the real problem ???
There is also   C:\inst.hta Infected: Trojan-Downloader.VBS.Small.ae found  by kaspersky
What should i do with this .... not much to find in google  ????
regards
morpheus
Yesterday it was excellent, today it's a bit slower ....
Two remarques
Zone alarm is constantly monitoring (and the days before (off line) , but yesterday when it worked well for an hour of so (see above) there was no monitoring from za .....
When i visit www.destandaard.be and clicking on one of the news items(fotos) i got problems after 2 or 3 pages ..... Slow and not able to return ....
And this was also not the case testerday ....
Could this site have scripts that are in conflict with my pc ....
what should  I do
regards
morpheus
hi,
all the trouble is gone when i shut down spysweeper... a conflict ???
regards :smash:
morpheus,
Quotewhen i shut down spysweeper... a conflict ???
Do you mean you getting an Error message, can you say what it is you are getting.
morpheus,
Take a look at this post about  Spysweeper
QuoteDid you update Webroot Spysweeper to the new version 5.0.5?
Numerous problems have been reported regarding CPU usage at or near 100% with the last update.
http://forums.scotsnewsletter.com/index.php?s=&showtopic=15852&view=findpost&p=193255
http://www.broadbandreports.com/forum/remark,16483017
http://www.castlecops.com/f163-Spysweeper.html (numerous threads)
As far as I know, the problem was solved for everyone who experienced this problem and reverted to version 4.5 (some had to uninstall in safe mode).
morpheus
hi,
no, i get no error messages... it's just much better when i shutt off spysweeper .(4.05)
I try now to figure out how that i can use ss by removing the conflicting program ...
I wrote ss yesterday .... but still no answer ... probably on vacation ... :tease:
regards
