Miscellaneous => LandzDown Lounge => Topic started by: Brynn on January 10, 2006, 11:19:26 AM
Hey Everyone,
I can't seem to figure out how to delete a message I've posted. I clicked on HELP, which says -- to delete a message, click "Delete". But I don't see a delete button in the editor, or anywhere else!
Ever since I've been posting at LzD, I've not been redirected anywhere after posting a message. I click Post, my screen goes blank...well, the browser goes blank, actually. All I can do is click Refresh. (If I click Back, I just go back to the editor.) So I click Refresh, and I get the Retry/Cancel dialog box (something like - can't refresh this page without resending the info), I choose Retry, and then I get a LzD page that is mostly blank, except for an error message indicating I have posted a duplicate message. Fortunately, it contains a HOME link, which takes me back to the forum Home. Then I can navigate back to the thread I posted in, to confirm that the message posted. And messages have always posted this way for me.
I've always thought it was a permanent glitch, of sorts, in the forum program/software. But now that I realize there's no Delete button, when the HELP pages say there is one, I'm thinking there might be a setting of mine that's not allowing the forums to function properly. I normally keep my browser "locked down", but even though I've put LzD into the Trusted Zone, it hasn't resolved these 2 problems. Oh, and I've configured cookie-, ad-, pop up blockers, as well as firewall, to match Trusted Zone settings. Also, on the Look and Layout Preferences page in my LzD profile, I have the box checked for "Return to topics after posting by default."
What else can I try, to resolve these things? All comments, tips, or ideas welcome!
Brynn,
If i have this right and i have been trying it out using differant theames a member can delete a post that has been made as a reply but NOT if the post is a topic starter.
if the post you want to remove is a topic starter then I recommend that you edit the post usinf the modify button type in some thing like "Sorry Please remove this post" and I sure that one of the Admin will remove it for you. (https://www.landzdown.com/proxy.php?request=http%3A%2F%2Fsmilies.sofrayt.com%2Ffsc%2Fwink2.gif&hash=026d7c7f666300aa5560f32f726a9d4a87a10844)
And as far as your other problem are you allowing Cookies to be set on your pc from the forum just a thought.
GR@PH;<'S :breakkie:
What GR@PH;<'S said is very true.
As to the redirection, is Javascript enabled? I would clean out cookies you have for this site, clear out the tmporary internet files/DNS cache. What browser is it you are using?
Thanks GR@PH;<'S and SpyDie,
I don't have a delete button for any message, topic-starter or not.
I'm accepting cookies from LzD.
I'm using IE6.
I'm pretty sure I have javascript enabled. (There are a few settings, where one configures a Custom security zone, which the 2 sites whose instructions I followed (Eric Howes' and mitch's) to set up my Custom zones, did not address. One of those is "Binary and script behaviors". So in the absence of instructions, I chose "Disable". So if "Binary and script behaviors" includes javascript, then I do have it set to disable. If not, then otherwise, I have javascript enabled.)
I clean out cookies and empty temp internet files once or twice per week, and doing so has not affected these problems.
Hey Folks,
I know it's been a while since I last posted in this thread. But I just solved the redirection problem (or - lack of redirection, to be more precise) which I described in the opening message. So just in case it ever comes up for others, I'll post the "fix". Not that I was still working on it ;) But I was having trouble viewing an entirely different kind of webpage on another website, and finally solved it by enabling META REFRESH. And low and behold, the next time I posted here at LzD, I was redirected! So, for whatever it's worth -- if you're not being redirected after posting at LzD, yet you have the option enabled in your LzD profile, check on your META REFRESH setting in IE Tools > Internet Options > Security > select the affected Zone, scroll to the setting, and click Enable. All best.
Brynn<
Glad you got it sorted and thanks for shearing this as it will help others (https://www.landzdown.com/proxy.php?request=http%3A%2F%2Fsmilies.sofrayt.com%2Ffsc%2Fgentleman.gif&hash=6c1090d9e743a45850d1ab96b5ae1394649c9d02)
