Windows 10 Release Preview
Started by Corrine, July 28, 2022, 05:19:30 PM
0 Members and 3 Guests are viewing this topic.
Releasing Windows 10, version 22H2 to the Release Preview Channel
QuoteToday we are releasing the first preview build of Windows 10, version 22H2. Windows 10 Build 19045.1865 (KB5015878) is now available in the Release Preview Channel for Windows Insider Program for Business participants to validate on devices in their organizations.
This build is also available to any Windows Insider in the Release Preview Channel via the "seeker" experience in Windows Update. This means Insiders currently in the Release Preview Channel can go to Settings > Windows Update and choose to download and install Windows 10, version 22H2. Once an Insider updates their PC to Windows 10, version 22H2, they will continue to automatically receive new servicing updates through Windows Update (the typical monthly update process).
Releasing Windows 10 Build 19045.2787 to Release Preview Channel
This update includes the following improvements:
  • This update affects the ms-appinstaller URI. It now works with the DesktopAppInstaller policy.
  • The update addresses an issue that affects the Remote Procedure Call Service (rpcss.exe). The issue might cause a race condition between the Distributed Component Object Model (DCOM) and the Microsoft Remote Procedure Call (RPC) endpoint mapper.
  • This update addresses an issue that affects the Microsoft HTML Application Host (HTA). This issue blocks code execution that uses Microsoft HTA. This occurs when you turn on Windows Defender Application Control (WDAC) User Mode Code Integrity (UMCI) enforced mode.
  • This update addresses an issue that affects Desired State Configuration. It loses its previously configured options. This occurs if metaconfig.mof is missing.
  • This update addresses compatibility issues that affect some printers. These printers use Windows Graphical Device Interface (GDI) printer drivers. These drivers do not completely adhere to GDI specifications.
  • This update addresses an issue that affects the Simple Certificate Enrollment Protocol (SCEP) certificate. The system reports some SCEP certificate installations as failed. Instead, the system should report them as pending.
  • This update addresses an issue that affects USB printers. The system classifies them as multimedia devices even though they are not.
  • This update addresses an issue that affects the Fast Identity Online 2.0 (FIDO2) PIN credential icon. It does not appear on the credentials screen of an external monitor. This occurs when that monitor is attached to a closed laptop.
  • This update affects applications that use the Windows UI Library in the Windows App SDK (WinUI 3). It makes printing for them possible on Windows 10 devices.
  • This update addresses an issue that affects the SharedPC account manager. It cannot delete multiple accounts during cleanup.
  • This update addresses an issue that might affect lsass.exe. It might stop responding. This occurs when it sends a Lightweight Directory Access Protocol (LDAP) query to a domain controller that has a very large LDAP filter.
Releasing Windows 10 Build 19045.2908 to Release Preview Channel
  • New! This update adds the ability to sync language and region settings when you change your Microsoft account display language or regional format. Windows will save those settings to your account if you have turned on Language preferences sync in your Windows backup settings.
  • New! This update changes firewall settings. You can now configure application group rules.
  • New! This update brings back the search box experience on the Windows 10 taskbar. If you have a top, bottom, regular, or small icons taskbar, you will see the search box appear. You can use it to easily access apps, files, settings, and more from Windows and the web. You will also have access to the latest search updates, such as search highlights. If you want to restore your original search experience, you can do that easily by using the context menu or responding to a dialog that appears when you use search.
  • This update affects the Islamic Republic of Iran. The update supports the government's daylight saving time change order from 2022.
  • The update addresses an issue that sends unexpected password expiration notices to users. This occurs when you set up an account to use "Smart Card is Required for Interactive Logon" and set "Enable rolling of expiring NTLM secrets".
  • This update addresses an issue that affects the Local Security Authority Subsystem Service (LSASS) process. It might stop responding. Because of this, the machine restarts. The error is 0xc0000005 (STATUS_ACCESS_VIOLATION).
  • This update addresses an issue that affects Microsoft Edge IE mode. Pop-up windows open in the background instead of in the foreground.
  • This update addresses an issue that affects Edge IE mode. The Tab Window Manager stops responding.
  • This update addresses an issue that affects protected content. When you minimize a window that has protected content, the content displays when it should not. This occurs when you are using Taskbar Thumbnail Live Preview.
  • This update addresses an issue that affects provisioning packages. They fail to apply in certain circumstances when elevation is required.
  • This update addresses an issue that affects mobile device management (MDM) customers. The issue stops you from printing. This occurs because of an exception.
  • This update changes the app icons for certain mobile providers.
  • This update addresses an issue that affects the Windows Defender Application Control. The policy that blocks software using a hash rule might not stop the software from running.
  • This update addresses an issue that affects the Chinese input method. You cannot see all of the first suggested item.
  • This update affects Xbox Elite users who have the Xbox Adaptive Controller. This update applies your controller remapping preferences on the desktop.
  • This update addresses an issue that occurs when you use a PIN to sign in to Windows Hello for Business. Signing in to Remote Desktop Services might fail. The error message is, "The request is not supported".
  • This update addresses an issue that might affect the keyboard layout when you sign in to a console session. The layout might be reset to the system default. This occurs when you lock your machine or have more than one keyboard layout in Settings.
  • This update addresses an issue that might affect news and interests. It might flicker on the taskbar and File Explorer might stop responding.
  • This update addresses rendering issues that affect the search box gleam (an animated icon). The issue occurs when you use wide, narrow, or small taskbar mode.
  • This update addresses an issue that affects Microsoft Edge WebView2. This issue might cause an infinite loop when you try to restart its process.
  • This update addresses an issue that affects Administrator Account Lockout policies. GPResult and Resultant Set of Policy did not report them.
  • This update addresses an issue that affects Active Directory Users & Computers. It stops responding. This occurs when you use TaskPad view to enable or disable many objects at the same time.
  • This update addresses an issue that affects the Unified Write Filter (UWF). When you turn it off by using a call to Windows Management Instrumentation (WMI), your device might stop responding.
  • This update addresses an issue that affects the Resilient File System (ReFS). A stop error prevents the OS from starting up correctly.
  • This update addresses an issue that affects MySQL commands. The commands fail on Windows Xenon containers.
  • This update addresses an issue that affects SMB Direct. Endpoints might not be available on systems that use multi-byte character sets.
Releasing Windows 10 Build 19045.3154 to Release Preview Channel
  • New! This update improves several simplified Chinese fonts and the Microsoft Pinyin Input Method Editor (IME) to support GB18030-2022. You can enter and display characters from conformance level 1 or 2 using the additions to Microsoft Yahei, Simsun, and Dengxian. This update now supports Unicode Extensions E and F in the Simsun Ext-B font. This meets the requirements for level 3.
  • New! This update adds many new features and improvements to Microsoft Defender for Endpoint. For more information, see Microsoft Defender for Endpoint.
  • New! With this update, you can now authenticate across Microsoft clouds. This feature also satisfies Conditional Access checks if they are needed.
  • This update addresses an issue that affects the on-screen keyboard. The issue stops it from opening after you lock the machine.
  • This update addresses an issue that affects a scheduled monthly task. It might not run on time if the next occurrence happens when daylight savings time occurs.
  • This update addresses an issue that affects all the registry settings under the Policies paths. They might be deleted. This occurs when you do not rename the local temporary user policy file during Group Policy processing.
  • This update affects the Desktop Window Manager (DWM). It improves its reliability.
  • This update addresses an issue that affects .msi files. A minor update is not installed. This occurs when you use the EnterpriseDesktopAppManagement configuration service provider (CSP) to distribute the .msi file.
  • This update addresses an issue that affects the Spooler service. It stops working. This issue occurs when you print using a certain workspace.
  • This update addresses an issue that affects a tib.sys driver. It does not load. This occurs when HyperVisor-protected Code Integrity (HVCI) is enabled.
  • This update addresses an issue that affects NCryptGetProperty(). When you call it with NCRYPT_KEY_TYPE_PROPERTY, the system returns 0x1 instead of 0x20. This occurs when the key is a machine key.
  • This update addresses an issue that affects HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders. You can now set and maintain the correct default permissions for this directory path. When the permissions are wrong, the Start menu, search, and Azure Active Directory (Azure AD) authentication fail.
  • This update addresses an issue that affects those who enable the "Smart Card is Required for Interactive Logon" account option. When RC4 is disabled, you cannot authenticate to Remote Desktop Services farms. The error message is, "An authentication error has occurred. The requested encryption type is not supported by the KDC."
  • This update addresses an issue that affects HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders. You can now set and maintain the correct default permissions for this directory path. When the permissions are wrong, Start menu, search, and Azure Active Directory (Azure AD) authentication fails.
Releasing Windows 10 Build 19045.3269 to Release Preview Channel
Windows 10 22H2 Build 19045.3269 (KB5028244) to the Release Preview Channel.
  • This update addresses an issue that affects the Windows Notification Platform. It fails to send notifications from applications to you.
  • This update addresses an issue that affects hybrid joined devices. You cannot sign in to them if they are not connected to the internet. This occurs when you use a Windows Hello for Business PIN or biometric credentials. This issue applies to a cloud trust deployment.
  • This update affects Windows Autopilot profiles. The process to download the Windows Autopilot policy is more resilient. This helps when a network connection might not be fully initialized. This update increases the retry attempts when you try to download the Windows Autopilot profile.
  • This update addresses an issue that might affect Win32 and Universal Windows Platform (UWP) apps. They might close when devices enter Modern Standby. Modern Standby is an expansion of the Connected Standby power model. This issue occurs if certain Bluetooth Phone Link features are turned on.
  • This update addresses an issue that affects Event Forwarding Subscriptions. When you add an Event Channel to the subscription, it forwards events you do not need.
  • This update addresses an issue that affects the Windows Management Instrumentation (WMI) repository. This causes an installation error. The issue occurs when a device does not shut down properly.
  • This update affects user mode printer drivers. They unload unexpectedly. This occurs when you print from multiple print queues to the same printer driver.
  • This update enhances hinting for some of the letters of the Verdana Pro font family.
  • This update addresses an issue that might affect your computer when you are playing a game. Timeout Detection and Recovery (TDR) errors might occur.
  • This update affects text edit controls in XAML. You cannot edit the controls again after they become read only. This occurs when you use the new Microsoft Input Method Editor for Japanese, Chinese, and Korean.
  • This update addresses an issue that affects a printing job. An unexpected Internet Printing Protocol (IPP) mode switch can cause the print job to abruptly stop. This occurs when there is an independent hardware vendor (IHV) driver.
  • This update makes Country and Operator Settings Asset (COSA) profiles up to date.
  • This update addresses an issue that affects certain display and audio devices. They are missing after your system resumes from sleep.
  • This update addresses a deadlock in Internet Protocol Security (IPsec). When you configure servers with IPsec rules, they stop responding. This issue affects virtual and physical servers.
  • This update addresses an issue that might affect some VPN clients. They might not establish a connection.
  • This update affects the Windows Kernel Vulnerable Driver Blocklist, DriverSiPolicy.p7b. It adds drivers that are at risk for Bring Your Own Vulnerable Driver (BYOVD) attacks.
  • This update addresses an issue that causes Windows to fail. This occurs when you use BitLocker on a storage medium that has a large sector size.
  • This update addresses an issue that affects the Search app. It opens in full screen, blocks additional Start menu actions, and you cannot close it.
  • This update addresses an issue that affects I/O over Server Message Block (SMB). It might fail when you use the LZ77+Huffman compression algorithm.
Releasing Windows 10 Build 19045.3391 to Release Preview Channel
Windows 10 22H2 Build 19045.3391 (KB5029331) to the Release Preview Channel.
  • New! This update improves how Windows detects your location. This helps to give you better weather, news, and traffic information.
  • New! This update expands the roll out of notification badging for Microsoft accounts on the Start menu. A Microsoft account is what connects Windows to your Microsoft apps. The account backs up all your data and helps you to manage your subscriptions. You can also add extra security steps to keep you from being locked out of your account. This feature gives you quick access to important account-related notifications.
  • This update makes daylight saving time (DST) changes for Israel.
  • This update addresses an issue that affects the Group Policy Service. It will not wait for 30 seconds, which is the default wait time, for the network to be available. Because of this, policies are not correctly processed.
  • This update adds a new API for D3D12 Independent Devices. You can use it to create multiple D3D12 devices on the same adapter. To learn more, see D3D12 Independent Devices.
  • This update addresses an issue that affects an app that simulates keyboard input. That app might not send Japanese characters to other apps.
  • This update addresses an issue that affects a WS_EX_LAYERED window. The window might render with the wrong dimensions or at the wrong position. This occurs when you scale the display screen.
  • This update addresses an issue that affects print jobs that are sent to a virtual print queue. They fail without an error.
  • This update addresses an issue that affects disk partitions. The system might stop working. This occurs after you delete a disk partition and add the space from the deleted partition to an existing BitLocker partition.
  • This update addresses an issue that affects Remote Desktop (RD) sessions. They disconnect when multiple apps are in use.
  • This update addresses an issue that affects the display of the search box.
  • This update addresses an issue that affects settings. They do not sync even if you turn on the toggle on the Windows backup page in the Settings app.
  • This update addresses an issue that affects the Resultant Set of Policy (RSOP). The Windows LAPS "BackupDirectory" policy setting was not being reported. This occurs when the setting is set to 1, which is "Back up to AAD."
Releasing Windows 10 Build 19045.3513 to Release Preview Channel
This update includes the following improvements Windows 10, version 22H2:
  • New! This update completes the work to comply with the GB18030-2022 requirements. It removes and remaps characters for Microsoft Wubi input and Microsoft Pinyin U-mode input. You can no longer enter character codepoints that are not supported. All the required codepoints are up to date.
  • New! This update brings back an improved search box experience on the taskbar. If you have a top, bottom, regular, or small icons taskbar, you will see the search box appear. You can use it to easily access apps, files, settings, and more from Windows and the web. You will also have access to the latest search updates, such as search highlights. If you want to restore your previous search experience, you can do that easily. Use the taskbar shortcut menu or respond to a dialog that appears when you use search.
  • New! This update adds animations to a few icons on the news and interests taskbar button. These animations occur when:
  • A new announcement appears on the news and interests taskbar button.
  • You hover over or click the icon while the announcement is on the taskbar.
  • This update supports daylight saving time (DST) changes in Greenland.
  • This update changes the spelling of Ukraine's capital from Kiev to Kyiv.
  • This update addresses an issue that affects Microsoft Excel. It stops responding when you try to share a file as a PDF in Microsoft Outlook.
  • This update addresses an issue that is related to changes in the forwarding of events.
  • This update addresses an issue that affects an Application Virtualization (App-V) environment. Copy operations within it stop working. This occurs after you install the April 2023 update.
  • This update addresses an issue that affects Microsoft Print to PDF. It uses the metadata for the name you sign in with as the author of a printed PDF. It should use the display name instead.
  • This update addresses an issue that affects some USB printers. Microsoft Defender stops them from printing.
  • This update addresses an issue that affects device health. Some devices cannot attest to their security health.
  • This update addresses an issue that affects Windows Defender Application Control (WDAC). AppID Tagging policies might greatly increase how long it takes your device to start up.
  • This update addresses an issue that affects the touch keyboard. Sometimes it does not open.
  • This update addresses an issue that affects IMEPad. It stops working. This occurs when you enter end-user-defined characters (EUDC).
  • This update addresses an issue that affects application compatibility. It is related to Microsoft Defender for Endpoint.
  • This update addresses an issue that affects Remote Apps. The display of some elements is not aligned correctly.
  • This update addresses an issue that affects toast notifications. They might not appear when you use UI Automation tools to read them.
  • This update addresses an issue that affects the Microsoft Distributed Transaction Coordinator (DTC). It has a handle leak. Because of this, the system runs out of memory.
  • This update addresses an issue that might cause a user-mode memory leak. It might occur when you call CopyFile() or MoveFile().
  • This update addresses an issue that might make Windows stop responding. This might occur if you use Microsoft OneDrive files that are compressed by NTFS.
  • This update addresses an issue that affects external binding. It fails. This occurs after you install Windows updates dated May 2023 or later. Because of this, there are issues that affect LDAP queries and authentication.
Releasing Windows 10 Build 19045.3633 to Release Preview Channel
This Build is for Insiders who are on Windows 10, version 22H2 and includes the following improvements:
  • This update supports daylight saving time (DST) changes in Syria. To learn more, see Interim guidance for Syria DST changes 2022.
  • This update addresses a memory leak in ctfmon.exe.
  • This update addresses a memory leak in TextInputHost.exe.
  • This update addresses an issue that affects touchscreens. They do not work properly when you use more than one display.
  • This update addresses an error that occurs when you print using v4 print drivers.
  • This update addresses an issue that affects Outlook. It stops responding. This occurs when you print to an Internet Printing Protocol (IPP) printer that has a slow response time.
  • This update addresses an issue that affects connectivity. It is lost. This occurs when you add a second network interface card (NIC) that has no default gateway.
  • This update makes Country and Operator Settings Asset (COSA) profiles up to date for certain mobile operators.
  • This update addresses an issue that affects Windows Defender Application Control (WDAC). Its "allow" policies might block some binaries from running.
  • This update addresses an issue that affects robocopy. The /efsraw switch stops it from copying data properly.
Releasing Windows 10 Build 19045.3754 to Release Preview Channel
This Build is for Insiders who are on Windows 10, version 22H2.
After installing today's November 2023 non-security preview update (KB5032278), Windows Insiders in Release Preview with eligible devices3 running Windows 10, version 22H2 who are interested in experiencing Copilot in Windows as soon as possible when we begin rolling it out in the near future, can choose to do so by going to Settings > Update & Security > Windows Update and turning on "Get the latest updates as soon as they're available" and Check for updates 4,5. This will be a phased launch via controlled feature rollout (CFR) over the coming months.
Windows 10 Pro edition devices on version 22H2 that are managed by organizations will not be included in the initial rollout of Copilot in Windows. Windows 10 Enterprise and Education edition devices on version 22H2 will also not be included in the initial rollout of Copilot in Windows.
When we begin rolling Copilot in Windows (in preview) for devices running Windows 10, version 22H2 Home and Pro editions, we will publish a follow-up blog post to this one.
Today's November 2023 non-security preview update includes the following improvements:
  • New!If you use Home or Pro consumer devices or non-managed business devices, you can get some of the newest experiences as soon as they are ready. To do so, go to Settings > Update & Security > Windows Update. Set the Get the latest updates as soon as they are available toggle to on. Note that this toggle is not turned on for devices that your IT department manages unless IT configures a new policy.
  • New! This update adds new functionality that affects app defaults. To learn more, see A principled approach to app pinning and app defaults in Windows.
  • New! The news & interests feature on your device is now larger! This will help you use the feature more effectively and show the content you care about most on a larger scale.
  • New! This update adds Windows Update opt-in notifications to the screen when you sign in.
  • This update affects the Netherlands time zone. It adds the recent man-made landmass outside of Rotterdam to the shape files.
  • This update addresses an issue that affects the Trusted Sites Zone logon policy. You cannot manage it using mobile device management (MDM).
  • This update addresses an issue that causes IE mode to stop responding. This occurs if you press the left arrow key when an empty text box has the focus and caret (cursor) browsing is on.
  • This update addresses an issue that affects IE mode. A webpage stops working as expected when there is an open modal dialog.
  • This update addresses app cursor issues. These issues occur when apps use the WebView2Standalone XAML control.
  • This update addresses an issue that causes IE mode to stop responding. This occurs when you have multiple IE mode tabs open.
  • This update addresses an issue that affects fontdrvhost.exe. It stops responding when you use Compact Font Format version 2 (CFF2) fonts.
  • This update addresses an issue that affects non-admin processes. Game performance goes down, and the video stutters.
  • This update addresses an issue that affects protected content. It stops cross-process windows from being created. Because of this update, you can keep using out-of-process hosting for things like WebView2 under protected, top-level windows.
  • This update addresses an issue that affects the cursor. Its movement lags in some screen capture scenarios.
  • This update addresses an issue that affects the touch keyboard. It might not appear during the out-of-box experience (OOBE).
  • This update affects Microsoft Defender for Endpoint (MDE). It enables Conditional Access (CA) scenarios.
  • This update addresses a localization issue for Great Britain English (EN-GB) locales. The error message for invalid characters in a new Windows Hello PIN is wrong.
  • This update addresses a leak in volatile notifications. This might stop you from signing in to your machine.
  • This update addresses an issue that affects Windows LAPS. Its PasswordExpirationProtectionEnabled policy fails to turn on the setting.
1 Copilot is currently available in preview in select global markets. It is our intention to add additional markets over time.
2 Devices running Home and Pro (non-managed) on Windows 10, version 22H2.
3 4GB RAM and 720p display required. Timing of feature delivery and availability varies by market and device. Requires Microsoft account to login.
4 Device may need to reboot to enable new features.
5 Note the toggle won't be enabled for managed devices (those that are managed by Windows Update for Business or WSUS).
6 Screenshot of Copilot on Windows 10 above is simulated, subject to change. Feature availability and rollout timing varies by market and device.
Releasing Windows 10 Build 19045.3757 to Release Preview Channel
With this update, we are beginning to roll out Copilot in Windows (in preview)1 for devices running Windows 10, version 22H2 Home and Pro editions2. Windows Insiders in Release Preview with eligible devices3 running Windows 10, version 22H2 who are interested in experiencing Copilot in Windows as soon as possible can choose to do so by going to Settings > Update & Security > Windows Update and turning on "Get the latest updates as soon as they're available" and Check for updates4,5. Windows Insiders on eligible devices in the Release Preview Channel who already did this with last week's update should see Copilot in Windows shortly. As a reminder, this will be a phased launch via controlled feature rollout (CFR) over the coming months.
The Copilot in Windows button will appear on the right side of the taskbar in Windows 10. When you select it, Copilot in Windows appears at the right on your screen. It will not overlap with desktop content or block open app windows.
Windows 10 Pro edition devices on version 22H2 that are managed by organizations will not be included in this initial rollout of Copilot in Windows. Windows 10 Enterprise and Education edition devices on version 22H2 will also not be included in this initial rollout of Copilot in Windows. To prepare for Copilot in Windows on Windows 10, IT administrators can click here to learn how they can manage Copilot in Windows for their organization.
Releasing Windows 10 Build 19045.3992 to Release Preview Channel
This update includes the following features and improvements:
  • New! This update adds a feature for eye control system settings. You can back up these settings from the former device while you set up a new device. Then those settings will install automatically on the new device so you can use them when you reach the desktop.
  • New! The coming weeks will bring a richer weather experience to your lock screen. This includes dynamic, interactive weather updates. So, as you hover over the weather on your lock screen, you will see more information. When you tap or click on the weather card and sign in, Microsoft Edge opens with the full forecast in MSN weather. If you already use Weather in Settings > Personalization > lock screen > Lock screen status, there is nothing for you to do. Also, this new experience will be on by default if Lock screen status is set to "None." Like today, lock screen status will be available when you lock your screen no matter which personalization option you select (Windows spotlight, Picture, or Slideshow).
  • This update addresses an issue that affects an Internet Explorer shortcut. After you use a policy to remove it, the shortcut reappears.
  • This update addresses an issue that affects Windows Management Instrumentation (WMI). A caching issue occurs. The issue causes CurrentTimeZone to change to the wrong value.
  • This update addresses an issue that affects XPath queries on FileHash and other binary fields. It stops them from matching values in event records.
  • This update addresses a known issue that affects BitLocker data-only encryption. A mobile device management (MDM) service, such as Microsoft Intune, might not get the right data.
  • This update addresses an issue that affects some single-function printers. They might install as a scanner.
  • This update addresses an issue that affects the Code Integrity Module (ci.dll). This issue stops your device from responding.
  • This update includes quarterly changes to the Windows Kernel Vulnerable Driver Blocklist file, DriverSiPolicy.p7b. It adds to the list of drivers that are at risk for Bring Your Own Vulnerable Driver (BYOVD) attacks.
  • This update affects Unified Extensible Firmware Interface (UEFI) Secure Boot systems. It adds a renewed signing certificate to the Secure Boot DB variable. You can now opt for this change.
  • This update addresses an issue that stops you from reconnecting to an existing Remote Desktop session. Instead, you get a new one.
  • This update addresses an issue that occurs when you change the keyboard language. The change fails to apply to RemoteApps in some scenarios.
  • This update addresses an issue that affects Windows Local Administrator Password Solution (LAPS) Post Authentication Actions (PAA). The actions occur at restart instead of at the end of the grace period.
  • This update addresses an issue that affects Active Directory. Bind requests to IPv6 addresses fail. This occurs when the requestor is not joined to a domain.
  • This update addresses an issue that affects the LocalUsersAndGroups CSP. It stops processing group memberships if it cannot find a group.
  • This update addresses an issue that affects deleted cloud files. When a cloud provider vetoes a deletion request, the files might still be removed.
  • This update addresses an issue that affects MSIX applications. They do not open, and, in some cases, they make the host unresponsive. This occurs when they use MSIX App Attach with a CimFS image.
  • This update addresses an issue that affects Group Policy Folder Redirection in a multi-forest deployment. The issue stops you from choosing a group account from the target domain. Because of this, you cannot apply advanced folder redirection settings to that domain. This issue occurs when the target domain has a one-way trust with the domain of the admin user. This issue affects all Enhanced Security Admin Environment (ESAE), Hardened Forests (HF) or Privileged Access Management (PAM) deployments.
Releasing Windows 10 Build 19045.4116 to Release Preview Channel
Windows 10 22H2 Build 19045.4116 (KB5034843) to the Release Preview Channel for those Insiders who are on Windows 10, version 22H2.
  • New! This update adds Desktop Spotlight to your desktop background. Just one click or tap of the icon on your desktop takes you to Bing, where you can explore the world one picture at a time.
  • New! Using Windows share, you can now directly share URLs to apps like WhatsApp, Gmail, Facebook, and LinkedIn. Sharing to X (formerly Twitter) is coming soon.
  • This update addresses an issue that affects Azure Virtual Desktop sessions. There are delays when you sign in.
  • This update affects games you install on a secondary drive. Now, they remain installed on the drive.
  • This update addresses an issue that affects Windows Hello for Business. You cannot use it to authenticate to Microsoft Entra ID on certain apps. This occurs when you use Web Access Management (WAM).
  • This update addresses an issue that affects Microsoft Edge. The UI is wrong for Internet Options Data Settings.
  • This update addresses an issue that affects the Japanese Input Method Editor (IME). It fails to work for custom desktops.
  • This update addresses an issue that affects Remote Desktop Web Authentication. You might not be able to connect to sovereign cloud endpoints.
Releasing Windows 10 Build 19045.4233 to Release Preview Channel
  • New! This update adds Windows Spotlight to your desktop background. This feature displays new images as your desktop wallpaper. If you want to know more about an image, click or tap the Learn More button, which takes you to Bing. To turn on this feature, go to Settings > Personalization > Background > Personalize your background. Choose Windows spotlight. Note this feature might not be available to all users because it will roll out gradually.
  • New! This update adds more content to your lock screen. In addition to weather, sports, traffic, and finance content will appear.  To turn on this feature, go to Settings > Personalization > Lock screen. Note this feature might not be available to all users because it will roll out gradually.
  • New! This update affects Windows Hello for Business. IT admins can now use mobile device management (MDM) to turn off the prompt that appears when users sign in to an Entra-joined machine. To do this, they can turn on the "DisablePostLogonProvisioning" policy setting. After a user signs in, provisioning is off for Windows 10 and Windows 11 devices.
  • When you sign in, you might see a message that invites you to upgrade to Windows 11. This message only appears if your device is eligible for an upgrade. Note this feature might not be available to all users because it will roll out gradually.
  • This update supports daylight saving time (DST) changes in Palestine. To learn more, see Interim guidance for DST changes announced by Palestinian Authority for 2024, 2025.
  • This update supports daylight saving time (DST) changes in Kazakhstan. To learn more, see Interim guidance for Kazakhstan time zone changes 2024.
  • This update supports daylight saving time (DST) changes in Samoa. To learn more, see Interim guidance for Samoa DST changes 2021.
  • This update changes the English name of the former Republic of Turkey. The new, official name is the Republic of Türkiye.
  • This update addresses an issue that affects the COM+ component. Some applications that depend on it stop responding.
  • This update addresses an issue that stops some apps and features from being available. This occurs after you upgrade to Windows 11.
  • This update addresses a deadlock issue in CloudAP. It occurs when different users sign in and sign out at the same time on virtual machines.
  • This update addresses an issue that affects a network resource. You cannot access it from a Remote Desktop session. This occurs when you turn on the Remote Credential Guard feature and the client is Windows 11, version 22H2 or higher.
  • This update addresses an issue that affects Microsoft Edge. It fails to open on Surface Hub (Team OS).
  • This update affects the Antimalware Scan Interface (AMSI) AmsiUtil class. It helps to detect the bypass of the AMSI scan. This update also addresses some long-term issues that expose your device to threats.
  • This update addresses an issue that affects the time service. You can configure it using mobile device management (MDM) or a Group Policy Object (GPO). But the Windows Settings app does not match what you have configured.
  • This update addresses an issue that affects the touch keyboard. It does not open sometimes.
  • This update addresses an issue that occurs when you use LoadImage() to load a top-down bitmap. If the bitmap has a negative height, the image does not load and the function returns NULL.
  • This update addresses an issue that affects scanners. They stop responding when you connect to them using eSCL over USB.
  • This update makes Country and Operator Settings Asset (COSA) profiles up to date for some mobile operators.
  • This update addresses an issue that affects the existing AppLocker rule collection enforcement mode. It is not overwritten when rules merge with a collection that has no rules. This occurs when the enforcement mode is set to "Not Configured."
  • This update addresses an issue that affects the Group Policy service. It fails after you use LGPO.exe to apply an audit policy to the system.
  • This update addresses a reliability issue. It affects a Virtual Remote App product when you use a custom shell to open it.
UPDATE 3/19: We have released Windows 10 22H2 Build 19045.4235 (KB5035941) to the Release Preview Channel for those Insiders who are on Windows 10, version 22H2. This update is just a re-release with the same changes documented below on 3/14.
Releasing Windows 10 Build 19045.4353 to Release Preview Channel
This update includes the following features and improvements to the Release Preview Channel for those Insiders who are on Windows 10, version 22H2:
  • New! This update starts the rolls out of account-related notifications for Microsoft accounts in Settings > Home. A Microsoft account connects Windows to your Microsoft apps. The account also backs up all your data and helps you to manage your subscriptions. You can also add extra security steps to keep you from being locked out of your account. This feature displays notifications across the Start menu and Settings. You can manage your Settings notifications in Settings > Privacy & security > General.
  • This update addresses an issue that affects app licensing. Because of this, Copilot in Windows (in preview) does not work as you expect.
  • This update addresses an issue that occurs when your device resumes from Modern Standby. You might get the stop error, "0x9f DRIVER_POWER_STATE_FAILURE."
  • This update addresses a race condition that might stop a machine from starting up. This occurs when you set up a bootloader to start up multiple OSes.
  • This update affects media allocations. It improves their memory granularity for some hardware setups. This lowers overcommitment. Also, performance is more efficient.
  • This update addresses an issue that affects an accelerator backing store management path. A memory leak occurs that affects some devices.
  • This update addresses an issue that affects the container networking Address Resolution Protocol (ARP). It returns the wrong Virtual Subnet ID (VSID) for external ports.
  • This update affects hypervisor-protected code integrity (HVCI). It accepts drivers that are now compatible.
  • This update addresses an issue that affects Protected Process Light (PPL) protections. You can bypass them.
  • This update addresses an issue that affects some wireless earbuds. Bluetooth connections are not stable. This occurs on devices that have firmware from April 2023 and later.
  • This update addresses an issue that affects the Distributed Transaction Coordinator (DTC). A memory leak occurs when it retrieves mappings.
  • This update addresses an issue that affects Windows Local Administrator Password Solution (LAPS). Its Post Authentication Actions (PAA) do not occur at the end of the grace period. Instead, they occur at restart.
  • This update makes some changes to Windows Search. It is now more reliable, and it is easier to find an app after you install it. This update also gives you a personalized app search experience.
