What Am I Used for?
Started by SpyDie, July 21, 2009, 10:27:25 PM
Triple Helix
Tell me if you need a hint!
TH
Triple Helix
Helix,
is it a water cutter.
As in users water to cut.
Triple Helix
No sorry! But it is a type of cutter!
TH
Triple Helix
Triple Helix,
Is it an alloy cutter say for cutting wheels.
if not then i need a hint or two.
That is unless anyone else wants to have a guess.
Triple Helix
Quote from: GR@PH;<'S on January 14, 2012, 10:48:04 PM
Triple Helix,
*DM
Find the first letter!
TH
Triple Helix
Triple Helix,
Electrical discharge machine.
Triple Helix
Quote from: GR@PH;<'S on January 15, 2012, 10:02:29 PM
Triple Helix,
Correct EDM!  :Hammys pint:
Triple Helix
Ok what am I.
BeeZee
It is a tie-rod used for steering.
BeeZee,
Your turn.
BeeZee
BeeZee,
Is it a die form a Tap & Die Set.
BeeZee
No, it is not a die from a tap and die set.
I will admit that my picture isn't the best, so here is another picture.
BeeZee,
Hmm looks as if it is geared and used as a seal so would it be used on the end of an electrical motor.
May be  [username]  may have the anwser.
maybe a clue
BeeZee
A clue !!
Well.....OK. It has something to do with welding.
