Spyware Doctor?
Started by Ripley, December 26, 2005, 04:57:26 PM
I got SpywareBlaster updated & active, but I'm just trying to figure out if Ewido keeps "removing" after the trial period ends.
Apparently, some programs loose this capabilityafter the trial period ends unless you pay for it?
Quote from: default on January 10, 2006, 05:24:52 AM
I am using the free trial that does not remove any thing with it's scans. I like it. It's active blocking seems to work well and it seem very good at blocking keyloggers.
I went back to Ewido.net and looked better at the fine print:
"This setup contains the free as well as the plus-version of the ewido security suite. After the installation, a free 14-day test version containing all the extensions of the plus-version will be activated. At the end of the test phase, the extensions of the plus version are deactivated and the freeware version can be used unlimited times. The purchased license code of the plus version can be entered at any time.
Additional features of the Plus-Version:
Realtime monitoring of the entire system
Memory Scan detects active threats
Self-protection at kernel layer guarantees gapless monitoring
Automatic online-update"
It would appear Ewido keeps doing the removal part even after the trial ends.  All my scans are clean, so I haven't had a chance to check this out.
