Pc doesn't start
Started by Andre21, October 22, 2015, 09:39:53 AM
Andre21
The pc suddenly started freezed with the motherboard theme . i checked the cables ,all looks fine . any ideas?
Paddy
Try this, do a forced power down. Press and hold the power button for five seconds till the computer shuts down then give it a minute and power the machine up again. Let us know if it returns back to normal..
Paddy..
Andre21
I did that a few times ,it starts the same .
Remove every USB connected device then try and boot. You might get an error like no keyboard if all you have is a USB connector for keyboard  but at least it will go a bit further.
Next connect the keyboard and mouse and see if it boots up.
Andre21
It doesn't work . I'll buy another  ;D
techie
There are two things you didn't try. Turn off the system and unplug the power. Then hold the the power button for about 30 seconds. Reattach the power cord and try booting up.
The second, enter your bios settings and set it to default, save and exit.
