Windows 10 Insider Dev Channel (Fast Ring)
Started by Corrine, December 16, 2019, 10:40:17 PM
Announcing Windows 10 Insider Preview Build 19613 | Windows Experience Blog
QuoteUPDATE 4/27: We've released Cumulative Update Build 19613.1005 (KB4558320) today with no major changes. This update is designed to test our servicing pipeline with builds from the Active Development Branch in the Fast ring.
Windows Insider Preview Build 19619.1000 Released to Insiders on the Fast Ring:  Announcing Windows 10 Insider Preview Build 19619 | Windows Experience Blog.
The update includes trusted information about the coronavirus pandemic using the search bar in Windows, including a coronavirus info banner in Search Home.  Another new feature will allow you to control your music and audio apps from within the Your Phone app.
Fixes:
  • We fixed an issue resulting in some Insiders experiencing bugchecks with error DPC WATCHDOG VIOLATION in the last few builds. This is also believed to be the root cause of some Insiders experiencing their PC frequently freezing.
  • We fixed an issue while typing into the browser that could result in the Japanese IME unexpectedly being in Private mode even though the browser wasn't in inPrivate mode.
  • We fixed an issue causing many Schannel errors to appear in the System event log.
  • We fixed an issue resulting in some unexpected characters showing up in the text strings of intl.cpl's Additional Settings > Currency.
  • We fixed an issue resulting in stordiag.exe crashing on launch if you tried to open it while running a repro mode trace while filing feedback under the "Disks and Storage" context in the Feedback Hub.
Windows Insider Build 19624 Released to Fast Ring:  Announcing Windows 10 Insider Preview Build 19624 | Windows Experience Blog.
General changes & improvements
  • We're temporarily turning off the new search box in the default apps Settings pages while we work on improving performance and reliability.
  • We're updating the VPN connection logic based on feedback, so that if you disconnect from a VPN network, it will now uncheck the option to auto-connect (similar to how it's handled for Wi-Fi).
  • Based on feedback we're updating the text of the Add a Device dialog so the list of examples under Bluetooth includes controllers.
  • We're updating the Optional Updates Available section that appears in Windows Update settings, so that you will now be able to copy the text in case you need it.
Fixes
  • We've fixed an issue that was causing unexpected flickering across Windows shell surfaces and apps in the last two builds.
  • We've fixed an issue causing IIS configuration to be set to default after taking a new build.
  • We've fixed an issue causing a transient access error when quickly switching between WSL distros using the File Explorer integration.
  • We fixed an issue impacting explorer.exe reliability for some Insiders recently.
  • We fixed an issue resulting in Settings and the taskbar volume flyout crashing recently when selecting certain endpoints from the audio endpoint list.
  • We fixed a race condition that could result in VPN not auto-connecting (if it was set up to do that) after upgrade.
  • We've fixed an issue where the battery icon on the lock screen always shows close to empty, regardless of actual battery levels. If you're still experiencing this issue, please report it in the Feedback Hub.
  • We fixed a recent issue where if you opened your laptop after it'd been asleep, and it was connected to an external monitor with an external camera, Windows Hello would recognize you but not dismiss the lock screen.
  • We fixed an issue that could result in your device bug checking after it'd been asleep.
  • We fixed an issue resulting in certain Bluetooth mice being very slow to reconnect to your device after it'd been asleep.
  • We fixed an issue preventing you from navigating out of the Connect app's settings dialog using a mouse.
  • We fixed an issue resulting in Windows Security's Core Isolation feature failing to enable on certain devices recently.
  • We fixed an issue resulting in Windows Update failing with error code 0x800700b7.
  • We fixed a deadlock that could result in Windows Update's checking for updates not completing and showing as in progress until Settings was closed and reopened.
  • We fixed an issue where some of the buttons and links on the Language Settings page weren't the correct color when using high contrast.
  • We fixed an issue where the text in the Optimize Drives window under Scheduled Optimization section would be truncated in a number of different languages and at certain text scaling levels.
Windows Insider Preview Build 19628 Released to Fast Ring:  Announcing Windows 10 Insider Preview Build 19628 | Windows Experience Blog.
General Improvements & Changes includes the initial support for DNS over HTTPS, so that you can opt into using encryption when Windows makes DNS queries. Follow the instructions in this blog post to opt in as it will be off by default.
The fix in the build was for an issue causing some devices fail to update with error code 0xc0000409. If you continue to experience this error, please let us know by filing new feedback in Feedback Hub.
Windows Insider Preview Build 19631 Released to Fast Ring:  Announcing Windows 10 Insider Preview Build 19631 | Windows Experience Blog.
Fixes:
  •   We fixed the issue causing the IIS configuration being set to default after taking a new build.
  •   We fixed an issue that could result in a key press not waking up a device from connected standby in certain scenarios.
  •   We fixed an issue impacting Remote Desktop reliability.
Windows Insider Build 19635 Released to Fast Ring:  Announcing Windows 10 Insider Preview Build 19635 | Windows Experience Blog.
Fixes
  • We fixed an issue resulting in the apostrophes in the Location not available dialog, Mount File dialog, and File Explorer folder options text not being displayed correctly.
  • We fixed an issue where the Work or School account > Allow Windows Search to provide... toggle under Search Settings could be unexpectedly disabled.
  • We fixed an issue resulting in cellular data not working on certain devices.
  • We fixed an issue that could result in Settings crashing when changing display orientation or resolution.
  • We fixed an issue resulting in some Insiders seeing a large number of "Program Compatibility Assistant Service stopped working" critical events in Reliability Monitor.
  • We fixed an issue that could result in constant display flashing on certain devices.
  • We fixed an issue with the camera on certain devices showing unexpected artifacts.
Windows Insider Preview Build 19640 Released to Fast Ring:  Announcing Windows 10 Insider Preview Build 19640 | Windows Experience Blog
No fixes listed.  See the blog post for changes and improvements as well as known issues.
Windows Insider Preview Build 19645 Released to Fast RIng:  Announcing Windows 10 Insider Preview Build 19645 | Windows Experience Blog.
Note:  See the blog post for information on the changed servicing model for the Linux kernel inside of Windows Subsystem for Linux 2 distributions.
Fixes:
  • We've fixed an issue where some devices booting from eMMC storage bugchecked when resuming from hibernate.
  • We fixed multiple Japanese and Chinese IME issues that impacted IME mode switching within applications and Windows notification area.
  • We've fixed an issue where taskbar preview thumbnails weren't rendering consistently (showing a blank area).
  • We fixed an issue resulting in the handwriting input panel not appearing in certain text fields after being tapped with a pen.
  • We fixed an issue where resizing a snapped application in tablet mode would minimize the app to the taskbar instead of adjusting the app size.
  • We fixed an issue where Windows Hello Setup would crash if facial recognition was already set up and you chose the Improve Recognition button.
  • We fixed an issue for some users where your PC wouldn't recognize it when you inserted a smart card (event log showing error 621).
xrobwx71
Windows Insider Preview Build 20150 Released to Fast Ring:  Announcing Windows 10 Insider Preview Build 20150 | Windows Experience Blog
The build contains three new Windows Subsystem for Linux (WSL) features: GPU compute, WSL install, and WSL update.  In addition, this release returns to builds from the RS_PRERELEASE branch.
Fixes:
  • We fixed an issue resulting in Visual Studio windows not consistently accepting clicks.
  • We've fixed an issue where the Documents and Downloads sections in Settings > Privacy was showing a broken icon next to their name (just a rectangle).
  • We fixed an issue where, if you paused Windows Update while a new build was downloading and then closed Settings, when you reopened Settings the Windows Update page may appear blank.
  • We fixed an issue where updates made when editing VPN networks in Settings might not persist.
  • We fixed an issue where the copy button under Settings > Network & Internet-Status > Properties wasn't actually copying the content to the clipboard.
  • We fixed an issue resulting in the data usage number in Network & Internet Settings not displaying correctly in Japanese if the data usage was less than 1 MB.
  • We fixed a crash some Insiders were experiencing when opening Sound Settings.
  • We fixed an issue where the Optimize Drives window position wasn't preserved on elevation.
  • We fixed a typo in the group policies under User Configuration > Administrative Templates > Windows Component > File Explorer > Do not move deleted files to the Recycle Bin.
  • We fixed an issue resulting in the On-Screen Keyboard no longer displaying text predictions.
  • We fixed an issue where double-clicking a OneDrive file in File Explorer might unexpectedly show a notification saying, "Windows Defender SmartScreen is downloading from OneDrive.
  • We fixed an issue where Resource Monitor could end up showing CPU usage at more than 100 percent.
  • We fixed an issue that could result in qaa-Latn unexpectedly appearing in your list of keyboards after upgrading.
  • We fixed an issue where, with multiple input methods, typing in your password incorrectly on the login screen would result in your keyboard changing back to your default input method (if that's not what you were typing with).
  • We fixed an issue where the touch keyboard space bar label would disappear when pressing it while using Japanese curve-flick input in abc mode.
  • We fixed an issue that could result in your browser not launching in the foreground after selecting a web link from another app.
  • We fixed an issue that could result in Search not accepting typed input.
  • We fixed an issue where, if pinned to Start, the Windows Security app tile would be missing an icon when the tile was medium sized.
  • We've made some updates to improve performance of the Windows Security app if there are a large number of detections.
  • We fixed a few issues that could result in your PC bugchecking.
Windows Insider Preview Build 20152 Released to Fast Ring/Dev Channel:  Announcing Windows 10 Insider Preview Build 20152 | Windows Experience Blog.
  • We fixed an issue that could result in Notepad unexpectedly being removed after resetting your PC. If you were impacted by this, you can reinstall Notepad via Optional Features in Settings.
  • We fixed an issue where the "Windows needs space to continue" dialog might have told you to select Continue but no Continue button was displayed.
  • We fixed an issue that could result in the Windows Update icon unexpectedly not appearing in the notification area of the taskbar when an update was ready for reboot.
  • We fixed an issue that could result in an IME typing as if it was ON, when it was actually in OFF state, and tapping the IME mode indicator in the taskbar wouldn't change the mode.
Windows Insider Preview Build 20161 Released to Dev Channel:  Announcing Windows 10 Insider Preview Build 20161 | Windows Experience Blog.
Please note that not all features will be immediately available at first as they are rolled out to the Dev Channel in order to quickly identify issues that may impact performance and reliability.
New features include:
-- Theme-aware tiles in Start
-- ALT + TAB between apps and sites on Microsoft Edge in both the active and in each browser window
-- A more personalized Taskbar for new users
-- Improving the notification experience
-- Making Settings even better
-- Improving the tablet experience for 2-in-1 devices
Read about the new features as well as the fixes and known issues in the referenced blog post.
Windows Insider Preview Build 20170 Released to Dev Channel:  Announcing Windows 10 Insider Preview Build 20170 | Windows Experience Blog.
QuotePLEASE NOTE: Windows Insiders with PCs that have AMD processors will not be offered this build today due to a bug impacting overall usability of these PCs. The issue should be fixed for the next flight.
See the blog post for new features/known issues/fixes.
Windows Insider Preview Build 20175 Released to Dev Channel:  Announcing Windows 10 Insider Preview Build 20175 | Windows Experience Blog.
Also note from the blog post:  "Insider Preview Builds 20161 and below will expire on July 31st. To avoid hitting this expiration, please update to Insider Preview Builds 20170 or newer."
Via Twitter:
QuoteHey Folks!  We have a new build for #WindowsInsiders in the Dev Channel! Check out Build 20175. https://aka.ms/wip20175 #AreYouFlightingYet ^AL
The update has improvements for pinned sites in Microsoft Edge, introduces Reset-AppxPackage and more.
Windows Insider Build 20180 Released to Dev Channel:  Announcing Windows 10 Insider Preview Build 20180 | Windows Experience Blog.
QuoteIMPORTANT NOTE: Insider Preview Builds 20161 and below will expire on July 31st. To avoid hitting this expiration, please update to Insider Preview Builds 20170 or newer.
Much of the new features mentioned on July 1st in Build 20161, including theme-aware tiles on Start, are turned on in this Build. However, the new pinned sites capability mentioned with last week's flight of Build 20175 is still only available to a subset of Insiders.
Changes and Improvements:
  • Based on feedback, we're changing the tablet posture logic for 2-in-1 devices to now only apply when using a single screen.
  • Based on feedback we're updating the new folder icon in the Start menu's All app's list to be a little smaller so it better aligns with the size of the other icons.
  • We've updated the search box in the Default Apps settings pages to improve performance.
