To keep PaleMoon forum accounts alive
Started by ky331, December 28, 2021, 12:33:11 PM
I received the following information via e-mail:
In January 2022 we will be performing a user account purge based on last
active date. (exact date for this maintenance not set but likely middle of
the month somewhere)
This is in line with our privacy policy and facilitates removal of account
data for accounts that have been inactive for a long time.
To make sure your account isn't purged, log in to the forum at least once
before the purge date if you have been inactive for a very long time.
Posting anything is not required.
Just log in and you're set. You can
verify your last active date by checking your user profile.
https://forum.palemoon.org/
If you don't mind your account being purged from the forum system, you
don't have to do anything. If your account has been inactive long enough,
it will be cleaned up accordingly.
If your account was purged after this maintenance due to inactivity, then
you will have to re-register on the forum if you want to participate again.
Important: when your account has been purged there will be no way for forum
staff to restore it, nor will there be a way to link any newly created
account to old posts. So, if you are inactive but wish to retain your
posting history on your account make sure you log in to your account on the
forum before the maintenance occurs.
Thanks. Looks like I'll need to stick my nose in there and log in.
