Zlob downloader
Started by seathach, June 09, 2006, 05:34:28 PM
seathach
I have Zlob. downloader.  Avg didn't find it but sb s&d did but it can't remove it.  I couldn't do it manually, it said a program was using it.  How do I get rid if it?
Cheers Fraser  :shock:
seathach,
Please can you make sure that you are using
Ad-aware SE Build 106
Then use the WebUpDate
SE1R111 08.06.2006
To do this Open Ad-aware
Click the WebUpDate
button at the top right hand side of the Ad-aware screen (The world globe).
Click "Connect"
Ad-aware will then download the latest  Definition file for you.
To make sure it is updated , look at the main
Ad-aware screen, and look under "Initialization Status"
It should say the Latest Definition file.
As Logs are stored in :
C:\Documents and Settings\USERNAME\Application Data\Lavasoft\Ad-aware\Logs\.
An easy way to get there is to
click Start,
click Run
And type in and press ENTER: %appdata%
then click  Lavasoft
then Ad-Aware
and then Logs.
scroll down to find the latest one that you have
(by date & time)
(note The Application Data is a hidden folder, so you will need to show hidden files and folders
and for Windows 98/ME users your logs are stored in
C:\WINDOWS\All Users\Application Data\ ) by default.
GR@PH;<'S   :breakkie:
seathach
Thanks for the reply I hope this is what you're looking for:
Ad-Aware SE Build 1.05
Logfile Created on:09 June 2006 22:03:04
Using definitions file:SE1R111 08.06.2006
EzuLa(TAC index:6):18 total references
MRU List(TAC index:0):14 total references
Ad-Aware SE Settings
Set : Scan active processes
Set : Scan registry
Set : Deep-scan registry
Set : Scan my Hosts file
Extended Ad-Aware SE Settings
09-06-2006 22:03:04 - Scan started. (Full System Scan)
MRU List Object Recognized!
    Location:          : C:\Documents and Settings\IDEAs\Application Data\microsoft\office\recent
    Description        : list of recently opened documents using microsoft office
    Location:          : C:\Documents and Settings\IDEAs\recent
    Location:          : software\microsoft\direct3d\mostrecentapplication
    Description        : most recent application to use microsoft direct3d
    Description        : most recent application to use microsoft direct X
    Location:          : software\microsoft\directdraw\mostrecentapplication
    Description        : most recent application to use microsoft directdraw
    Location:          : S-1-5-21-73586283-746137067-1060284298-1003\software\microsoft\internet explorer
    Description        : last download directory used in microsoft internet explorer
    Location:          : S-1-5-21-73586283-746137067-1060284298-1003\software\microsoft\internet explorer\typedurls
    Description        : list of recently entered addresses in microsoft internet explorer
    Location:          : S-1-5-21-73586283-746137067-1060284298-1003\software\microsoft\office\9.0\common\open find\microsoft word\settings\save as\file name mru
    Description        : list of recent documents saved by microsoft word
    Location:          : S-1-5-21-73586283-746137067-1060284298-1003\software\microsoft\search assistant\acmru
    Description        : list of recent search terms used with the search assistant
    Location:          : S-1-5-21-73586283-746137067-1060284298-1003\software\microsoft\windows\currentversion\applets\paint\recent file list
    Description        : list of files recently opened using microsoft paint
    Location:          : S-1-5-21-73586283-746137067-1060284298-1003\software\microsoft\windows\currentversion\explorer\comdlg32\lastvisitedmru
    Description        : list of recent programs opened
    Location:          : S-1-5-21-73586283-746137067-1060284298-1003\software\microsoft\windows\currentversion\explorer\comdlg32\opensavemru
    Description        : list of recently saved files, stored according to file extension
    Location:          : S-1-5-21-73586283-746137067-1060284298-1003\software\microsoft\windows\currentversion\explorer\recentdocs
    Description        : list of recent documents opened
    Location:          : S-1-5-21-73586283-746137067-1060284298-1003\software\microsoft\windows media\wmsdk\general
    Description        : windows media sdk
Listing running processes
#:1 [smss.exe]
    FilePath           : \SystemRoot\System32\
    ProcessID          : 408
    ThreadCreationTime : 09-06-2006 18:45:02
    BasePriority       : Normal
#:2 [csrss.exe]
    FilePath           : \??\C:\WINDOWS\system32\
    ProcessID          : 456
    ThreadCreationTime : 09-06-2006 18:45:05
#:3 [winlogon.exe]
    ProcessID          : 480
    ThreadCreationTime : 09-06-2006 18:45:06
    BasePriority       : High
#:4 [services.exe]
    ProcessID          : 524
    ThreadCreationTime : 09-06-2006 18:45:07
    FileVersion        : 5.1.2600.0 (xpclient.010817-1148)
    ProductVersion     : 5.1.2600.0
#:5 [lsass.exe]
    ProcessID          : 536
#:6 [svchost.exe]
    ProcessID          : 700
    ThreadCreationTime : 09-06-2006 18:45:09
#:7 [svchost.exe]
    ProcessID          : 724
#:8 [svchost.exe]
    ProcessID          : 808
    ThreadCreationTime : 09-06-2006 18:45:10
#:9 [svchost.exe]
    ProcessID          : 864
    ThreadCreationTime : 09-06-2006 18:45:11
#:10 [spoolsv.exe]
    ProcessID          : 1120
    ThreadCreationTime : 09-06-2006 18:45:13
    FileVersion        : 5.1.2600.0 (XPClient.010817-1148)
#:11 [explorer.exe]
    ProcessID          : 1184
    FileVersion        : 6.00.2600.0000 (xpclient.010817-1148)
    ProductVersion     : 6.00.2600.0000
    InternalName       : explorer
#:12 [avgamsvr.exe]
    FilePath           : C:\PROGRA~1\Grisoft\AVGFRE~1\
    ProcessID          : 1288
    ThreadCreationTime : 09-06-2006 18:45:16
    FileVersion        : 7,1,0,365
    ProductVersion     : 7.1.0.365
    ProductName        : AVG Anti-Virus System
    CompanyName        : GRISOFT, s.r.o.
    FileDescription    : AVG Alert Manager
    InternalName       : avgamsvr
    LegalCopyright     : Copyright © 2005, GRISOFT, s.r.o.
    OriginalFilename   : avgamsvr.EXE
#:13 [avgupsvc.exe]
    ProcessID          : 1324
    FileVersion        : 7,1,0,349
    ProductVersion     : 7.1.0.349
    ProductName        : AVG 7.0 Anti-Virus System
    FileDescription    : AVG Update Service
    InternalName       : avgupsvc
    OriginalFilename   : avgupdsvc.EXE
#:14 [avgemc.exe]
    ProcessID          : 1356
    FileVersion        : 7,1,0,371
    ProductVersion     : 7.1.0.371
    FileDescription    : AVG E-Mail Scanner
    InternalName       : avgemc
    OriginalFilename   : avgemc.exe
#:15 [ewidoctrl.exe]
    FilePath           : C:\Program Files\ewido anti-malware\
    ProcessID          : 1392
    FileVersion        : 3, 0, 0, 1
    ProductVersion     : 3, 0, 0, 1
    ProductName        : ewido control
    CompanyName        : ewido networks
    FileDescription    : ewido control
    InternalName       : ewido control
    LegalCopyright     : Copyright © 2004
    OriginalFilename   : ewidoctrl.exe
#:16 [ewidoguard.exe]
    ProcessID          : 1404
    ThreadCreationTime : 09-06-2006 18:45:17
    ProductName        : guard
    FileDescription    : guard
    InternalName       : guard
    OriginalFilename   : guard.exe
#:17 [wdfmgr.exe]
    ProcessID          : 1512
    ThreadCreationTime : 09-06-2006 18:45:18
    FileVersion        : 5.2.3790.1230 built by: dnsrv(bld4act)
    ProductVersion     : 5.2.3790.1230
    FileDescription    : Windows User Mode Driver Manager
    InternalName       : WdfMgr
    OriginalFilename   : WdfMgr.exe
#:18 [vsmon.exe]
    FilePath           : C:\WINDOWS\SYSTEM32\ZONELABS\
    ProcessID          : 1588
    ThreadCreationTime : 09-06-2006 18:45:19
    FileVersion        : 6.1.744.001
    ProductVersion     : 6.1.744.001
    ProductName        : TrueVector Service
    CompanyName        : Zone Labs, LLC
    FileDescription    : TrueVector Service
    InternalName       : vsmon
    LegalCopyright     : Copyright © 1998-2005, Zone Labs, LLC
    OriginalFilename   : vsmon.exe
#:19 [wuauclt.exe]
    ProcessID          : 1664
    ThreadCreationTime : 09-06-2006 19:17:29
    FileVersion        : 5.8.0.2469 built by: lab01_n(wmbla)
    ProductVersion     : 5.8.0.2469
    FileDescription    : Automatic Updates
    InternalName       : wuauclt.exe
    OriginalFilename   : wuauclt.exe
#:20 [mouse32a.exe]
    FilePath           : C:\Program Files\Kensington\Kensington Mouse 1.1\
    ProcessID          : 2000
    ThreadCreationTime : 09-06-2006 19:18:31
    FileVersion        : 3.0.1.0
    ProductVersion     : 3.0.0.0
    LegalCopyright     : Copyright 2001 by LEE,WEI-BIN.
#:21 [dragdiag.exe]
    FilePath           : C:\Program Files\Thomson\SpeedTouch USB\
    ProcessID          : 1876
    ThreadCreationTime : 09-06-2006 19:18:35
    FileVersion        : 301.0.0.12
    ProductVersion     : 301.0.0.12
    ProductName        : SpeedTouch USB
    CompanyName        : THOMSON Telecom Belgium
    FileDescription    : SpeedTouch Statistics
    LegalCopyright     : Copyright© THOMSON Telecom Belgium 1999-2004
    LegalTrademarks    : SpeedTouch
#:22 [avgcc.exe]
    ProcessID          : 436
    ThreadCreationTime : 09-06-2006 19:18:38
    FileVersion        : 7,1,0,381
    ProductVersion     : 7.1.0.381
    FileDescription    : AVG Control Center
    InternalName       : AvgCC
    LegalCopyright     : Copyright © 2006, GRISOFT, s.r.o.
    OriginalFilename   : AvgCC.EXE
#:23 [zlclient.exe]
    FilePath           : C:\Program Files\Zone Labs\ZoneAlarm\
    ProcessID          : 792
    ThreadCreationTime : 09-06-2006 19:18:55
    ProductName        : Zone Labs Client
    FileDescription    : Zone Labs Client
    InternalName       : zlclient
    OriginalFilename   : zlclient.exe
#:24 [qttask.exe]
    FilePath           : C:\Program Files\QuickTime\
    ProcessID          : 276
    ThreadCreationTime : 09-06-2006 19:18:59
    FileVersion        : 6.4
    ProductVersion     : QuickTime 6.4
    ProductName        : QuickTime
    CompanyName        : Apple Computer, Inc.
    InternalName       : QuickTime Task
    LegalCopyright     : © Apple Computer, Inc. 2001-2003
    OriginalFilename   : QTTask.exe
#:25 [realplay.exe]
    FilePath           : C:\Program Files\Real\RealPlayer\
    ProcessID          : 1064
    ThreadCreationTime : 09-06-2006 19:19:04
    FileVersion        : 6.0.9.584
    ProductVersion     : 6.0.9.584
    ProductName        : RealPlayer (32-bit)
    CompanyName        : RealNetworks, Inc.
    FileDescription    : RealPlayer
    InternalName       : REALPLAY
    LegalCopyright     : Copyright © RealNetworks, Inc. 1995-2000
    LegalTrademarks    : RealAudio(tm) is a trademark of RealNetworks, Inc.
    OriginalFilename   : REALPLAY.EXE
#:26 [e_s4i0t1.exe]
    FilePath           : C:\WINDOWS\System32\spool\DRIVERS\W32X86\3\
    ProcessID          : 600
    ThreadCreationTime : 09-06-2006 19:19:08
    FileVersion        : 3.00
    ProductVersion     : 3.00
    ProductName        : EPSON Status Monitor 3
    CompanyName        : SEIKO EPSON CORPORATION
    FileDescription    : EPSON Status Monitor 3
    InternalName       : E_S4I0T1
    LegalCopyright     : Copyright (C) SEIKO EPSON CORP. 2004
    OriginalFilename   : E_S4I0T1.EXE
#:27 [msmsgs.exe]
    FilePath           : C:\Program Files\Messenger\
    ProcessID          : 940
    ThreadCreationTime : 09-06-2006 19:19:21
    FileVersion        : 4.7.2009
    ProductVersion     : Version 4.7
    ProductName        : Messenger
    FileDescription    : Messenger
    InternalName       : msmsgs
    LegalCopyright     : Copyright (c) Microsoft Corporation 1997-2003
    LegalTrademarks    : Microsoft(R) is a registered trademark of Microsoft Corporation in the U.S. and/or other countries.
    OriginalFilename   : msmsgs.exe
#:28 [myspaceim.exe]
    FilePath           : C:\Program Files\MySpace\IM\
    ProcessID          : 1548
    ThreadCreationTime : 09-06-2006 19:19:28
    FileVersion        : 1.0.312.0
    ProductVersion     : 1.0.312.0
    ProductName        :  MySpaceIM
    FileDescription    : MySpace Instant Messenger
    InternalName       : MySpaceIM
    LegalCopyright     : Copyright MySpace.com 2006.  All rights reserved.
    OriginalFilename   : MySpaceIM.exe
#:29 [easyshare.exe]
    FilePath           : C:\Program Files\Kodak\Kodak EasyShare software\bin\
    ProcessID          : 1716
    ThreadCreationTime : 09-06-2006 19:20:02
    FileVersion        : 5, 2, 30, 84
    ProductVersion     : 5, 2, 0, 49
    ProductName        : KODAK EasyShare Software
    FileDescription    : KODAK EasyShare Software
    InternalName       : EasyShare
    LegalCopyright     : © Eastman Kodak Company, 2002-2005. All Rights Reserved.
    OriginalFilename   : EasyShare.exe
#:30 [kodak software updater.exe]
    FilePath           : C:\Program Files\Kodak\KODAK Software Updater\7288971\Program\
    ProcessID          : 2084
    ThreadCreationTime : 09-06-2006 19:20:11
#:31 [svchost.exe]
    ProcessID          : 2344
    ThreadCreationTime : 09-06-2006 19:22:39
#:32 [iexplore.exe]
    FilePath           : C:\Program Files\Internet Explorer\
    ProcessID          : 3944
    ThreadCreationTime : 09-06-2006 20:58:45
    FileDescription    : Internet Explorer
    InternalName       : iexplore
    OriginalFilename   : IEXPLORE.EXE
#:33 [ad-aware.exe]
    FilePath           : C:\Program Files\Lavasoft\Ad-Aware SE Personal\
    ProcessID          : 1924
    ThreadCreationTime : 09-06-2006 21:01:43
    FileVersion        : 6.2.0.206
    ProductVersion     : VI.Second Edition
    LegalCopyright     : Copyright © Lavasoft Sweden
Memory scan result:
New critical objects: 0
Objects found so far: 14
Started registry scan
EzuLa Object Recognized!
    Type               : Regkey
    Data               :
    Category           : Data Miner
    Comment            :
    Rootkey            : HKEY_CLASSES_ROOT
    Object             : clsid\{10049d2a-2965-4e4f-8c7e-cb33ad95feb7}
    Type               : RegValue
    Data               :
    Comment            :
    Value              :
    Type               : Regkey
    Data               :
    Comment            :
    Object             : interface\{0fd6420a-f789-40ae-b921-3983f84e074e}
    Type               : RegValue
    Data               :
    Comment            :
    Value              :
    Type               : Regkey
    Data               :
    Comment            :
    Object             : interface\{994a0535-b09c-4d1c-aa4a-2f76002349b1}
    Type               : RegValue
    Data               :
    Comment            :
    Value              :
    Type               : Regkey
    Data               :
    Comment            :
    Object             : typelib\{82910ce3-d86a-435a-a519-6a8c369855d3}
Registry Scan result:
New critical objects: 7
Objects found so far: 21
Started deep registry scan
Deep registry scan result:
Started Tracking Cookie scan
Tracking cookie scan result:
Disk Scan Result for C:\
Scanning Hosts file......
Hosts file scan result:
109 entries scanned.
New critical objects:0
    Type               : Regkey
    Data               :
    Comment            :
    Object             : le.toy24
    Type               : RegValue
    Data               :
    Comment            :
    Object             : le.toy24
    Value              :
    Type               : Regkey
    Data               :
    Comment            :
    Object             : le.toy24.1
    Type               : RegValue
    Data               :
    Comment            :
    Object             : le.toy24.1
    Value              :
    Type               : Regkey
    Data               :
    Comment            :
    Object             : onone.thegimp
    Type               : RegValue
    Data               :
    Comment            :
    Value              :
    Type               : Regkey
    Data               :
    Comment            :
    Object             : onone.thegimp.1
    Type               : RegValue
    Data               :
    Comment            :
    Value              :
    Type               : RegValue
    Data               :
    Comment            :
    Rootkey            : HKEY_USERS
    Object             : .default\software\microsoft\internet explorer\urlsearchhooks
    Value              : {CFBFAE00-17A6-11D0-99CB-00C04FD64497}
    Type               : RegValue
    Data               :
    Comment            :
    Object             : .default\software\microsoft\internet explorer\toolbar\shellbrowser
    Value              : {0E5CBF21-D15F-11D0-8301-00AA005B4383}
    Type               : RegValue
    Data               :
    Comment            :
    Object             : .default\software\microsoft\internet explorer\toolbar\webbrowser
Conditional scan result:
New critical objects: 11
Objects found so far: 32
22:19:41 Scan Complete
Summary Of This Scan
Total scanning time:00:16:36.584
Objects scanned:114433
Objects identified:18
Objects ignored:0
New critical objects:18
