Malware?
Started by craige, June 10, 2006, 08:11:37 PM
craige
i was told that some one here might be able to help me with what ever this problem is\
http://forum.avast.com/index.php?topic=21563.0
mitch
how old is the D drive?
or is it just a partition of the c drive?
what other anti-mailware programs have you tried?
can you right click any file and select properties? if so  anything unusual about the " last modified date"?
craige
the d drive is a drive by its self and its only about a year and a little over half old. iv just used avast and zonelab and avast found win32:dialer-461 [Trj]. and when i click properties one any thing in d it shows no ms-dos name and modified says [unknown] along with created and accessed. but my Recycling bin is fine. and both times this happened i was running bitlord and it froze after about a gig or two was downloaded and when i restarted they were like this. the second time there was about 2 to 3 hours after it froze that i found it and restarted it. when i try and scan for errors it gets to checking for lost file fragments and freezes, iv left it for about an hour after this happens and i can still move the mouse but the clock is stoped and i cant click any thing.
craige
btw im on cable so i dont think that dialer did any thing
mitch
ok, lets do a few things first
run a ad-aware log and post it here ok?
here is the info on "how to"
http://www.landzdown.com/index.php?topic=425.0
let's see what it says first ok?
don't want to have you run a bunch of things, let's do it nice and slow and safe !
and have you tried to do a "error check scan" in SAFE mode?
and sounds like you also could use some good protection ;-)
click my sig and just READ  "how did i get infected" we can do all that after you are back to normal
mitch
craige,
Please can you make sure that you are using
Ad-aware SE Build 106
Then use the WebUpDate
SE1R111 08.06.2006
To do this Open Ad-aware
Click the WebUpDate
button at the top right hand side of the Ad-aware screen (The world globe).
Click "Connect"
Ad-aware will then download the latest  Definition file for you.
To make sure it is updated , look at the main
Ad-aware screen, and look under "Initialization Status"
It should say the Latest Definition file.
then scan  doing a  "Full Scan" and then post your logfile here by using the Add-Reply Feature .
As Logs are stored in :
C:\Documents and Settings\USERNAME\Application Data\Lavasoft\Ad-aware\Logs\.
An easy way to get there is to
click Start,
click Run
And type in and press ENTER: %appdata%
then click  Lavasoft
then Ad-Aware
and then Logs.
scroll down to find the latest one that you have
(by date & time)
(note The Application Data is a hidden folder, so you will need to show hidden files and folders
and for Windows 98/ME users your logs are stored in
C:\WINDOWS\All Users\Application Data\ ) by default.
GR@PH;<'S   :breakkie:
craige
iv already got adaware se but havnt ran it as zonelab has an anti spyware thing. let me ru adaware
craige
and iv tryed running it in safe mode and it does the same thing. and iv tryed in msdos and get bad file command and it now restarts in msdos every time i restart. iv typed win and it loads msdos so iv gone to step by step and oking every thing but dos and then loading all windows drivers and it works
craige
here
Ad-Aware SE Build 1.06r1
Logfile Created on:Saturday, June 10, 2006 5:56:23 PM
Using definitions file:SE1R111 08.06.2006
MRU List(TAC index:0):11 total references
Ad-Aware SE Settings
Set : Search for low-risk threats
Set : Scan active processes
Set : Scan registry
Set : Deep-scan registry
Set : Scan within archives
Set : Scan my Hosts file
Extended Ad-Aware SE Settings
6-10-06 5:56:23 PM - Scan started. (ADS scan)
Performing deep Scan and listing Alternate Data Streams...
C: Drive does not support Alternate Data Streams.
Performing deep scan...
Disk Scan Result for C:\
New critical objects: 0
Objects found so far: 0
Deep scanning and examining files (D:)
D: Drive does not support Alternate Data Streams.
Disk Scan Result for D:\
MRU List Object Recognized!
    Location:          : .DEFAULT\software\jasc\paint shop pro 7\general
    Description        : last save as directory used in jasc paint shop pro
    Location:          : .DEFAULT\software\jasc\paint shop pro 7\recent file list
    Description        : list of recently used files in jasc paint shop pro
    Location:          : .DEFAULT\software\jasc\paint shop pro 8\recent file list
    Location:          : software\microsoft\directdraw\mostrecentapplication
    Description        : most recent application to use microsoft directdraw
    Location:          : .DEFAULT\software\microsoft\internet explorer
    Description        : last download directory used in microsoft internet explorer
    Location:          : .DEFAULT\software\microsoft\mediaplayer\preferences
    Description        : last playlist loaded in microsoft windows media player
    Location:          : .DEFAULT\software\microsoft\windows\currentversion\applets\paint\recent file list
    Description        : list of files recently opened using microsoft paint
    Location:          : .DEFAULT\software\microsoft\windows\currentversion\applets\wordpad\recent file list
    Description        : list of recent files opened using wordpad
    Location:          : .DEFAULT\software\nico mak computing\winzip\filemenu
    Description        : winzip recently used archives
    Location:          : .DEFAULT\software\microsoft\windows media\wmsdk\general
    Description        : windows media sdk
    Location:          : .DEFAULT\software\winrar\dialogedithistory\extrpath
    Description        : winrar "extract-to" history
Conditional scan result:
Objects found so far: 11
6:04:24 PM Scan Complete
Summary Of This Scan
Total scanning time:00:08:00.210
Objects scanned:24884
Objects identified:0
Objects ignored:0
New critical objects:0
mitch
ok the mru's can be deleted !
go here
http://www.ewido.net/en/download/
It is a free version of the program.
    * Install ewido AntiMalware
    * Launch ewido, there will be a large yellow  E  icon on your desktop, double-click it.
    * The program will prompt you to update.  Click the OK button.
    * The program will now open to the main screen
    * On the left-hand side of the main screen, click on Update
    * Click on Start. The update will start and a progress bar will show the updates being installed.
    * When complete, the status bar at the bottom will display "Update successful".
NOTE the first 30 days it is the full version  and you will have active scanning
at the end of 30 days you can uninstall it or have it as a good manual scanner
run a scan and save the log and post it here ok?
let's see what they find ( they are true malware tools, not wanna-be's)
the above ewido instructions copied from one of corine's post ;-)
craige
oops didnt run full scan
Logfile Created on:Saturday, June 10, 2006 6:20:29 PM
Set : Scan registry
6-10-06 6:20:29 PM - Scan started. (Full System Scan)
Listing running processes
#:1 [KERNEL32.DLL]
    FilePath           : C:\WINDOWS\SYSTEM\
    ProcessID          : 4279205605
    Threads            : 6
    Priority           : High
    FileVersion        : 4.10.1998
    ProductVersion     : 4.10.1998
    ProductName        : Microsoft(R) Windows(R) Operating System
    FileDescription    : Win32 Kernel core component
    InternalName       : KERNEL32
    LegalCopyright     : Copyright (C) Microsoft Corp. 1991-1998
    OriginalFilename   : KERNEL32.DLL
#:2 [MSGSRV32.EXE]
    ProcessID          : 4294901793
    Threads            : 1
    Priority           : Normal
    FileDescription    : Windows 32-bit VxD Message Server
    InternalName       : MSGSRV32
    LegalCopyright     : Copyright (C) Microsoft Corp. 1992-1998
    OriginalFilename   : MSGSRV32.EXE
#:3 [MPREXE.EXE]
    ProcessID          : 4294915729
    Threads            : 1
    Priority           : Normal
    FileDescription    : WIN32 Network Interface Service Process
    InternalName       : MPREXE
    LegalCopyright     : Copyright (C) Microsoft Corp. 1993-1998
    OriginalFilename   : MPREXE.EXE
#:4 [mmtask.tsk]
    ProcessID          : 4294951845
    Threads            : 1
    Priority           : Normal
    FileVersion        : 4.03.1998
    ProductVersion     : 4.03.1998
    ProductName        : Microsoft Windows
    FileDescription    : Multimedia background task support module
    InternalName       : mmtask.tsk
    LegalCopyright     : Copyright © Microsoft Corp. 1991-1998
    OriginalFilename   : mmtask.tsk
#:5 [MSGLOOP.EXE]
    ProcessID          : 4294950869
    Threads            : 1
    Priority           : Normal
    FileVersion        : 4.05.00.2112
    ProductVersion     : 4.05.00.2112
    ProductName        : WaveStream\Endless Wave
    CompanyName        : Rockwell Corporation
    FileDescription    : Rockwell WaveStream Message Server
    InternalName       : MSGLOOP.EXE
    LegalCopyright     : Copyright (c) Rockwell Corporation 1996-1998.
    OriginalFilename   : MSGLOOP.EXE
#:6 [VSMON.EXE]
    FilePath           : C:\WINDOWS\SYSTEM\ZONELABS\
    ProcessID          : 4294739825
    Threads            : 24
    Priority           : Normal
    FileVersion        : 6.1.744.001
    ProductVersion     : 6.1.744.001
    ProductName        : TrueVector Service
    CompanyName        : Zone Labs, LLC
    FileDescription    : TrueVector Service
    InternalName       : vsmon
    LegalCopyright     : Copyright © 1998-2005, Zone Labs, LLC
    OriginalFilename   : vsmon.exe
#:7 [MSG32.EXE]
    ProcessID          : 4294746193
    Threads            : 2
    Priority           : Realtime
    LegalCopyright     : Copyright © Rockwell Corporation 1996-1998.
#:8 [FIRESVC.EXE]
    FilePath           : C:\PROGRAM FILES\MCAFEE DESKTOP FIREWALL FOR WINDOWS 98\
    ProcessID          : 4294788789
    Threads            : 13
    Priority           : Normal
    FileVersion        : 8.0
    ProductVersion     : 8.0
    ProductName        : McAfee Desktop Firewall
    CompanyName        : Networks Associates Technology, Inc.
    FileDescription    : Fire Service
    InternalName       : FireService
    LegalCopyright     : Copyright © 2003 Networks Associates Technology, Inc. All Rights Reserved.
    LegalTrademarks    : Network Associates, McAfee
    OriginalFilename   : FireSvc.exe
#:9 [FRAMEWORKSERVICE.EXE]
    FilePath           : C:\PROGRAM FILES\NETWORK ASSOCIATES\COMMON FRAMEWORK\
    ProcessID          : 4294785637
    Threads            : 12
    Priority           : Normal
    FileVersion        : 3.1.1.184
    ProductName        : McAfee Common Framework
    CompanyName        : Network Associates, Inc.
    FileDescription    : Framework Service
    InternalName       : Framework
    LegalCopyright     : Copyright© 2000-2003 Networks Associates Technology, Inc. All Rights Reserved.
    OriginalFilename   : Framework.exe
#:10 [ASHSERV.EXE]
    FilePath           : C:\PROGRAM FILES\ALWIL SOFTWARE\AVAST4\
    ProcessID          : 4294834817
    Threads            : 24
    Priority           : Normal
    FileVersion        : 4, 7, 844, 0
    ProductVersion     : 4, 7, 0, 0
    ProductName        : avast! Antivirus
    FileDescription    : avast! antivirus service
    InternalName       : aswServ
    LegalCopyright     : Copyright (c) 2006 ALWIL Software
    OriginalFilename   : aswServ.exe
#:11 [NAPRDMGR.EXE]
    ProcessID          : 4294700145
    Threads            : 6
    Priority           : Normal
    FileDescription    : NAI Product Manager
    InternalName       : Product Manager
    OriginalFilename   : naPrdMgr.exe
#:12 [TASKMON.EXE]
    ProcessID          : 4294566793
    Threads            : 1
    Priority           : Normal
    FileDescription    : Task Monitor
    InternalName       : TaskMon
    LegalCopyright     : Copyright (C) Microsoft Corp. 1998
    OriginalFilename   : TASKMON.EXE
#:13 [SYSTRAY.EXE]
    ProcessID          : 4294556881
    Threads            : 1
    Priority           : Normal
    FileDescription    : System Tray Applet
    InternalName       : SYSTRAY
    OriginalFilename   : SYSTRAY.EXE
#:14 [WMIEXE.EXE]
    ProcessID          : 4294552481
    Threads            : 2
    Priority           : Normal
    FileVersion        : 5.00.1755.1
    ProductVersion     : 5.00.1755.1
    ProductName        : Microsoft(R) Windows NT(R) Operating System
    FileDescription    : WMI service exe housing
    InternalName       : wmiexe
    LegalCopyright     : Copyright (C) Microsoft Corp. 1981-1998
    OriginalFilename   : wmiexe.exe
#:15 [ATICWD32.EXE]
    ProcessID          : 4294329993
    Threads            : 1
    Priority           : Normal
    FileVersion        : 4.10.2339
    ProductVersion     : 4.10.2339
    ProductName        : ATI Technologies Inc.
    CompanyName        : ATI Technologies Inc.
    FileDescription    : ATI Common Windows Display Driver Extension
    InternalName       : ATICWD32
    LegalCopyright     : Copyright © ATI Technologies Inc., 1998
    OriginalFilename   : ATICWD32.EXE
#:16 [RPCSS.EXE]
    ProcessID          : 4294314849
    Threads            : 8
    Priority           : Normal
    FileVersion        : 4.71.2900
    ProductVersion     : 4.71.2900
    ProductName        : Microsoft(R) Windows NT(TM) Operating System
    FileDescription    : Distributed COM Services
    InternalName       : rpcss.exe
    OriginalFilename   : rpcss.exe
#:17 [HPSYSDRV.EXE]
    ProcessID          : 4294374081
    Threads            : 1
    Priority           : Normal
    FileVersion        : 1, 7, 0, 0
    ProductVersion     : 1, 7, 0, 0
    ProductName        : hpsysdrv
    CompanyName        : Hewlett-Packard Company
    FileDescription    : hpsysdrv
    InternalName       : hpsysdrv
    OriginalFilename   : hpsysdrv.exe
#:18 [MMKEYBD.EXE]
    FilePath           : C:\PROGRAM FILES\NETROPA\ONE-TOUCH MULTIMEDIA KEYBOARD\
    ProcessID          : 4294349673
    Threads            : 7
    Priority           : Normal
    FileVersion        : 3.0.6.5
    ProductVersion     : 3.0.6.5
    ProductName        : One-touch Multimedia Keyboard
    CompanyName        : Netropa Corp.
    FileDescription    : One-touch Multimedia Keyboard
    InternalName       : MMKEYBD
    LegalCopyright     : Copyright © 1995-1998 Netropa Corp.
    OriginalFilename   : MMKEYBD.EXE
#:19 [MA2507MON.EXE]
    FilePath           : C:\PROGRAM FILES\HI-SPEED USB-TO-IDE WIN98 DRIVER\
    ProcessID          : 4294405789
    Threads            : 1
    Priority           : Normal
    FileVersion        : 1, 4, 0, 12
    ProductVersion     : 1, 4, 0, 12
    ProductName        : Hi-Speed USB-to-IDE
    CompanyName        : Prolific Technology Inc.
    FileDescription    : PL2507 Safely Remove Hardware
    InternalName       : PL2507MON
    LegalCopyright     : Copyright (C) Prolific Technology Inc.
    OriginalFilename   : PL2507MON.EXE
    Comments           : License to Maxtor Corporation
#:20 [AVGAMSVR.EXE]
    FilePath           : C:\PROGRAM FILES\GRISOFT\AVG FREE\
    ProcessID          : 4294204933
    Threads            : 4
    Priority           : Normal
    FileVersion        : 7,1,0,365
    ProductVersion     : 7.1.0.365
    ProductName        : AVG Anti-Virus System
    CompanyName        : GRISOFT, s.r.o.
    FileDescription    : AVG Alert Manager
    InternalName       : avgamsvr
    LegalCopyright     : Copyright © 2005, GRISOFT, s.r.o.
    OriginalFilename   : avgamsvr.EXE
#:21 [UPDATERUI.EXE]
    ProcessID          : 4294208861
    Threads            : 5
    Priority           : Normal
    FileDescription    : Common User Interface
    InternalName       : UpdaterUI
    OriginalFilename   : UpdaterUI.exe
#:22 [KEYBDMGR.EXE]
    ProcessID          : 4294208117
    Threads            : 1
    Priority           : Normal
    FileVersion        : 3.0.6.4
    ProductVersion     : 3.0.6.4
    ProductName        : Keyboard Manager
    FileDescription    : Keyboard Manager
    InternalName       : Keyboard Manager
    LegalCopyright     : Copyright © 1998, Netropa Corp.
    OriginalFilename   : KeybdMgr.exe
#:23 [TBMON.EXE]
    FilePath           : C:\PROGRAM FILES\COMMON FILES\NETWORK ASSOCIATES\TALKBACK\
    ProcessID          : 4294185949
    Threads            : 1
    Priority           : Normal
    FileVersion        : 2.0.266.0
    ProductVersion     : 2.0.266.0
    ProductName        : TalkBack Monitor
    FileDescription    : TalkBack Monitor
    InternalName       : TBMON
    LegalCopyright     : ©2003 Networks Associates Technology, Inc. All Rights Reserved.
    LegalTrademarks    : McAfee & Network Associates are registered trademarks of Netxt
    OriginalFilename   : TBMON.EXE
#:24 [ZLCLIENT.EXE]
    FilePath           : C:\PROGRAM FILES\ZONE LABS\ZONEALARM\
    ProcessID          : 4294203677
    Threads            : 11
    Priority           : Normal
    ProductName        : Zone Labs Client
    FileDescription    : Zone Labs Client
    InternalName       : zlclient
    OriginalFilename   : zlclient.exe
#:25 [ASHWEBSV.EXE]
    ProcessID          : 4294245109
    Threads            : 19
    Priority           : Normal
#:26 [OSD.EXE]
    FilePath           : C:\PROGRA~1\NETROPA\ONSCRE~1\
    ProcessID          : 4294259225
    Threads            : 1
    Priority           : Normal
    FileVersion        : 2.42
    ProductVersion     : 2.42
    ProductName        : OSD
    FileDescription    : Onscreen Display
    InternalName       : OSD
    LegalTrademarks    : Netropa
    OriginalFilename   : OSD.EXE
#:27 [FIRETRAY.EXE]
    ProcessID          : 4294303637
    Threads            : 3
    Priority           : Normal
    FileVersion        : 8.0
    FileDescription    : McAfee Desktop Firewall Tray Application
    InternalName       : FireTray
    OriginalFilename   : FireTray.exe
#:28 [DDHELP.EXE]
    ProcessID          : 4294155233
    Threads            : 2
    Priority           : Realtime
    FileVersion        : 4.08.01.0881
    ProductVersion     : 4.08.01.0881
    ProductName        : Microsoft® DirectX for Windows®  95 and 98
    FileDescription    : Microsoft DirectX Helper
    InternalName       : DDHelp.exe
    LegalCopyright     : Copyright © Microsoft Corp. 1994-2001
    OriginalFilename   : DDHelp.exe
#:29 [FIREFOX.EXE]
    FilePath           : C:\PROGRAM FILES\MOZILLA FIREFOX\
    ProcessID          : 4294261945
    Threads            : 10
    Priority           : Normal
#:30 [EXPLORER.EXE]
    ProcessID          : 4293918801
    Threads            : 9
    Priority           : Normal
    FileVersion        : 4.72.3110.1
    ProductVersion     : 4.72.3110.1
    InternalName       : explorer
    LegalCopyright     : Copyright (C) Microsoft Corp. 1981-1997
#:31 [AD-AWARE.EXE]
    FilePath           : C:\PROGRAM FILES\LAVASOFT\AD-AWARE SE PERSONAL\
    ProcessID          : 4294381173
    Threads            : 3
    Priority           : Normal
    FileVersion        : 6.2.0.236
    ProductVersion     : SE 106
Memory scan result:
Started registry scan
Registry Scan result:
Started deep registry scan
Deep registry scan result:
Started Tracking Cookie scan
Tracking cookie scan result:
Deep scanning and examining files (c:)
Disk Scan Result for c:\
Deep scanning and examining files (d:)
Disk Scan Result for d:\
Scanning Hosts file......
Hosts file location:"C:\WINDOWS\hosts".
Hosts file scan result:
1 entries scanned.
6:30:25 PM Scan Complete
Total scanning time:00:09:56.270
Objects scanned:62796
Objects ignored:0
craige
dont make fun of me but im still on 98. im trying to build a new computer and should be able to finish it once school gets out and i can get a job
mitch
did you see my post above?
run ewido
and you can only run one firewall at a time!!
you have ZA and Mcafee??????
and just as bad with 2 a/v's?
craige
the mcafee this is a desktop firewall, it contrals programs. and i removed avg and avast, zonelab has a anti virus in it. and ill run that program but it says its for 2000 and xp
craige
i tryed ewido and i get "ewido needs 2000 or higher to run"
