ESET online scanner
Started by patm, August 29, 2012, 05:13:08 AM
patm
hi, ran the scanner and have 6 threats that say unable to clean. if i run it again with the Remove found threats box checked will the threats be removed.
thanks, patm
patm
hi, i keep on getting the message about what to do with googleupdatetaskusers-1-5-21-1214440339-1592454029-839522115-1004ua.job. is this a virus ?. i dont know what to do so i keep blocking it ?
Hi, patm.  Welcome to LandzDown Forum.
I've merged your two posts to one topic.  Regarding the Private Firewall question, the "googleupdatetaskusers" is part of the Google Chrome and Google Earth update mechanism.  If you have either installed, you should allow it.
Let's see with ESET found.  Run ESET again but this time, do the following:
  • Click Scan
  • Wait for the scan to finish
In addition, please follow the instructions here:  Log Posting Instructions
patm
dom i turn off AV and maleware programs.
patm
Hi, patm.
While scanning with ESET, it is best to temporarily disable your security programs.  However, don't forget to turn them back on again after completing the scan.  They do not need to be disabled while creating the other logs for review.
patm
little scare after scan finished i copied the log. then iwas not able to connect to internet. i turned off privatefirewall- still no connection. rebooted and everything seems ok. as far as the googleupdatetaskusers, the message popped up, this time it said program either modified or deleted if deleted then delete which i clicked. actually after i did that i could not connect until i rebooted. well, anyway here is the log copy:
# version=7
# IEXPLORE.EXE=8.00.6001.18702 (longhorn_ie8_rtm(wmbla).090308-0339)
# OnlineScanner.ocx=1.0.0.6583
# api_version=3.0.2
# EOSSerial=686e16663efbf54ba1b5f7f6bed399bf
# end=finished
# remove_checked=false
# archives_checked=true
# unwanted_checked=true
# unsafe_checked=true
# antistealth_checked=true
# utc_time=2012-08-30 12:53:36
# local_time=2012-08-29 08:53:36 (-0500, Eastern Daylight Time)
# country="United States"
# lang=1033
# compatibility_mode=3587 16777174 85 68 369908 164353275 0 0
# scanned=90200
# found=6
# cleaned=0
# scan_time=2529
C:\Documents and Settings\All Users\Documents\My Documents\My Documents\Downloads\Funkymix_Collection_001_-_131_(1986_-_2010)_downloader(1).exe   a variant of Win32/ExpressFiles application (unable to clean)   00000000000000000000000000000000   I
C:\Documents and Settings\All Users\Documents\My Documents\My Documents\Downloads\Funkymix_Collection_001_-_131_(1986_-_2010)_downloader.exe   a variant of Win32/ExpressFiles application (unable to clean)   00000000000000000000000000000000   I
C:\Documents and Settings\All Users\Documents\My Documents\My Documents\Downloads\WinZip165.exe   a variant of Win32/OpenInstall application (unable to clean)   00000000000000000000000000000000   I
C:\Documents and Settings\pjm\My Documents\Downloads\Funkymix_Collection_001_-_131_(1986_-_2010)_downloader(1).exe   a variant of Win32/ExpressFiles application (unable to clean)   00000000000000000000000000000000   I
C:\Documents and Settings\pjm\My Documents\Downloads\Funkymix_Collection_001_-_131_(1986_-_2010)_downloader.exe   a variant of Win32/ExpressFiles application (unable to clean)   00000000000000000000000000000000   I
C:\Documents and Settings\pjm\My Documents\Downloads\WinZip165.exe   a variant of Win32/OpenInstall application (unable to clean)   00000000000000000000000000000000   I
patm
i cleaned up a little and ran eset scan again and no problems found. i checked the uninstall box and went to copy the log but it was gone. do you recommend running any other diagnostic. i have norton av 2012, malwarebytes, superantispyware and spybot on my windows xp home. any others recommended.
thanks, patm
Hi, patm.
I cannot provide any advice without knowing what is on the computer.  Please post the requested logs.  See Log Posting Instructions
patm,
The ESET on-line scanner will remove the items that it finds upon the re-booting of the PC.
Although your PC is or seems to be running ok may I saguest that you follow Corrines advice with Log Posting Instructions and post the log files here for peace of mind.
patm
i reran eset scan to obtain the log. is it normal to lose internet connection after the scan. i have to restart for connection. also, should i create a new restore point.
# version=7
# api_version=3.0.2
# end=finished
# utc_time=2012-08-30 08:29:13
# local_time=2012-08-30 04:29:13 (-0500, Eastern Daylight Time)
# lang=1033
# compatibility_mode=3587 16777190 85 68 440833 164424200 0 0
# scanned=90682
# found=0
# cleaned=0
# scan_time=2141
No, it is not normal to lose your Internet connection after running the ESET online scan.  Re-running the scan only shows that the last time you ran it, you checked the box to "Remove found threats".
Quote from: Corrine on August 30, 2012, 04:50:07 PM
Hi, patm.
patm
i am pretty sure i ran eset scan with the "Remove found threats" box unchecked and archive box checked but i will run it again.
thanks, patm
patm, Please don't run ESET again.  That won't help us help you.
Instead, please post the requested logs:  Log Posting Instructions
patm
help
i do the following
Please download DDS.scr by sUBs and save it to your desktop.
•Link
A.Double-Click dds.scr and a command window will appear. This is normal
B.Shortly after two logs will appear, DDS.txt & Attach.txt
C.A window will open instructing you save & post (do not attach) the logs
D.Save the logs to a convenient place such as your desktop
the black box pops up then a message fromm privatefirewall pops up and i click allow, wat and nothing happens.
patm
patm
OK HAD TO TURN OFF PRIVATEFIREWALL. now running.
PATM
